a.graf 0 6 июля, 2011 Опубликовано 6 июля, 2011 · Жалоба Вышел новый Hotfix:16.50.001 293005 ALLEGRO_EDITOR DATABASE Allegro crash when attempting to move mech. symbol 298289 CIS EXPLORER CIS querry gives wrong results 366939 ALLEGRO_EDITOR OTHER Cannot attach refdes on silk subclass with add text 432200 ALLEGRO_EDITOR MANUFACT Fillets with an arc are required for Flexi designs 443447 APD SHAPE Shapes not following the acute angle trim control setting. 473308 PSPICE AA_SENS Passing variables to lower level blocks using subparam 517556 PSPICE AA_SENS Advanced Analysis does not support variables being passed down the hierarchy 548143 ALLEGRO_EDITOR SHAPE Dynamic shpe on Etch TOP will not void properly. 606959 ADW COMPONENT_BROWSE Key properties with blank values are not getting read in shooping cart 616466 ALLEGRO_EDITOR SHAPE Solid shapes are not getting filled 641358 SIP_LAYOUT DIE_STACK_EDITOR Request for Via and Multi Layer Pin support for DIE stack Area (blue region) 644122 SIP_LAYOUT OTHER SiP Layout - xsection - ERROR Adjacent conductive layers are not allowed, but these are diestack layers not conductor 645816 ALLEGRO_EDITOR SHAPE Slide a cline all removes gnd shapes on board 725355 ALLEGRO_EDITOR SHAPE User can not voided Logo correctly. 763569 CONCEPT_HDL CORE Display status of Hide/Show unconnected pins icon in DE HDL UI 770021 CAPTURE BACKANNOTATE Changing pin group property after pin swap resets pin numbers 792126 CAPTURE PROPERTY_EDITOR Attempt to change display for occ prop resets 799014 CONCEPT_HDL CONSTRAINT_MGR concept2cm errors not shown in export physical after hier_write 803147 CIS LINK_DATABASE_PA Link DB part should not change RefDes of multi package part 804240 PSPICE DEHDL Problem in simulation result for a multi-section split part. 809118 CAPTURE NETLISTS ENH to compare two schematic Capture designs 816568 ALLEGRO_EDITOR SHAPE shape disappears when update to smooth.. State no etch 830053 CAPTURE STABILITY DXF export fails if schematic folder name as / 832108 ALLEGRO_EDITOR SHAPE Shape void incorrectly. 833542 CONCEPT_HDL CORE PDF publisher font is NOT WYSIWIG with respect to what seen in DE HDL 835777 CIS DERIVE_NEW_DB_PA For XLS, donot display table as worksheetName$worksheetName to avoid 8012 error 837640 CIS GEN_BOM date format of CIS BOM has broken macros of 16.2 in 16.3 version 844074 APD SPECCTRA_IF Export Router fails with memory errors. 851595 CONCEPT_HDL CORE Pin numbers overlap on the pin and increase in size 852832 CAPTURE BACKANNOTATE Why is Capture crashing with Mentor back annotation? 855015 ALLEGRO_EDITOR OTHER The rats are NOT connecting to the ends of the clines like they should be. 859883 CAPTURE NETLISTS ENH to compare two schematic Capture designs 866009 SIG_INTEGRITY OTHER Net with Pull-up/down should not be used for Diff-pair. 866830 SCM REPORTS Multiple lines added as separator between title block and report header instead of single line 866833 SCM REPORTS Extra indentation is left in the left side of the report when the Line Numbers are set to OFF 868618 SCM IMPORTS Block re-import does not update the docsch and sch view 873402 SIP_LAYOUT LOGIC pin swap for co-design die in SiP 874010 SIG_INTEGRITY OTHER PCB SI crashes when the Xnet is extracted with VARIANT_TO_IGNORE property. 874400 ALLEGRO_EDITOR INTERACTIV Flip mode issue with move command 874966 ALLEGRO_EDITOR INTERFACES Placed mechanical component do not get Ref Des or part number in IDF file 875709 ALLEGRO_EDITOR REPORTS Film area report generated incorrect data at l1 876275 CONCEPT_HDL CONSTRAINT_MGR Constraint Manager not retaining target net 879361 SCM UI SCM crashes when opening project 879496 CONCEPT_HDL OTHER Customer wants to have “the tabulation” key as separator in HDL BOM. 879514 PSPICE AA_MC Monte Carlo to handle equation as comp VALUE. 881845 ALLEGRO_EDITOR SHAPE Delete island deletes complete shape 882413 PDN_ANALYSIS PCB_PI PDN Analysis should support routed power nets 882427 PDN_ANALYSIS PCB_PI PDN Analysis target impedance should have a variable multiplier 882567 SIG_INTEGRITY OTHER PCB SI crash if boolean type prop was specified to VARIANT env. 882644 ALLEGRO_EDITOR PLACEMENT PCB Place Replicate Function automatically match Enhancement 883164 ALLEGRO_EDITOR INTERACTIV Vias marked fanout moves away from position when moving component 883224 SIG_INTEGRITY SIMULATION crash while reflection simulation from Constraint Manager 883760 PCB_LIBRARIAN METADATA Incorrectly formatted revision.dat file in the metadata folder 885391 SIG_INTEGRITY SIMULATION RLGC data sampling algorithm and w-element interpolation. 885849 ALLEGRO_EDITOR MANUFACT Silkscreen Audit cannot find Solder mask for the text string 885996 SIG_INTEGRITY OTHER The effect of sn_maxwidthlimit user preference is not seen in cross section impedance calculations 886090 ALLEGRO_EDITOR INTERACTIV Add Arc w/Radius does not snap to grid 887180 CAPTURE SCHEMATIC_EDITOR Signals Navigation window doesn’t get updated for Buses 887442 APD SHAPE Copper pour of Dynamic shapes on Top layer which contains many existing signal traces fails. 887578 SCM AUTO_UI Component Replace pops-up the DSPANE-204 Message 887926 SIG_INTEGRITY GEOMETRY_EXTRACT Field solution failed if diff trace on bottom doesn't have reference plane. 888414 SIG_EXPLORER OTHER View Trace Parameter display the thickness of dielectric incorrectly. 888600 CONCEPT_HDL CREFER Cross References not added to Schegen schematic 888679 SIP_LAYOUT SHAPE Can't create the Dynamic shape on layer M1_sig without unwanted horizontal openings appearing. 888804 ALLEGRO_EDITOR OTHER Fillet will become static shape after import from partition board. 888945 CONCEPT_HDL OTHER unplaced component after placing module 889222 ALLEGRO_EDITOR SHAPE Allegro freezes/hangs when adding shape as Polygon with OpenGL ON. 889365 SIG_INTEGRITY GEOMETRY_EXTRACT top/bottom trace impedances extracted to sigxp are wrong in 16.3 889404 ALLEGRO_EDITOR OTHER Incorrect pad size for Top conductor padstack written to column 59-62. 889426 CONCEPT_HDL CHECKPLUS CheckPlus does not find single node net 889636 ALLEGRO_EDITOR MANUFACT Incorrect spelling of "Visibility" in "Film Control" tab in the Artwork Control Form 891235 F2B PACKAGERXL Packager crashes without creating a pxl.log file 891292 ALLEGRO_EDITOR SHAPE arc routing causes weird undesireable shape fill performance 891856 ALLEGRO_EDITOR EDIT_ETCH crash when sliding diff pairs 892375 ALLEGRO_EDITOR PLACEMENT Place Replicate Update disband other groups, irrespective Fixed property added or not. 892455 ALLEGRO_EDITOR SYMBOL Why the overlapping pins are not reported with DRC? 892541 SIG_EXPLORER OTHER Export/Import layerstack through the technology file is changing the layer thickness 892766 APD WIREBOND Excuting Finger moving cannot push aside finger to move with together by shove all mode 892907 ALLEGRO_EDITOR DRC_CONSTR DRC not reported for etch_turn_under_pin violations 892963 ALLEGRO_EDITOR SKILL Bad shape boundary created after axlPolyOperation 'OR 892964 SIP_LAYOUT LOGIC Request that Edit Parts List use Dashes "-". 893295 APD WIREBOND Why move wirebond command does not shove wirebonds? This result in drcs. 893706 CONSTRAINT_MGR OTHER On line DRC hangs on partitioned board 893743 APD EDIT_ETCH Route behavior when spanning pads not as expected. 893783 SIP_LAYOUT OTHER Padstack Design Editing update File menu with a Update to Design and Close instead of 2 operation 894456 ALLEGRO_EDITOR REPORTS Request Net names be added to Propagation delay lines of the DRC report. 894499 SIG_INTEGRITY LIBRARY Tool crashes when moving a cline or selecting the Info icon with OpenGL on. 894582 APD SHAPE When making a dynamic xhatch Via shapes surrounding are abnormal. 895542 SIP_LAYOUT WIREBOND SIP design crashing when moving bond finger using blur mode BLUR_BONDFINGER_PRESRV_CON 895591 ALLEGRO_EDITOR PCAD_IN Importing PCAD file fails to get to the point where we can map layers 895757 APD ARTWORK Import Gerber command could not be imported Gerber data 895964 CONCEPT_HDL CHECKPLUS The CheckPlus command “getFileSubstrings” is not working correctly 896428 SCM UI Changed Ref Des value not maintained in DEHDL block when part is replaced 896655 CAPTURE EDIF Import/Export Design of Hierarcy design with OrCAD Capture 896846 CAPTURE IMPORT/EXPORT Import edif2cap and capture is crashing 897155 ALLEGRO_EDITOR REPORTS Copper coverage in L2 and L7 looks like the same but film area report had large gap. 897654 CAPTURE EE_INTERSHEET_RE Capture crashes on adding intersheet refernces in abbreviated format on attached design. 899344 RF_PCB BE_IFF_EXPORT dlibx2iff does not provide the component boundary drawing 899629 CONSTRAINT_MGR OTHER ECset for Total Etch Lenght is not present in OrCAD Prof 900175 CONCEPT_HDL CONSTRAINT_MGR Few Xnets are lost from Match Group after packaging and importing the netlist to board file. 900481 CONCEPT_HDL CORE Genview creates a larger symbol without taking the no. of pin in consideration 900813 ALLEGRO_EDITOR DRC_CONSTR With rotated pads, pad (pin - via) soldermask spacing DRC is unreasonable. 900905 PSPICE STABILITY Simsrvr crash and RPC Server unavailable error while running simulation. 901783 CONCEPT_HDL CORE CDS_PART_NAME is annotated on the schematic canvas after running back annotation in 16.5 901909 APD EXPORT_DATA The "package_pin_delay_length.rpt" with Z-axis delay turned on seems wrong 901987 CONCEPT_HDL OTHER SPB16.5 zoom fit does not center the page while ploting the schematic page 902133 CIS OTHER The visible part property value are being shown very distant from part graphics on schematic 902166 SPECCTRA ROUTE Specctra crashes when reading in "bestsave.w" file 902170 ALLEGRO_EDITOR DATABASE Diffpair Issues with OrCad PCB Designer Professional 902177 CONSTRAINT_MGR CONCEPT_HDL Option to view the layer thickness in CM worksheet through worksheet customization 902463 ALLEGRO_EDITOR INTERACTIV APD crashes when we click ( show element ) on certain components 902621 CONCEPT_HDL OTHER Design Differences (vdd) Crashes 902909 APD WIREBOND die to die wirebond crash 902933 ALLEGRO_EDITOR PADS_IN Pads_in fails while reading PADS ASCII file body 903284 PDN_ANALYSIS PCB_STATICIRDROP IRDrop voltage gradients are plotted outside of the PCB outline 903680 CONSTRAINT_MGR ECS_APPLY Constraint Manager not passing all hiearchical member objects to a custom measurement. 904403 ALLEGRO_EDITOR DATABASE Allegro crashes when refreshing module Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
a.graf 0 2 августа, 2011 Опубликовано 2 августа, 2011 · Жалоба Hotfix version: 002 527444 ALLEGRO_EDITOR EDIT_ETCH Slide command needs to be enhanced for same net spacings 583257 ALLEGRO_EDITOR EDIT_ETCH Add Connect and slide command needs to be enhanced for same net spacings. 592956 ALLEGRO_EDITOR EDIT_ETCH Same net traces will not push and/or shove each other. 745285 ALLEGRO_EDITOR EDIT_ETCH Requesting a true "shove" in Route > Slide for Same net routing. 773503 CAPTURE OTHER Doing "Mirror Horizontally" creates extra un-connects or extra junction dots in Capture V16.3. 774270 F2B PACKAGERXL Require to ignore space in Pattern setting to prevent duplicated Refdes. 799984 ALLEGRO_EDITOR INTERACTIV Enhance the Fix command to select just cline segs 809008 CAPTURE SCHEMATIC_EDITOR New nodes get appeared within the design when we select the design and do "Mirror Horizontally". 810058 CAPTURE SCHEMATIC_EDITOR New nodes get appeared within the design when we select the design and do "Mirror Horizontally". 821133 ALLEGRO_EDITOR MANUFACT Output artwork for pad data that are suppressed unconnected pads with Gerber 6x00 format 831710 CAPTURE SCHEMATIC_EDITOR Capture adds extra junctions to design by itself 842410 ALLEGRO_EDITOR EDIT_ETCH Ability to slide with "Shove" for "Same Net" segments/vias. 854971 ALLEGRO_EDITOR INTERACTIV Capability to add cline segment in a temp group 860772 ADW PCBCACHE Save Shopping Cart (pcbcache) is crashing component browser 867842 CAPTURE PROJECT_MANAGER Capture crash with 'Open File Location" 868306 CAPTURE CONNECTIVITY mirror vertically removes junction creates extra nets 882677 EMI RULE_CHECK bypass_plane_split fail if BYPASS_XXXX_EFFECT_DISTANCE 891439 ALLEGRO_EDITOR INTERACTIV moving cline segments 893544 ALLEGRO_EDITOR INTERFACES IPC-D-356A netlist issue with BB vias. 893765 ALLEGRO_EDITOR PARTITION Mail command not sending out email on Linux platforms. 894390 SIP_LAYOUT EXPORT_DATA Generate all balls in the xml file for export to EDI's readPackage command 895933 APD DATABASE Update Symbol shifts the center of the Dynamic Fillet and creating DRCs 896598 ALLEGRO_EDITOR PLACEMENT error message is misleading 897196 CIS LINK_DATABASE_PA Schematic Contents are not shown in CIS window while link Dbase part for parts placed from library 898598 ALLEGRO_EDITOR MENTOR Negative planes from Mentor Board Station not being translated. 899556 ALLEGRO_EDITOR ARTWORK Import artwork seems not to work correctly. 900501 ALLEGRO_EDITOR PLACEMENT "Place Replicate Apply" is showing lot of DRC's during placement of replicated circuit in 16.5 901141 CIS EXPLORER Japanese character appear garbled in CIS explorer window. 901666 CAPTURE OTHER Home page of Flowcad-Switzerland and Flowcal-Poland is not preserved on captre restart on start page 902066 ALLEGRO_EDITOR DRC_CONSTR Shape in Region not follow the constrains 902349 CAPTURE LIBRARY Capture crashes while closing library 902508 F2B PACKAGERXL SPB16.5 Packager-XL consumes much more memory than 16.3 902841 CAPTURE GENERAL Capture Start page does not show 902876 F2B PACKAGERXL Packager fails on the design upreved in 16.5 902959 CONCEPT_HDL HDLDIRECT HDLDirect Error while saving design 903171 PSPICE NETLISTER Why Capture is treating hierarchical power ports as floting nets in complex heirarchy designs? 903713 ALLEGRO_EDITOR PARTITION Placement Replication do not work fine in the Design Partition 903799 SIP_LAYOUT DIE_EDITOR Disappear die pins after exiting co-design die editor 904021 ALLEGRO_EDITOR OTHER Export PDF from SPB 16.5 produces a file not text searchable 904339 CONCEPT_HDL CORE new design crashes using the attached CDS_SITE 904522 F2B PACKAGERXL Part will not package in 16.5 but packages in 16.3 904764 APD OTHER Enhance Scale Factor of Stream Out to support 4 decimal places 904771 ALLEGRO_EDITOR MANUFACT Pin Number display issue. 904853 ALLEGRO_EDITOR GRAPHICS Enhancement for showing Static shape as it was seen in 16.3 905144 CONSTRAINT_MGR ECS_APPLY Min Line Spacing is larger than Primary or Neck Gap less(-) Tolerance but No Warning in CM 905314 F2B PACKAGERXL Import physical causes csb corruption 905337 CONCEPT_HDL CORE ConceptHDL crashes after Import Design process. 905533 ALLEGRO_EDITOR INTERACTIV Pin numbers for components on BOTTOM Side are moved in Preselect mode,when the BOTTOM layer is invisible 905796 CONCEPT_HDL CONSTRAINT_MGR Fujitsu CM issue inaccurate concept2cm diff pair issues 905811 CAPTURE EE_INTERSHEET_RE interesheet references in the form of grid grid page number instead of page number grid 906118 CONCEPT_HDL CONSTRAINT_MGR Cannot open CM if SIGNAL_MODEL value was not assigned in ptf. 906153 ALLEGRO_EDITOR SCRIPTS Unable to run allegro script in batch mode on the attached board. 906182 APD EXPORT_DATA Modify Board Level Component Output format 906200 ALLEGRO_EDITOR DFA Enh- DFA drc invoked in Batch mode returns false constraint value in Show Element 906517 PSPICE PROBE PSpice new cursor window shows incorrect result. 906627 ADW COMPONENT_BROWSE ppt options are not read if ucb is launched from FM. works fine if launched from dehdl. 906647 SIG_INTEGRITY LIBRARY lib_dist creates a signoise.log in current directory (with backup files like ,1 ,2 etc.) on each run 906673 F2B PACKAGERXL Ignore the signal model validity check during packaging 906688 ADW LRM A copy of source design gets created in worklib of target design after 'Import Design' 906750 ALLEGRO_EDITOR PARTITION Importing design partition removes the testpoint reference designation 906874 PSPICE NETLISTER Error less than 2 connections for unconnected hierarchical pin 907095 F2B OTHER Part Manager does not show Error as Undefined when directive ptf_mismatch_exclude_inj_prop is used 907424 ALLEGRO_EDITOR GRAPHICS Allegro add option for pre 16.5 shape display 907490 CAPTURE NETLIST_LAYOUT 16.5 Layout netlist is not correct. It differs form 16.3 layout netlist. 907884 SIP_LAYOUT MANUFACTURING Need to add an "NC" pin text option for "Manufacturing Documentation Display Pin Text" 907885 SIG_INTEGRITY OTHER Matchgroup targets lost when importing netlist to Allegro layout in HF31 907929 CAPTURE TCL_SAMPLE TCL command to delete a property from parts in a library is not working correctly 907933 SIG_INTEGRITY OTHER Single line impedence not working in OrCad PCB Professional 907963 CONCEPT_HDL CORE Design uprev issue when moving from 16.2 to 16.5 908000 SIG_INTEGRITY OTHER Inconsistence z-axis delay reported on Tpoint when define at via location. 908057 CONCEPT_HDL CORE DE HDL crash with the cut and paste of a signal name 908060 CONCEPT_HDL CORE CTRL+LMB Option not working correctly in 16.3 908210 CAPTURE CONNECTIVITY Connection is being lost while dragging a component 908241 CAPTURE DRC DRC error column is blank in DRC markers window in 16.5 908339 RF_PCB BE_IFF_IMPORT mechanical holes VIAFC are not at the right place 908534 SIP_LAYOUT SYMB_EDIT_APPMOD issues with symbol editor and copying pin arrays 908535 F2B DESIGNVARI When I try to view my variant file the variant editor crashes 908595 APD 3D_VIEWER Cadence Design 3D viewer" screen pops up and is all black because the colors have all converted to b 908849 CAPTURE ANNOTATE Getting crash while annotating the attached design 908874 CONCEPT_HDL CORE Part Manager - No Part Found error when using CCR# 775788 feature 909077 CONCEPT_HDL CORE After packaging pin numbers remains invisible even when $PN 909104 ALLEGRO_EDITOR SYMBOL Warning message needs to be modified. It does not save the symbol and also not tell the actual problem. 909417 ALLEGRO_EDITOR REPORTS "report -v upc" returns 'Segmentation fault' on Linux 909635 SIP_LAYOUT DIE_STACK_EDITOR Add Interposer crashes in SiP Layout 909749 ALLEGRO_EDITOR MANUFACT Allegro Crash during dimensioning 909760 SIP_LAYOUT MANUFACTURING Create bond finger solder mask doesn't follow the mask opening as defined in the padstack 909861 F2B PACKAGERXL NetAssembler broken within the latest 16.30.031 910006 CONCEPT_HDL INFRA Motorola design fails to uprev from 16.3 to 16.5, xcon file is getting corrupted. 910141 CAPTURE NETGROUPS Modify NetGroup definition does not update Offpage Connector 910340 ADW LRM Import design in schematic, only 1 page import, the entire block is getting imported. 910678 SIG_INTEGRITY OTHER The Analyze> Model Assignment> Auto setup is not creating/assigning models to discrete components in 16.5 910713 F2B DESIGNVARI Variant Editor crashes when you click web link under “Physical Part Filter” window. 910936 F2B PACKAGERXL ConceptHDL subdesign net name is inconsistent 911530 ALLEGRO_EDITOR SYMBOL Package Symbol Wizard does not create symbol with the name given 911631 CONCEPT_HDL CORE DEHDL crashes when opening a design 912001 ALLEGRO_EDITOR OTHER option_licenses entries are made in allegro.ini even when not set as default 912459 F2B BOM BOMHDL crashes before getting to a menu 913359 APD MANUFACTURING Package Report shows incorrect data Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
rloc 43 2 августа, 2011 Опубликовано 2 августа, 2011 · Жалоба Hotfix version: 002 Опаздываете с новостями, вышел уже более недели назад :1111493779: Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
JohnSilver 1 11 августа, 2011 Опубликовано 11 августа, 2011 · Жалоба А вот я видел, человек указывал свою версию PCB Editor 16.5.003. Получается уже 3-ий вышел? Или я чего то недопонимаю? А вообще откуда берется инфо о выходе хотфиксов? На сайте Cadence ничего не нашел. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Uree 1 11 августа, 2011 Опубликовано 11 августа, 2011 · Жалоба Вышел 3-й, 4-го августа еще. DATE: 08-4-2011 HOTFIX VERSION: 003 ================================================================================ =================================================== CCRID PRODUCT PRODUCTLEVEL2 TITLE ================================================================================ =================================================== 787414 CAPTURE PROPERTY_EDITOR Part value can’t be moved on schematic if a part has been copied to a new design and not saved yet. 903898 PCB_LIBRARIAN GRAPHICAL_EDITOR PDV move symbol graphics and Undo causes corruption in graphics 904287 ALLEGRO_EDITOR ARTWORK some cline with arc is missed, when creating artwork. 904418 CHANNEL_ANALYS SIMULATION channel analysis sim does not give valid result 905777 SIG_INTEGRITY SIMULATION User gets popup message that halts an analysis until it is acknowledged 906139 SIG_INTEGRITY OTHER Bus sim result were cleared at the next run even if no preference changed. 908680 SIG_INTEGRITY OTHER Extra prop delay due to resistance 909583 ALLEGRO_EDITOR SKILL axlPolyOperation AND operation is not working correctly. 910315 ADW LRM Import Design with ADW causes partmgr and pxl errors 910689 CONCEPT_HDL CONSTRAINT_MGR NO_SWAP_COMP warning after uprev to 16.5 911684 CONCEPT_HDL CONSTRAINT_MGR Attribute Definitions are incompatible for attribute 'HEADER'. when attempting to place in 16.5 912343 APD OTHER APD crash on trying to modify the padstack 912384 PCB_LIBRARIAN CORE PDV Symbol Editor often freezes when moving groups objects by arrow keys 912853 APD OTHER Fillets lost when open in 16.3. 913586 ALLEGRO_EDITOR ARTWORK Cannot create the drill figures in this design. 914009 ALLEGRO_EDITOR DRC_CONSTR Diff impedance worksheet showing almost zero impedance for differential pair in attached testcase. 914110 CONCEPT_HDL OTHER DEHDL 16.5 Uprev overides property values on hierachical blocks 914264 F2B OTHER Cross Probing from DEHDL for global nets present inside block doesn’t highlight in PCB Editor. 914309 CONCEPT_HDL CORE 16.5 DEHDL crash on saving the user design 914558 ALLEGRO_EDITOR ARTWORK Gerber6x00 output creates unpainted niche in a shape 914633 ALLEGRO_EDITOR ARTWORK Artwork failing in v16.5 while the same design when downrev'd to 16.3 is working fine. 914634 ALLEGRO_EDITOR SKILL IsThrough flag for a padstack is reset 914746 ALLEGRO_EDITOR DRC_CONSTR DRC Update repeats takes longer on each successive pass. 914962 ALLEGRO_EDITOR SHAPE Corruption with Shape filling 915583 CONCEPT_HDL CORE performance issues in 16.5 compared to 16.3 915630 PCB_LIBRARIAN OTHER Error when running SI Model Interface Comparison using IBIS models 915742 CONCEPT_HDL HDLDIRECT I get a newgenasym error and crash when trying to save the symbol 916154 SCM NETLISTER scm crashes when exporting physical database to allegro 916448 CAPTURE NETLIST_LAYOUT Capture 16.5 Layout netlist contains errors 916462 ALLEGRO_EDITOR DATABASE Edit>Split_plane>create hangs Allgro PCB Editor 916469 ALLEGRO_EDITOR REPORTS One Unrouted pin does not show in Unconnected Pins Report 916495 ALLEGRO_EDITOR INTERACTIV Pick selects components from invisible (Off ) layer 916889 CAPTURE NETGROUPS How to change unnamed net group name? 917002 ALLEGRO_EDITOR OTHER Allegro PDF Publisher creates extra circles not available on film 917434 APD OTHER Stream out GDSII has more pads in output data. 917739 CONCEPT_HDL INFRA Global Net tied to port is getting split into 2 nets in 16.5, in 16.3 it is treated as a single net 918187 CONSTRAINT_MGR OTHER Missing acGetTotalEtchLength predicate. 918576 CAPTURE DRC Incorrect DRC is reported for visible power pins which are connected to power symbol Насчет информации как-то не задумывался, просто заходил в саппорт и смотрел, нет ли нового хотфикса. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
aosp 0 30 августа, 2011 Опубликовано 30 августа, 2011 · Жалоба залил четвертый вообще можно самим скачивать прямо из Capture Надо в Start Page выбрать дистрибьютера из Нидерландов, там логин не нужен Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
