Azatot 0 February 3, 2015 Posted February 3, 2015 · Report post Так Qsys генерит inout только для шины данных: Беру из вкладки HDL Example Qsys'а (в VHDL): component Nios1_proc is port ( clk_0 : in std_logic := 'X'; -- clk reset_n : in std_logic := 'X'; -- reset_n out_port_from_the_pio_0 : out std_logic_vector(7 downto 0); -- export tri_state_bridge_0_bridge_0_out_select_n_to_the_cfi_flash_0 : inout std_logic_vector(0 downto 0) := (others => 'X'); -- select_n_to_the_cfi_flash_0 tri_state_bridge_0_bridge_0_out_write_n_to_the_cfi_flash_0 : inout std_logic_vector(0 downto 0) := (others => 'X'); -- write_n_to_the_cfi_flash_0 tri_state_bridge_0_bridge_0_out_read_n_to_the_cfi_flash_0 : inout std_logic_vector(0 downto 0) := (others => 'X'); -- read_n_to_the_cfi_flash_0 tri_state_bridge_0_bridge_0_out_data_to_and_from_the_cfi_flash_0 : inout std_logic_vector(7 downto 0) := (others => 'X'); -- data_to_and_from_the_cfi_flash_0 tri_state_bridge_0_bridge_0_out_address_to_the_cfi_flash_0 : inout std_logic_vector(23 downto 0) := (others => 'X'); -- address_to_the_cfi_flash_0 tristate_conduit_bridge_0_out_tcm_byteenable_n_out : inout std_logic_vector(3 downto 0) := (others => 'X'); -- tcm_byteenable_n_out tristate_conduit_bridge_0_out_tcm_irq_in_in : in std_logic_vector(0 downto 0) := (others => 'X'); -- tcm_irq_in_in tristate_conduit_bridge_0_out_tcm_data_out : inout std_logic_vector(31 downto 0) := (others => 'X'); -- tcm_data_out tristate_conduit_bridge_0_out_tcm_write_n_out : inout std_logic_vector(0 downto 0) := (others => 'X'); -- tcm_write_n_out tristate_conduit_bridge_0_out_tcm_reset_out : inout std_logic_vector(0 downto 0) := (others => 'X'); -- tcm_reset_out tristate_conduit_bridge_0_out_tcm_chipselect_n_out : inout std_logic_vector(0 downto 0) := (others => 'X'); -- tcm_chipselect_n_out tristate_conduit_bridge_0_out_tcm_address_out : inout std_logic_vector(15 downto 0) := (others => 'X'); -- tcm_address_out tristate_conduit_bridge_0_out_tcm_read_n_out : inout std_logic_vector(0 downto 0) := (others => 'X') -- tcm_read_n_out ); Quote Share this post Link to post Share on other sites More sharing options...
doom13 0 February 3, 2015 Posted February 3, 2015 · Report post Взято с форума Альтеры: Connect pins #BE0, #BE1 to the same named module port pins. Connect pins A1,A2,A3 to module pins A2,A3,A4. Tie pins A8,A9 high, all remaining address pins low. IRQ and Reset connected to obvious pins. #IOR, #IOW to #RD,#WR. #ADS, AEN low, LCLK, #BE2,#BE3 high. With the address lines connected as described, your registers should be on 32bit boundaries: BASE+0,BASE+4,BASE+8,etc. As a test try to read the BSR: write 0x0003 to BASE+0xE, then you should read something like 0x339n from BASE+0xA. You may have to use 0x1C,0x14 instead of 0xE,0xA depending on if you have used any of the built-in macros to do the job. Once this works, you will know what kind of changes will be needed to the driver - mainly shift and mask. Quote Share this post Link to post Share on other sites More sharing options...
Azatot 0 February 3, 2015 Posted February 3, 2015 · Report post Взято с форума Альтеры: Попробовал так. Подключил, как написано, пишу 0х0003, читаю 0х3. Ради интереса записал 0х0007 и 0х0123, прочитал 0х7 и 0х123. По моему, не работает. А ссылку не кинете на тему альтеровского форума откуда взяли этот текст? Quote Share this post Link to post Share on other sites More sharing options...
doom13 0 February 3, 2015 Posted February 3, 2015 · Report post А ссылку не кинете на тему альтеровского форума откуда взяли этот текст? Тут смотрите. Попробовал так. Подключил, как написано, пишу 0х0003, читаю 0х3. Ради интереса записал 0х0007 и 0х0123, прочитал 0х7 и 0х123. По моему, не работает. Что-то не понял, почему не работает, что записали то и прочитали. Что не так? Quote Share this post Link to post Share on other sites More sharing options...
Azatot 0 February 4, 2015 Posted February 4, 2015 · Report post Что-то не понял, почему не работает, что записали то и прочитали. Что не так? Да что то не понятно мне. Пишу: for(i=0;i<20;i++) { IOWR_16DIRECT(LAN_BASE_ADDRESS+0xE, 14, 0x0003); reg[i]=IORD_16DIRECT(LAN_BASE_ADDRESS+i, 14); } Хочу записывая один регистр, посмотреть, что в других, включая и записанный. В reg[] после выхода из for какая то ерунда лежит. В том числе и в BASE_ADR+0xA. Пишу: IOWR_16DIRECT(LAN_BASE_ADDRESS+0xE, 14, 0x0003); reg2=IORD_16DIRECT(LAN_BASE_ADDRESS+0xA, 14); IOWR_16DIRECT(LAN_BASE_ADDRESS+0xE, 14, 0x0003); reg3=IORD_16DIRECT(LAN_BASE_ADDRESS+0xB, 14); IOWR_16DIRECT(LAN_BASE_ADDRESS+0xE, 14, 0x0003); reg4=IORD_16DIRECT(LAN_BASE_ADDRESS+0xC, 14); IOWR_16DIRECT(LAN_BASE_ADDRESS+0xE, 14, 0x0003); reg5=IORD_16DIRECT(LAN_BASE_ADDRESS+0xD, 14); Так же, по идее, как и с for, но в результате выдает: reg2=0х3 reg3=0х300 reg4=0х3 reg5=0х0 Quote Share this post Link to post Share on other sites More sharing options...
Azatot 0 February 4, 2015 Posted February 4, 2015 · Report post Исходный проект на DK-NIOS-2S60N и тексты для NiosII от 2009 года в среде QII-7.2 имеются. Serhiy_UA А Вы бы не могли поделиться этим проектом, если, конечно есть такая возможность. Я бы попробовал проц в Qsys открыть и посмотреть что куда идет. Да и ethernet софт на Ниос тоже пригодился бы. Quote Share this post Link to post Share on other sites More sharing options...
Aleksei_Rostov 0 February 18, 2015 Posted February 18, 2015 (edited) · Report post Serhiy_UA А Вы бы не могли поделиться этим проектом, если, конечно есть такая возможность. Я бы попробовал проц в Qsys открыть и посмотреть что куда идет. Да и ethernet софт на Ниос тоже пригодился бы. около года назад делал проект на аналогичной плате с ethernet'ом. Среда была насколько помню 9.1 для сборки системы использовал SOPC а не qsys. С платой шли примеры для ethernet (tcp/ip и web). В качестве основы взял пример tcp/ip, в примере через командную строку можно было светодиоды зажигать на плате Далее в SOPC разобрал этот пример. Нашел функции записи/чтения буфера и отправления пакетов. Так собрал свой проект. если еще актуально могу поднять проект и посмотреть Edited February 18, 2015 by farbius Quote Share this post Link to post Share on other sites More sharing options...
Azatot 0 February 26, 2015 Posted February 26, 2015 · Report post около года назад делал проект на аналогичной плате с ethernet'ом. Среда была насколько помню 9.1 для сборки системы использовал SOPC а не qsys. С платой шли примеры для ethernet (tcp/ip и web). В качестве основы взял пример tcp/ip, в примере через командную строку можно было светодиоды зажигать на плате Далее в SOPC разобрал этот пример. Нашел функции записи/чтения буфера и отправления пакетов. Так собрал свой проект. если еще актуально могу поднять проект и посмотреть Был бы очень благодарен, если бы могли поднять проект. Просто примеров на плату у меня не было, а найти рабочий не получается. Quote Share this post Link to post Share on other sites More sharing options...
