Flood 15 January 15, 2020 Posted January 15, 2020 · Report post Давайте собирать здесь информацию о вышедших хотфиксах для версии 17.4. Fixed CCRs: SPB 17.4 HF001 11-23-2019 ======================================================================================================================================================== CCRID Product ProductLevel2 Title ======================================================================================================================================================== 2115805 ADW DBEDITOR 'BOTH' in ALT_SYMBOLS prevents correct generation of part_table.ptf 2141840 ADW FLOW_MGR EDM Flow Manager crashes on opening TDO-enabled projects on some versions of Linux 567342 ALLEGRO_EDITOR COLOR Add option under View menu for 'load color view' 720274 ALLEGRO_EDITOR COLOR Add menu option for the 'colorview load' command 2077601 ALLEGRO_EDITOR DATABASE For multi-zone flex board with one and two layers, drill legend for mechanical hole not created in one-layer zone 2151260 ALLEGRO_EDITOR DFM DFF Copper Spacing - Trace to Thru via hole false error, typically on arc segments 2157524 ALLEGRO_EDITOR DFM DFF CF sliver violation not detected when shape formed is too narrow 2163835 ALLEGRO_EDITOR DFM PCB Editor crashes on moving line in board file 2167426 ALLEGRO_EDITOR DRAFTING The diameter symbol is in front of the measurements instead of being behind 2118231 ALLEGRO_EDITOR DRC_CONSTR Crash during DRC: DBDoctor exits with error 'Illegal database pointer encountered' 2150923 ALLEGRO_EDITOR DRC_CONSTR Via at SMD fit DRC not detected with rounded rectangle pads 2119099 ALLEGRO_EDITOR EDIT_ETCH When routing to an unused suppressed via padstack, PCB Editor is not following the cline to drill constraint value 2140643 ALLEGRO_EDITOR EDIT_ETCH Crash on editing board file 2155363 ALLEGRO_EDITOR EDIT_ETCH Unable to route with Hug or Shove selected as Bubble type and unused pad suppression enabled 2157174 ALLEGRO_EDITOR EDIT_ETCH Incremental move using ix for sliding via slides via in y direction as well for Pre-select operation 2140162 ALLEGRO_EDITOR INTERACTIV Using axlAirGap(),testing with a NPTH padstack which has no pad, the coordinates are swapped in return value. 2155499 ALLEGRO_EDITOR INTERACTIV Inconsistencies while defining and adding properties to text objects 2162490 ALLEGRO_EDITOR INTERACTIV OrCAD PCB Design crashes when modifying Outline Vertex 2161517 ALLEGRO_EDITOR MULTI_USER Allegro Symphony is slow 1934516 ALLEGRO_EDITOR OTHER Show measure returns a large value for Airgap when measuring gap between a pin with null pad and another pin 2160610 ALLEGRO_EDITOR SCHEM_FTB Import netlist directory path is not saved 2162492 ALLEGRO_EDITOR SCHEM_FTB Import netlist does not remember the last/latest import directory path 2164135 ALLEGRO_EDITOR SCHEM_FTB The Import Logic form is not able to remember the Import Directory path in release 17.2-2016, HotFix 059 2166451 ALLEGRO_EDITOR SCHEM_FTB Import Logic/ Netlist does not remember import directory path in release 17.2-2016, HotFix 059 2168387 ALLEGRO_EDITOR SCHEM_FTB Import Netlist directory is not saving in design. 2168915 ALLEGRO_EDITOR SCHEM_FTB Import Logic does not remember import directory 2172195 ALLEGRO_EDITOR SCHEM_FTB Path set in 'Import directory' while performing 'File' - 'Import' -'Logic/Netlist' is not remembered 2182677 ALLEGRO_EDITOR SCHEM_FTB Import Netlist does not remember the last 'Import directory' path 2182777 ALLEGRO_EDITOR SCHEM_FTB 'File' - Import Logic/Netlist' does not remember the last 'Import directory' value 2139039 ALLEGRO_EDITOR SHAPE Same net shape to hole spacing is only detecting DRC and not voiding shape 2144493 ALLEGRO_EDITOR SHAPE Tapered Trace - 'Desired Angle' reset to default value (60) 2144663 ALLEGRO_EDITOR SHAPE Tapered shape - 'Desired Angle' reset to 60 2152607 ALLEGRO_EDITOR SHAPE Edit Shape Vertex slow to respond when degas holes are present 2166870 ALLEGRO_EDITOR SHAPE Tapered trace angle does not work 2173679 ALLEGRO_EDITOR SHAPE Taper trace does not keep the desired angle when form is closed 2136158 ALLEGRO_EDITOR STEP Update STEP Mapping Data Only should be a separate menu/command 1990594 ALLEGRO_EDITOR UI_FORMS The new browse window from Netlist Import fills in a name in the directory field 1621188 ALLEGRO_EDITOR UI_GENERAL Setup > Outlines>Design Outline should have Apply disabled in Edit mode 1699230 ALLEGRO_EDITOR UI_GENERAL Changes made in Visibility tab are lost 1833733 ALLEGRO_EDITOR UI_GENERAL Menu displays garbled text when customized for Chinese in release 17.2-2016 2156748 ALLEGRO_EDITOR UI_GENERAL Incorrect datatip display for pin without pin number 2051884 ALLEGRO_PROD_TOOLB CORE Panelization with the Productivity Toolbox is deleting design outline 2136311 APD EDIT_ETCH Hug broken in slide command 2134146 APD SHAPE Dynamic shape not voiding consistently 1711460 APD UI_GENERAL 'Help' - 'About' shows wrong design application name 2009024 ASI_SI GUI PCBSI Report file export fails on Linux 2154651 CONCEPT_HDL CORE Wire > NetGroup > Edit... crashes DE-HDL 2169550 CONCEPT_HDL CORE DE-HDL crashes on saving hierarchy for large designs 2106767 CONSTRAINT_MGR SCM Clicking Resolve in the 'Alias Property Conflict Report' does not perform any action 2162536 CONSTRAINT_MGR UI_FORMS Enabling Directly-Set filter in Physical or Spacing CSet worksheet crashes PCB Editor 2123632 F2B BOM BOM-HDL .rpt file does not adhere to settings defined 2142211 F2B BOM Unable to create comma separated BOM Report 1979056 PCB_LIBRARIAN SYMBOL_EDITOR System Capture: Filled dots are shown as circles 2104538 PSPICE AA_FLOW Distribution defined in DIST property on part is not honored 2088188 PSPICE AA_MC PSpice AA MC log file is not showing error if distribution is not defined 2104482 PSPICE AA_MC Distribution cannot be defined at the global level in assign tolerance GUI 2111593 PSPICE AA_MC PSpice Advanced Analysis MC - distribution in global tolerance window does not work 2161864 PULSE R2PLM Second publish with CPM-derived item number and cadName set to $NUMBER causes 'an item is not unique' error 1784979 SIP_LAYOUT DATABASE Results are not consistent on turning on/off the pins/vias in the Color Dialog box using the Visibility tab 2020912 SIP_LAYOUT UI_GENERAL Capture Canvas Image will not save in .jpg format, only saves in .BMP format. 2092069 SIP_LAYOUT UI_GENERAL Generic: File browser does not append selected file extension if none provided, always uses original 2144754 SYSTEM_CAPTURE DARK_THEME create variant form has dark blue on dark black background.. can't read it 2170317 SYSTEM_CAPTURE MISCELLANEOUS Custom forms do not appear in the proper size within the tool 2163119 SYSTEM_CAPTURE NEW_PROJECT Unable to place special symbols. 2166932 SYSTEM_CAPTURE SELECTION_FIL Discrepancy in the total number of objects reported in the Selection Filter 2175529 TOPXP GUI topxp doesn't give warning/error when ngnd is not connected 2176710 TOPXP GUI lost s-param checking functions for wrapped s-param model in spice block 2179306 TOPXP GUI Need to have the option for DC level shift as default 2170140 TOPXP PARALLELBUS_A Circuit/channel sim correlation does not produce output 2171205 TOPXP PARALLELBUS_A SystemSI does not allow simulations beyond 1000 bits when Spectre is used Fixed CCRs: SPB 17.4 HF002 01-10-2020 ======================================================================================================================================================== CCRID Product ProductLevel2 Title ======================================================================================================================================================== 2172317 ADW DBEDITOR Adding a property to EDM root classification does not add to the child classifications 2175654 ADW FLOW_MGR Cannot see any flow files to select in EDM flow manager 2176681 ADW FLOW_MGR Message regarding error detected in the CPM file (FM-107) on opening or creating new project 2177303 ADW FLOW_MGR Error on opening and creating new project (FM-107) 2177411 ADW FLOW_MGR Opening ECAD designs throw bad configuration error after Java upgrade to 1.8.0_231. 2178451 ADW FLOW_MGR ERROR (FM-107) on opening project 1932831 ADW LIBDISTRIBUTI fetch_dump stops responding intermittently when using HTTP over high latency networks 2175810 ADW LIBDISTRIBUTI Incomplete copy of principal.jar during lib_dist_client/fetch_dump. 2182780 ALLEGRO_EDITOR CROSS_SECTION Cross-section chart 'Draw options' - 'Layer Gradient Draw'/'Background Gradient Draw' not working properly 2182820 ALLEGRO_EDITOR CROSS_SECTION Release 17.4-2019: Color Draw - Gradients is not working in via list viewer 2165940 ALLEGRO_EDITOR DFM DesignTrue mask to trace and mask to shape checking not performing correctly 2167385 ALLEGRO_EDITOR DFM DesignTrue DFF annular ring fiducial to antipad checks not working. 2167469 ALLEGRO_EDITOR DFM DesignTrue DFM: plated slot annular ring pad to mask checks inconsistent 2167972 ALLEGRO_EDITOR DFM Thieving vias are treated as antenna vias in DesignTrue DFF copper features antenna via checks 2183231 ALLEGRO_EDITOR DFM Design performance slow when DFF checks are turned on. 2163281 ALLEGRO_EDITOR DRC_CONSTR Pad-Pad Direct Connect waived constraint reappears after DRC update 2168354 ALLEGRO_EDITOR DRC_CONSTR Differential pair static phase is yellow, but nets are routed 2167870 ALLEGRO_EDITOR DXF Compose Shape: Imported DXF shape broken into arcs 2155376 ALLEGRO_EDITOR EDIT_ETCH Unwanted cline segment is added when neighboring cline is slided 2173191 ALLEGRO_EDITOR EDIT_ETCH Cannot create unique via structure 2177943 ALLEGRO_EDITOR INTERFACES PDF Export contains extra page for bond wires 2132476 ALLEGRO_EDITOR MANUFACT Silkscreen is different for rounded rectangle pads and rectangular pads 2136257 ALLEGRO_EDITOR MANUFACT 'Clear soldermask pad' option is not working in 'Auto Silkscreen' 2146676 ALLEGRO_EDITOR MANUFACT Autosilk bug causes WARNING(SPMHA1-36): Illegal LINE identifier -- while running a symbol update 2113054 ALLEGRO_EDITOR MULTI_USER UDbidRange error in Symphony team design 2121348 ALLEGRO_EDITOR MULTI_USER Changes are not updated for some users in a team in Symphony 2161495 ALLEGRO_EDITOR MULTI_USER Symphony: Changes not saved with 'rejected by server' and 'Waiting for a UDbidRange' messages 2177830 ALLEGRO_EDITOR MULTI_USER Symphony not writing back to the master 2176609 ALLEGRO_EDITOR PAD_EDITOR Padstack Editor should be updated for Slot Hole to prevent Secondary Drill tab from being shown. 2184958 ALLEGRO_EDITOR PLACEMENT Quickplace fails to place components with the ALT_SYMBOL property 1940677 ALLEGRO_EDITOR SCRIPTS Commands in two script files executed in the incorrect order 2046472 ALLEGRO_EDITOR SCRIPTS Replay of script to set paper size in PDF OUT shows "Value for field is not legal" 2185517 ALLEGRO_EDITOR UI_FORMS Route Automatic form flicker when adding a new pass to Routing Passes tab 2188939 ALLEGRO_EDITOR UI_FORMS Visibility filters for pin numbers of chip-on-board wire bond die bump 2088685 ALLEGRO_EDITOR UI_GENERAL Memory leak and performance degradation opening 1000 .dra databases 2092690 ALLEGRO_EDITOR UI_GENERAL PCB Editor slows down during opening of 1000 databases 2160120 ALLEGRO_EDITOR UI_GENERAL When using Pop Mirror funckey, component jumps to origin in OrCAD PCB Designer 2184444 ALLEGRO_EDITOR UI_GENERAL Highlight command replaces assigned color output and Dehighlight does not get it back 2204326 ALLEGRO_EDITOR UI_GENERAL Allegro_html environment variable cross-probing behavior different in release 17.4-2019 than 17.2-2016 2194007 ALLEGRO_EDITOR VALOR Release 17.4-2019: Cannot generate ODB++ output with the Expert Suite bundle licenses 2176543 ALLEGRO_LIB_CRT CORE Variable DFA_DEV_CLASS is not being exported into the Allegro footprint 1500285 APD EDIT_ETCH 'Route' - 'Slide' performs erratically when fillets are present where the cline sizes transition 2185101 CAPTURE BACKANNOTATE Release 17.4-2019: Design Sync does not work on design with occurrence properties 2188890 CAPTURE BACKANNOTATE Design Sync not working on hierarchical designs. 2196225 CAPTURE BACKANNOTATE Unable to Design Sync Board to Schematic 2181901 CAPTURE DRC Unable to delete DRC Markers in release 17.4-2019 2186321 CAPTURE DRC 'Show DRC output' in DRC window does not remember NONE option 2190356 CAPTURE DRC Cannot delete DRC-markers in schematic 2191194 CAPTURE DRC Cannot remove DRC markers in the Design rule check GUI 2202656 CAPTURE DRC Capture release 17.4-2019: Delete existing DRCs does not work 2176603 CAPTURE NETLIST_ALLEG Differences shown in design sync dialog for a CM-enabled project even if schematic and board are in sync 2195754 CAPTURE NETLIST_ALLEG Design Sync giving the same report even if the connection exist 2172767 CONCEPT_HDL CORE DE-HDL crashes on renaming signal on an interface with a second tab with the symbol open 2174515 CONCEPT_HDL CORE No architecture declaration in the source file message while doing Generate View for Hierarchical split symbol . 2177255 CONCEPT_HDL CORE DE-HDL stops responding on Copy-Paste of properties from one instance to another 2179334 CONCEPT_HDL CORE The database version tag '<schemaVersion>' is not updated for release 17.4-2019 2173568 CONCEPT_HDL INTERFACE_DES DE-HDL crashes when drawing a wire to a netgroup 2170851 CONCEPT_HDL OTHER DE-HDL menu related message not clear 2173009 CONCEPT_HDL OTHER Launching Project Manager (projmgr.exe) takes time to get license from license server 2053288 CONSTRAINT_MGR INTERACTIV Constraint Manager: region deleted even on clicking 'NO' 1988160 CONSTRAINT_MGR OTHER Clicking on CSet link in Show Constraints form does not go to CSet in CM 2185694 CONSTRAINT_MGR OTHER Relative prop delay values in 17.4-2019 do not show pin pairs on choosing Analyze from popup on the Match Group 2187251 CONSTRAINT_MGR OTHER Constraint Manager crashes when clicking on the cell for the MAX_PARALLEL rule 2174345 CONSTRAINT_MGR SCHEM_FTB Running Import Logic on an out-of-sync board does not bring in the constraints and connectivity 2187242 CONSTRAINT_MGR UI_FORMS CSet names from the 'Value Filter' not sorted alphabetically 2195944 CONSTRAINT_MGR UI_FORMS Re-launching CM does not retain the last state 2195948 CONSTRAINT_MGR UI_FORMS UI issues with CM in release 17.4 - Expanded state of WS is not getting preserved on applying object filters. 2175399 PSPICE ENVIRONMENT PSpice AA Topics are missing from Learning Resources for release 17.4-2019 2174141 PSPICE NETLISTER Netlister not able to pass local parameter in specific case for complex hierarchical designs 2176668 PULSE UNIFIED_SEARC 3D STEP models are not downloaded for some providers 2107770 SCM NETLISTER Error (SPCOHD-198) regarding incorrect signal syntax on netlisting 2172198 SIP_LAYOUT DIE_ABSTRACT_ SiP Layout uses 25GB memory for showing IC details and does not finish command for showing details 2090037 SIP_LAYOUT INTERACTIVE Batch Layer Compare: cannot check quadrant against another symmetrical quadrant in same design using Mirror/Rotate 2175747 SIP_LAYOUT ORBITIO_IF Support component height translation between OrbitIO and Allegro layout editor 2057538 SIP_LAYOUT STREAM_IF Streaming out a design with embedded dual-sided symbol (eBar) causes inadvertent mirrored symbol in .sf file 2187945 SIP_LAYOUT STREAM_IF Stream out causes crash 2165064 SIP_LAYOUT WIREBOND Wire Bond push and shove tools not working in a constraint area. 2182331 SYSTEM_CAPTURE CROSSPROBE Cross-probe from System Capture to Allegro PCB Editor loop back issues 2167994 SYSTEM_CAPTURE EDIT_SEARCHRE Unable to edit a net name on canvas after modifying it using an external editor 2168628 SYSTEM_CAPTURE EDIT_SEARCHRE Find Results: pop-up Edit menu does not appear for user property with NULL value 2166980 SYSTEM_CAPTURE PROJECT_EXPLO Navigating signals from the Navigation viewer jumps to the project viewer 1996873 SYSTEM_CAPTURE UI Incorrect message to resolve conflict during part packaging 2168585 SYSTEM_CAPTURE UI Error message from the "Violation Window" does not resolve '%S' 2166933 SYSTEM_CAPTURE WIRING Visible net properties are not getting moved with the circuit move Quote Share this post Link to post Share on other sites More sharing options...
Flood 15 February 23, 2020 Posted February 23, 2020 · Report post Fixed CCRs: SPB 17.4 HF003 02-7-2020 ======================================================================================================================================================== CCRID Product ProductLevel2 Title ======================================================================================================================================================== 2174984 ADW DBEDITOR Local Flow Verify - Failed to verify the part due to the error null - FAILED 2180529 ADW DBEDITOR Unable to release a part - For logical part, pack type is present in chips.prt but missing in ptf 2193985 ADW PART_BROWSER Part Information Manager not displaying DRA footprints in lower-level folders 2195842 ALLEGRO_EDITOR ARTWORK Drill Symbol Triangle has an offset in Artwork 2191531 ALLEGRO_EDITOR DATABASE Export libraries cannot export package 2167460 ALLEGRO_EDITOR DFM DesignTrue annular ring SMD pin to antipad checks not working in HotFix 058 2186669 ALLEGRO_EDITOR DFM DFF check of 'Copper Spacing: Shape to Shape' should not generate DRC for shapes generated for teardrop 2184335 ALLEGRO_EDITOR EDIT_ETCH PCB Editor stops responding when routing an arc by using the 'Connect' command 2199429 ALLEGRO_EDITOR EDIT_ETCH PCB Editor stops responding when routing a cline 1744042 ALLEGRO_EDITOR GRAPHICS Unused pad suppression is not working on a few nets 2200146 ALLEGRO_EDITOR IN_DESIGN_ANA On creating groups for Return Path Analysis, PCB Editor crashes 2177214 ALLEGRO_EDITOR PAD_EDITOR Import/Export .pxml file issue: thermal data is not imported 2179169 ALLEGRO_EDITOR PLACEMENT Via array staggered not working 2183401 ALLEGRO_EDITOR SCHEM_FTB 17.4 Design sync is not working with spaces in the path 2193390 ALLEGRO_EDITOR SCHEM_FTB Capture crashes when board filename contains a space 2193886 ALLEGRO_EDITOR SCHEM_FTB Capture crashes if new layout name or path has spaces 2193896 ALLEGRO_EDITOR SCHEM_FTB Design Sync fails when there is space character in project directory 2205386 ALLEGRO_EDITOR SCHEM_FTB Capture 17.4 goes into 'not responding' mode when the design sync contains space or different characters 2206402 ALLEGRO_EDITOR SCHEM_FTB Design sync in capture stops responding if there are spaces in directory name 2207279 ALLEGRO_EDITOR SCHEM_FTB Design sync does not work. Gives error about something in session log, that is not there. 2211384 ALLEGRO_EDITOR SCHEM_FTB Design Sync fails when there is space character in project directory 2212155 ALLEGRO_EDITOR SCHEM_FTB Capture crash on creating new layout when design file path has space in it 2214652 ALLEGRO_EDITOR SCHEM_FTB Capture crash on creating new layout because of space in board filename 2199694 ALLEGRO_EDITOR SHAPE Board crashes with Shape update 2190606 ALLEGRO_EDITOR UI_FORMS Custom SKILL form display gets extended in release 17.4-2019 2190607 ALLEGRO_EDITOR UI_FORMS Property edit/assign window does not show Value column 2197816 ALLEGRO_EDITOR UI_FORMS In File > Import Logic/Netlist, TAB key selection is not working properly 2197844 ALLEGRO_EDITOR UI_FORMS Add space after the X and Y labels in the Define Grid window 2207434 ALLEGRO_EDITOR UI_FORMS GUI from SKILL routines are all truncated in release 17.4-2019 but are fine in previous releases 2213968 ALLEGRO_EDITOR UI_FORMS Issue with Property Edit - 'DYN_THERMAL_CON_TYPE ' Assign form: Form can be resized but is not dynamic 2215590 ALLEGRO_EDITOR UI_FORMS Edit property window has column with fixed size 2216405 ALLEGRO_EDITOR UI_FORMS assign window for Property Edit does not show Value column 2191455 ALLEGRO_EDITOR UI_GENERAL Alt key removes heads up display 2195848 ALLEGRO_EDITOR UI_GENERAL Panning does not work in 17.4 when pcb_autoroam environment variable is set 2205534 ALLEGRO_EDITOR UI_GENERAL Allegro editors and viewers crash if allegro_history set to 0. 2168018 ALLEGRO_PROD_TOOLB CORE PCB Design Compare - Limit check to outline extents only functionality 2172272 ALLEGRO_PROD_TOOLB CORE Placing a module in Fab panelization gives error message regarding handling nil 2163792 ALTM_TRANSLATOR PCB_EDITOR Third-party translator translating symbol names incorrectly 2079742 APD DIE_GENERATOR Die symbol property reset does not work 2200707 APD PADSTACK_EDIT Pad Editor cannot save the pad and cannot close it. 2197201 CAPTURE DRC PCB Footprint symbols in a completed 17.2 design are reported as missing in Capture Online DRC 2190454 CAPTURE NETLIST_ALLEG Cross-section layers not creating in Constraint Manager in release 17.4-2019 2191880 CAPTURE NETLIST_ALLEG Design sync is not respecting the character length limit specified in Create Netlist dialog under Setup 2195552 CAPTURE NETLIST_ALLEG Sync between Capture and PCB Editor fails if custom PCB Footprint property is used 2196312 CAPTURE NETLIST_ALLEG Design sync is not respecting the character length limit specified in Create Netlist dialog under Setup 2203680 CAPTURE NETLIST_ALLEG Netlsiting displays errors but the log file is empty 2198474 CAPTURE PCBFLOW Netrev process continuously running in background even when capture is left idle and nothing is happening 2104576 CONCEPT_HDL CORE Validating physical part information for components in design - DE-HDL stops responding for 2 minutes 2184466 CONCEPT_HDL CORE Choosing 'Rename signal' should prompt to save all pages 2186418 CONCEPT_HDL CORE Allegro Design Entry HDL crashes when run from command line 2187234 CONCEPT_HDL CORE Layer specific constraints are displayed incorrectly on the canvas 2187237 CONCEPT_HDL CORE Restrict modifying the text size of attributes on the canvas when a component is locked 2164539 CONCEPT_HDL CREFER Crefer missing when instance and part names are same 2195341 CONCEPT_HDL CREFER crefer treats all notes as left-justified in release 17.2-2016, HotFix 061 2191513 CONCEPT_HDL OTHER net_spacing_type cannot be deleted from nets 2211141 CONSTRAINT_MGR ANALYSIS CM physical - add via to from Library stops responding in release 17.4 HotFix 002 2213280 CONSTRAINT_MGR DATABASE Undesired multiple Targets set for a single Matched Group in CM 2187885 CONSTRAINT_MGR UI_FORMS Switching worksheets from "CSet Assignment Matrix" to other worksheet is slow 2195942 CONSTRAINT_MGR UI_FORMS Directive CM_FILTER_SKILL_DEFINED_PSCSETS is not working in release 17.4, HotFix 001 2175941 INSTALLATION BASE "Anyone who uses this computer (All Users)" is disabled even when the user is with Administrator privileges. 2195765 INSTALLATION BASE 'Install for all users' is grayed out while installing release 17.4-2019 2203319 INSTALLATION BASE "Anyone who uses this computer (All Users)" is disabled even when the user is with Administrator privileges. 2177200 ORBITIO LEFDEFINTERFA OrbitIO stops responding when importing Innovus created def 2180100 PSPICE LIBRARIES Incorrect search result and message for EVALAA 2166988 PULSE R2PLM Invalid credentials during login: require to close and run R2PLM 2195275 PULSE R2PLM Stale BOM is published unless BOM refresh icon is clicked 2189236 PULSE UNIFIED_SEARC "+" in part name causing errors in Search 2206626 PULSE UNIFIED_SEARC Search Providers does not allow to place parts and keeps waiting for result 2195018 SCM SETUP Adding PINUSE column to CCP crashes SCM 2187247 SIG_EXPLORER OTHER SigXPlorer crashes when launching Help > About 2188742 SIG_EXPLORER OTHER SigXPlorer cannot be launched with Aurora in release 17.4-2019 2190608 SYSTEM_CAPTURE ARCHIVER Error regarding missing cell on archiving a design 2173730 SYSTEM_CAPTURE DOCUMENTATION Application notes refer to incorrect location in release 17.4-2019 2185147 SYSTEM_CAPTURE DRC Crash while executing Tcl command 'setDRC' before opening the project 2168976 SYSTEM_CAPTURE PACKAGER RefDes conflict violation does not appear when PACK_IGNORE is removed from a part and a conflict is created 2168980 SYSTEM_CAPTURE PACKAGER RefDes disappears from the part because of PACK_IGNORE when doing a Copy/Paste Quote Share this post Link to post Share on other sites More sharing options...
