jenya7 0 10 января, 2018 Опубликовано 10 января, 2018 · Жалоба Может кто работал с этой микросхемой? Сломал уже весь мозг. Обращаюсь к MAX6956 из Kinetic K70. Насчет чтения в документации написано так The MAX6956 is read using the MAX6956’s internally stored command byte as address pointer, the same way the stored command byte is used as address pointer for a write. The pointer generally autoincrements after each data byte is read using the same rules as for a write (Table 4). Thus, a read is initiated by first configuring the MAX6956’s command byte by performing a write (Figure 8). The master can now read n consecutive bytes from the MAX6956, with the first data byte being read from the register addressed by the initialized command byte. When performing read-afterwrite verification, remember to reset the command byte’s address because the stored control byte address generally has been autoincremented after the write. Чтение #define MAX6956_SLAVE_ADDR 0x80 //A0,A1-GND void MAX6956_Read(unsigned char reg_addr, unsigned char *reg_data) { unsigned char slave_addr = MAX6956_SLAVE_ADDR | 0x01; //--------------first - set the address to read from //Start I2C1_Start() /* Send Slave Address with W/R bit = 1 */ I2C1_write_byte(slave_addr); I2C1_Wait(); /* Write Register Address */ I2C1_write_byte(reg_addr); I2C1_Wait(); //-------------second - read from the address /* Do a repeated start */ I2C1_RepeatedStart(); //??? /* Send Slave Address */ I2C1_write_byte(slave_addr); I2C1_Wait(); /* Write Register Address */ I2C1_write_byte(reg_addr); I2C1_Wait(); /* Put in Rx Mode */ //I2C1_C1 &= (~I2C_C1_TX_MASK); /* Turn off ACK since this is second to last byte being read*/ //I2C1_C1 |= I2C_C1_TXAK_MASK; /* read */ *reg_data = I2C1_D; I2C1_Wait(); /* Send stop since about to read last byte */ I2C1_Stop(); } Для проверки обращаюсь в регистр с известным значением после рисета. MAX6956_Read( 0x09, &data); if (data != 0xAA) return MAX6956_ERROR; На скопе вижу клок на SCL (400 kHz), вижу правильные адреса на SDA а возвращаемое значение 0х81. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
ryabikin 0 13 января, 2018 Опубликовано 13 января, 2018 · Жалоба Два раза посылается адрес 0x81? И для чтения и для записи? На мой взгляд нужно так: старт 0x80 - будем записывать reg_addr - записываем адрес региста повторный старт 0x81 - будем читать reg_addr - откуда читаем цикл чтения данных Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
jenya7 0 15 января, 2018 Опубликовано 15 января, 2018 · Жалоба Два раза посылается адрес 0x81? И для чтения и для записи? На мой взгляд нужно так: старт 0x80 - будем записывать reg_addr - записываем адрес региста повторный старт 0x81 - будем читать reg_addr - откуда читаем цикл чтения данных да. точно. я просто пропустил эту строчку. проблема что на несколько чтений SDA линия остается внизу, флаг BUSY поднимается и все, I2C не реагирует. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
