mirobest 0 17 февраля, 2020 Опубликовано 17 февраля, 2020 · Жалоба Я пытаюсь создать коннектор с 400 контактами как 10 частей (A ... J) с 40 контактами в каждой A1...A40, B1...B40 ..... Объясните пожалуйста пошагово. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
PBO 1 17 февраля, 2020 Опубликовано 17 февраля, 2020 · Жалоба 23 minutes ago, mirobest said: Я пытаюсь создать коннектор с 400 контактами как 10 частей (A ... J) с 40 контактами в каждой A1...A40, B1...B40 ..... Объясните пожалуйста пошагово. A heterogeneous device is defined as a physical package which is represented by at least two non-equivalent symbols on a DxDesigner schematic. These symbols may differ in logic function, pin count, pin labels, attributes, and number of slots. The different symbols collectively correspond to a single physical device type for layout, and sometimes correspond to a single model for simulation. The combination of identical DEVICE attribute values and HETERO attribute values on each of the non-equivalent symbols is used to implement heterogeneous device support for the PCB interfaces. The value of the HETERO attribute binds the different symbols together. Note: It is important to follow the methodology for specifying heterogeneous devices, particularly the testing phase of placing the heterogeneous symbols on a test sheet and running it through ViewPCB. This may save you significant debug time and effort when attempting to generate a PCB netlist for your entire board. There are four types of heterogeneous devices and the Type 3 Hetero is used to allow multiple symbols on the schematic to correspond to a single physical device type for layout. Note: ViewSim does not support Type 3 Hetero devices. The method for declaring your part as a heterogeneous device is as follows: Add an identical HETERO attribute to all involved symbols that contains a value that matches the form: HETERO=(symname1),(symname2),(symname3) The layout system sees a device that has pinouts that correlate to the superset of all schematic-only symbols enclosed in parentheses. Thus, the different pieces of the IC are seen as one whole. Make sure that all symbols (not instances) have the same DEVICE attribute value. Make sure that the # (pin number) attributes on each symbol indicate the number of slots that the specific symbol occupies in the device. Also, the # attribute should refer only to package pin numbers that the slot occupies. Create a prototype schematic using these symbols hooked up to nets. Run this schematic completely through ViewPCB, and examine the netlist and optional device files to evaluate the results Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
mirobest 0 17 февраля, 2020 Опубликовано 17 февраля, 2020 (изменено) · Жалоба Я безуспешно пытался сделать так : В вкладке Gates создал 10 элементов A - J Во вкладке Pins , обьявил 400 контактов с автоинкрементом в 1. Получил 400 элементов Gate A, A1 ..... Gate A, A400 Затем пытался начиная с 41 элемента менять Gate A на Gate B и перименовывать A41 в B1 и т.д 40 раз Но генерируется ошибка. Не понимаю что делать.... добавлять по одному пину в каждый из 10 Gates как то грустно.... Изменено 17 февраля, 2020 пользователем mirobest Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Gorby 6 17 февраля, 2020 Опубликовано 17 февраля, 2020 · Жалоба Дайте доку на компонент и желаемую разбивку. Завтра сделаю. Задаром. И да, магическое число 400... Это не Нвидия Джексон случайно? Вот он родимый: символ одной секции и компонент (Декаль или Футпринт это Вы сами) CONN_TEST.c CONN_TEST.p Эти файлы импортировать в библиотекаре. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Zig 31 18 февраля, 2020 Опубликовано 18 февраля, 2020 · Жалоба 9 часов назад, Gorby сказал: И да, магическое число 400... Или FMC (FPGA Mezzanine Card)? Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
mirobest 0 18 февраля, 2020 Опубликовано 18 февраля, 2020 · Жалоба https://www.molex.com/molex/products/part-detail/pcb_receptacles/0459714315 12 hours ago, Gorby said: Дайте доку на компонент и желаемую разбивку. Завтра сделаю. Задаром. И да, магическое число 400... Это не Нвидия Джексон случайно? Вот он родимый: символ одной секции и компонент (Декаль или Футпринт это Вы сами) CONN_TEST.c CONN_TEST.p Эти файлы импортировать в библиотекаре. Я только начал с PADS Logic Объясните пожалуйста шаг за шагом: файлы импортировать в библиотекаре. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Gorby 6 18 февраля, 2020 Опубликовано 18 февраля, 2020 · Жалоба 1. Run PADS Logic. 2. File->Library 3. Select desired library (usr ?) 4. Click Logic button, then Import button and select file CONN-TEST.c 5. Click Parts button , then Import button and select file CONN-TEST.p 6. Now enter * into mask input field and press Apply. You should see a new component. Берут большие сомнения в Вашей способности осилить такую задачу. Могу помочь. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
mirobest 0 18 февраля, 2020 Опубликовано 18 февраля, 2020 · Жалоба 10 секций: A, B, C, D, G, E, F, G, H, J, K и 40 контактов в каждом (A1..A40, B1..B40, ...) Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Gorby 6 18 февраля, 2020 Опубликовано 18 февраля, 2020 · Жалоба Just now, mirobest said: 10 секций: A, B, C, D, G, E, F, G, H, J, K и 40 контактов в каждом (A1..A40, B1..B40, ...) Капец. Точно Вам говорю: Вы не осилите. Забирайте два файла, импортируйте и пользуйте. Аттрибуты не забудьте заполнить. Потом БОМ автоматом выйдет. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
