Перейти к содержанию
Исходная задача: сделать загрузку из EPCS в SRAM.
Но заткнулся в epcs.
Все сделал по мануалу, за исключением того, что использую NIOS IDE. (Cyclone 3, Quartus 9).
Проблема в том, что не собирается проект в NIOS:
**** Build of configuration Release for project SRAMCPU ****
make -s all includes
Compiling main.cpp...
Linking SRAMCPU.elf...
obj/main.o(.text+0x18): In function `alt_sys_init':
/cygdrive/d/altera/try/SRAM/software/SRAMCPU_syslib/Release/system_description/alt_sys_init.c:96: undefined reference to `alt_epcs_flash_init(alt_flash_epcs_dev*)'
obj/main.o(.text+0x1c):/cygdrive/d/altera/try/SRAM/software/SRAMCPU_syslib/Release/system_description/alt_sys_init.c:96: undefined reference to `alt_epcs_flash_init(alt_flash_epcs_dev*)'
obj/main.o(.data+0x14):/cygdrive/d/altera/try/SRAM/software/SRAMCPU_syslib/Release/system_description/alt_sys_init.c:96: undefined reference to `alt_epcs_flash_write(alt_flash_dev*, int, void const*, int)'
obj/main.o(.data+0x18):/cygdrive/d/altera/try/SRAM/software/SRAMCPU_syslib/Release/system_description/alt_sys_init.c:96: undefined reference to `alt_epcs_flash_read(alt_flash_dev*, int, void*, int)'
obj/main.o(.data+0x1c):/cygdrive/d/altera/try/SRAM/software/SRAMCPU_syslib/Release/system_description/alt_sys_init.c:96: undefined reference to `alt_epcs_flash_get_info(alt_flash_dev*, flash_region**, int*)'
obj/main.o(.data+0x20):/cygdrive/d/altera/try/SRAM/software/SRAMCPU_syslib/Release/system_description/alt_sys_init.c:96: undefined reference to `alt_epcs_flash_erase_block(alt_flash_dev*, int)'
obj/main.o(.data+0x24): In function `main':
../main.cpp:34: undefined reference to `alt_epcs_flash_write_block(alt_flash_dev*, int, int, void const*, int)'
collect2: ld returned 1 exit status
make: *** [SRAMCPU.elf] Error 1
Код программы:
#include "system.h"
#include "alt_types.h"
#include "sys/alt_irq.h"
#include "alt_sys_init.c"
#include "altera_avalon_pio_regs.h"
#define ALT_USE_EPCS_FLASH
#include <altera_avalon_epcs_flash_controller.h>
#include "epcs_commands.h"
#include "sys/alt_flash.h"
#include "sys/alt_flash_dev.h"
int main()
    //initialization
    alt_sys_init();
    while(1)
В комметах то, что нашел по теме, но не помогло..
Подскажите, пожалуйста, в чем может быть проблема?
Поделиться сообщением
Ссылка на сообщение
Поделиться на другие сайты
Описанный способ, конечно, имеет право на существование, но, имхо, это способ трансректальный. :cranky:
Используйте FlashProgrammer
Ссылка на сообщение
Я правильно понимаю, что через FlashProgrammer грузится и конфигурация FPGA, и программа для ниоса?
Просто в результате нужна система, которая грузится из ECPS, при этом ниос работает на SRAM без on-chip.
Ссылка на сообщение
А что вам мешает сделать по этому же мануалу проект в SRAM?
Ссылка на сообщение
Я не совсем понимаю принцип работы данной системы.
Как мне кажется, FPGA грузится из EPCS, потом как то нужно загрузить код программы в SRAM. Верно? В каком направлении копать?
Собрал в SOPC идентично с мануалом альтеры, остаются все те же ошибки про epcs.
Ссылка на сообщение
Предлагаю вам преодолеть этот путь постепенно. Сначала создайте проект, который грузится из внутренней памяти. Потом проект, загружающийся из epcs. Потом переходите к проекту, работающему во внешней памяти. И у вас всё получится.
Ссылка на сообщение
Проекты, которые грузятся по AS из EPCS и работают на on-chip, есть и работают. Проблем не было.
Что то ниосу не нравится в модуле EPCS Serinal Flask Controller, без использования внешней памяти. Там дополнительно не нужно ничего настраивать?
Изменено пользователем Unfog
Ссылка на сообщение
Не совсем понял ваш вопрос. То есть, проект в SRAM памяти работает и проект из EPCS грузится. Но совместный проект не работает?
Ссылка на сообщение
Работает простая конфигурация, когда альтера загружается из EPCS, NIOS работает на встроенной on-chip. (Прошиваю pof программером)
Потом я добавляю Flash Controller в SOPC и начинают вылезать вышеуказанные ошибки.
Попробую дома тот же проект в Q11 собрать..
Спасибо за ответы!
Ссылка на сообщение
Спасибо за ответы!
Может вам помогут пошаговые инструкции, которые уже давно лежат?..
Ссылка на сообщение
На Q11 аналогичная ситуация.
Очень смущают сообщения типа "undefined reference to `".. В настойках линкера ничего менять не нужно?
Ссылка на сообщение
Да почитайте же наконец юзергайд на FlashProgrammer!!!
Там все английским по белому расписано!
В Вашей SOPC-системе должен присутствовать epcs_flash_controller, и процессорное ядро должно иметь jtag drbug модуль. Вектор сброса процессора должен указывать на epcs_flash_controller. Прежде, чем запускать FlashProgrаmmer, Вы должны по JTAG'у сконфигурировать Вашу ПЛИС'ку соответствующим sof-файлом.
С помощью FlashProgramer'а Вы прошиваете в конфигурационное ПЗУ (т.е. в EPCS'ку) и конфигурацию ПЛИС'ки (sof-файл), и исполняемый код процессора (elf-файл).
Как это все работает.
В epcs_flash_controller'е имеется небольшой блок памяти, в котором живет программа-копировщик (она предназначена для копирования кода приложения из EPCS'ки в ту память, куда Вы укажете). После включения питания сперва происходит конфигурация ПЛИС'ки. Ваш проект начинает работать, и процессор по вектору сброса попадает в epcs_flash_controller и исполняет код копировщика, который в этом контроллере находится. После окончания копирования процессор переходит в ту область памяти, где теперь живет код приложения (т.е. туда, куда он только что этот код скопировал), и начинает этот код приложения исполнять.
Все...
Ссылка на сообщение
Спасибо за объяснения.
Я так и делаю. Делал полные копии в SOPC с мануалов - результат один.
Сейчас повторил все в Eclipse - собралось с первого раза.
Отсюда вопросы:
Стоит ли переходить на Eclipse?
Муторно ли переносить проекты с IDE?
Что сделать, чтобы заработало в IDE?
Ссылка на сообщение
А что именно Вы называете IDE?
Старую версию среды или режим командной строки?
В общем и целом - работать должно в любом варианте, независимо от версий и режимов.
Ссылка на сообщение
Старую версию.
Я понимаю, что должно работать везде. Но видимо есть нюансы.
Ссылка на сообщение
Присоединяйтесь к обсуждению
Гость
Ответить в этой теме...
  • Создать...
