rom67 0 2 ноября, 2016 Опубликовано 2 ноября, 2016 · Жалоба DATE: 10-29-2016 HOTFIX VERSION: 008 ================================================================================ =================================================== CCRID PRODUCT PRODUCTLEVEL2 TITLE ================================================================================ =================================================== 1644406 ALLEGRO_EDITOR SHAPE Alternate symbol placement results in illegal parent identifier error 1647098 SIP_LAYOUT OTHER SiP crashes on symbol copy and rotate 1647154 APD OTHER Disconnected Clines not working 1648817 GRE IFP_INTERACTIVE Allegro PCB Editor stops responding on adding netgroups to a nested netgroup 1649829 CONCEPT_HDL CORE Project Manager: A delay is observed before the sub menus of the File and Tools menus appear 1652930 ALLEGRO_EDITOR OTHER Command-line version of switchversion not working 1653109 ASDA DESIGN_CORRUPTIO SDA not pulling latest library information for part 1655377 FLOWS PROJMGR Project Manager crashes on Windows 10 Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
rom67 0 13 декабря, 2016 Опубликовано 13 декабря, 2016 · Жалоба вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: 009 DATE: 12-8-2016 HOTFIX VERSION: 009 ================================================================================ =================================================== CCRID PRODUCT PRODUCTLEVEL2 TITLE ================================================================================ =================================================== 1212577 PSPICE MODELEDITOR IBIS translation fails without any information in log file 1311687 PSPICE MODELEDITOR Timeout error while translating IBIS model 1327174 PSPICE MODELEDITOR Log file should list error details during IBIS Translation 1499665 ALLEGRO_EDITOR INTERACTIV Offset Move depends on move setting. 1516093 ALLEGRO_EDITOR PADS_IN Pads library translator does not translate slot orientation 1565795 ALLEGRO_EDITOR UI_GENERAL Search does not work in the Defined Variables window 1568817 ALLEGRO_EDITOR UI_GENERAL Padstack editor not accepting comma as decimal separator with system locale set as LANG ru_RU.UTF-8 1569272 ALLEGRO_EDITOR PLACEMENT Get the error message 'E- (SPMHDB-394): Placement cannot be completed ... 'after creating Place Replicate circuit 1577379 CONCEPT_HDL CORE Packager-XL gives different results when run from DE-HDL and ADW Flow Manager 1578523 ALLEGRO_EDITOR PAD_EDITOR Library Padstack Browser does not refresh preview 1578533 ALLEGRO_EDITOR PAD_EDITOR New Padstack Editor does not automatically update the geometry 1581129 CONSTRAINT_MGR UI_FORMS Unable to dock the Electrical worksheet in Constraint Manager 1582103 ALLEGRO_EDITOR PADS_IN PADS Library Import creates additional filled shape not present in source data 1591027 ADW LIBDISTRIBUTION Library Distribution redistributes previously distributed models 1592026 CIS VIEW_DATABASE_PA View database part does not work from schematic pages of an externally referenced design 1593389 CAPTURE GEN_BOM Include files in Tools - BOM not working 1593404 SIP_LAYOUT EDIT_ETCH Slide command moves via toward the object 1595872 CIS PART_MANAGER Capture CIS Part Manager PCB Footprint update case-sensitivity issue 1596955 ALLEGRO_EDITOR EDIT_ETCH Scribble mode is not working as per expectation. 1600936 ALLEGRO_EDITOR INTERACTIV Pin DataTips differ between 16.6 and 17.2 1605961 ALLEGRO_EDITOR COLOR Wildcards not working in the Filter Nets field of the Color Dialog window 1606392 ALLEGRO_EDITOR PLACEMENT Filmmask not shown when component is attached to cursor 1607016 ADW TDA TDO crashes after LRM update during check-in hierarchy 1608059 CONCEPT_HDL CREFER Removing crefs from top-level design also removes .csb files from lower-level blocks 1608278 CAPTURE OTHER Crystal Reports: User is prompted for ODBC password to create a BOM report 1610377 CAPTURE PROPERTY_EDITOR Discrepancies between the NET_SPACING_TYPE property (or any other property) text and the actual property 1610456 ALLEGRO_EDITOR DATABASE Strip design and selecting user defined subclasses results in database corruption. 1612793 CONCEPT_HDL OTHER Pattern-based auto-distribution of split symbols not working if there are spaces before commas 1613442 CONCEPT_HDL CORE Signal names are not horizontally centered when the wires are added using different methods 1613559 ASDA IMPORT_DEHDL_SHE custom variables from the BOM Tables are not getting imported 1614093 CONCEPT_HDL CORE Import Design window has artificial 64 char limit for path - prevents access to some locations 1614372 CONCEPT_HDL EDIF300 OFFPAGE symbol is exported as PageBorder in EDIF300 schematic 1615075 APD LOGIC Netlist-In wizard fails to import the net names, but gives a successful completion Info message 1616131 ALLEGRO_EDITOR PLACEMENT While placing a module, the Mirror command in the right-click pop-up menu is not working 1617377 ALLEGRO_EDITOR UI_GENERAL Visibility pane does not retain the correct layer view 1617404 ALLEGRO_EDITOR UI_GENERAL axlUIMenuChange does not work as expected in 17.2 1619412 ALLEGRO_EDITOR INTERACTIV Script to create new padstacks from existing padstack is putting in wrong values for a regular pad 1621842 ALLEGRO_EDITOR PLACEMENT mechanical symbol without placebound will not place in QuickPlace 1621874 ASDA PRINT Print - Save as PDF uses the default printer options only 1621887 ALLEGRO_EDITOR INTERACTIV Getting a 'Could not satisfy the snap condition' message when using the Snap pick to option 1622680 ALLEGRO_EDITOR PADS_IN Import PADS fails with the 'ERROR: *NET* section found. Translation of netlist is not allowed.' message 1623832 ADW COMPONENT_BROWSE Incorrect part placement on schematic in Design Entry HDL 16.6-S073 1624813 CAPTURE GENERAL The Value property is always left aligned when placing a symbol on the schematic 1624953 ALLEGRO_EDITOR UI_GENERAL Custom views in 17.2 do not return to original 1625000 ASDA CANVAS_EDIT File - Save Project does not provide any indication of saving or progress bar 1625163 CONSTRAINT_MGR OTHER There is no status for the analyze command in the Constraint Manager in 17.2 1626647 PSPICE ENVIRONMENT Capture crashes when loading a design with two hyphens in sim profile name 1628357 CONSTRAINT_MGR OTHER Constraint Manager shows differences if exporting and importing constraints on the same board. 1628409 ALLEGRO_EDITOR PAD_EDITOR Pad Stack Editor does not remember last used directory 1631443 CONCEPT_HDL ERCDX ERC reports warning due to lower-case value of some properties in chips.prt 1632195 SCM OTHER 'No known page border found' error in cref.log 1632365 CONSTRAINT_MGR OTHER Select command is disabled in the right-click pop-up menu from Constraint Manager in SPB 17.2 1632462 ALLEGRO_EDITOR 3D_CANVAS 3D View (new) and PCB Editor crash when checking collisions 1632590 ALLEGRO_EDITOR 3D_CANVAS PCB Editor crashes when 3D View is open and more 16.6 boards are opened 1633433 CONSTRAINT_MGR UI_FORMS Expand - Collapse feature for multiple objects not working correctly 1633454 ADW TDA TDO crashes if DAO throws an exception 1633526 PSPICE AA_PPLOT Spaces in Simulation Profile cause error in Parametric Plotter 1633608 ALLEGRO_EDITOR COLOR 'Retain objects custom color' should not enabled as default. 1636216 ALLEGRO_EDITOR 3D_CANVAS Interactive 3D canvas (Unsupported prototype) is not mapping step model when assigned to device 1636899 ALLEGRO_EDITOR 3D_CANVAS The new 3D Viewer is not taking the Package Height set on the PLACE_BOUND layer into account when displaying it. 1638185 CAPTURE DATABASE Opening CIS database locks all part libraries none of which are open 1639409 ASDA CANVAS_EDIT Handling of MAKE_BASE property from DE-HDL designs imported into SDA 1639541 CONSTRAINT_MGR OTHER PCB Editor 17.2 crashes when making changes in Constraint Manager 1639613 APD STREAM_IF The stream out command has created sharp angles in the GDSII output file 1640061 ASDA HIERARCHY Incorrect message received when invalid characters are specified for subdesign suffix 1641118 F2B DESIGNVARI Some DNI parts are not identified in the variant view due to the BLOCK 1641410 ASDA CONSTRAINT_MANAG No errors or issues reported when incorrect topology is applied to a net or an Xnet 1642891 CONSTRAINT_MGR CONCEPT_HDL DE-HDL crashes randomly while working on Constraint Manager 1643003 CAPTURE PROJECT_MANAGER Start page shows latest as S004 after installing S005 1643532 ALLEGRO_EDITOR OTHER Strip design command fails to delete symbol text in the attached design 1645529 ASDA CONSTRAINT_MANAG Unable to delete the diff pair from the nets 1645639 CONSTRAINT_MGR CONCEPT_HDL DE-HDL crashes when the XNET_PINS property value has a trailing comma character 1646354 CONSTRAINT_MGR CONCEPT_HDL Cannot select Design Instance/Block Filter from the View menu in Constraint Manager 1646612 PCB_LIBRARIAN CORE Generate Symbol option crashes Part Developer 1646932 ALLEGRO_EDITOR MANUFACT Manufacture - Auto Rename Refdes keeps defaulting to Use Default Grid even if another is chosen 1647190 APD REPORTS 'Sorted by Bond Finger' report shows incorrect wire bond connection 1647673 ASDA EXPORT_PCB Two Physical folders are seen after installation of QIR 1647729 ALLEGRO_EDITOR SKILL axlFillet returns t when fillet is not added. 1647779 CONSTRAINT_MGR OTHER 'Software Version' in the cmDiffUtility viewer does not show the correct version 1647843 ALLEGRO_EDITOR ARTWORK Misleading information in command window when artwork import fails 1648575 CAPTURE OTHER Suppress warning setting must be written in capture.ini file 1649060 CONSTRAINT_MGR CONCEPT_HDL Rename dcfx to dcf process results in error in log file and dcf not updated 1650106 ALLEGRO_EDITOR 3D_CANVAS 3D canvas rotates mirrored components in unmirrored angle 1650238 SIP_LAYOUT WIREBOND When performing 'Adjust Min DRC', the reference bond finger should not move. 1650734 APD SHAPE Shape on L1 does not flood properly 1650793 CONSTRAINT_MGR CONCEPT_HDL Conflict of XNET_PINS definition between the chips and the SIGNAL_MODEL is not handled correctly 1650801 ALLEGRO_EDITOR SCHEM_FTB Running Export Physical with Update PCB enabled in Project Manager crashes netrev.exe 1651011 ALLEGRO_EDITOR 3D_CANVAS Interactive 3D viewer shows mechanical symbol mirrored 1651063 ALLEGRO_EDITOR CROSS_SECTION Cross-section preview is incorrect 1651066 ALLEGRO_EDITOR DATABASE Pins not connecting even after running the Tools - Derive Connectivity command 1651700 ALLEGRO_EDITOR SKILL Running axlXSectionModify() on a layer removes the value of the material 1651925 ALLEGRO_EDITOR ARTWORK Searching for a macro in the artwork data file: Count for the macro does not match the actual count in the output 1652230 CONCEPT_HDL CORE The master.tag and vlog004u.sir files are not created in the entity directory on saving symbols 1653080 CONCEPT_HDL ERCDX Difference in results from SPB16.6 in 'erc.rpt' when logic_data is renamed as worklib in SPB17.2 on RHEL6.5 1653422 ADW LIBIMPORT Classifications not linked to a Part Number or Cell Model are removed during Library Import 1653526 ALLEGRO_EDITOR DATABASE Via padstack keepout is not displayed on the canvas when pads suppression is enabled. 1653951 ALLEGRO_EDITOR CROSS_SECTION Cross Section Editor changes lost despite selecting No to the 'All changes will be lost ...' message 1656224 ADW FLOW_MGR Copy Project wizard no longer allows dashes in the 'Name of new project folder' field 1656581 ALLEGRO_EDITOR OTHER PDF generated for layer with shape shows undesired voids if film is mirrored and Filled Shape is not selected 1656608 APD REPORTS Incorrect calculation in the metal usage report 1656726 CONCEPT_HDL CORE Interface command always disabled in the Wire menu 1656841 CONSTRAINT_MGR UI_FORMS Incorrect layer information is displayed in the Edit Via List dialog when a filter is applied 1657220 ALLEGRO_EDITOR SKILL axlXSectionGet() returns Primary list of layers and not All stackups 1657257 SIP_LAYOUT EXTRACT When using extracta, custom layer names not getting retained 1658440 ALLEGRO_EDITOR PAD_EDITOR The location of a drill in the .pad file is different from the .dra file 1658445 CONSTRAINT_MGR CONCEPT_HDL When DCF file is converted to ASCII, no further updates are allowed. 1659473 SIP_LAYOUT WIREBOND When moving wirebonds they are jumping instead of sliding 1659498 ALLEGRO_EDITOR INTERACTIV Unable to turn off line on Etch Wire for Jumpers 1659644 CONCEPT_HDL OTHER Predefined nets are not listed if 16.6 design is being opened in 17.2 1660475 CONSTRAINT_MGR UI_FORMS The CTRL+V shortcut is not working in the Export Constraints window in Constraint Manager 17.2 1660492 ALLEGRO_EDITOR UI_GENERAL PCB Editor crashes when using multiple desktops on Windows 10 1661133 CONSTRAINT_MGR ANALYSIS PCB Editor crashes if comma is used in the Value field for Analysis Mode 1661307 CONSTRAINT_MGR CONCEPT_HDL Prevent creation of diff pairs on VOLTAGE nets 1661357 ALLEGRO_EDITOR EDIT_ETCH PCB Editor crashes when using Route - Connect 1661874 ASDA DESIGN_CORRUPTIO Unable to delete the ZERO part from the schematic page 1662799 ADW SRM Mechanical symbols are not being displayed in the Mechanical tab of Symbol Rollback Manager 1664797 SIG_INTEGRITY GUI Unnecessary coupled interconnect models were generated during View Waveform. 1664858 ALLEGRO_EDITOR EDIT_ETCH PCB Editor crashes during Auto Interactive trunk route. 1664911 ALLEGRO_EDITOR OTHER PCB Editor freezes after DRC Update is performed 1666329 CONSTRAINT_MGR OTHER SCM Import Physical process crashes cmfeedback 1666551 ALLEGRO_EDITOR ARTWORK Import Artwork, Mirror option separates imported artwork to different XY locations 1666723 ECW TDO-SHAREPOINT TDO login is not working with Site Minder because of incorrect characters in the Site Minder login form HTML 1667068 ALLEGRO_EDITOR SHAPE Update shape removing the shape voiding 1669828 F2B DESIGNVARI Variant Editor crashes on Windows 10 T540 P laptops but works fine on Windows 10 desktops 1670221 ALLEGRO_EDITOR DATABASE Non-recoverable corruption error is reported when saving the board after adding a layer 1672134 ALLEGRO_EDITOR ZONES TDP needs FIXED component override Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
rom67 0 9 января, 2017 Опубликовано 9 января, 2017 · Жалоба вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: 010 DATE: 01-6-2017 HOTFIX VERSION: 010 ================================================================================ =================================================== CCRID PRODUCT PRODUCTLEVEL2 TITLE ================================================================================ =================================================== 1524700 F2B DESIGNVARI Variant file cannot be loaded 1597787 CONCEPT_HDL MARKERS Save As in Marker dialog causes DE-HDL to crash 1599843 CONCEPT_HDL INTERFACE_DESIGN Moving NG causes extra elements or moving 1620017 F2B PACKAGERXL Packager Fails with ERROR(SPCOPK-1053) when $PART_NUMBER property for components has a value 1632977 CONCEPT_HDL INTERFACE_DESIGN Connectivity error when moving NG members 1635941 ALLEGRO_EDITOR INTERFACES Shape created by IPC 2581 for negative film is not same as the shape on board 1656357 CONCEPT_HDL CORE Pasting a signal name across pages causes the name to overlap with the wire segment 1657346 CONCEPT_HDL PDF Wire Pattern set to two-dot chain line in a schematic appears as a solid line in the PDF output 1658048 ALLEGRO_EDITOR COLOR color_lastgroup is not working in SPB 17.2 1658874 CONCEPT_HDL CORE 'Insert (n) Pages' command does not work when the CONFIRM_WRITE directive is ON 1659030 RF_PCB LIBRARY Offset is not calculated from the center if using negative values for input pins when placing MSOP symbols 1659097 CONCEPT_HDL CORE mouse stroke fails to be enabled on startup with left moust button (LMB) 1659532 CONCEPT_HDL CORE About Import Design command with the CONFIRM_WRITE directive 1659929 CONSTRAINT_MGR UI_FORMS Using wildcards in filename for Import Constraints does not work in 17.2 1660200 ALLEGRO_EDITOR UI_GENERAL Move by Sym Pin # edit box is obfuscated 1662821 ALLEGRO_EDITOR OTHER Cross section chart does not show stack vias in 17.2 1663641 CONCEPT_HDL COPY_PROJECT File - Copy Project in Project Manager creates two designs if there are dashes in the design name 1665652 ALLEGRO_EDITOR SHAPE Critical fillet and shape issues in 17.2 1665918 CONCEPT_HDL CHECKPLUS Error (100) Program Internal Error "Create_flat_node" with checkplus run 1667056 ASI_PI GUI Power Feasibility Editor does not list capacitors connected to selected nets/parts 1668137 ALLEGRO_EDITOR SCRIPTS PCB Editor crashing when running Script Replay 1669651 CONCEPT_HDL CREFER CreferHDL values are invisible 1669707 CONCEPT_HDL CORE Pin numbers not visible on the canvas after replacing a part with the same symbol but a different part property 1670339 ALLEGRO_EDITOR OTHER Small shapes define on the mechanical symbol Board Geometry – Outline are not converted to the Cutout subclass. 1670564 ALLEGRO_EDITOR MANUFACT exported gerber file can't import in brd 1670687 ALLEGRO_EDITOR NC nclegend.log reports missing columns which are present in the NC Legend 1670811 PSPICE AA_MC AA MC Plot settings options 1671428 ALLEGRO_EDITOR UI_FORMS Display origin checkbox position changes in Step Mapping dialog 1671728 CONCEPT_HDL CORE Option requested to reload preferred_projects.txt without re-opening DE-HDL 1671901 ALLEGRO_EDITOR UI_GENERAL Toolbar and menus are locked or greyed out 1672477 ALLEGRO_EDITOR DRC_CONSTR DRC generated by Dynamic fillets 1673499 ALLEGRO_EDITOR DATABASE Would you please check on the drill table title issue of backdrill design in v172. 1673681 ALLEGRO_EDITOR UI_GENERAL F1 for Help not working in PCB Editor 17.2 1675499 ALLEGRO_EDITOR DATABASE Running the Gloss command causes PCB Editor to crash... 1676480 ALLEGRO_EDITOR MANUFACT Creating Variant Assy_Bot Drawing showing Variant Assy Top Drawing 1677431 ALLEGRO_EDITOR DATABASE Get ERROR(SPMHA1-141): Invalid sector row. Contact cadence customer support when opening DRA File 1677651 CONSTRAINT_MGR CONCEPT_HDL DE-HDL crash on design after successful packaging 1677672 CONCEPT_HDL CORE Whitespaces in URL links are not resolved correctly on Linux with Firefox 1680837 ALLEGRO_EDITOR SHAPE Updating the shape makes the shape disconnect from Thru pins of same net 1681059 ALLEGRO_EDITOR SHAPE Shape Voiding using DV_SQUARECORNERS environmental variable does not always produce voids with square corners. 1682312 SIG_INTEGRITY LICENSING Allegro Sigrity SI/PI Product Choices window is blank after installing 17.2-s009 hotfix Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
rom67 0 23 января, 2017 Опубликовано 23 января, 2017 · Жалоба вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: 011 DATE: 01-20-2017 HOTFIX VERSION: 011 ================================================================================ =================================================== CCRID PRODUCT PRODUCTLEVEL2 TITLE ================================================================================ =================================================== 1618986 CONCEPT_HDL CORE Information required about the DONT_FORCE_ORIGIN_ONGRID directive 1629696 PSPICE PROBE After successfully exporting traces to csv, PSpice crashes on a subsequent attempt to export traces 1667213 CAPTURE NETLIST_ALLEGRO Tools - Create Netlist stops responding on Windows10 1667599 APD OTHER Wire Bond operations taking longer than expected to complete 1667678 MODEL_EDITOR PARSE Signal model assignment creates ESpice models that do not pass Model Integrity checks 1670120 ALLEGRO_EDITOR UI_GENERAL In 17.2, the Static Phase meter shows up in the middle of the screen instead of the lower right corner 1670927 ALLEGRO_EDITOR DRAFTING Using zcopy to create a Route Keepin results in database errors 1675359 ALLEGRO_EDITOR ARTWORK Subclass ETCH/WIRE is added to artwork definition though the visibility of 'ALL Layers' is turned off 1675619 ALLEGRO_EDITOR MANUFACT Differences observed in IPC-D-356A between releases 16.6 and 17.2 1676161 ADW FLOW_MGR Operation load JNI code failed error while opening project in SPB 17.2 1677405 CONCEPT_HDL OTHER When moving a wire with a dot, the dot is not removed directly 1678061 PSPICE SLPS Simulating an SLPS co-simulation with a Fixed-step solver with a value smaller than 1E-4 results in a crash 1679347 PSPICE SLPS SLPS crashes when co-simulating without opening OrCAD Capture or PSpice 1680113 ALLEGRO_EDITOR SHAPE Irregular void created on dynamic shapes 1680802 ALLEGRO_EDITOR DATABASE A 16.3 database locked with disabled export of design data should be view only in 16.6 1681129 ALLEGRO_EDITOR DATABASE Match Groups in the DE-HDL design are not getting transferred to the board file 1681514 ALLEGRO_EDITOR UI_GENERAL Opening the Dynamic Shapes State report hangs PCB Editor in 17.2 Hotfix 009 1681727 CAPTURE NETGROUPS In 17.2, Capture crashes when closing a design that has assigned Netgroups 1682297 ALLEGRO_EDITOR DATABASE Derived padstack and associated padshapes not updated when design is upreved for compatibility with the current version 1682447 CONSTRAINT_MGR CONCEPT_HDL Extraction issue on differential pairs in the given design 1682454 CONSTRAINT_MGR CONCEPT_HDL Design with NO_XNET_CONNECTION property on parts is exported to PCB Editor; many other components get the property 1682469 CONSTRAINT_MGR CONCEPT_HDL Creating a CSet from an existing CSet leads to invalid CSet names in Constraint Manager connected to DE-HDL 1683919 ECW TDO-SHAREPOINT Site Minder integration for login from TDA not working after SSL certificate update 1684111 ALLEGRO_EDITOR SHAPE Dynamic Shape not voiding overlapped static shape 1684508 ALLEGRO_EDITOR AUTOVOID Allegro PCB Editor stops responding when deleting a via 1685540 ALLEGRO_EDITOR OTHER If text is attached to an object, the object is also printed in the PDF 1685810 ALLEGRO_EDITOR PAD_EDITOR In 17.2, Padstack Editor does not save adjacent layer information for BOTTOM pads 1685986 ALLEGRO_EDITOR PADS_IN PADS Translator-generated output shows incorrect unit for the soldermask oversize option 1686127 ALLEGRO_EDITOR SHAPE The void of shape missed in artwork. 1686791 ALLEGRO_EDITOR OTHER Searchable property unavailable on bottom layer pins in the generated PDF Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
rom67 0 13 февраля, 2017 Опубликовано 13 февраля, 2017 · Жалоба вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: 012 DATE: 02-3-2017 HOTFIX VERSION: 012 ================================================================================ =================================================== CCRID PRODUCT PRODUCTLEVEL2 TITLE ================================================================================ =================================================== 1659641 ADW FLOW_MGR Documentation Editor does not invoke when a .brd file is opened from EDM Flow Manager 1661632 CONCEPT_HDL OTHER Page skipped in DE-HDL when navigating using the Page Up and Page Down keys 1668325 ALLEGRO_EDITOR SHAPE Updating shapes to smooth creates erratic voids. 1670082 CONSTRAINT_MGR ANALYSIS Inconsistency in Constraint Analysis Modes - Electrical in OrCAD PCB Designer Professional 17.2 1674231 ECW METRICS Re-upload for local metric packets that failed on first attempt is not working when Pulse server name contains dots 1674338 APD SHAPE Shape is not clearing slivers that are smaller than the 'Minimum aperture for gap width' of '18 um' 1675677 ADW DBEDITOR DBeditor Issue-Searching by using the Properties method 1677489 CONCEPT_HDL CREFER CRefer points to incorrect page numbers when there are page mismatches in the logical and physical page numbers 1679351 ALLEGRO_EDITOR REPORTS Missing Fillets Report is not showing missing fillets on the bottom layer 1681002 ALLEGRO_EDITOR OTHER 17.2 STEP output fails to produce an output similar to 16.6 1682287 ALLEGRO_EDITOR EDIT_ETCH Auto-interactive Delay tune (AiDT) rips lines that have been routed 1682900 ALLEGRO_EDITOR PLACEMENT Moving a symbol by snapping to segment vertex with 17.2 Hotfix 009 crashes PCB Editor 1684117 CONCEPT_HDL CONSTRAINT_MGR Property deleted from Constraint Manager is not getting updated in the DE-HDL canvas 1686803 ALLEGRO_EDITOR INTERFACES PCB Editor crashes if the 'ipc2581_group_drills' variable is set. 1687816 ALLEGRO_EDITOR PLOTTING Export PDF Vector text option does not work 1688287 CONSTRAINT_MGR DATABASE PCB Editor crashing while adding a net to a net group. 1689881 ALLEGRO_EDITOR DFA Record and replay script for loading DFA spreadsheet not working 1690958 ALLEGRO_EDITOR SKILL SKILL command axlDBDelLock is not working as explained in the documentation 1692166 APD DATABASE DB Doctor returns 'ERROR(SPMHDB-252): A corrupt database pointer was detected' for a specific design 1693431 ALLEGRO_EDITOR SKILL Running axlXSectionModify and axlXSectionSet results in warnings and corrupts multi-zone cross-section 1693719 ALLEGRO_EDITOR MANUFACT Incorrect suppressed holes information in the drill file created 1693846 ALLEGRO_EDITOR MANUFACT PCB Editor crashes when running the gloss command 1694151 CONCEPT_HDL CORE Rename Signal for unnamed net added the sig_name at the incorrect position with small text size. 1694867 ALLEGRO_EDITOR SHAPE Void is deleted by the shape merge command 1695131 ALLEGRO_EDITOR SKILL PCB Editor crashes when using the axlSpreadsheetDefineCell SKILL function Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
rom67 0 19 февраля, 2017 Опубликовано 19 февраля, 2017 · Жалоба вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: 013 Fixed CCRs in SPB 17.2 HF013 02-17-2017 ================================================================================ CCRID Product ProductLevel2 Title ================================================================================ 1567741 ADW COMPONENT_BRO The PPL_list never gets read when using a saveconf.ctr located in the global site.cpm 1697109 ALLEGRO_EDITOR ARTWORK Artwork not showing padstacks for the soldermask layer 1682297 ALLEGRO_EDITOR DATABASE Derived padstack and associated padshapes not updated when design is upreved for compatibility with the current version 1697309 ALLEGRO_EDITOR DATABASE PCB Editor 17.2 uprev changes NC pins from non-plated to plated 1698624 ALLEGRO_EDITOR DATABASE Opening 16.6 board in 17.2 converts non-plated holes to plated 1697092 ALLEGRO_EDITOR OTHER axlDBViaStack crashes PCB Editor session and corrupts the board 1687819 ALLEGRO_EDITOR UI_GENERAL Change in Region and Language settings of Windows impacts decimal character in Padstack Editor 1696637 ALLEGRO_EDITOR UI_GENERAL Padstack Editor uses Region and Language settings for the decimal symbol 1699326 ALLEGRO_EDITOR UI_GENERAL Padstack Editor follows the geographical area rules set in the Control Panel while PCB Editor does not 1616138 ALTM_TRANSLATOR PCB_EDITOR Board file imported from third-party tool to PCB Editor has the shapes but not the components 1666020 ALTM_TRANSLATOR PCB_EDITOR Board converted from a third-party tool to PCB Editor has missing components 1690448 CAPTURE CORRUPT_DESIG Corrupt design: nets in this design are not displayed when running Edit - Browse - Nets 1690455 CAPTURE CORRUPT_DESIG Corrupt design: all the nets in this design are not displayed when running Edit - Browse - Nets 1684180 CONCEPT_HDL CORE Message should indicate that the user needs to reload the design after setting SET STICKY_OFF 1695987 CONCEPT_HDL CORE $PN placement in DE-HDL during part development is not following mouse placement 1688287 CONSTRAINT_MGR DATABASE PCB Editor crashing while adding a net to a net group. 1675013 ORBITIO ALLEGRO_SIP_I Failed to import brd file 1698968 SIP_LAYOUT 3D_VIEWER 3D viewer shows keepin and not design outline. 1699884 SIP_LAYOUT ASSY_RULE_CHE SiP Layout crashes on using Assembly Rules Checker 1689969 SIP_LAYOUT DIE_EDITOR SiP Layout crashes when moving dies using relative coordinates 1696239 SIP_LAYOUT DIE_EDITOR When using the Die-stack Editor to move and stretch wires, SiP Layout crashes 1695372 SIP_LAYOUT REPORTS Running the Metal Usage reports fails on the Primary side. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
rom67 0 5 марта, 2017 Опубликовано 5 марта, 2017 · Жалоба вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: 014 Fixed CCRs: SPB 17.2 HF014 03-4-2017 ================================================================================ ======================================================================== CCRID Product ProductLevel2 Title ================================================================================ ======================================================================== 1691828 ADW COMPONENT_BRO Part Information Manager displays incorrect data related to attributes on relationships 1700963 ALLEGRO_EDITOR DATABASE Running the 'slide' command results in the cline segment losing connectivity 1685502 ALLEGRO_EDITOR INTERFACES The Export - PDF command fails to export the TOP etch subclass with error code SPMHGE-268 1644643 ALLEGRO_EDITOR MANUFACT The NC drill legend does not match the drill customization data 1700557 ALLEGRO_EDITOR MANUFACT DXF output does not contain drill figure data 1660252 ALLEGRO_EDITOR NC NC Drill file generated with errors 1677775 ALLEGRO_EDITOR NC Merging of drills not retained in database. 1701554 ALLEGRO_EDITOR SHAPE Shape spacing clearance is not updated unless the shape vertex is deleted 1704669 ALLEGRO_EDITOR SHAPE Route Keepin is not getting created at a specific location 1685995 ALLEGRO_EDITOR SKILL All film sequence numbers are returned as 0 when using the SKILL function axlGetParam 1621336 ALLEGRO_EDITOR UI_GENERAL Changing the color visibility does not refresh the screen color immediately 1668817 ALLEGRO_EDITOR UI_GENERAL Changing the visibility or the color on the canvas in release 17.2-2016 takes longer than release 16.6 1671268 ALLEGRO_EDITOR UI_GENERAL Visibility Window: There is a noticeable lag when enabling etch, via, and pin on a specific layer one by one 1690691 ALLEGRO_EDITOR UI_GENERAL Reports not generating if the 'allegro_html_qt' environment variable is disabled 1709903 ALLEGRO_EDITOR UI_GENERAL Toggling layer visibility does not change the display until the mouse pointer is moved 1647596 APD EXPORT_DATA Allegro Package Designer crashes when trying to export board-level components 1688035 APD OTHER Significant difference seen in the percentage of metal between the Metal Usage reports of positive and negative layers 1690777 CONCEPT_HDL CHECKPLUS Rules Checker returns an error when the value of the PACK_TYPE property is in lowercase 1695987 CONCEPT_HDL CORE $PN placement in DE-HDL during part development is not following mouse placement 1700873 CONCEPT_HDL CORE With duplicate part table files, running the Assign Power Pins command crashes DE-HDL without any message 1702703 CONCEPT_HDL CORE Location of $PN in DE-HDL Symbol Editor is not as precise as it was in 17.2 Hotfix 011 1705999 CONCEPT_HDL CORE Signal naming is not working correctly in SPB 17.2 1677489 CONCEPT_HDL CREFER CRefer points to incorrect page numbers when there are page mismatches in the logical and physical page numbers 1698259 CONSTRAINT_MGR CONCEPT_HDL Unstable $LOCATION property in release 17.2-2016 1702537 CONSTRAINT_MGR CONCEPT_HDL ECSet mapping errors reported after removing the signal models on an upreved design 1703981 CONSTRAINT_MGR TECHFILE Importing a technology file (.tcf) results in packaging errors 1673115 ECW INTEGRATION Import from external data sources (Integrations) truncates input values to 128 characters 1699395 FSP FPGA_SUPPORT Selecting a QSF part name in the FPGA Properties window crashes FSP 1704353 INSTALLATION DOWNLOAD_MGR Selecting 'View' in Download Manager results in error, 'Object Reference not set to an instance of an object' 1705265 INSTALLATION DOWNLOAD_MGR Problem installing OrCAD Library Builder from Download Manager 1646635 PDN_ANALYSIS PCB_PI PCB Editor uses 'powerdc.exe' to launch PowerDC instead of the 'powerdc' script Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
rom67 0 27 марта, 2017 Опубликовано 27 марта, 2017 · Жалоба вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: 015 DATE: 03-16-2017 HOTFIX VERSION: 015 ================================================================= CCRID Product ProductLevel2 Title ================================================================= 1653366 ALLEGRO_EDITOR INTERFACES Unable to attach step model to symbol 1671760 ALLEGRO_EDITOR INTERFACES Step package mapping window unable to display step model 1706879 ALLEGRO_EDITOR MANUFACT Trace gets moved to dielectric layer after using the Gloss function 1708685 ALLEGRO_EDITOR MANUFACT Incomplete ncdrill holes data in drl file 1712057 ALLEGRO_EDITOR PAD_EDITOR Changing text size and restarting Padstack Editor results in incorrectly scaled forms 1709335 ALLEGRO_EDITOR SCHEM_FTB Cannot import netlist from attached design 1687329 ALLEGRO_EDITOR SHAPE Shape is not voiding uniformly when component is rotated in 30 degrees 1698539 ALLEGRO_EDITOR SHAPE A thin shape is left when dv_fixfullcontact is enabled. 1620210 ALLEGRO_EDITOR UI_GENERAL Need to run PCB Editor from both 17.2-2016 and 16.6 releases simultaneously 1687819 ALLEGRO_EDITOR UI_GENERAL Change in Region and Language settings of Windows impacts decimal character in Padstack Editor 1699326 ALLEGRO_EDITOR UI_GENERAL Padstack Editor follows the geographical area rules set in the Control Panel while PCB Editor does not 1711341 ALLEGRO_EDITOR UI_GENERAL Incorrect pad size in Padstack Editor when the German regional settings are used 1712496 ALLEGRO_EDITOR UI_GENERAL Padstack Editor shows incorrect values when using comma and 3 decimal places 1714744 ALLEGRO_EDITOR UI_GENERAL Using comma instead of dot as integer separator results in incorrect diameter value 1715714 ALLEGRO_EDITOR UI_GENERAL If the 'Decimal places' field is set to 3, values in PAD Designer change automatically 1713292 APD WIREBOND Allegro Package Designer crashes when adding wire to a die pad 1710973 ASDA PACKAGER Unable to export Allegro SDA project to PCB Layout 1698697 CONCEPT_HDL COPY_PROJECT Copy project corrupts the .dcf file 1705401 CONCEPT_HDL CORE Alignment issues while pasting signal names in 16.6 Hotfix 084 1707116 CONCEPT_HDL CORE SIG_NAME is placed on non-grid position 1710486 CONCEPT_HDL CORE Rename Signal places sig_name at an incorrect position for an unnamed net 1667786 CONSTRAINT_MGR XNET_DIFFPAIR Parts with NO_XNET_CONNECTION getting extracted into SigXplorer 1709508 SIG_INTEGRITY REPORTS Allegro Sigrity SI crashes when running a reflection simulation 1710097 SIP_LAYOUT DIE_STACK_EDI The IY option of the 'move and stretch wire' command moves the die to incorrect coordinates 1712964 SIP_LAYOUT SYMBOL SiP Layout crashes when using Renumber Pins in Symbol Edit application mode Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
rom67 0 10 апреля, 2017 Опубликовано 10 апреля, 2017 · Жалоба вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: 016 Fixed CCRs: SPB 17.2 HF016 04-6-2017 ================================================================================ ======================================================================== CCRID Product ProductLevel2 Title ================================================================================ ======================================================================== 1567741 ADW COMPONENT_BRO The PPL_list never gets read when using a saveconf.ctr located in the global site.cpm 1623832 ADW COMPONENT_BRO Incorrect part placement on schematic in Design Entry HDL 16.6-S073 1673128 ADW COMPONENT_BRO Directive is saved in project CPM 1673510 ADW COMPONENT_BRO Lifecycle status color column is not sorted correctly in Component Browser search results 1691828 ADW COMPONENT_BRO Part Information Manager displays incorrect data related to attributes on relationships 1604734 ADW DATABASE Parts displaying non-key properties and values in the Component Browser in ADW 1585203 ADW DBEDITOR Optimize check-in of footprints with multiple padstacks 1675677 ADW DBEDITOR Database Editor (dbeditor) hangs while searching by property 1142957 ADW DSN_FLOW No Help available for schematic design verification 1609186 ADW DSN_MIGRATION ADW Design Migration utility should handle ADW board reference projects and manage atdm.ini 1656224 ADW FLOW_MGR Copy Project wizard no longer allows dashes in the 'Name of new project folder' field 1659641 ADW FLOW_MGR Documentation Editor does not invoke when a .brd file is opened from EDM Flow Manager 1676161 ADW FLOW_MGR Opening a project in release 17.2 flags the 'Operation load JNI code failed' error 1591757 ADW GENERIC_UI Running 'Create Test Schematic' in ADW Flow Manager results in Error SPCOCN-1736 1591027 ADW LIBDISTRIBUTI Library Distribution redistributes previously distributed models 1588111 ADW LIBIMPORT Library Import fails with Java errors while processing .csv files 1653422 ADW LIBIMPORT Classifications not linked to a Part Number or Cell Model are removed during Library Import 1632223 ADW LRM Checking in a hierarchy causes a crash 1618173 ADW SRM SRM does not automatically run when a .brd file is opened from EDM Flow Manager in release 17.2 Hotfix 003 1618832 ADW SRM SRM marks parts as updated even when they are not updated 1662799 ADW SRM Mechanical symbols are not being displayed in the Mechanical tab of Symbol Rollback Manager 1633454 ADW TDA TDO crashes if DAO throws an exception 1628403 ADW TDO-SHAREPOIN Objects remain checked out after multiple failed 'check-in hierarchy' attempts 1632462 ALLEGRO_EDITOR 3D_CANVAS 3D View (new) and PCB Editor crash when checking collisions 1632590 ALLEGRO_EDITOR 3D_CANVAS PCB Editor crashes when 3D View is open and more 16.6 boards are opened 1636216 ALLEGRO_EDITOR 3D_CANVAS Interactive 3D canvas (Unsupported prototype) is not mapping Step model when assigned to a device 1636899 ALLEGRO_EDITOR 3D_CANVAS The new 3D Viewer is not taking the Package Height set on the PLACE_BOUND layer into account when displaying it. 1642367 ALLEGRO_EDITOR 3D_CANVAS Component height is not correct in new 3D Viewer 1642668 ALLEGRO_EDITOR 3D_CANVAS The new 3D canvas does not show STEP model of the drawing (.dra) 1650106 ALLEGRO_EDITOR 3D_CANVAS 3D Canvas: Symbols are mirrored at incorrect angles 1651011 ALLEGRO_EDITOR 3D_CANVAS Interactive 3D viewer shows mechanical symbol mirrored 1653247 ALLEGRO_EDITOR 3D_CANVAS New interactive 3D Viewer shows wrong placement 1658275 ALLEGRO_EDITOR 3D_CANVAS Components on the bottom side are shifted in the new 3D view 1635858 ALLEGRO_EDITOR ARTWORK Get 'WARNING: Null REGULAR-PAD specified for padstack' messages in log file when generating artwork for all layers 1639244 ALLEGRO_EDITOR ARTWORK When importing an artwork, a sub-folder is created with the value of the ads_sdart environment variable 1647843 ALLEGRO_EDITOR ARTWORK Misleading information in command window when artwork import fails 1651925 ALLEGRO_EDITOR ARTWORK Searching for a macro in the artwork data file: Count for the macro does not match the actual count in the output 1658173 ALLEGRO_EDITOR ARTWORK ARTWORK: Value of Scale factor for output. 1661760 ALLEGRO_EDITOR ARTWORK Import artwork to Design Outline layer does not give error in Allegro prompt. 1666551 ALLEGRO_EDITOR ARTWORK Import Artwork: Mirror option separates imported artwork to different XY locations 1675359 ALLEGRO_EDITOR ARTWORK Subclass ETCH/WIRE is added to artwork definition though the visibility of 'ALL Layers' is turned off 1697109 ALLEGRO_EDITOR ARTWORK Artwork not showing padstacks for the soldermask layer 1684508 ALLEGRO_EDITOR AUTOVOID Allegro PCB Editor stops responding when deleting a via 1605961 ALLEGRO_EDITOR COLOR Wildcards not working in the Filter Nets field of the Color Dialog window 1633608 ALLEGRO_EDITOR COLOR Dehighlight command: The 'Retain Objects Custom Color' option should not be enabled by default 1658048 ALLEGRO_EDITOR COLOR color_lastgroup is not working in SPB 17.2 1667778 ALLEGRO_EDITOR COLOR Add option to set FORM mini dehl_retain_color to NO 1669462 ALLEGRO_EDITOR COLOR Changes made to the Visibility tab are not reflected in the Color Dialog window 1641265 ALLEGRO_EDITOR CROSS_SECTION The differential impedance value for a layer is not getting updated 1648149 ALLEGRO_EDITOR CROSS_SECTION Getting warning when calculating impedance in mixed stackup 1651063 ALLEGRO_EDITOR CROSS_SECTION Cross-section preview is incorrect 1653951 ALLEGRO_EDITOR CROSS_SECTION Cross Section Editor changes lost despite selecting No to the 'All changes will be lost ...' message 1671441 ALLEGRO_EDITOR CROSS_SECTION Enhancement request for cross section dialog box 1673320 ALLEGRO_EDITOR CROSS_SECTION Diff impedance calculation fails 1690021 ALLEGRO_EDITOR CROSS_SECTION How to keep settings of expanded/compressed columns in the Xsection 1703831 ALLEGRO_EDITOR CROSS_SECTION Calculation of Diff Z0 fails in flex designs 1711484 ALLEGRO_EDITOR CROSS_SECTION ShowAll Column does not retain its status 1607250 ALLEGRO_EDITOR DATABASE A board file created in release 16.5 crashes when opened in 16.6 Hotfix 69 1610456 ALLEGRO_EDITOR DATABASE Selecting user-defined subclasses when using strip design results in database corruption 1633707 ALLEGRO_EDITOR DATABASE Cannot remove Route_Keepout associated with a pin 1638251 ALLEGRO_EDITOR DATABASE Unplated hole changed to plated hole after uprev from release 16.6 to 17.2 1651066 ALLEGRO_EDITOR DATABASE Pins not connecting even after running the Tools - Derive Connectivity command 1653526 ALLEGRO_EDITOR DATABASE Via padstack keepout is not displayed on the canvas when pads suppression is enabled. 1670221 ALLEGRO_EDITOR DATABASE Non-recoverable corruption error is reported when saving the board after adding a layer 1672841 ALLEGRO_EDITOR DATABASE ERROR(SPMHDB-153): Table corrupt; current/maximum mismatch 1673499 ALLEGRO_EDITOR DATABASE Drill table title issues of backdrill designs in release 17.2 1673613 ALLEGRO_EDITOR DATABASE COVERLAY_TOP not present in the Non-conductor section of Color Dialog window 1675499 ALLEGRO_EDITOR DATABASE Running the Gloss command causes PCB Editor to crash 1677431 ALLEGRO_EDITOR DATABASE Get ERROR(SPMHA1-141): Invalid sector row. Contact cadence customer support when opening DRA File 1680802 ALLEGRO_EDITOR DATABASE Release 16.3 database locked by disabling export of design data should be view-only in release 16.6 1681129 ALLEGRO_EDITOR DATABASE Match Groups in DE-HDL design are not getting transferred to the board file 1682297 ALLEGRO_EDITOR DATABASE Derived padstack and associated padshapes not updated when design is upreved for compatibility with the current version 1688123 ALLEGRO_EDITOR DATABASE Drill Plating Issue 1697309 ALLEGRO_EDITOR DATABASE In release 17.2, PCB Editor uprev changes NC pins from non-plated to plated 1698624 ALLEGRO_EDITOR DATABASE Opening a 16.6 board in release 17.2 converts non-plated holes to plated 1700963 ALLEGRO_EDITOR DATABASE Running the 'slide' command results in the cline segment losing connectivity 1701995 ALLEGRO_EDITOR DATABASE When upreving a 16.6 brd to release 17.2, lines drawn on OUTLINE are translated to CUTOUT and not DESIGN_OUTLINE 1710772 ALLEGRO_EDITOR DATABASE Mirror command not working on zones 1713335 ALLEGRO_EDITOR DATABASE Defining Adjacent_layer_keepout_above and/or Adjacent_layer_keepout_below and then saving the .dra file giving error 1689881 ALLEGRO_EDITOR DFA Record and replay script for loading DFA spreadsheet not working 1693289 ALLEGRO_EDITOR DFA File - Save As script does not save the DFA file 1670927 ALLEGRO_EDITOR DRAFTING Using zcopy to create a Route Keepin results in database errors 1488909 ALLEGRO_EDITOR DRC_CONSTR Test Via causes net scheduling verification to fail 1644004 ALLEGRO_EDITOR DRC_CONSTR Unreported DRCs from dynamic copper to line and dynamic copper to SMT pin 1651425 ALLEGRO_EDITOR DRC_CONSTR The .brd file crashes when moving text controlled with minimum metal to metal constraints 1663494 ALLEGRO_EDITOR DRC_CONSTR Reported Mechanical Pin to conductor spacing DRC constraint value is incorrect leading to false DRCs 1672477 ALLEGRO_EDITOR DRC_CONSTR Although Allow DRC is not selected, DRC generated by dynamic fillets 1596955 ALLEGRO_EDITOR EDIT_ETCH Scribble mode not showing correct finish point in single trace mode 1639483 ALLEGRO_EDITOR EDIT_ETCH Manually routing discrete components with incorrect constraints causes PCB Editor to crash 1661357 ALLEGRO_EDITOR EDIT_ETCH PCB Editor crashes when using Route - Connect 1664858 ALLEGRO_EDITOR EDIT_ETCH PCB Editor crashes during Auto Interactive trunk route. 1682287 ALLEGRO_EDITOR EDIT_ETCH Auto-interactive Delay tune (AiDT) rips lines that have been routed 1687049 ALLEGRO_EDITOR EDIT_ETCH Create a Via Structure disconnects nets 1704296 ALLEGRO_EDITOR EDIT_ETCH Asymmetrical fanout created for BGA Quadrant style 1686873 ALLEGRO_EDITOR EDIT_SHAPE Merge static shapes deletes both the shapes selected. 1629925 ALLEGRO_EDITOR GRAPHICS Errors reported and no layout data drawn in PCB Editor in release 17.2 Hotfix 003 on Ubuntu 14.04 1619412 ALLEGRO_EDITOR INTERACTIV Script to create new padstacks from existing padstack is putting in wrong values for a regular pad 1621887 ALLEGRO_EDITOR INTERACTIV Getting a 'Could not satisfy the snap condition' message when using the Snap pick to option 1628895 ALLEGRO_EDITOR INTERACTIV Shape Edit mode: An error message is required when attempting to edit a Shape with the FIXED property 1659498 ALLEGRO_EDITOR INTERACTIV Unable to turn off line on Etch Wire for Jumpers 1666379 ALLEGRO_EDITOR INTERACTIV Place replicate is not working on the attached test case 1668282 ALLEGRO_EDITOR INTERACTIV Grid display incorrect for repeated grids 1675531 ALLEGRO_EDITOR INTERACTIV Design Entry CIS: Cross Probing with PCB Editor and Constraint Manager is not working 1694470 ALLEGRO_EDITOR INTERACTIV Update description of variable padstack_nowarning_display 1696855 ALLEGRO_EDITOR INTERACTIV Mixed grid setting is not displayed correctly on Define Grid screen. 1698192 ALLEGRO_EDITOR INTERACTIV Deleting and replacing a component causing database corruption in Hotfix 009 1703671 ALLEGRO_EDITOR INTERACTIV An error occurs when defining grids with zero increment value 1703812 ALLEGRO_EDITOR INTERACTIV Crash during move when using the 'snap pick to' option set to symbol origin 1719276 ALLEGRO_EDITOR INTERACTIV Setting variable grid for 'All Etch' displays an error in the Define Grid form 1635941 ALLEGRO_EDITOR INTERFACES Shape created by IPC 2581 for negative film does not match the shape on the board 1639845 ALLEGRO_EDITOR INTERFACES Step file not generated when board is exported to a folder with special characters in name 1641339 ALLEGRO_EDITOR INTERFACES DXF_IN does not show all the subclasses available in the design 1648183 ALLEGRO_EDITOR INTERFACES Allegro STEP Export: Using the 'step_3D_copper' variable, pads not exported in the same plane as traces and shapes 1653366 ALLEGRO_EDITOR INTERFACES Unable to attach step model to symbol 1663422 ALLEGRO_EDITOR INTERFACES Shape loses group membership after importing through sub-drawing 1671760 ALLEGRO_EDITOR INTERFACES Step package mapping window unable to display step model 1685502 ALLEGRO_EDITOR INTERFACES The Export - PDF command fails to export the TOP etch subclass with error code SPMHGE-268 1686803 ALLEGRO_EDITOR INTERFACES PCB Editor crashes if the 'ipc2581_group_drills' variable is set. 1633647 ALLEGRO_EDITOR MANUFACT Variant issue: Create Assembly Drawing command not creating filled shapes for keying pegs in attached design 1637959 ALLEGRO_EDITOR MANUFACT Thieving uses different clearance values around the route keepin. 1644643 ALLEGRO_EDITOR MANUFACT The NC drill legend does not match the drill customization data 1646932 ALLEGRO_EDITOR MANUFACT Manufacture - Auto Rename Refdes keeps defaulting to Use Default Grid even if another is chosen 1670564 ALLEGRO_EDITOR MANUFACT Exported Gerber file cannot be imported in brd 1675619 ALLEGRO_EDITOR MANUFACT Differences observed in IPC-D-356A between releases 16.6 and 17.2 1676480 ALLEGRO_EDITOR MANUFACT Creating Variant Assy_Bot Drawing showing Variant Assembly Top Drawing 1693719 ALLEGRO_EDITOR MANUFACT Incorrect suppressed holes information in the drill file created 1693846 ALLEGRO_EDITOR MANUFACT PCB Editor crashes when running the gloss command 1700557 ALLEGRO_EDITOR MANUFACT DXF output does not contain drill figure data 1706879 ALLEGRO_EDITOR MANUFACT Trace gets moved to dielectric layer after using the Gloss function 1708685 ALLEGRO_EDITOR MANUFACT Incomplete ncdrill holes data in drl file 1716431 ALLEGRO_EDITOR MANUFACT Test points generation stops due to an error 1660252 ALLEGRO_EDITOR NC NC Drill file generated with errors 1670687 ALLEGRO_EDITOR NC nclegend.log reports missing columns which are present in the NC Legend 1677775 ALLEGRO_EDITOR NC Merging of drills not retained in database. 1607956 ALLEGRO_EDITOR OTHER Unable to generate the model index file from the command line using the mkdeviceindex utility 1623112 ALLEGRO_EDITOR OTHER Switch Release unable to identify the 16.6 release when it is installed in the All Users mode 1641994 ALLEGRO_EDITOR OTHER DB Doctor: Incorrect spelling of 'eliminated' in the log file messages 1642597 ALLEGRO_EDITOR OTHER Importing .tdp file: Footprints not included in the .tdp file are updated in the design 1643532 ALLEGRO_EDITOR OTHER Strip design command fails to delete symbol text in the attached design 1652930 ALLEGRO_EDITOR OTHER Command-line version of switchversion not working 1656581 ALLEGRO_EDITOR OTHER PDF generated for layer with shape shows undesired voids if film is mirrored and Filled Shape is not selected 1660496 ALLEGRO_EDITOR OTHER SiP Layout crashes when trying to generate abstract level view by using export chips and connectivity 1662821 ALLEGRO_EDITOR OTHER Cross section chart does not show stack vias in release 17.2 1664911 ALLEGRO_EDITOR OTHER PCB Editor freezes after DRC Update is performed 1670339 ALLEGRO_EDITOR OTHER Small shapes defined on the mechanical symbol Board Geometry – Outline are not converted to the Cutout subclass. 1681002 ALLEGRO_EDITOR OTHER STEP output in release 17.2 is different from release 16.6 1685464 ALLEGRO_EDITOR OTHER The 'alias ~S save' command is not recognized when set in the local env file 1685540 ALLEGRO_EDITOR OTHER If text is attached to an object, the object is also printed in the PDF 1686791 ALLEGRO_EDITOR OTHER Searchable property unavailable on bottom layer pins in the generated PDF 1696486 ALLEGRO_EDITOR OTHER STEP export results vary between releases 16.6 and 17.2 1697092 ALLEGRO_EDITOR OTHER axlDBViaStack crashes PCB Editor session and corrupts the board 1706623 ALLEGRO_EDITOR OTHER axlBackdrillGet crashes for invalid argument 1622680 ALLEGRO_EDITOR PADS_IN Import PADS fails with the 'ERROR: *NET* section found. Translation of netlist is not allowed.' message 1685986 ALLEGRO_EDITOR PADS_IN PADS Translator-generated output shows incorrect unit for the soldermask oversize option 1578533 ALLEGRO_EDITOR PAD_EDITOR New Padstack Editor does not automatically update the geometry 1586957 ALLEGRO_EDITOR PAD_EDITOR In Pad Editor, selecting a pad geometry is not showing up in the Design Layers tab 1610984 ALLEGRO_EDITOR PAD_EDITOR Geometry set in tabs not read, only initial value set in Start page is used 1614015 ALLEGRO_EDITOR PAD_EDITOR Padstack Editor in release 17.2 does not auto fill geometry in design layers 1628409 ALLEGRO_EDITOR PAD_EDITOR Padstack Editor does not remember the last used directory 1636012 ALLEGRO_EDITOR PAD_EDITOR Keepout should not be allowed if antipad is not defined for outer layers 1641973 ALLEGRO_EDITOR PAD_EDITOR Padstack Editor: Path to the previously opened .pad file is not seeded in the File - Open dialog on a fresh launch 1642789 ALLEGRO_EDITOR PAD_EDITOR In release 17.2, 'Units' and 'Decimal Places' in Padstack Editor are not updated as per the .pad file 1646914 ALLEGRO_EDITOR PAD_EDITOR The 'Save' button is grayed out in Padstack Editor 1657553 ALLEGRO_EDITOR PAD_EDITOR No possibility to specify Padstack Editor default library path at invocation 1657609 ALLEGRO_EDITOR PAD_EDITOR Changing Tolerance field in Padstack Editor does not activate the Save button 1658440 ALLEGRO_EDITOR PAD_EDITOR The location of a drill in the .pad file is different from the .dra file 1662225 ALLEGRO_EDITOR PAD_EDITOR Padstack editor dialog message doesn't match available options 1667062 ALLEGRO_EDITOR PAD_EDITOR Padstack editor does not retain the decimal places from the previous session 1672774 ALLEGRO_EDITOR PAD_EDITOR Pad Editor graphics appear to show offset incorrectly 1674157 ALLEGRO_EDITOR PAD_EDITOR Update Symbols does not update Pad Type Information 1675438 ALLEGRO_EDITOR PAD_EDITOR Drill hole size warning for the SMD pad 1684376 ALLEGRO_EDITOR PAD_EDITOR Pad Editor issues with settings, such as decimal places, layers, and so on 1685810 ALLEGRO_EDITOR PAD_EDITOR In release 17.2, Padstack Editor does not save adjacent layer information for BOTTOM pads 1690376 ALLEGRO_EDITOR PAD_EDITOR Variable padstack_nowarning_display fails to suppress warnings 1694649 ALLEGRO_EDITOR PAD_EDITOR Change Cancel button to No in warning generated when updating padstacks in design layout 1712057 ALLEGRO_EDITOR PAD_EDITOR Changing text size and restarting Padstack Editor results in incorrectly scaled forms 1620814 ALLEGRO_EDITOR PARTITION Etch and Via are not imported with the partition 939242 ALLEGRO_EDITOR PLACEMENT Cross probing between Capture and PCB Editor is inconsistent 1103945 ALLEGRO_EDITOR PLACEMENT Place Replicate Create does not include the etch connected to pin 1233019 ALLEGRO_EDITOR PLACEMENT Allow cross probe object selection apart from highlighting during place replicate 1569272 ALLEGRO_EDITOR PLACEMENT Get the error message 'E- (SPMHDB-394): Placement cannot be completed ... ' after creating Place Replicate circuit 1606392 ALLEGRO_EDITOR PLACEMENT Filmmask not shown when component is attached to cursor 1633581 ALLEGRO_EDITOR PLACEMENT On mirroring a part, the cursor moves to the origin of the board 1633601 ALLEGRO_EDITOR PLACEMENT Place>Via Arrays>Boundary command: Via arrangement pattern deteriorated in Hotfix 004 as compared to Hotfix 003 1643078 ALLEGRO_EDITOR PLACEMENT PCB Editor flags an error message when a module is placed at a specific angle 1682900 ALLEGRO_EDITOR PLACEMENT Moving a symbol by snapping to segment vertex in release 17.2 Hotfix 009 crashes PCB Editor 1696932 ALLEGRO_EDITOR PLACEMENT Inconsistency with Snap pick to when selecting Segment Midpoint 1687816 ALLEGRO_EDITOR PLOTTING Export PDF Vector text option does not work 1654500 ALLEGRO_EDITOR REPORTS In release 17.2 Hotfix 006, display of Netin (back anno.) report fails when variable ads_sdreport is set 1679351 ALLEGRO_EDITOR REPORTS Missing Fillets Report is not showing missing fillets on the bottom layer 1623904 ALLEGRO_EDITOR SCHEM_FTB Logic import fails, but no error mentioned in the netrev.lst file 1643992 ALLEGRO_EDITOR SCHEM_FTB Export Physical fails with the 'netrev.exe has stopped working' error 1650801 ALLEGRO_EDITOR SCHEM_FTB Running Export Physical with Update PCB enabled in Project Manager crashes netrev.exe 1709335 ALLEGRO_EDITOR SCHEM_FTB Cannot import netlist from attached design 1668137 ALLEGRO_EDITOR SCRIPTS PCB Editor crashes on running Script Replay 1496199 ALLEGRO_EDITOR SHAPE Overlapping route keepouts result in a broken shape. 1607954 ALLEGRO_EDITOR SHAPE Dynamic Shape not updating correctly 1611446 ALLEGRO_EDITOR SHAPE Inconsistent break in shape when creating voids in a design in 16.6 Hotfix 69 1625610 ALLEGRO_EDITOR SHAPE Modifying a shape boundary leads to other shapes losing their voids 1626001 ALLEGRO_EDITOR SHAPE Shape to route keepout DRCs reported for dynamic shapes in the attached design 1644406 ALLEGRO_EDITOR SHAPE Alternate symbol placement results in illegal parent identifier error 1653400 ALLEGRO_EDITOR SHAPE Dynamic shape does not void a via. 1665652 ALLEGRO_EDITOR SHAPE Critical fillet and shape issues in release 17.2 1667068 ALLEGRO_EDITOR SHAPE Update shape removing the shape voiding 1668262 ALLEGRO_EDITOR SHAPE dynamic shape does not void custom route keepout with arc 1668325 ALLEGRO_EDITOR SHAPE Updating shapes to smooth creates erratic voids. 1680113 ALLEGRO_EDITOR SHAPE Irregular void created on dynamic shapes 1680837 ALLEGRO_EDITOR SHAPE Updating the shape makes the shape disconnect from Thru pins of same net 1681059 ALLEGRO_EDITOR SHAPE Shape voiding using DV_SQUARECORNERS environmental variable does not always produce voids with square corners. 1682569 ALLEGRO_EDITOR SHAPE Variable 'dv_squarecorners' not working correctly. 1684111 ALLEGRO_EDITOR SHAPE Dynamic Shape not voiding overlapped static shape 1686127 ALLEGRO_EDITOR SHAPE The void of shape missed in artwork. 1687329 ALLEGRO_EDITOR SHAPE Shape is not voiding uniformly when component is rotated by 30 degrees 1694867 ALLEGRO_EDITOR SHAPE Void is deleted by the shape merge command 1696240 ALLEGRO_EDITOR SHAPE SKILL error when merging polygons 1698539 ALLEGRO_EDITOR SHAPE A thin shape is left when dv_fixfullcontact is enabled. 1701554 ALLEGRO_EDITOR SHAPE Shape spacing clearance is not updated unless the shape vertex is deleted 1704669 ALLEGRO_EDITOR SHAPE Route Keepin is not getting created at a specific location 1709968 ALLEGRO_EDITOR SHAPE In release 17.2, DB Doctor reports error in shape when no error was reported in release 16.6 for the same shape 1596780 ALLEGRO_EDITOR SKILL PCB Editor crashes after doing SRM update and save 1623935 ALLEGRO_EDITOR SKILL On running the SKILL function, axlSectionModify, Shield and Etch Factor are not updated 1632505 ALLEGRO_EDITOR SKILL In release 17.2 Hotfix 004, PCB Editor crashes after SRM update and save 1647729 ALLEGRO_EDITOR SKILL When a fillet insert fails, the 'axlFillet' function returns 't' instead of nil 1651700 ALLEGRO_EDITOR SKILL Running axlXSectionModify() on a layer removes the value of the material 1651701 ALLEGRO_EDITOR SKILL Cannot set the etch factor value in the cross-section using the axlXSectionModify() skill command 1657220 ALLEGRO_EDITOR SKILL axlXSectionGet() returns Primary list of layers and not All stackups 1658419 ALLEGRO_EDITOR SKILL PCB Editor crashes after running SRM 1658948 ALLEGRO_EDITOR SKILL axlIsLayerNegative() is not working in release 17.2 1670956 ALLEGRO_EDITOR SKILL axlIsLayerNegative() always returns nil 1685995 ALLEGRO_EDITOR SKILL All film sequence numbers are returned as 0 when using the SKILL function axlGetParam 1687239 ALLEGRO_EDITOR SKILL Problem with skill function axlCNSGetPhysical - incorrect parse string 1690958 ALLEGRO_EDITOR SKILL SKILL command axlDBDelLock is not working as explained in the documentation 1692345 ALLEGRO_EDITOR SKILL The axlGetParm documentation example for deleting an artwork record is incorrect. 1693431 ALLEGRO_EDITOR SKILL Running axlXSectionModify and axlXSectionSet results in warnings and corrupts multi-zone cross-section 1695131 ALLEGRO_EDITOR SKILL PCB Editor crashes when using the axlSpreadsheetDefineCell SKILL function 1707878 ALLEGRO_EDITOR SKILL Object rat_t does not work with axlDBPinPairLength. 1626716 ALLEGRO_EDITOR UI_FORMS Z-Copy menu is not available with OrCAD PCB designer Professional license 1671428 ALLEGRO_EDITOR UI_FORMS Display origin checkbox position changes in Step Mapping dialog 1565795 ALLEGRO_EDITOR UI_GENERAL Search does not work in the Defined Variables window 1568817 ALLEGRO_EDITOR UI_GENERAL Padstack editor not accepting comma as decimal separator with system locale set as LANG ru_RU.UTF-8 1588769 ALLEGRO_EDITOR UI_GENERAL Alt+key shortcuts are not available in release 17.2 1589396 ALLEGRO_EDITOR UI_GENERAL Option needed in release 17.2 to change the placement of the Find, Visibility, and Options tabs similar to releases 16.x 1598061 ALLEGRO_EDITOR UI_GENERAL Adjust menus to allow side by side view 1599901 ALLEGRO_EDITOR UI_GENERAL Color Dialog box is not updating according to visibility tab. 1602563 ALLEGRO_EDITOR UI_GENERAL Shortcuts to menu items not working in release 17.2 1603776 ALLEGRO_EDITOR UI_GENERAL Alt key not working with menu commands 1609794 ALLEGRO_EDITOR UI_GENERAL PCB Editor: Shortcut keys to menus are not available in release 17.2 1611293 ALLEGRO_EDITOR UI_GENERAL If the Command window is floating, it cuts off text from the bottom half of the last line. 1611516 ALLEGRO_EDITOR UI_GENERAL Keyboard shortcuts have no response 1611652 ALLEGRO_EDITOR UI_GENERAL New artwork film not appearing in the drop-down list for Visibility Tab 1614763 ALLEGRO_EDITOR UI_GENERAL Cannot scroll to the bottom of an undocked command window in PCB Editor 1617377 ALLEGRO_EDITOR UI_GENERAL Visibility pane does not retain the correct layer view 1617404 ALLEGRO_EDITOR UI_GENERAL axlUIMenuChange does not work as expected in release 17.2 1618205 ALLEGRO_EDITOR UI_GENERAL New Artwork film added is not updated in Visibility - View 1619873 ALLEGRO_EDITOR UI_GENERAL Command Window scrollbar does not reach its end 1620210 ALLEGRO_EDITOR UI_GENERAL Need to run PCB Editor from both 17.2-2016 and 16.6 releases simultaneously 1621336 ALLEGRO_EDITOR UI_GENERAL Changing the color visibility does not refresh the screen color immediately 1624617 ALLEGRO_EDITOR UI_GENERAL Dialog box title under Setup > Outlines > Design Outline... Design is misspelled as "Desgin" 1624953 ALLEGRO_EDITOR UI_GENERAL Custom views in release 17.2 do not return to original 1631646 ALLEGRO_EDITOR UI_GENERAL Visibility pane not retaining the correct layer view 1633726 ALLEGRO_EDITOR UI_GENERAL Visibility tab not dynamically updating the view list when artwork film changes 1636864 ALLEGRO_EDITOR UI_GENERAL Domain Selection for Visibility does not work with Hotfix 004 unless you save and reopen the board file 1637062 ALLEGRO_EDITOR UI_GENERAL The last line of the floating command window in release 17.2 is hidden behind the command window frame 1642645 ALLEGRO_EDITOR UI_GENERAL Cannot scroll to the bottom of an undocked command window in PCB Editor 1645335 ALLEGRO_EDITOR UI_GENERAL PCB Editor crashes in Hotfixes 004 and 005 if ODE and Allegro Manufacturing options are installed 1646228 ALLEGRO_EDITOR UI_GENERAL Running the axlUIMenuInsert command to add a submenu after running the axlUIMenuFind command crashes the tool 1647520 ALLEGRO_EDITOR UI_GENERAL PCB Editor crashes after installing release 17.2 Hotfix 005 1647541 ALLEGRO_EDITOR UI_GENERAL Release 17.2 Hotfix 005: PCB Editor crashes immediately after launch 1650044 ALLEGRO_EDITOR UI_GENERAL Keyboard shortcuts are not working properly in release 17.2 1651912 ALLEGRO_EDITOR UI_GENERAL Inconsistent response when using the Alt key 1652423 ALLEGRO_EDITOR UI_GENERAL Using the F1 key does not display the help document 1654600 ALLEGRO_EDITOR UI_GENERAL Spelling Mistake in "Design Outline" dialog box, Setup->Outlines->Design Outline, misspelled as "Desgin" 1654777 ALLEGRO_EDITOR UI_GENERAL Reports UI does not work properly when writing a report file. 1655500 ALLEGRO_EDITOR UI_GENERAL Visibility selection ignored after color change 1655514 ALLEGRO_EDITOR UI_GENERAL Artwork Film is available in the View section only after you restart PCB Editor 1660200 ALLEGRO_EDITOR UI_GENERAL Symbol pin # box is unclear 1660492 ALLEGRO_EDITOR UI_GENERAL PCB Editor crashes when using multiple desktops on Windows 10 1663819 ALLEGRO_EDITOR UI_GENERAL In release 17.2, SKILL function, axlOpenDesign(), does not work as expected 1668817 ALLEGRO_EDITOR UI_GENERAL Changing the visibility or the color on the canvas in release 17.2-2016 takes longer than release 16.6 1670120 ALLEGRO_EDITOR UI_GENERAL In release 17.2, Static Phase meter shows up in the middle of the screen instead of the lower-right corner 1671268 ALLEGRO_EDITOR UI_GENERAL Visibility Window: There is a noticeable lag when enabling etch, via, and pin on a specific layer one by one 1671334 ALLEGRO_EDITOR UI_GENERAL Design outline is not shown in 'World View' window 1671901 ALLEGRO_EDITOR UI_GENERAL Move command followed by object selection grays out or locks toolbar and menus 1672148 ALLEGRO_EDITOR UI_GENERAL Add option in release 17.2 to change the placement of the Find, Visibility, and Options tabs similar to earlier release 1673681 ALLEGRO_EDITOR UI_GENERAL F1 for Help not working in PCB Editor in release 17.2 1679418 ALLEGRO_EDITOR UI_GENERAL On choosing Edit - Move, the 'Symbol pin #' box is obfuscated 1679761 ALLEGRO_EDITOR UI_GENERAL Choosing Edit - Spin hides 'Symbol pin #' partially 1681514 ALLEGRO_EDITOR UI_GENERAL Opening the Dynamic Shapes State report hangs PCB Editor in release 17.2 Hotfix 009 1686887 ALLEGRO_EDITOR UI_GENERAL Hyper Text no longer selects coordinates for easy copy 1687286 ALLEGRO_EDITOR UI_GENERAL In 17.2 Hotfix 009, the Static Phase meter shows up in the middle of the screen instead of the lower-right corner 1687819 ALLEGRO_EDITOR UI_GENERAL Change in Region and Language settings of Windows impacts decimal character in Padstack Editor 1690691 ALLEGRO_EDITOR UI_GENERAL Reports not generating if the 'allegro_html_qt' environment variable is disabled 1692416 ALLEGRO_EDITOR UI_GENERAL Underscores in menu commands denoting shortcuts are missing in release 17.2 1693968 ALLEGRO_EDITOR UI_GENERAL Batch process that uses SKILL is taking too long to process files and generate reports 1696637 ALLEGRO_EDITOR UI_GENERAL Padstack Editor uses Region and Language settings for the decimal symbol 1699326 ALLEGRO_EDITOR UI_GENERAL Padstack Editor follows the geographical area rules set in the Control Panel while PCB Editor does not 1702420 ALLEGRO_EDITOR UI_GENERAL Unable to maximize reports viewer in 17.2 1703065 ALLEGRO_EDITOR UI_GENERAL Menu shortcuts do not work as expected 1703107 ALLEGRO_EDITOR UI_GENERAL Scripting using regional settings for decimal separator 1707547 ALLEGRO_EDITOR UI_GENERAL Release 17.2: The Alt key function is not working in PCB Editor 1709280 ALLEGRO_EDITOR UI_GENERAL Alt+Function key not working in release 17.2. 1709903 ALLEGRO_EDITOR UI_GENERAL Toggling layer visibility does not change the display until the mouse pointer is moved 1711341 ALLEGRO_EDITOR UI_GENERAL Incorrect pad size in Padstack Editor when the German regional settings are used 1712496 ALLEGRO_EDITOR UI_GENERAL Padstack Editor shows incorrect values when using comma and 3 decimal places 1714744 ALLEGRO_EDITOR UI_GENERAL Using comma instead of dot as integer separator results in incorrect diameter value 1715714 ALLEGRO_EDITOR UI_GENERAL If the 'Decimal places' field is set to 3, values in PAD Designer change automatically 1636097 ALLEGRO_EDITOR ZONES Technology Dependent Packaging footprints not updating in the design 1636185 ALLEGRO_EDITOR ZONES Import Placement not placing Technology Dependent Packaging (TDP) footprints in a zone 1639896 ALLEGRO_PROD_TOOLB CORE MFG collector does not move files to subdirectories 1608804 ALTM_TRANSLATOR DE_HDL Translation issues in symbols with multiple physical pins mapping to a single logical function 1658525 ALTM_TRANSLATOR DE_HDL Invalid characters in pin names 1658536 ALTM_TRANSLATOR DE_HDL All cell names should be generated in lowercase letters 1609962 ALTM_TRANSLATOR PCB_EDITOR Errors reported during design translation 1616138 ALTM_TRANSLATOR PCB_EDITOR Board file imported from third-party tool to PCB Editor has the shapes but not the components 1666020 ALTM_TRANSLATOR PCB_EDITOR Board converted from a third-party tool to PCB Editor has missing components 1649222 APD ASSY_RULE_CHE Allegro Package Designer stops responding on running the Acute Angle Metal DRC 1692166 APD DATABASE DB Doctor returns 'ERROR(SPMHDB-252): A corrupt database pointer was detected' for a specific design 1661562 APD DRC_CONSTRAIN The wrong space calculation on finger to trace 1647596 APD EXPORT_DATA Allegro Package Designer crashes when trying to export board-level components 1615075 APD LOGIC Netlist-In wizard fails to import the net names, but gives a successful completion Info message 1623666 APD OTHER Incorrect vector pin syntax appears in the chips file written using 'RF Module - Export chips & connectivity' 1647154 APD OTHER Disconnected Clines not working 1667599 APD OTHER Wire Bond operations taking longer than expected to complete 1688035 APD OTHER Significant difference seen in the percentage of metal between the Metal Usage reports of positive and negative layers 1647190 APD REPORTS 'Sorted by Bond Finger' report shows incorrect wire bond connection 1656608 APD REPORTS Incorrect calculation in the metal usage report 1650734 APD SHAPE Shape on L1 does not flood properly 1674338 APD SHAPE Shape is not clearing slivers that are smaller than the 'Minimum aperture for gap width' of '18 um' 1682398 APD SHAPE Deleting islands causes out of date shapes 1640611 APD SKILL Launching XtractIM from SiP Layout with the attached design crashes both SiP Layout and XtractIM 1639613 APD STREAM_IF The stream out command has created sharp angles in the GDSII output file 1713292 APD WIREBOND Allegro Package Designer crashes when adding wire to a die pad 1625000 ASDA CANVAS_EDIT File - Save Project does not provide any indication of saving or progress bar 1638112 ASDA CANVAS_EDIT Unable to rename multiple selected buses using the 'Assign Name' command 1639409 ASDA CANVAS_EDIT When importing a DE-HDL design, the MAKE_BASE property should be removed from the nets 1645571 ASDA CANVAS_EDIT Various routing inconsistencies with synonym bodies on the canvas 1656336 ASDA CANVAS_EDIT Presence of illegal characters in the net name removes the entire net name 1667176 ASDA CANVAS_EDIT Unable to add the port symbol in a specific scenario 1641410 ASDA CONSTRAINT_MA No errors or issues reported when incorrect topology is applied to a net or an Xnet 1641473 ASDA CONSTRAINT_MA Importing a tech file into SDA makes the tool unresponsive 1645529 ASDA CONSTRAINT_MA Unable to delete differential pairs on nets 1661350 ASDA CONSTRAINT_MA Unable to create physical & spacing class from the docked CM 1653109 ASDA DESIGN_CORRUP SDA not pulling latest library information for part 1661874 ASDA DESIGN_CORRUP Unable to delete the ZERO part from the schematic page 1647673 ASDA EXPORT_PCB After installing release 17.2-2016 Hotfix 009, two folders named 'physical' are created for a design 1646086 ASDA IMPORT_BLOCK Importing a DE-HDL design into SDA results in error 'IMPSHT-42 Alias cannot be created' 1613559 ASDA IMPORT_DEHDL_ Custom variables from the BOM Tables are not getting imported 1645557 ASDA IMPORT_DEHDL_ Importing a DE-HDL design into SDA adds the COMMENT_BODY attribute to nets 1625209 ASDA IMPORT_PCB File Import from PCB Editor shows board differences 1647580 ASDA IMPORT_PCB SDA - File Import from PCB Editor has duplicated RefDes on schematic. 1652753 ASDA MISCELLANEOUS Tcl command window should display correct casing for autocompleted command 1654973 ASDA MISCELLANEOUS If there is a casing mismatch in the Tcl command name, correct command is not picked from the list 1710973 ASDA PACKAGER Unable to export Allegro SDA project to PCB Layout 1652718 ASDA PAGE_MANAGEME Page numbering on the page border does not update correctly when pages are moved, added, deleted 1621874 ASDA PRINT Print - Save as PDF uses the default printer options only 1699454 ASDA TABLE In the table object, cursor skips a cell on the first use of the TAB key 1702702 ASDA TABLE Copy-pasting table objects to a new page fills the headers and rows in black 1667056 ASI_PI GUI Power Feasibility Editor does not list capacitors connected to selected nets/parts 1623113 ASI_SI GUI Aggressor waveforms are not displayed in the Waveform viewer after running a crosstalk simulation 1668877 CAPTURE ANNOTATE Using Ctrl+drag does not preserve the reference designator value 1690448 CAPTURE CORRUPT_DESIG Corrupt design: nets in this design are not displayed when running Edit - Browse - Nets 1690455 CAPTURE CORRUPT_DESIG Corrupt design: all the nets in this design are not displayed when running Edit - Browse - Nets 1665454 CAPTURE NETGROUPS Incremental copy for alias does not work anymore. 1681727 CAPTURE NETGROUPS In release 17.2, Capture crashes when closing a design that has assigned NetGroups 1667213 CAPTURE NETLIST_ALLEG Tools - Create Netlist stops responding on Windows 10 1608278 CAPTURE OTHER Crystal Reports: User is prompted for ODBC password to create a BOM report 1634598 CAPTURE OTHER The ‘OrCAD_Capture_CIS_option’ license not released even after selecting another product option 1636090 CAPTURE OTHER Capture crashes after switching from release 17.2 Hotfix 003 to 004 due to some Tcl files 1648575 CAPTURE OTHER The setting to suppress warnings must be added in the capture.ini file 1650029 CAPTURE OTHER Crash while archiving a newly created PSpice project without adding simulation profile 1659602 CAPTURE OTHER Saving CIS BOM via TCL command window 1678715 CAPTURE OTHER Capture.ini [WebResourcesMenu] is not working in release 17.2 1619449 CAPTURE PROJECT_MANAG Search not working in a PSpice project 1643003 CAPTURE PROJECT_MANAG Release 17.2-2016 Hotfix 005: The Start page shows incorrect release number of the latest release 1670133 CAPTURE PROJECT_MANAG Start Page showing wrong Software Version 1670766 CAPTURE PROJECT_MANAG autoreference does not work properly 1676095 CAPTURE PROJECT_MANAG (SID:22758) OrCAD Capture Start Page reporting wrong hotfix installed 1610377 CAPTURE PROPERTY_EDIT Discrepancies between the NET_SPACING_TYPE property (or any other property) text and the actual property 1658315 CAPTURE TCL_INTERFACE Inserting text with double quotes is not working as expected in PDF created from Capture 1642601 CIS OTHER Design Entry CIS: SQL server password is required each time the tool is launched 1595872 CIS PART_MANAGER Capture CIS Part Manager PCB Footprint update case-sensitivity issue 1592026 CIS VIEW_DATABASE View database part does not work from schematic pages of an externally referenced design 1665918 CONCEPT_HDL CHECKPLUS Error (100) Program Internal Error 'Create_flat_node' with checkplus run 1690777 CONCEPT_HDL CHECKPLUS Rules Checker returns an error when the value of the PACK_TYPE property is in lowercase 1622715 CONCEPT_HDL CONSTRAINT_MG Extracting an XNet crashes DE-HDL 1642012 CONCEPT_HDL CONSTRAINT_MG Schematic-defined net groups without any members cannot be deleted in Constraint Manager 1684117 CONCEPT_HDL CONSTRAINT_MG Property deleted from Constraint Manager is not getting updated in the DE-HDL canvas 1712279 CONCEPT_HDL CONSTRAINT_MG Differential pairs are dropped from Net Classes when upreved to release 17.2-2016 1663641 CONCEPT_HDL COPY_PROJECT File - Copy Project in Project Manager creates two designs if there are dashes in the design name 1665449 CONCEPT_HDL COPY_PROJECT Copy project fails with error COPYPROJ-77 1698697 CONCEPT_HDL COPY_PROJECT Copy project corrupts the .dcf file 1577379 CONCEPT_HDL CORE Packager-XL gives different results when run from DE-HDL and ADW Flow Manager 1582276 CONCEPT_HDL CORE Need the ability to delete an image placed on the DE-HDL canvas 1594101 CONCEPT_HDL CORE No error or warning issued on specifying an incorrect unit for voltage 1618986 CONCEPT_HDL CORE Information required about the DONT_FORCE_ORIGIN_ONGRID directive 1623231 CONCEPT_HDL CORE Unable to make the Attributes form part of the standard display in DE-HDL 1632504 CONCEPT_HDL CORE DE-HDL core dumps during Save Hierarchy on Linux 1642015 CONCEPT_HDL CORE Pin exists on block but no corresponding port exists in the underlying schematic 1649829 CONCEPT_HDL CORE Project Manager: A delay is observed before the submenus of the File and Tools menus appear 1652230 CONCEPT_HDL CORE The master.tag and vlog004u.sir files are not created in the entity directory on saving symbols 1656357 CONCEPT_HDL CORE Pasting a signal name across pages causes the name to overlap with the wire segment 1656726 CONCEPT_HDL CORE Interface command always disabled in the Wire menu 1658874 CONCEPT_HDL CORE 'Insert (n) Pages' command does not work when the CONFIRM_WRITE directive is ON 1659097 CONCEPT_HDL CORE Mouse strokes are not enabled on startup in the Pre-select mode 1659532 CONCEPT_HDL CORE Need csa files when Import Design command is used with the CONFIRM_WRITE directive 1661778 CONCEPT_HDL CORE Advanced Find will not find pins with the SIG_NAME property attached 1666084 CONCEPT_HDL CORE All user-defined properties are not listed in the Customize columns in Variant Editor 1667043 CONCEPT_HDL CORE Incorrect information in cpm.log file 1669707 CONCEPT_HDL CORE Pin numbers not visible on the canvas after replacing a part with the same symbol but a different part property 1670659 CONCEPT_HDL CORE SIGNAME text off grid when pasting copy using ctrl+v. 1671728 CONCEPT_HDL CORE Option requested to reload preferred_projects.txt without re-opening DE-HDL 1677672 CONCEPT_HDL CORE Whitespaces in URL links are not resolved correctly on Linux with Firefox 1684180 CONCEPT_HDL CORE Message should indicate that the user needs to reload the design after setting SET STICKY_OFF 1694151 CONCEPT_HDL CORE Rename Signal for unnamed net added the sig_name at the incorrect position with small text size. 1695987 CONCEPT_HDL CORE $PN placement in DE-HDL during part development is not following mouse placement 1697732 CONCEPT_HDL CORE Warning (SPCOCN-922): The object is being placed towards the left edge of the schematic. Ensure that the objects are pla 1697955 CONCEPT_HDL CORE Rename Signal places sig_name at an incorrect position for an unnamed net 1700873 CONCEPT_HDL CORE With duplicate part table files, running the Assign Power Pins command crashes DE-HDL without any message 1702703 CONCEPT_HDL CORE Location of $PN in DE-HDL Symbol Editor is not as precise as it was in 17.2 Hotfix 011 1705401 CONCEPT_HDL CORE Alignment issues while pasting signal names in 16.6 Hotfix 084 1705999 CONCEPT_HDL CORE Signal naming is not working correctly in SPB 17.2 1707116 CONCEPT_HDL CORE SIG_NAME is placed on non-grid position 1710486 CONCEPT_HDL CORE Rename Signal places sig_name at an incorrect position for an unnamed net 1711635 CONCEPT_HDL CORE The arrow keys do not work as expected in Windows mode 1713091 CONCEPT_HDL CORE Difference in the behavior of 'Add Signal Name' in DE-HDL between releases 16.6 and 17.2 1669651 CONCEPT_HDL CREFER CreferHDL values are invisible 1677489 CONCEPT_HDL CREFER CRefer points to incorrect page numbers when there are page mismatches in the logical and physical page numbers 1614372 CONCEPT_HDL EDIF300 OFFPAGE symbol is exported as PageBorder in EDIF300 schematic 1631443 CONCEPT_HDL ERCDX ERC reports warning due to lower-case value of some properties in chips.prt 1653080 CONCEPT_HDL ERCDX Difference in results from SPB16.6 in 'erc.rpt' when logic_data is renamed as worklib in SPB17.2 on RHEL6.5 1599843 CONCEPT_HDL INTERFACE_DES Moving end part of a NetGroup adds extra elements 1632977 CONCEPT_HDL INTERFACE_DES Connectivity error when moving NetGroup members 1597787 CONCEPT_HDL MARKERS Save As in Marker dialog causes DE-HDL to crash 1659644 CONCEPT_HDL OTHER Predefined nets are not listed if a design from release 16.6 is opened in release 17.2. 1661632 CONCEPT_HDL OTHER Page skipped in DE-HDL when navigating using the Page Up and Page Down keys 1677405 CONCEPT_HDL OTHER When moving a wire with a dot, the dot is not removed directly 1708820 CONCEPT_HDL OTHER In a board cache flow, component bodies are missing when importing another board cached flow project. 1657346 CONCEPT_HDL PDF Wire Pattern set to two-dot chain line in a schematic appears as a solid line in the PDF output 1661133 CONSTRAINT_MGR ANALYSIS PCB Editor crashes if comma is used in the Value field for Analysis Mode 1670082 CONSTRAINT_MGR ANALYSIS Inconsistency in Constraint Analysis Modes - Electrical in OrCAD PCB Designer Professional in release 17.2-2016 1609817 CONSTRAINT_MGR CONCEPT_HDL DE-HDL crashes on opening project 1623888 CONSTRAINT_MGR CONCEPT_HDL Ambiguous and inaccurate mapping errors reported when an ECSet is applied to a differential pair object 1636404 CONSTRAINT_MGR CONCEPT_HDL Release 17.2 Hotfix 004: In DE-HDL Constraint Manager, invalid voltage units are allowed without any error or warning 1639928 CONSTRAINT_MGR CONCEPT_HDL The '-filterFile' argument is not recognized when cmDiffUtility is run as a command line operation 1642891 CONSTRAINT_MGR CONCEPT_HDL DE-HDL crashes randomly while working on Constraint Manager 1645639 CONSTRAINT_MGR CONCEPT_HDL DE-HDL crashes when the XNET_PINS property value has a trailing comma character 1646354 CONSTRAINT_MGR CONCEPT_HDL Cannot select Design Instance/Block Filter from the View menu in Constraint Manager 1649060 CONSTRAINT_MGR CONCEPT_HDL Renaming dcfx to dcf does not update the dcf file and results in an error in the log file 1650793 CONSTRAINT_MGR CONCEPT_HDL Conflict of XNET_PINS definition between the chips and the SIGNAL_MODEL is not handled correctly 1657048 CONSTRAINT_MGR CONCEPT_HDL Unable to navigate through the search results in the CM Reports 1661307 CONSTRAINT_MGR CONCEPT_HDL Prevent creation of differential pairs on VOLTAGE nets 1677651 CONSTRAINT_MGR CONCEPT_HDL DE-HDL crash on design after successful packaging 1682447 CONSTRAINT_MGR CONCEPT_HDL Extraction issue on differential pairs in design 1682454 CONSTRAINT_MGR CONCEPT_HDL If a design with NO_XNET_CONNECTION property on parts is exported to PCB Editor, many other components get the property 1698259 CONSTRAINT_MGR CONCEPT_HDL Unstable $LOCATION property in release 17.2-2016 1702537 CONSTRAINT_MGR CONCEPT_HDL ECSet mapping errors reported after removing the signal models on an upreved design 1718073 CONSTRAINT_MGR CONCEPT_HDL ECSet mapping errors on an upreved design in release 17.2: Pins in XNet and CSet do not match 1688287 CONSTRAINT_MGR DATABASE PCB Editor crashing while adding a net to a net group. 1717336 CONSTRAINT_MGR DATABASE Netclass members change during logic import; it's a toggle switch 1718514 CONSTRAINT_MGR ECS_APPLY Extracted topology does not use the PINUSE overrides specified on the canvas 1682885 CONSTRAINT_MGR INTERACTIV Constraint Manager worksheet switching does not work correctly in Linux 1625163 CONSTRAINT_MGR OTHER Status indicator for the Analyze command is missing in Constraint Manager in release 17.2 1628357 CONSTRAINT_MGR OTHER Constraint Manager shows differences if exporting and importing the same constraints on the same board 1631114 CONSTRAINT_MGR OTHER SKILL functions axlCnsPurgeAll and axlCNSDelete delete spacing constraint sets but not deleting names 1632365 CONSTRAINT_MGR OTHER Select command is disabled in the right-click pop-up menu from Constraint Manager in SPB 17.2 1639541 CONSTRAINT_MGR OTHER In release 17.2, PCB Editor crashes when updating Constraint Manager 1647779 CONSTRAINT_MGR OTHER 'Software Version' in the cmDiffUtility viewer does not show the correct version 1666329 CONSTRAINT_MGR OTHER SCM Import Physical process crashes cmfeedback 1669523 CONSTRAINT_MGR OTHER Select is disabled in Constraint Manager when a command is active in PCB Editor 1670802 CONSTRAINT_MGR OTHER Selecting a list of nets using the shift key does not work in Spacing and Physical domain 1670922 CONSTRAINT_MGR OTHER Title of the Layer Remove window is Constraint Manager 1678235 CONSTRAINT_MGR OTHER Select option grayed out in Constraint Manager if a command is active in PCB Editor 1680917 CONSTRAINT_MGR OTHER In release 17.2, nets cannot be selected in Constraint Manager when a PCB Editor command is active 1691125 CONSTRAINT_MGR OTHER Highlight command no longer selects the net in CM 1703791 CONSTRAINT_MGR OTHER Cross highlighting and assigning color to nets between PCB Editor and CM does not work 1703981 CONSTRAINT_MGR TECHFILE Importing a technology file (.tcf) results in packaging errors 1633433 CONSTRAINT_MGR UI_FORMS Expand - Collapse feature for multiple objects not working correctly 1649603 CONSTRAINT_MGR UI_FORMS Expand and Collapse commands do not work when multiple objects are selected 1654931 CONSTRAINT_MGR UI_FORMS Expand, collapse only works on one of the multiple selected objects. 1656841 CONSTRAINT_MGR UI_FORMS Incorrect layer information is displayed in the Edit Via List dialog when a filter is applied 1660475 CONSTRAINT_MGR UI_FORMS In release 17.2, the CTRL+V shortcut is not working in the Export Constraints window in Constraint Manager. 1668794 CONSTRAINT_MGR UI_FORMS Incorrect via name shown when filtering via list 1678305 CONSTRAINT_MGR UI_FORMS Unable to use the CM worksheet customization (wcfx) from the CDS_SITE area 1679909 CONSTRAINT_MGR UI_FORMS Incorrect layer order getting saved when defining BB vias in Constraint Manager PCSet 1691906 CONSTRAINT_MGR UI_FORMS Display Issue: When you use the filters, the horizontal scroll bars are duplicated 1667786 CONSTRAINT_MGR XNET_DIFFPAIR Parts with NO_XNET_CONNECTION getting extracted into SigXplorer 1606682 ECW ADMINISTRATIO ECWBackup and ECWRestore fail when data is 1GB or more 1673115 ECW INTEGRATION Import from external data sources (Integrations) truncates input values to 128 characters 1677893 ECW INTEGRATION Integrations list update is not working as per scheduled time 1652707 ECW METRICS Incorrect date and time displayed in mouseover tooltip on the Metric Trend chart 1654512 ECW METRICS Incorrect date and time displayed in mouseover tooltip on the Metric Trend chart 1668953 ECW METRICS IE11 Swedish only: Incorrect date and time displayed in mouseover tooltip on the Metric Trend chart 1677443 ECW METRICS Queued up metric packets on Pulse server are not processed if there are any packets related to a deleted project 1666723 ECW TDO-SHAREPOIN TDO login is not working with Site Minder because of incorrect characters in the Site Minder login form HTML 1683919 ECW TDO-SHAREPOIN Site Minder integration for login from TDA not working after SSL certificate update 1524700 F2B DESIGNVARI Variant file cannot be loaded 1632844 F2B DESIGNVARI Part is simultaneously defined as Pref and DNI in Variant Editor with no error 1641118 F2B DESIGNVARI Some DNI parts are not identified in the variant view due to the BLOCK 1669828 F2B DESIGNVARI Variant Editor crashes on some Windows 10 systems 1620017 F2B PACKAGERXL Packager Fails with ERROR(SPCOPK-1053) when $PART_NUMBER property for components has a value 1644131 F2B PACKAGERXL Option needed to package a DE-HDL design with PTF errors into a board file 1663676 F2B PACKAGERXL Physical net name (PNN) errors in the log file 1655377 FLOWS PROJMGR Project Manager crashes at launch on Windows 10 1699395 FSP FPGA_SUPPORT Selecting a QSF part name in the FPGA Properties window crashes FSP 1621390 GRE CORE Design crashes during the Spatial Planning phase 1669583 GRE DETAIL AiDT always fails push when there is a connect shape attached to the cline being tuned 1648817 GRE IFP_INTERACTI Allegro PCB Editor stops responding on adding netgroups to a nested netgroup 1704353 INSTALLATION DOWNLOAD_MGR Selecting 'View' in Download Manager results in error: 'Object Reference not set to an instance of an object' 1705265 INSTALLATION DOWNLOAD_MGR Problem installing OrCAD Library Builder from Download Manager 1686350 INSTALLATION SPB InstallDiagnose fails to repair some errors 1667678 MODEL_EDITOR PARSE Signal model assignment creates ESpice models that do not pass Model Integrity checks 1619610 ORBITIO ALLEGRO_SIP_I Some mechanical pins appear rotated by 90 degrees when imported 1630458 ORBITIO ALLEGRO_SIP_I Import OrbitIO Database file (.oio) in SiP: Bill of Materials report does not include standard dies 1635593 ORBITIO ALLEGRO_SIP_I Importing .sip file reports undefined argument error while processing shapes 1675013 ORBITIO ALLEGRO_SIP_I Failed to import brd file 1646612 PCB_LIBRARIAN CORE Generate Symbol option crashes Part Developer 1672369 PCB_LIBRARIAN EXPLORER Cannot create a New library build in Library Explorer. 1634392 PCB_LIBRARIAN OTHER Launching Library Explorer without -proj option makes it crash 1646635 PDN_ANALYSIS PCB_PI PCB Editor uses 'powerdc.exe' to launch PowerDC instead of the 'powerdc' script 1670811 PSPICE AA_MC Advanced Analysis MC plot window options need to be changed 1633526 PSPICE AA_PPLOT Spaces in Simulation Profile cause error in Parametric Plotter 1626647 PSPICE ENVIRONMENT Capture crashes when loading a design with two hyphens in sim profile name 1631034 PSPICE ENVIRONMENT When simulating the design in release 17.2, Capture crashes but works with release 16.6 1648284 PSPICE ENVIRONMENT PSpice project crashes when a design is opened in release 17.2 1663336 PSPICE MODELEDITOR Ibis translation not supporting paths with spaces 1629696 PSPICE PROBE After successfully exporting traces to csv, PSpice crashes on a subsequent attempt to export traces 1647402 PSPICE PROBE Unable to print on Windows 10 as no plots are displayed in the Probe window 1678061 PSPICE SLPS Simulating an SLPS co-simulation with a Fixed-step solver with a value lower than 1E-4 results in a crash 1679347 PSPICE SLPS SLPS crashes when co-simulating without opening OrCAD Capture or PSpice 1659030 RF_PCB LIBRARY Offset is not calculated from the center if using negative values for input pins when placing MSOP symbols 1631792 SCM OTHER The NC net has re-attached itself to another net, RIGHT_LEFT_N, in the design 1632195 SCM OTHER 'No known page border found' error in cref.log 1679376 SIG_EXPLORER OTHER Topology created in OrCAD PCB SI license cannot be reopened with the same license 1626546 SIG_INTEGRITY FIELD_SOLVERS Extra RL elements in via spice circuit model generated by Via Model Generator 1664797 SIG_INTEGRITY GUI Unnecessary coupled interconnect models were generated during View Waveform. 1682312 SIG_INTEGRITY LICENSING Allegro Sigrity SI/PI Product Choices window is blank after installing release 17.2 Hotfix 009 1709508 SIG_INTEGRITY REPORTS Allegro Sigrity SI crashes when running a reflection simulation 1698968 SIP_LAYOUT 3D_VIEWER 3D viewer shows keepin and not design outline. 1699884 SIP_LAYOUT ASSY_RULE_CHE SiP Layout crashes on using Assembly Rules Checker 1666484 SIP_LAYOUT CROSS_SECTION On converting a design from release 16.6 to release 17.2, a Dielectric thickness of ‘0.2032’ is added to another layer. 1689969 SIP_LAYOUT DIE_EDITOR SiP Layout crashes when moving dies using relative coordinates 1696239 SIP_LAYOUT DIE_EDITOR When using the Die-stack Editor to move and stretch wires, SiP Layout crashes 1643557 SIP_LAYOUT DIE_GENERATOR The dies in the design are not updated on importing die text files 1687988 SIP_LAYOUT DIE_GENERATOR 'compose die from geometry' does not retain the user-defined padstack name 1715016 SIP_LAYOUT DIE_GENERATOR Using Die Text-In wizard to replace a die reconnects wire bonds to the wrong die in stack-up 1710097 SIP_LAYOUT DIE_STACK_EDI The IY option of the 'move and stretch wire' command moves the die to incorrect coordinates 1593404 SIP_LAYOUT EDIT_ETCH Slide command moves via toward the object 1657257 SIP_LAYOUT EXTRACT When using extracta, custom layer names not getting retained 1641435 SIP_LAYOUT IMPORT_DATA Need SiP Stream mapping layer count to match Virtuoso stream layer mapping count 1620601 SIP_LAYOUT MANUFACTURING Need the ability to create LINES with round end caps in the same way as the LINES appear in the database 1638094 SIP_LAYOUT OTHER Cross Section Editor not reading updated information 1647098 SIP_LAYOUT OTHER Cadence SIP RF Layout GXL crashes when a symbol is copied and rotated 90 degrees 1705963 SIP_LAYOUT PADSTACK_EDIT Pad Designer: "None" changing spontaneously into "Circle 0.000" in a pad stack definition and unable to save 1695372 SIP_LAYOUT REPORTS Running the Metal Usage reports fails on the Primary side. 1713767 SIP_LAYOUT REPORTS Reports in release 17.2 for the Verilog Port Name are adding incorrect data that was not found in release 16.6 1696218 SIP_LAYOUT SKILL SiP Layout crashes on reassigning nets 1712964 SIP_LAYOUT SYMB_EDIT_APP SiP Layout crashes when using Renumber Pins in Symbol Edit application mode 1695885 SIP_LAYOUT UI_GENERAL Visibility Tab check box: unchecked "All" disables access to "Shp" check box 1623823 SIP_LAYOUT WIREBOND NO_WIREBOND property is ignored by Add/Edit Non-Standard 1641483 SIP_LAYOUT WIREBOND SiP Layout - Modify the wirebond report generation for Start and End height when using a DISCRETE class footprint 1650238 SIP_LAYOUT WIREBOND When performing 'Adjust Min DRC', the reference bond finger should not move. 1659473 SIP_LAYOUT WIREBOND When moving wirebonds they are jumping instead of sliding 1639838 SIP_RF DIEEXPORT Enhance the error message, SIP-1507, to include that overlapping pins within tolerance are included during die export 1653894 SIP_RF DIEEXPORT Redundant error message for die export, when view name is other than "layout" 1681332 SIP_RF OTHER Running die export causes Virtuoso to crash 1679336 SPECCTRA LICENSING Min/Max Propagation Delay cannot be routed by PCB Router using OrCAD PCB Designer Professional 1641879 XTRACTIM GUI XtractIM crashes on extracting a SiP design if 'SI Ignore' is selected for a die stack layer in Cross Section Editor Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
rom67 0 12 апреля, 2017 Опубликовано 12 апреля, 2017 · Жалоба вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: 017 Fixed CCRs: SPB 17.2 HF017 04-13-2017 ===================================================================== CCRID Product ProductLevel2 Title ===================================================================== 1732877 ALLEGRO_EDITOR SKILL axlXSectionGet fails in 17.2 HF016 ===================================================================== Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
rom67 0 9 мая, 2017 Опубликовано 9 мая, 2017 · Жалоба вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: 018 Fixed CCRs: SPB 17.2 HF018 04-23-2017 ================================================================================ ======================================================================== CCRID Product ProductLevel2 Title ================================================================================ ======================================================================== 1721773 ADW ADW_UPREV adw_uprev updates all versions in history log to the new version. Should only insert note about uprev. 1684346 ADW LIBDISTRIBUTI lib_dist_client fails for new release 17.2-2016 design server 1696632 ADW LIBDISTRIBUTI lib_dist_client fails on release 17.2 Designer Server having release 16.6 Master Server 1705224 ADW LIBDISTRIBUTI Cannot migrate Library Footprint Models having subdirectory to release 17.2-2016 1721017 ADW LIBDISTRIBUTI adwserver -install fails intermittently during Master Library Server or MLR distribution 1711373 ALLEGRO_EDITOR COLOR Cannot interact with Allegro PCB Editor when Color dialog is open 1710772 ALLEGRO_EDITOR DATABASE Mirror command not working on zones 1725621 ALLEGRO_EDITOR DATABASE PCB Editor crashes when moving a group of components or clines 1699796 ALLEGRO_EDITOR EDIT_ETCH AiDT fails and reports there are no timing constraints even when propagation delay is set 1726483 ALLEGRO_EDITOR EDIT_ETCH PCB Editor crashing when converting corners to arcs 1726678 ALLEGRO_EDITOR INTERFACES IDX copper layer export does not export all pin pads 1691036 ALLEGRO_EDITOR MANUFACT Fillet not centered on trace 1732304 ALLEGRO_EDITOR MANUFACT Countersink does not have drill figure on NCCOUNTERDRILL-1 subclass 1719564 ALLEGRO_EDITOR OTHER Cannot open PDF published in release 17.2-2016 in third-party software 1723065 ALLEGRO_EDITOR OTHER PDF out does not print the outline correctly 1729247 ALLEGRO_EDITOR OTHER Cannot delete shape on Route Keepout layer 1722747 ALLEGRO_EDITOR PAD_EDITOR Option to enable 'Connect by Touch' in Pad Editor 1731643 ALLEGRO_EDITOR PAD_EDITOR Changes to secondary drill are not saved on padstack update 1727303 ALLEGRO_EDITOR REPORTS The 'Shape Dynamic State' report has changed to 'Shape Dynamic Status' in release 17.2-2016 1695879 ALLEGRO_EDITOR SHAPE Dynamic shape priority error creates shorts. 1713014 ALLEGRO_EDITOR SHAPE Incorrect behavior of donut shaped pads at certain rotations 1588769 ALLEGRO_EDITOR UI_GENERAL Alt+key shortcuts are not available in release 17.2 1602563 ALLEGRO_EDITOR UI_GENERAL Shortcuts to menu items not working in release 17.2 1603776 ALLEGRO_EDITOR UI_GENERAL Alt key not working with menu commands 1611516 ALLEGRO_EDITOR UI_GENERAL Keyboard shortcuts have no response 1647271 ALLEGRO_EDITOR UI_GENERAL Preselection is not working for docked Find window 1650044 ALLEGRO_EDITOR UI_GENERAL Keyboard shortcuts are not working properly in release 17.2 1651912 ALLEGRO_EDITOR UI_GENERAL Inconsistent response when using the Alt key 1679964 ALLEGRO_EDITOR UI_GENERAL Many dialog boxes are blurred in Allegro PCB Editor 1692416 ALLEGRO_EDITOR UI_GENERAL Underscores in menu commands denoting shortcuts are missing in release 17.2 1693055 ALLEGRO_EDITOR UI_GENERAL Reports with html links end with an extra > at the end 1693968 ALLEGRO_EDITOR UI_GENERAL Batch process that uses SKILL is taking too long to process files and generate reports 1698840 ALLEGRO_EDITOR UI_GENERAL In release 17.2-2016 Waive DRC report, selected coordinates of a Waived DRC remain blue 1703065 ALLEGRO_EDITOR UI_GENERAL Menu shortcuts do not work as expected 1707547 ALLEGRO_EDITOR UI_GENERAL Release 17.2: The Alt key function is not working in PCB Editor 1709280 ALLEGRO_EDITOR UI_GENERAL Alt+Function key not working in release 17.2. 1711203 ALLEGRO_EDITOR UI_GENERAL Color does not change for selected coordinates in reports and Show Element 1711724 ALLEGRO_EDITOR UI_GENERAL In release 17.2-2016, custom interactive menus stop responding when invoking another custom command 1715613 ALLEGRO_EDITOR UI_GENERAL With undocked Options window there is a mix up of entered text and funckey 1719301 ALLEGRO_EDITOR UI_GENERAL Selected coordinates do not change color in reports and Show Element 1724197 ALLEGRO_EDITOR UI_GENERAL Short cuts and hot keys not working in PCB Editor in release 17.2-2016 1728724 ALLEGRO_EDITOR UI_GENERAL Funckey is not working in release 17.2-2016 1673703 ALLEGRO_PROD_TOOLB OTHERS Design compare not reporting the Top and Bottom layer differences 1704474 ALLEGRO_PROD_TOOLB OTHERS When using Productivity Toolkit - PCB Design Compare, 'Override undefined width' is incorrectly applied 1571035 ALTM_TRANSLATOR CAPTURE Circles in third-party schematics not getting translated into Capture 1588911 ALTM_TRANSLATOR CAPTURE Capture crashes when translating, project and libraries are empty 1589394 ALTM_TRANSLATOR CAPTURE Schematic getting shifted off the page after translation 1631294 ALTM_TRANSLATOR CAPTURE Errors while translating third-party design when original design is in metric units 1663176 ALTM_TRANSLATOR CAPTURE Only first sheet of design getting translated from third-party schematic into Capture 1694363 ALTM_TRANSLATOR CAPTURE Capture is unable to translate third-party designs 1539739 ALTM_TRANSLATOR CORE Capture crashes on importing a third-party project 1542860 ALTM_TRANSLATOR CORE Capture crashes on clicking Translate after selecting a third-party design 1551642 ALTM_TRANSLATOR CORE Unable to import third-party schematics into Capture 1572929 ALTM_TRANSLATOR CORE Footprint names getting altered during translation 1568436 ALTM_TRANSLATOR PCB_EDITOR Unable to translate third-party layout data into PCB Editor 1629256 ALTM_TRANSLATOR PCB_EDITOR Getting empty symbol and devices folders when importing into PCB Editor 1664120 ALTM_TRANSLATOR PCB_EDITOR Import from third-party to PCB Editor is not translating data correctly 1701537 ALTM_TRANSLATOR PCB_EDITOR Import does not complete and reports errors 1698706 APD DIE_GENERATOR When using Compose Symbol from Geometry, circle from DXF cannot generate to pin 1714528 APD DIE_GENERATOR Getting 'illegal pad pointer' warning when creating die from geometry 1714532 APD DIE_GENERATOR Compose Die from Geometry creates incorrect pad shapes 1734310 APD MULTI_USER Symphony server mode malfunctions when die layer present. 1725506 APD SHAPE In release 17.2-2016 Hotfix 015, void is not generated in Artwork for BC7 layer causing short 1724395 APD WIREBOND Running axlBondWireDelete returns error message 1726609 ASDA CANVAS_EDIT Paste should not be allowed in the Current Refdes column of the Change Refdes form 1719754 CONCEPT_HDL ARCHIVER Path stored in the compressed file starts from /home instead of the current working directory 1726570 CONCEPT_HDL CHECKPLUS Checkplus crashes on Windows 10 1697977 CONCEPT_HDL CONSTRAINT_MG Differential pair disappears when it is packaged 1679575 CONCEPT_HDL CORE Page numbers are duplicated in Hierarchy Viewer when editing page names 1697732 CONCEPT_HDL CORE Pasting a signal name results in warning (SPCOCN-922) if the wire is too close to the edge of the page border 1711564 CONCEPT_HDL CREFER CRefer crashes while processing a hierarchical design containing subdesigns 1730736 CONCEPT_HDL OTHER Crash on generating BOM from design 1608350 CONSTRAINT_MGR CONCEPT_HDL Name of buffer model is not passed from Constraint Manager of DE-HDL to SigXplorer 1715803 CONSTRAINT_MGR CONCEPT_HDL Extract a net from constraint manager to SigXplorer, the models assigned are not displayed in SigXplorer 1718073 CONSTRAINT_MGR CONCEPT_HDL ECSet mapping errors on an upreved design in release 17.2: Pins in XNet and CSet do not match 1720886 CONSTRAINT_MGR CONCEPT_HDL SigXplorer does not extract assigned model from the schematic 1718514 CONSTRAINT_MGR ECS_APPLY Extracted topology does not use the PINUSE overrides specified on the canvas 1722306 GRE CORE Boards with Total Etch Length constraint only should not include z-axis when budgeting pin pairs 1710049 PSPICE SIMULATOR Functions are not taking parameters in correct order 1693021 SIG_INTEGRITY OTHER PINUSE is not updated correctly at model assignment with specific steps 1730854 SIP_LAYOUT SYMB_EDIT_APP Cannot delete all the die pin from a symbol using the Symbol Edit application mode Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
rom67 0 14 мая, 2017 Опубликовано 14 мая, 2017 · Жалоба вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: 019 Fixed CCRs: SPB 17.2 HF019 05-6-2017 ================================================================================ ======================================================================== CCRID Product ProductLevel2 Title ================================================================================ ======================================================================== 1701785 ADW ADWSERVER Getting 'Unable to locate tools.jar' error while using 'Copy Projects' 1706782 ADW ADW_UPREV Design uprev failed with error 'ERROR (FM-107): Failed to run adw_uprev' 1508159 ADW FLOW_MGR Flow Manager 'Open Last Project' option points to a deleted project 1690903 ADW FLOW_MGR Flow Manager library project list empty after 'Remove From List' 1705224 ADW LIBDISTRIBUTI Cannot migrate Library Footprint Models having subdirectory to release 17.2-2016 1672037 ALLEGRO_EDITOR EDIT_ETCH Add ZigZag Pattern crashes PCB Editor 1695711 ALLEGRO_EDITOR EDIT_ETCH In release 17.2-2016, Fiber Weave Effect - Add ZigZag Pattern crashes in Windows 10 1706522 ALLEGRO_EDITOR INTERFACES DFX import displays error message '*Error* eval: undefined function - cloneID' but imports outline 1716336 ALLEGRO_EDITOR INTERFACES DXF file is not correctly imported into PCB Editor 1720290 ALLEGRO_EDITOR INTERFACES Incorrect rotation of padstack after dxf import 1724683 ALLEGRO_EDITOR INTERFACES DXF OUT: incorrect Rounded/Chamfered rectangle pad rotation 1732587 ALLEGRO_EDITOR INTERFACES Format/content of ipc356 files exported in release 17.2-2016 different from release 16.6 1737516 ALLEGRO_EDITOR INTERFACES IDX Import works differently for placed and unplaced parts 1715152 ALLEGRO_EDITOR SCRIPTS Clicking Layout in Project Manager fails to load PCB Editor and gives message 'Word too long' 940699 ALLEGRO_EDITOR SHAPE Update shape to smooth fails to void a few clines. 1706581 ALLEGRO_EDITOR SHAPE Dynamic shape void clearance errors with vias 1638300 ALLEGRO_EDITOR UI_GENERAL Version information set in $cdsversion truncated on title bar for some tools 1697732 CONCEPT_HDL CORE Pasting a signal name results in warning (SPCOCN-922) if the wire is too close to the edge of the page border 1729510 CONCEPT_HDL CORE Changing the name of a split block adds pages that are part of the page gaps 1721065 CONSTRAINT_MGR CONCEPT_HDL Physical import errors on changing plane to conductor in stack-up 1734875 CONSTRAINT_MGR OTHER 'Create Spacing CSet' crashes tool from existing CSet context and grayed out in design context 1473104 ECW PART_LIST_MAN Pulse does not filter capacitor values correctly 1736580 PCB_LIBRARIAN SYMBOL_EDITOR Grids are not displayed correctly in Symbol Editor 1738955 PCB_LIBRARIAN SYMBOL_EDITOR Need ability to edit Symbol Properties 1735215 PSPICE FRONTENDPLUGI PSpice part search customization CDN_PSPICE_ODBC_SRC environment variable is not working 1733198 PSPICE PROBE Probe crashes when exporting trace expressions with multiple plots to CSV files 1737060 SIG_INTEGRITY SIGNOISE signoise fails for the AllegroSigrity_HS_Base_Suite option in release 17.2-2016 and release 16.6-2015 1707443 SIP_LAYOUT WIREBOND Moving bondfingers violates spacing constraint Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
rom67 0 22 мая, 2017 Опубликовано 22 мая, 2017 · Жалоба вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: 020 Fixed CCRs: SPB 17.2 HF020 05-21-2017 ================================================================================ ======================================================================== CCRID Product ProductLevel2 Title ================================================================================ ======================================================================== 1737443 ADW DBEDITOR Revising the schematic model classification for one category causes all parts in the library to be revised 1734123 ALLEGRO_EDITOR 3D_CANVAS Interactive 3D canvas crashes Allegro PCB Designer in 17.2 S016 1742084 ALLEGRO_EDITOR DATABASE Running DB Doctor on DRA files with custom pad shapes resets some of the custom padstack shapes in release 17.2 1739397 ALLEGRO_EDITOR INTERACTIV In release 17.2, running the SKILL function axlImportXmlDBRecords causes Allegro PCB Editor to crash 1724588 ALLEGRO_EDITOR MANUFACT Backdrill Route keepout suppressing existing Route Keepouts 1740036 ALLEGRO_EDITOR MANUFACT Generating the cross-section chart does not provide information about the overall board thickness 1743726 ALLEGRO_EDITOR OTHER IDF file export: In release 17.2, only one design outline is exported as against multiple board outlines in release 16.6 1744467 ALLEGRO_EDITOR OTHER The 'logical_op_new' variable is not displayed in User Preferences Editor 1729350 ALLEGRO_EDITOR REPORTS Net loop report is not working. 1713014 ALLEGRO_EDITOR SHAPE Incorrect behavior of donut shaped pads at certain rotations 1739870 ALLEGRO_EDITOR SHAPE The artwork is different from the PCB in release 17.2 Hotfix 17 1698869 ALLEGRO_EDITOR SKILL PCB Editor crashes when trying to open another .brd file after running SRM on first .brd file 1739307 ALLEGRO_EDITOR SKILL axlCNSDFAExport fails after first run 1743385 ALLEGRO_EDITOR SKILL SKILL APIs for STEP model mapping are not available in release 17.2 Hotfix 17 or 18 1685826 ALLEGRO_EDITOR UI_GENERAL Reports when opened from Status Form disappear behind PCB Editor canvas when clicking on canvas 1687797 ALLEGRO_EDITOR UI_GENERAL Cannot open two HTML windows, one after the other, while using SKILL function 1696229 ALLEGRO_EDITOR UI_GENERAL Setting the 'allegro_html' environment variable in User Preferences Editor overwrites existing popup text windows 1708636 ALLEGRO_EDITOR UI_GENERAL In SPB 17.2 release, keyboard focus automatically shifts to the newly opened dialog box 1711367 ALLEGRO_EDITOR UI_GENERAL Launching two report windows using SKILL is not working in 17.2 1742856 ALLEGRO_EDITOR UI_GENERAL Allegro PCB Editor crashes if Project Manager is open for a design in release 17.2 Hotfix 18 1729519 APD SHAPE shape degassing does not generate all voids to cover entire shape 1711375 CONCEPT_HDL CORE Copy-paste of schematic between two instances of DE-HDL is not working as expected 1737230 CONCEPT_HDL CORE On the Linux platform, copying of schematic objects does not work between designs of releases 16.6 and 17.2 1741375 CONCEPT_HDL CORE Inconsistent behavior of the Move command when moving a symbol 1743992 CONCEPT_HDL CORE Inconsistent behavior of the Move command when moving a symbol 1736093 CONSTRAINT_MGR CONCEPT_HDL Incorrect topology extraction and mapping errors related to MUX parts 1743518 CONSTRAINT_MGR CONCEPT_HDL Lag observed in expanding and collapsing the net classes in Constraint Manager 1730159 FSP ALLEGRO_INTEG FSP diff engine does not read PF Thevenin connections in FSP 1664070 ORBITIO ALLEGRO_SIP_I Display pads of SMD components on correct layer 1709319 ORBITIO USABILITY OrbitIO issues an error about Device template while importing brd with Bundles 1741150 PSPICE ENVIRONMENT Need a way to prevent the 'pspSimSetting.js' file from being overwritten by a hotfix installation in 17.2 1735354 PSPICE SIMULATOR Access to custom nom.lib is not working as expected 1716523 SIP_LAYOUT COLOR Tool crashes on using the PageUp, PageDown, and Tab keys in the Color dialog box. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
rom67 0 22 мая, 2017 Опубликовано 22 мая, 2017 · Жалоба . Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
rom67 0 6 июня, 2017 Опубликовано 6 июня, 2017 · Жалоба вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: 021 Fixed CCRs: SPB 17.2 HF021 06-3-2017 ====================================================================== ====================================================================== CCRID Product ProductLevel2 Title ====================================================================== ====================================================================== 1401318 ADW DBEDITOR Bulk Edit - Previously modified cells do not turn blue when selected 1621446 ADW DBEDITOR Bulk Edit - sorting highlights incorrect cells to mark them as changed 1743997 ADW LIB_FLOW Match file for standard models is incorrect 1746052 ALLEGRO_EDITOR DATABASE PCB Editor crashes when applying no drc property 1736067 ALLEGRO_EDITOR DRC_CONSTR Interlayer checks not reporting DRCs between cline and mask layer 1738587 ALLEGRO_EDITOR EDIT_ETCH Line width changing on slide for ETCH - Conductor (Not on a NET) 1745277 ALLEGRO_EDITOR EDIT_ETCH PCB Editor crashes on using the slide command 1747942 ALLEGRO_EDITOR EXTRACT Fabmaster Out does not export arc in pad_shape 1737202 ALLEGRO_EDITOR GRAPHICS Setting the variable display_raster_ops 1744042 ALLEGRO_EDITOR GRAPHICS Unused pad suppression is not working on few nets 1703848 ALLEGRO_EDITOR INTERFACES IPC 2581 fails with error 'E- (SPMHGE-268)' and the log file is empty 1743899 ALLEGRO_EDITOR MANUFACT Glossing dangling vias crashes PCB Editor 1744467 ALLEGRO_EDITOR OTHER The 'logical_op_new' variable is not displayed in User Preferences Editor 1748520 ALLEGRO_EDITOR OTHER TDP fails to load on an empty database 1748581 ALLEGRO_EDITOR PAD_EDITOR Padstack Editor crashes when changing default pad geometry 1751469 ALLEGRO_EDITOR PAD_EDITOR Padstack Editor crashes/freezes when browsing for a shape symbol 1725948 ALLEGRO_EDITOR SHAPE Shape differences after conversion from release 16.6 to release 17.2-2016 1729306 ALLEGRO_EDITOR SHAPE Seting shape_rki_autoclip variable causes no void to be generated 1698876 ALLEGRO_EDITOR UI_GENERAL Tabs are large and text is compressed in release 17.2-2016 1698883 ALLEGRO_EDITOR UI_GENERAL In release 17.2-2016, enlarging icons makes selection boxes/text unreadable on 4K monitors 1707933 ALLEGRO_EDITOR UI_GENERAL axlUIMenuFind not locating menu as per x_location 1741460 ALLEGRO_EDITOR UI_GENERAL Right-click, context menu options grayed in some cases after choosing Edit - Copy 1747588 ALLEGRO_EDITOR UI_GENERAL Interacting with PCB Editor by sending messages is not working 1747488 APD EDIT_ETCH Route connect is improperly affecting existing routes in locked high speed via structures 1750182 APD STREAM_IF The stream out settings are not saved 1752067 ASI_SI GUI Links to differential waveforms do not work in Sigrity SI report 1752131 CONCEPT_HDL COMP_BROWSER Symbol view in part manager doesn't match the symbol version 1754116 CONCEPT_HDL COMP_BROWSER Default Symbol selected is n°2 instead of n°1 in component Browser 1754949 CONCEPT_HDL COMP_BROWSER Part Information Manager displays preview window with the wrong symbol and missing footprint 1721334 CONCEPT_HDL CORE dsreportgen not able to resolve gated part on schematic 1750916 CONCEPT_HDL CORE DE-HDL crashes when trying to uprev a project in release 17.2-2016 1711487 CONCEPT_HDL INFRA Restrict opening of release 16.6 designs from a release 17.2-2016 design using File - View Design 1746915 CONSTRAINT_MGR CONCEPT_HDL Unable to copy a Physical and Spacing CSet generated from the Constraint Automation flow 1743523 CONSTRAINT_MGR DATABASE Suppress warning pop-ups from the constraint automation script 1746941 CONSTRAINT_MGR UI_FORMS 'Go to Source' from DRC tab is not working in release 17.2-2016 1753010 ECW METRICS Metrics not getting collected due to old license in use 1713052 FSP GUI Pin/Port Name and Group Name are not aligned properly in FPGA Port and Use Pin Mapping for DeviceInstance 1719099 FSP GUI Net naming wrong after building block 1719105 FSP GUI Tabular sorting not working in FPGA System Planner 1720479 PSPICE ENVIRONMENT Probe window does not open consistently on Windows 10 systems 1723411 PSPICE ENVIRONMENT Probe window does not open consistently on Windows 10 systems 1746628 PSPICE ENVIRONMENT PSpice Simulation Manager displays same message for all simulations in release 17.2-2016, Hotfix 016 1745976 SIG_INTEGRITY GEOMETRY_EXTR Arcs with coplanar waveguides are extracted with incorrect spacing 1690820 SIP_LAYOUT PLATING_BAR Cannot add fillets to pads with plating bars in release 17.2-2016 1725042 SIP_LAYOUT PLATING_BAR Creating a plating bar removes dynamic fillets 1747534 SIP_LAYOUT SHAPE Moving fiducial crashes SiP Layout Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
