Jump to content
Upgrading PI controller into a current driver for a YIG
There is a PI controller with certain AC behavior. I need to use this PI controller in order to drive a coil (current controlled oscillator) of 1.5 µH inductance. For DC behavior at 10 mV input I need 50 mA current on the coil at most. PI controller has proportional and integrator property.
How can I convert this behavior into a driver circuit?
Share this post
Link to post
Share on other sites
Что именно вы с индуктивностью делать собираетесь? Формировать ток в ней? Напряжение на выводах?
Share this post
Link to post
Hello Mackapp,I can write in russian but i will have lots of errors before I will write as I hear because I am only speaking russian.
The inductor threw which the current will flow controlles frequency (Its a current controlled oscilator which called YIG)
20mA threw the inductor will give me 5MHz .
I want to convert the AC voltage behavior of the original PI into current.I dont know what is the best configuration to do it?
I though of using NPN transistor somehow as shown below.
What do you reccomend?
Thanks.
Edited by sergey23
Share this post
Link to post
я так понимаю у него есть какая-то нагрузка, которая физически ведет себя как индуктивность. он хочет загонять в нее ток
http://www.vhfcomm.co.uk/A Simple Approach tyo YIG Oscil.pdf
sergey23, as you can see, for YIG operation you need simple DC power supply
Share this post
Link to post
Hello 1113, yes I understand ,but i need tp build a PI sort of driver.
could you help with the circuit I am trying to assemble?
Thanks.
Edited by sergey23
Share this post
Link to post
https://www.microlambdawireless.com/resources/driverappnote2.pdf
sergey23, please write in one topic everything that relates to frequency stabilization. As you can see, it is difficult for forum participants to understand what you are talking about. Preferably in the Rf&Microwave section.
Share this post
Link to post
Hello , I have recreated the circuit in the article as shown bellow and in the attached LTspice file.
I use this controller to drive a YIG in PLL , the controller gets two types of errors. DC and AC.
The PI=P+I controller handles a DC error using the I integrator and  P AC error using the proportional part.
Is there a way I could see how my controller handles these two types of error?
Thanks.
PI_driver (1).asc
Edited by sergey23
Share this post
Link to post
The THS3121 amplifier is the final driver for powering the low-impedance FM coil. The LT1028 is not designed for high output currents, its linearity quickly drops with increasing current. The PI circuit is supposed to be installed before the THS3121.
Are you sure that the LT1028 bandwidth is enough for the PI circuit? The amplifier bandwidth should be approximately 10 times larger than the calculated one. The RC element values are calculated depending on the loop transfer function.
Share this post
Link to post
Hello Rloc,I have built the driver circuit with THS3121 model as shown below in the photos and attached article.
I am not sure regarding LT1028.
What opamp you reccomend to use?
What PI circuit you reccomend to use?
How do you reccomend to connect the driver circuit with the controller?
Thanks/
YIG driver.zip
Share this post
Link to post
14 часов назад, sergey23 сказал:
More often I see AD797 and OPA211 for the bandwidth about 1Mhz.
As a first approximation, a 2nd order circuit for the voltage source is suitable, as you drew in the 1st message. But the nominal values of the RC elements must be selected depending on the loop transfer function. The calculation can be similar to the one in the following document after the "PHASE NOISE" section:
PLDRO.pdf
Share this post
Link to post
In that application your dont need any YIG driver, because frequency is constant. Try to  make PMYIG ( permanent magnet YIG) with mechanically tuned magnetic shunt. Set central frequency of YIG at external resonator frequency and close loop by FM coil.
At the other hand PLDRO ( phased locked DRO) may provide more phase noise perfomance than YIG, because Q factor of DRO is better usually.
Share this post
Link to post
55 минут назад, khach сказал:
Так у автора и задумано, разбросано кусками по разным темам.
Share this post
Link to post
2 часа назад, rloc сказал:
Автору мучается уже второй месяц с вадером (гулянием) тока основной обмотки ЖИГ. По опыту- даже крутой токовый источник keythley с 6 знаками точности этот вадер не давит, а соответственно частота гуляет и замкнуть петлю не получается. Была давно показана автору схема от старого аналогового гигатроникса ( без фапч) с одной хитрой цепью, которая к ОС по току добавляла ОС по напряжению от индуктивности обмотки. Проблема вадера сразу исчезала.
Share this post
Link to post
Hello rloc ,Thank you for the answer .So we have a driver and a PI controller ,how do you reccomend to combine these two ?
Hello Khach, what is the problem of "Vader" could you please show me the circuit that solves the "Vader" issue?
"Была давно показана автору схема от старого аналогового гигатроникса"
Thanks.
Edited by sergey23
Share this post
Link to post
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
  • Create New...
