sanmmm 0 April 30 Posted April 30 · Report post //////////////////////////////////////////////////////////////////// // // main_fft_twiddle_roms.v // // // This file is part of the "bel_fft" project // // Author(s): // - Frank Storm ([email protected]) // //////////////////////////////////////////////////////////////////// // // Copyright (C) 2010-2012 Authors // // This source file may be used and distributed without // restriction provided that this copyright statement is not // removed from the file and that any derivative work contains // the original copyright notice and the associated disclaimer. // // This source file is free software; you can redistribute it // and/or modify it under the terms of the GNU Lesser General // Public License as published by the Free Software Foundation; // either version 2.1 of the License, or (at your option) any // later version. // // This source is distributed in the hope that it will be // useful, but WITHOUT ANY WARRANTY; without even the implied // warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR // PURPOSE. See the GNU Lesser General Public License for more // details. // // You should have received a copy of the GNU Lesser General // Public License along with this source; if not, download it // from http://www.gnu.org/licenses/lgpl.html // //////////////////////////////////////////////////////////////////// // // CVS Revision History // // $Log$ // //////////////////////////////////////////////////////////////////// `include "bel_core/bel_fft_def.v" module main_fft_twiddle_roms (clk_i, rst_i, adr_i, rd_i, dat_o, cfg_sel_i); parameter word_width = 16; parameter config_num = 1; parameter max_awidth = 6; parameter size = 256; parameter awidth = 6; parameter file_name = "bel_rom_twiddles.dat"; parameter size2 = 256; parameter awidth2 = 6; parameter file_name2 = "bel_rom_twiddles2.dat"; parameter size3 = 256; parameter awidth3 = 6; parameter file_name3 = "bel_rom_twiddles3.dat"; parameter size4 = 256; parameter awidth4 = 6; parameter file_name4 = "bel_rom_twiddles4.dat"; input clk_i; input rst_i; input [max_awidth - 1:0] adr_i; input rd_i; output [word_width * 2 - 1:0] dat_o; input [config_num - 1:0] cfg_sel_i; reg [word_width * 2 - 1:0] rom [0:size - 1]; reg [awidth - 1:0] adr; reg [word_width * 2 - 1:0] dat_o; initial begin $readmemh (file_name, rom); end always @ (posedge rst_i or posedge clk_i) begin if (rst_i) begin adr <= 0; end else begin if (rd_i) begin adr <= adr_i; end end end generate if (config_num > 1) begin reg [word_width * 2 - 1:0] rom2 [0:size2 - 1]; initial begin $readmemh (file_name2, rom2); end if (config_num > 2) begin reg [word_width * 2 - 1:0] rom3 [0:size3 - 1]; initial begin $readmemh (file_name3, rom3); end if (config_num > 3) begin reg [word_width * 2 - 1:0] rom4 [0:size4 - 1]; initial begin $readmemh (file_name4, rom4); end always @ (cfg_sel_i or adr) begin case (cfg_sel_i) 4'b1000: begin dat_o = rom4[adr[awidth4 - 1: 0]]; end 4'b0100: begin dat_o = rom3[adr[awidth3 - 1: 0]]; end 4'b0010: begin dat_o = rom2[adr[awidth2 - 1: 0]]; end default: begin dat_o = rom[adr]; end endcase end end else begin always @ (cfg_sel_i or adr) begin case (cfg_sel_i) 3'b100: begin dat_o = rom3[adr[awidth3 - 1:0]]; end 3'b010: begin dat_o = rom2[adr[awidth2 - 1:0]]; end default: begin dat_o = rom[adr[awidth - 1:0]]; end endcase end end end else begin always @ (cfg_sel_i or adr) begin case (cfg_sel_i) 2'b10: begin dat_o = rom2[adr[awidth2 - 1:0]]; end default: begin dat_o = rom[adr[awidth - 1:0]]; end endcase end end end else begin always @ (adr) dat_o = rom[adr[awidth - 1:0]]; end endgenerate endmodule Quote Share this post Link to post Share on other sites More sharing options...
HardWareMan 10 May 8 Posted May 8 · Report post RTL Viewer вам в помощь. Quote Share this post Link to post Share on other sites More sharing options...
