Jump to content
Verilog, кошерный использование if ?
module test (input clk, a, b, output c);
logic tmp;
always @(posedge clk) begin
  tmp = a ^ b;
  c <= tmp;
end
endmodule
точнее не так
logic tmp;
  c <= pipa(a,b);
end
function automatic logic pipa (input logic data, datb);
  logic tmp;
begin
  tmp = data ^ datb;
  return tmp;
end
endfunction
endmodule
Ква 8.0 sp1.
Share this post
Link to post
Share on other sites
В оригинале второго варианта получено следующее:
Loading verilog file '/home/s-markov/work2/temp/test.v'
Detecting input file type automatically (-rtl or -netlist).
Running DC verilog reader
Reading with Presto HDL Compiler (equivalent to -rtl option).
Running PRESTO HDLC
Compiling source file /home/s-markov/work2/temp/test.v
Error:  /home/s-markov/work2/temp/test.v:3: Syntax error at or near token ';'. (VER-294)
Error:  /home/s-markov/work2/temp/test.v:10: Syntax error at or near token 'pipa'. (VER-294)
Error:  /home/s-markov/work2/temp/test.v:11: Syntax error at or near token ';'. (VER-294)
Error:  /home/s-markov/work2/temp/test.v:14: Syntax error at or near token ';'. (VER-294)
*** Presto compilation terminated with 4 errors. ***
Error: Can't read 'verilog' file '/home/s-markov/work2/temp/test.v'. (UID-59)
No designs were read
после переделки в привычный вид
module test (input clk, a, b, output reg c);
  c <= pipa(a,b);
end
function pipa;
  input data, datb;
  reg tmp;
  begin
    pipa = data ^ datb;
  end
endfunction
endmodule
чтение файла удалось:
Running PRESTO HDLC
statistics for FSM inference:
  dcfpga-flow: off
  no finite state machine inferred.
Inferred memory devices in process
    in routine test line 3 in file
|    Register Name    |   Type    | Width | Bus | MB | AR | AS | SR | SS | ST |
|        c_reg        | Flip-flop |   1   |  N  | N  | N  | N  | N  | N  | N  |
Presto compilation completed successfully.
Ну синтез, собственно, т.е. команду compile, я не запускал, ибо и так без синтеза ясно, что съедено, и схема, описанная тут, "всосана" правильно.
так, это я торможу.
После замены read_verilog на read_sverilog и первый проект в DC считался. Но, не без глюка - вместо "output c" все таки с меня стребовали "output reg c", ничего тут не сделать. А что - квартусу и слова "reg" оказалось не нужно для успешного синтеза?
Share this post
Link to post
ИМХО, пример выше не очень правильный с точки зрения блокирующего присваивания, а то заоптимизировалось в:
c<=a^b;
Так наверно будет более интересно : )
module test ( input clk, a, b,  output reg c );
reg tmp;
  tmp = a ^ b;
  c <= tmp;
end
endmodule
что скажет квартус?
Share this post
Link to post
Извиняюсь, я был не прав. DC не позволяет применять блокирующее и неблокирующее присваивание одной и той же переменной внутри одного блока always, а не просто мешать те и иные виды присваиваний. Т.е. ошибка звучит вот так :
Variable 'c' is the target of both blocking and nonblocking assignments in the same always block. (VER-134)
то есть речь вот о таком примере, перевариваемом ква без вопросов, но не перевариваемом DC:
  c  = b ^ c;
  c <= a ^ c;
end
endmodule
ЗЫ. Я сам не вижу причин ругать это еррором, но вот факт. квартус поддерживает, синопсис - нет.
Хоть убейся, не пойму, в чем отличие от варианта des00... Копия - строка в строку.
Share this post
Link to post
Не совсем.
У меня есть явно reg - к которому делается блокирующее присваивание(как промежуточный результат), а у des00 получается голая логика( без регистров) в одном из присваиваний(неявно получается assign)
Share this post
Link to post
у меня есть явно reg - к которому делается блокирующее присваивание(как промежуточный результат), а у des00 получается голая логика( без регистров) в одном из присваиваний
Это обычная синтаксическая ошибка (читай - глюк) Все то, что присваивается внутри always - должно быть регистровым типом. Т.е. вариант в виде des00 - это просто глюкавый вариант, который не компилируется по определению, а Вы исправили этот глюк, добавив слово reg после output. Что касается tmp - тип logic это тоже регистровый тип, ничем не хуже reg.
Share this post
Link to post
да нормальное описание, корявое но нормальное.
Если бы корявое - это не страшно.
А как Вы относитесь к тому, что в результате синтеза сигнал reset поступает на входы ena триггеров?
В перемежку с нормальным.
А клок один.
Share this post
Link to post
Ну я по крайней мере нормально. Так как изначально по описанию резет синхронный, то для того, чтобы резетнуть среднефпгашный триггер, нужно к приходу клока разрешить запись в него подачей единицы на ena и подать ноль на вход данных. А специальных вход sclr не везде есть, да и синтезаторы не всегда любят его юзать по прямому назначению.
Share this post
Link to post
2 des333
это же элементарно, если вы работали c VHDL там есть сигналы и переменные, в данном контексте использование
Спасибо за разъяснение, но я, наверное, неправильно выразился.  :)
У меня нет вопросов насчет того, что в итоге будет синтезировано и как работают блокирующее и неблокирующее присваивания.
Мне стало интересно почему Altera приводит данный код в своем примере, хотя одновременное использование обоих типов присваивания в одном блоке always является объектом для warning'a в Quartus:
In an always construct in a Verilog Design File (.v), you mixed blocking and non-blocking assignments. Although Verilog HDL permits you to mix both types of assignments, doing so can introduce subtle bugs into your HDL source; it can also introduce differences between the simulated behavior of the design and the synthesized netlist. In general, you should use blocking assignments in always constructs that model combinational logic and non-blocking assignments in always construct that model sequential logic.
Лично на мой взгляд такое описание затрудняет понимание кода, хотя иногда и сокращает его.
P.S. Хотя нет, вру: непонятно, зачем использовано блокирующее присваивание в этой строчке
if (count == 1)
  begin
  phaseupdown <= step;
  phasecounterselect = counter;
  count <= count + 1;
  end
Edited by des333
Share this post
Link to post
В проекте группа триггеров, по одному фронту клока. На всех подан ресет. Но одна группа -на aclr, другая на ena
Такое обычно бывает, кода не описаны сигналы в состояниях, когда это необходимо. При комбинаторике при описании автоматов лачи получаются.
Следовательно вряд ли товарищ делал то, чего хотел на самом деле.
Share this post
Link to post
На aclr? Это действительно странно. Процесс синхронный по одному клоку, резета в списке чувствительности нет, не должно быть aclr-а, никак не должно...
При комбинаторике
Да, при комбинаторике (always_comb или always @*) согласен, во избежание латчей важно описать все пути, но к имеющемуся always @(posedge smclk) это отношения не имеет, это не комбинаторный always.
Share this post
Link to post
я не анализировал. (В одном процессе по фронту клока я все условия работы счетчика один раз описываю).Скачал и посмотрел rtl
Share this post
Link to post
Насколько помню, в Quartus это даже на warning не тянет.  :)
Почему нет в списке чувствительности?
Если я правильно понял, sazh имеет в виду:
always @(posedge smclk or posedge reset)
begin
  if (reset)
    begin
      state <= do_nothing;
    end
  else
    state <= next_state;
end
Edited by des333
Share this post
Link to post
Не, аж на жирный еррор. Ради интереса проверил. По крайней мере в Q8.0
Share this post
Link to post
Учитывая следующие пункты:
1) Одновременное использование blocking and non-blocking assignments
2) Разное функциональное воздействие сигнала reset
3) Мелочи, вроде использования begin/end для обрамления одной строки кода в одном случае и не использования в другом
Мне кажется, что либо автор действительно не понимал, что пишет, либо он был очень небрежен, либо просто это коду "тысяча лет" и, в любом случае, как Coding Style от Altera его в коем случае не стоит.
Share this post
Link to post
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
  • Create New...
