Jump to content
JK триггер на VHDL
Здравствуйте!
1. Исправьте пожалуйста, чтобы оно скомпилировалось.
2. Почему нельзя объявить сигналы в теле процедуры?
signal C_S: std_logic;
signal C_R: std_logic;
-- Company:
-- Engineer:
-- Create Date:	20:36:52 04/05/2015
-- Design Name:
-- Module Name:	laba_4 - Behavioral
-- Project Name:
-- Target Devices:
-- Tool versions:
-- Description:
-- Dependencies:
-- Revision:
-- Revision 0.01 - File Created
-- Additional Comments:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
-- Uncomment the following library declaration if using
-- arithmetic functions with Signed or Unsigned values
--use IEEE.NUMERIC_STD.ALL;
-- Uncomment the following library declaration if instantiating
-- any Xilinx primitives in this code.
--library UNISIM;
--use UNISIM.VComponents.all;
entity laba_4 is
port( J: in std_logic;
		K: in std_logic;
		C: in std_logic;
		Q: out std_logic;
		not_Q: out std_logic
end laba_4;
architecture Behavioral of laba_4 is
-----------------------RS триггер-------------------------------
procedure RSTrigger(		signal S: in std_logic;
								signal R: in std_logic;
								signal Q: out std_logic;
								signal not_Q: out std_logic
							) is
begin
	Q <= not( R or not_Q );
	not_Q <= not( S or Q );
end RSTrigger;
-----------------------синхронный RS триггер-------------------------------
procedure CRSTrigger(   signal S: in std_logic;
								signal C: in std_logic;
							) is
begin
	C_S <= S and C;
	C_R <= R and C;
	RSTrigger( C_S, C_R, Q, not_Q );
end CRSTrigger;
-----------------------двухступенчатый RS триггер-------------------------------
procedure TwoRSTrigger( signal S: in std_logic;
							  ) is
begin
	signal not_Q_S: std_logic;
	signal Q_R: std_logic;
	if( C = '1' ) then
		CRSTrigger( S, R, C, Q, not_Q );
		not_Q_S <= not_Q;
		Q_R <= Q;
	else
		CRSTrigger( not_Q_S, Q_R, C, Q, not_Q );
	end if;
end TwoRSTrigger;
-----------------------JK триггер-------------------------------
procedure JKTrigger( signal J: in std_logic;
							signal K: in std_logic;
						  ) is
begin
	signal not_Q_J: std_logic;
	signal Q_K: std_logic;
	not_Q_J <= J and not_Q;
	Q_K <= K and Q;
	TwoRSTrigger( not_Q_J, Q_K, C, Q, not_Q );
end JKTrigger;
begin
JKTrigger( J, K, C, Q, not_Q );
end Behavioral;
Share this post
Link to post
Share on other sites
Здравствуйте!
Описание портов:
CLK − вход тактовой частоты;
Reset – вход асинхронного сброса;
J – J-вход;
K – K-вход;
Q – выход.
library IEEE;
use IEEE.std_logic_1164.all;
entity JK_tr is
      port (J: in STD_LOGIC;
            K:in STD_LOGIC;
            CLK:in STD_LOGIC;
            Reset: in STD_LOGIC;
            Q: out STD_LOGIC);
end JK_tr;
architecture JK_tr of JK_tr is
      begin
      process(clk, reset) is
      variable Qint: STD_LOGIC;
      begin
      if (reset ='0') then Qint:='0';
      elsif (CLK'event and CLK ='1') then
      if (J='1' and K='1') then Qint := not(Qint);
      elsif (J='0' and K='0') then Qint:=Qint;
      elsif (J='1' and K='0') then Qint:='1';
      elsif (J='0' and K='1') then Qint:='0';
      end if; end if;
      Q<=Qint;
      end process;
end JK_tr;
Share this post
Link to post
2 Maverick
вот так, по вашей вине, ещё один не научился пользоваться гуглом...
Share this post
Link to post
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
  • Create New...
