defunct 0 24 декабря, 2013 Опубликовано 24 декабря, 2013 · Жалоба Но разве не должно быть наоборот - если хоть один операнд знаковый, то результат становится знаковым? не должно быть наоборот. Результат приводится к большей разрядной сетке. unsigned имеет больше значащих разрядов чем signed. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
GenaSPB 11 5 января, 2014 Опубликовано 5 января, 2014 (изменено) · Жалоба Ну написано же в стандарте явно про беззнаковость size_t... 3.3.3.4 The sizeof operator Constraints The sizeof operator shall not be applied to an expression that has function type or an incomplete type, to the parenthesized name of such a type, or to an lvalue that designates a bit-field object. Semantics The sizeof operator yields the size (in bytes) of its operand, which may be an expression or the parenthesized name of a type. The size is determined from the type of the operand, which is not itself evaluated. The result is an integer constant. When applied to an operand that has type char , unsigned char , or signed char , (or a qualified version thereof) the result is 1. When applied to an operand that has array type, the result is the total number of bytes in the array./35/ When applied to an operand that has structure or union type, the result is the total number of bytes in such an object, including internal and trailing padding. The value of the result is implementation-defined, and its type (an unsigned integral type) is size_t defined in the <stddef.h> header. И про преобразование перед делением: 3.2.1.5 Usual arithmetic conversions Many binary operators that expect operands of arithmetic type cause conversions and yield result types in a similar way. The purpose is to yield a common type, which is also the type of the result. This pattern is called the usual arithmetic conversions: First, if either operand has type long double, the other operand is converted to long double . Otherwise, if either operand has type double, the other operand is converted to double. Otherwise, if either operand has type float, the other operand is converted to float. Otherwise, the integral promotions are performed on both operands. Then the following rules are applied: If either operand has type unsigned long int, the other operand is converted to unsigned long int. Otherwise, if one operand has type long int and the other has type unsigned int, if a long int can represent all values of an unsigned int, the operand of type unsigned int is converted to long int ; if a long int cannot represent all the values of an unsigned int, both operands are converted to unsigned long int. Otherwise, if either operand has type long int, the other operand is converted to long int. Otherwise, if either operand has type unsigned int, the other operand is converted to unsigned int. Otherwise, both operands have type int. The values of operands and of the results of expressions may be represented in greater precision and range than that required by the type; the types are not changed thereby. Изменено 5 января, 2014 пользователем Genadi Zawidowski Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
