rom67 0 5 марта, 2018 Опубликовано 5 марта, 2018 · Жалоба вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: 035 Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
rom67 0 7 марта, 2018 Опубликовано 7 марта, 2018 · Жалоба Fixed CCRs: SPB 17.2 HF035 02-30-2018 ================================================================================ ================================================================================ CCRID Product ProductLevel2 Title ================================================================================ ================================================================================ 1873547 ADW ADW_UPREV adw_uprev resulted in incomplete footprint XML 1643895 ADW DBEDITOR Create Footprint model name is not working properly if footprint exists in local flatlib 1846400 ADW DBEDITOR 'Copy As' and 'Rename' STEP model options do not work 1868299 ADW FLOW_MGR Copy Project fails and makes Flow Manager unresponsive 1872796 ADW PART_BROWSER Part/Model Details Attributes are all empty when connected to the EDM DB 1877199 ALLEGRO_EDITOR DATABASE Purging backdrill adds bottom filmmask to vias when it is not defined in the padstack 1877219 ALLEGRO_EDITOR DRC_CONSTR Allegro Crash at DRC Update 1875528 ALLEGRO_EDITOR GRAPHICS Subclasses disappear in partition 1868364 ALLEGRO_EDITOR OTHER Translator for Layout to PCB Editor fails in release 17.2-2016 but works in 16.6 1822989 ALLEGRO_EDITOR UI_GENERAL Allegro very slow 1855275 ALLEGRO_EDITOR UI_GENERAL Allegro becomes slow if OpenGL disabled 1868803 ALLEGRO_EDITOR UI_GENERAL Infinite Cursor misbehave 1869523 ALLEGRO_EDITOR UI_GENERAL PCB Editor hangs inconsistently on axlOpenDesign 1871409 ALLEGRO_EDITOR UI_GENERAL ESC key does not function with Enable_command_window_history set 1812306 ALLEGRO_PROD_TOOLB CORE Incorrect DIFF result of PCB Design Compare 1872772 ASDA MISCELLANEOUS SDA pulls a license for 'Allegro_performance' 1877070 CAPTURE OTHER Capture redraws icons 1863624 CONCEPT_HDL CONSTRAINT_MG XNet names are changed in the designs migrated to release 17.2-2016 1866290 CONCEPT_HDL CORE variant editor/DE-DHL crashed when changing a component property 1858139 CONCEPT_HDL OTHER Slow graphic response in Windows10: Icons redraw 1872703 CONCEPT_HDL OTHER Icon and toolbar in DE-HDL keeps on refreshing for every command 1873949 CONCEPT_HDL OTHER DE-HDL user interface refreshes frequently 1871542 CONSTRAINT_MGR INTERACTIV Extracting object with 'Referenced ECSet' does not inherit T-points from the applied ECSet 1868812 CONSTRAINT_MGR UI_FORMS Cannot Save Log File from CM ECSet Audit. 1878574 ECW PROJECT_MANAG Duplicate entries are created in SharePoint users list while creating project on SSO setup 1878619 ECW PROJECT_MANAG Too many mails generated on doing create project 1862772 ECW TDO-SHAREPOIN Logical BOM file name not displayed in Changed Files of Pulse Activity Log. 1860641 INSTALLATION DOWNLOAD_MGR Download Manager remembers credential settings 1867195 INSTALLATION DOWNLOAD_MGR Download manager crash 1872187 SIP_LAYOUT DRC_CONSTRAIN Sliding a cline removes DRC markers but updating DRC shows more DRC markers Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
rom67 0 19 марта, 2018 Опубликовано 19 марта, 2018 · Жалоба вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: 036 Fixed CCRs: SPB 17.2 HF036 03-16-2018 ================================================================================ ================================================================================ CCRID Product ProductLevel2 Title ================================================================================ ================================================================================ 1880209 ADW DBEDITOR DBEditor quick search is resetting the check boxes in the Attributes tab 1880376 ADW DBEDITOR Allegro EDM Database Editor wildcard search functionality broken after installing hotfix 034. 1855444 ALLEGRO_EDITOR DATABASE PCB Editor crashes on creating MDD files after deleting subclasses 1863478 ALLEGRO_EDITOR DATABASE PCB Editor crashes on a specific machine when loading any .mdd file 1875544 ALLEGRO_EDITOR SCHEM_FTB Constraints are getting removed 1719683 ALLEGRO_EDITOR UI_GENERAL Incorrect display when using infinite cursor. 1765989 ALLEGRO_EDITOR UI_GENERAL Selection window does not work correctly with infinite cursor option checked 1885667 ALLEGRO_EDITOR UI_GENERAL Infinite cursor is not working correctly 1873954 ASDA IMPORT_DEHDL_ SDA: Inconsistent pin number positions on part in an imported DE-HDL project 1873883 ASDA NEW_PROJECT SDA: New project from DE-HDL creates blank Page 1 1852036 ASDA VARIANT_MANAG Design with variant cannot generate a variant BOM 1875549 CONCEPT_HDL CORE Incorrect PART_NUMBER/VALUE properties on schematic 1881848 CONCEPT_HDL OTHER License issue: Cannot open Allegro Design Authoring and unable to choose options and features 1872189 CONSTRAINT_MGR CONCEPT_HDL Pin-pairs are created for incorrect members of differential pair after ECSet is applied 1880235 CONSTRAINT_MGR UI_FORMS Ability to lock auto-generated Constraint Set in UI 1868711 CONSTRAINT_MGR XNET_DIFFPAIR Nets are dropped from XNets on the BRD file in the front-to-back flow 1879296 ECW PROJECT_MANAG Mode to remove Uprev Lock from locked webs in admin keys 1881632 PSPICE SLPS PSpice creates 'psp_input.log' during co-simulation flow 1879302 SCM OTHER SCM crashes when global nets are changed in the Block Packaging Options dialog box 1879580 TDA SHAREPOINT GetData error when opening a project in Design Data Management Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
rom67 0 3 апреля, 2018 Опубликовано 3 апреля, 2018 · Жалоба вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: 037 Fixed CCRs: SPB 17.2 HF037 03-30-2018 ================================================================================ ================================================================================ CCRID Product ProductLevel2 Title ================================================================================ ================================================================================ 1886573 ALLEGRO_EDITOR IN_DESIGN_ANA Fail to launch Sigrity executable from release 17.2-2016 1891113 ALLEGRO_EDITOR NC Clubbing total backdrill layerwise data 1886085 ALLEGRO_EDITOR SHAPE Line to Thru Via DRC is not displayed automatically 1850888 ALLEGRO_PROD_TOOLB CORE Design Compare crashes immediately after execution 1639079 ALTM_TRANSLATOR CAPTURE Title block issues with third-party design 1722577 ALTM_TRANSLATOR CAPTURE Third-party translator does not work in Capture in release 17.2-2016 if CDSROOT is not defined 1744697 ALTM_TRANSLATOR CAPTURE Third-party translator crashes 1820160 ALTM_TRANSLATOR CAPTURE Title block does not show ghost image when selecting it for placement 1628560 ALTM_TRANSLATOR PCB_EDITOR Third-party translation to PCB Editor not working properly 1836750 ALTM_TRANSLATOR PCB_EDITOR Third-party translator fails to translate a complete design 1844423 ALTM_TRANSLATOR PCB_EDITOR Third-party translation takes a long time in release 17.2-2016 1849338 ALTM_TRANSLATOR PCB_EDITOR Third-party translated board not correct 1894607 CONCEPT_HDL CORE Closing CM during 'Save Hierarchy' crashes DE-HDL 1703351 CONSTRAINT_MGR CONCEPT_HDL SigXplorer shows invalid models instead of default models in extracted topology 1868687 CONSTRAINT_MGR CONCEPT_HDL DML-independent flow: some pin-pairs missing for Differential Pair XNets when migrating 16.6 design to 17.2 1868747 CONSTRAINT_MGR CONCEPT_HDL Additional pin-pairs created on migrating design to release 17.2-2016 DML-Independent flow 1887794 CONSTRAINT_MGR OTHER Ability to disable cross-section changes in F2B flow 1859193 MODEL_EDITOR TRANSLATION DML provided by Model Integrity has a parsing error: curve must start at time zero Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
rom67 0 3 мая, 2018 Опубликовано 3 мая, 2018 · Жалоба вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: 038 Fixed CCRs: SPB 17.2 HF038 04-27-2018 ================================================================================ ================================================================================ CCRID Product ProductLevel2 Title ================================================================================ ================================================================================ 1861616 ADW TDO-SHAREPOIN Team Design Option requires Allegro_ECAD_Collab_Workbench license feature 1784170 ALLEGRO_EDITOR 3D_CANVAS Allegro 3D Canvas does not show the flex zone thickness correctly 1801053 ALLEGRO_EDITOR 3D_CANVAS Moving component in 3D Canvas does not move the pads 1805038 ALLEGRO_EDITOR 3D_CANVAS Soldermask and drill not refreshed when component is moved in 3D Canvas, or on the board with Canvas open 1808579 ALLEGRO_EDITOR 3D_CANVAS 3D Canvas displays annular ring incorrectly 1816732 ALLEGRO_EDITOR 3D_CANVAS Mismatch in shape width between board and 3D Canvas 1822778 ALLEGRO_EDITOR 3D_CANVAS 3D Canvas does not display nets when selection is done through click drag 1838129 ALLEGRO_EDITOR 3D_CANVAS User is not able to create a pastemask layer that is visible in 3D Canvas 1842911 ALLEGRO_EDITOR 3D_CANVAS Etch shapes not visible in the 3D Canvas when invoked from a symbol drawing 1849380 ALLEGRO_EDITOR 3D_CANVAS Mirrored components placed in flex zones are not displayed in the 3D Canvas 1851898 ALLEGRO_EDITOR 3D_CANVAS STL export from 3D Viewer scales it up by 100 1853378 ALLEGRO_EDITOR 3D_CANVAS The new interactive 3D Canvas has a display issue with the off-centered drills. 1859713 ALLEGRO_EDITOR 3D_CANVAS PLACE_BOUND shape with package_height_max and package_height_min set displayed incorrectly in 3D Canvas 1880073 ALLEGRO_EDITOR 3D_CANVAS Design Outline is not displayed correctly in 3D Canvas 1880338 ALLEGRO_EDITOR 3D_CANVAS Step Model missing in interactive 3D canvas. 1881889 ALLEGRO_EDITOR 3D_CANVAS Changing the color of STEP model in STEP Mapping Window does not display this color in 3D Canvas. 1889861 ALLEGRO_EDITOR 3D_CANVAS 3D Canvas swaps padstack from Bottom to Top 1830749 ALLEGRO_EDITOR ARTWORK Gerber 4x and 6x output do not fill the shape 1848514 ALLEGRO_EDITOR COLOR axlVisibleDesign does not interact with wirebonds 1837388 ALLEGRO_EDITOR CROSS_SECTION Cannot add solder mask to the site layer mask file 1859797 ALLEGRO_EDITOR CROSS_SECTION The Report only option does not work when choosing Setup - Cross-section - Import - IPC2581 1877858 ALLEGRO_EDITOR CROSS_SECTION Dynamic Pads Suppression option is not working correctly 1880093 ALLEGRO_EDITOR CROSS_SECTION Unused Pad Suppression options are not working correctly and are reset on opening cross-section 1886283 ALLEGRO_EDITOR CROSS_SECTION Unable to turn on 'Dynamic Unused Pads Suppression' 1890959 ALLEGRO_EDITOR CROSS_SECTION Dynamic Pads Suppression option is not working correctly 1900397 ALLEGRO_EDITOR CROSS_SECTION Dynamic Unused Pad Suppression option in Cross-section not working at one go. 1905315 ALLEGRO_EDITOR CROSS_SECTION 'Dynamic Unused Pad Suppression' cannot be turned on. 1861406 ALLEGRO_EDITOR DATABASE Refresh symbol for flex zone not mapping padstack layers correctly 1877132 ALLEGRO_EDITOR DATABASE Fail to open #Taaaaed17598.tmp file and save database 1883747 ALLEGRO_EDITOR DATABASE PCB Editor crashes on stackup modification 1860238 ALLEGRO_EDITOR DFM Applying a DFF constraint set closes PCB Editor instantly 1872780 ALLEGRO_EDITOR DFM DFF false pin to via DRCs: Copper Spacing, SMD pin Pad to Thru Via pad 1823912 ALLEGRO_EDITOR DRC_CONSTR Thru pin to Thru pin DRC between Symbol Pin to Mechanical Hole (with NO regular pad) 1828168 ALLEGRO_EDITOR DRC_CONSTR Upgrading from release 16.3 to 17.2-2016: Differences in spacing constraints 1844780 ALLEGRO_EDITOR DRC_CONSTR Mechanical Pin to Shape Air Gap value is reduced when updating shape 1845011 ALLEGRO_EDITOR DRC_CONSTR When upgrading from 16.6 to 17.2, Spacing constraints for shape to mechanical pin not being resolved properly 1861548 ALLEGRO_EDITOR DRC_CONSTR Inconsistent Micro via to Micro via drill to drill overlap DRCs 1862281 ALLEGRO_EDITOR DRC_CONSTR Mechanical Pin/hole to Shape spacing too small 1887145 ALLEGRO_EDITOR DRC_CONSTR Mechanical pin to conductor spacing setting is overriding constraint region in release 17.2-2016 1893012 ALLEGRO_EDITOR DRC_CONSTR Shape voiding not taking the shape to hole spacing rules for NPTH 1906840 ALLEGRO_EDITOR GRAPHICS Context menu stays when PCB Editor is minimized. 1738624 ALLEGRO_EDITOR INTERACTIV 'Invalid Sector' error when saving psm file for symbol that has die pads, which are copied 1800741 ALLEGRO_EDITOR INTERACTIV Search in User Preferences Editor is giving incorrect results 1812530 ALLEGRO_EDITOR INTERACTIV PCB Editor crashes when opening a file that is in an unsupported format 1812570 ALLEGRO_EDITOR INTERACTIV PCB Editor hangs when an invalid pin number value is specified as the rotation point in the symbol preselect mode 1826819 ALLEGRO_EDITOR INTERACTIV 'Route - Resize/Respace - Align Vias' menu is not available 1842645 ALLEGRO_EDITOR INTERACTIV Via align command is missing from the menu path 1845748 ALLEGRO_EDITOR INTERACTIV With 'Shape - Change Shape Type' enabled, changing visibility reverts the Shape Fill selection to dynamic copper. 1849700 ALLEGRO_EDITOR INTERACTIV Add the reason for generating DBFIX_PAD, to the dbdoctor.log. 1860934 ALLEGRO_EDITOR INTERACTIV Auto-Paste environment variable is not working as it should 1861928 ALLEGRO_EDITOR INTERACTIV Provide a Persistent snap pick option for Display - Measure 1864238 ALLEGRO_EDITOR INTERACTIV Shape place rectangle issue: Dimension of placed rectangle changes on cancelling action 1877026 ALLEGRO_EDITOR INTERACTIV Filled rectangles on ETCH/TOP and ETCH/BOTTOM are not getting copied 1881637 ALLEGRO_EDITOR INTERACTIV Radius of Shape changes when trying to place circle using Place Circle mode. 1883032 ALLEGRO_EDITOR INTERACTIV Find by Query does not find all padstacks in a symbol drawing 1855248 ALLEGRO_EDITOR INTERFACES The Technology Dependent Footprint command returns an error 1885716 ALLEGRO_EDITOR INTERFACES Increase supported STEP model size to enable the use of models larger then 500MB 1860835 ALLEGRO_EDITOR MANUFACT Display a message when backdrill_max_pth_stub is defined for vias or pins only 1869528 ALLEGRO_EDITOR MANUFACT Backdrill out of date when deleting Teardrop and Sliding cline with Teardrop 1885672 ALLEGRO_EDITOR NC NC drill is creating false backdrills when repeat code is turned on in release 17.2-2016 1895084 ALLEGRO_EDITOR NC Padstacks with backdrill data trigger backdrill out-of-date even if the board is not set up for backdrilling 1837514 ALLEGRO_EDITOR PAD_EDITOR Offset is not consistent for keepout and mask layers in padstack editor. 1842902 ALLEGRO_EDITOR PAD_EDITOR Scrolling through the .pad files in the Library Padstack Browser displays Error(SPMHA1-161) 1846504 ALLEGRO_EDITOR PAD_EDITOR COVERLAY_TOP definition lost while opening and saving a 16.6 pad in 17.2 padstack editor 1879453 ALLEGRO_EDITOR PAD_EDITOR The 'Y' tolerance in the Padstack Editor does not update when changing the units of the padstack. 1805202 ALLEGRO_EDITOR PLACEMENT Place via array adds via on differential pairs incorrectly 1806675 ALLEGRO_EDITOR PLACEMENT Place - Manually - Quickview displays the Assembly Top details only 1835177 ALLEGRO_EDITOR PLACEMENT Can place symbol even after cancelling copy by choosing 'Oops' from pop-up 1846892 ALLEGRO_EDITOR PLOTTING PCB Editor Export PDF does not show lines correct for certain component 1006328 ALLEGRO_EDITOR SHAPE Static shapes should void around corners as dynamic shapes do 1033326 ALLEGRO_EDITOR SHAPE Cannot compose lines to shape 1045089 ALLEGRO_EDITOR SHAPE Dynamic shape voiding is inconsistent for solid and xhatch shape fill type 1069959 ALLEGRO_EDITOR SHAPE Compose shape crashes PCB Editor 1085907 ALLEGRO_EDITOR SHAPE Pad does not get thermal connections to shape if outside of the shape outline by more than DRC spacing. 1143563 ALLEGRO_EDITOR SHAPE The pin void inline clearance does not seem to dynamically update the shape and requires a 'force update'. 1243688 ALLEGRO_EDITOR SHAPE shape_rki_autoclip fails to clip shape to route keepin 1269069 ALLEGRO_EDITOR SHAPE Shape void not working properly in release 16.5 hotfix 054 1327755 ALLEGRO_EDITOR SHAPE Need the ability to nest dynamic shapes on different nets partially or entirely 1417394 ALLEGRO_EDITOR SHAPE Shape not updating correctly 1430742 ALLEGRO_EDITOR SHAPE When adding fillet to an irregular pad, the fillet might not be added or be strangely shaped 1750760 ALLEGRO_EDITOR SHAPE Shape to Route Keepout DRC for a void that meets route keepout 1793898 ALLEGRO_EDITOR SHAPE Add teardrops fails to add anything with different settings 1811662 ALLEGRO_EDITOR SHAPE 'show measure' gives incorrect air gap value between two pins 1820901 ALLEGRO_EDITOR SHAPE The pins on adjacent layers are voided as Rounded Rectangle instead of Rectangular as defined in padstacks 1829570 ALLEGRO_EDITOR SHAPE Display measure airgap value is very large 1858696 ALLEGRO_EDITOR SHAPE The via to the edge of the board is not connecting to shape even with the PAD_SHAPE_TOUCH_CONNECTION property added 1873384 ALLEGRO_EDITOR SHAPE Boolean AND operation returning nil 1873860 ALLEGRO_EDITOR SHAPE Copper shape does not respect route keepout 1889312 ALLEGRO_EDITOR SHAPE Shape voided for net vias on adding 'PAD_SHAPE_TOUCH_CONNECTIONS' when enabling via suppression 1890702 ALLEGRO_EDITOR SHAPE Not able to add teardrop in release 17.2-2016 1892692 ALLEGRO_EDITOR SHAPE Thermal relief connections being added to static shapes present in the void inside Dynamic Shapes 1893492 ALLEGRO_EDITOR SHAPE 'merge shapes' results in moved void 1896543 ALLEGRO_EDITOR SHAPE Same net pin will not add thermal connection to shape if it is a rotated slot in the symdef 1897645 ALLEGRO_EDITOR SKILL axlCNSGetSpacing() returns nil if active class is non-etch. 1822364 ALLEGRO_EDITOR UI_FORMS Design Parameters dialog disappears if prmed is called while show measure is active 1834395 ALLEGRO_EDITOR UI_FORMS Setup menu of OrCAD PCB Editor is missing the Anchor 3D View command 1838941 ALLEGRO_EDITOR UI_FORMS Anchor 3D View command is not available in OrCAD PCB Editor Setup menu 1716433 ALLEGRO_EDITOR UI_GENERAL Alias keys do not work until mouse scroll key is activated 1721761 ALLEGRO_EDITOR UI_GENERAL During manual placement of symbols, hovering over symbols does not highlight them 1732915 ALLEGRO_EDITOR UI_GENERAL Alias does not work in release 17.2-2016 when switching windows 1770723 ALLEGRO_EDITOR UI_GENERAL Funckey does not work if focus is not on canvas in release 17.2-2016 1793839 ALLEGRO_EDITOR UI_GENERAL Function Key does not work if a form is opened by a previous command 1813961 ALLEGRO_EDITOR UI_GENERAL Inconsistent file formats available when saving reports 1816716 ALLEGRO_EDITOR UI_GENERAL Shortcut not working when using working layer with 'add connect' 1864321 ALLEGRO_EDITOR UI_GENERAL Funckeys not being registered after focus has moved to other window and back again in PCB Editor 1865010 ALLEGRO_EDITOR UI_GENERAL PCB Editor does not get focus when clicking shortcut after switching from any other program or application 1868708 ALLEGRO_EDITOR UI_GENERAL Allegro PCB Editor, funckeys stop working intermittently in release 17.2-2016, hotfix 032 1869745 ALLEGRO_EDITOR UI_GENERAL Allegro 3D Canvas window becomes active on pointing at minimized icon on taskbar 1869860 ALLEGRO_EDITOR UI_GENERAL Hotkeys no longer functional on switching from PCB Editor to another application and then back again 1870744 ALLEGRO_EDITOR UI_GENERAL Need html extension added to Save pull down menu. 1870996 ALLEGRO_EDITOR UI_GENERAL If you switch from one active window to other, hotkeys stop working 1883507 ALLEGRO_EDITOR UI_GENERAL Hotkeys stop working after Allegro PCB Editor UI window is opened 1886981 ALLEGRO_EDITOR UI_GENERAL Focus lost from layout when switching between PCB Editor and Capture 1887519 ALLEGRO_EDITOR UI_GENERAL Release 17.2-2016, hotfix 034: Shortcuts defined using funckeys not working correctly 1887660 ALLEGRO_EDITOR UI_GENERAL Alias does not work in release 17.2-2016 when switching windows. 1891204 ALLEGRO_EDITOR UI_GENERAL PCB Editor crashes if SKILL form is closed using the Close icon ('X') 1898059 ALLEGRO_EDITOR UI_GENERAL Funckey commands are not working consistently in release 17.2-2016 1902322 ALLEGRO_EDITOR UI_GENERAL Cannot use funckey commands when cross-probing 1905906 ALLEGRO_EDITOR UI_GENERAL Issue with keys and focus when navigating between windows 1913768 ALLEGRO_EDITOR UI_GENERAL Uppercase funckey shortcuts do not work 1751586 APD OTHER axlGetMetalUsageForLayer() for etch returns value including pins and vias 1863241 APD SHAPE Fillet is left on the T-Point without Cline(center) connection. 1894438 APD STREAM_IF APD/SiP Layout: Export rounded features as circumscribed and not inscribed polygon in GDS 1812699 ASDA AUTOMATION Enhance the performance when extracting data from SDA, using TCL functions 1863436 ASDA CANVAS_EDIT alignment guides are not displayed when placing or copy a part, only when moving. They are most needed during placement 1863445 ASDA CANVAS_EDIT dark theme blue text in docked CM needs to be a different color. difficult to read 1802111 ASDA DARK_THEME Dark theme in SDA should also change the border line color and text color of grid references: they are still black 1869951 ASDA EXPORT_PCB File browser button in Export to PCB Layout flashes graphics of the window behind the form 1845831 ASDA FORMAT_OBJECT Width of the twisted pair of wire should automatically be set to 6, otherwise it is not drawn correctly 1879914 ASDA INTERNATIONAL Using French Keyboard cannot use the . (point) delimiter to set VOLTAGE property value 1865753 ASDA MISCELLANEOUS Inconsistent and non-ideal behavior in SDA product choice dialog, small box, hard to check unlike the bottom box 1863457 ASDA PACKAGER globaly unset all user assigned references 1889301 ASDA TDO SDA TDO Crashes when switching to/from Offline mode 1823203 ASDA VARIANT_MANAG Variant setting part to not present does not do anything 1823992 ASDA VARIANT_MANAG Variant Editor fails to read netlist if a net is named NC 1863451 ASDA VARIANT_MANAG variant mode can select multiple parts to add to variant but can't select multiple parts to hit reset 1863455 ASDA VARIANT_MANAG Cant resize any panales in variant view mode 1874952 ASDA VARIANT_MANAG Letter I in the alternate part icons in variant spreadsheet should be white for readability 1878401 ASDA VARIANT_MANAG SDA Variant Display - DNI marker color switches between black and red 1877239 ASDA WORKSPACE SDA DRC window is hidden if undocked and minimized 1809605 CAPTURE LIBRARY Part has pins in the incorrect order in the Connectors library 1638693 CAPTURE OTHER Capture Footprint Viewer not showing footprint. 1873612 CONCEPT_HDL COPY_PROJECT Copy project causes nets to be added to net groups and ports - fails to package due to mismatch 1779289 CONCEPT_HDL CORE Adding a component and wire and saving the design results in a 'Connectivity save failed' error 1878719 CONCEPT_HDL CORE Cannot enable or apply block variants at the top-level in a hierarchical design. 1865480 CONCEPT_HDL OTHER 'partmgr -ptfMode shoppingCart' cannot output cell name with project ptf file into shoppingCart.xml 1829966 CONSTRAINT_MGR CONCEPT_HDL DML independent flow: Export Physical audits missing signal models in release 17.2 1904458 CONSTRAINT_MGR ECS_APPLY 'Audit - ECSets' crashes DE-HDL in release 17.2-2016, Hotfix 037 1798269 CONSTRAINT_MGR OTHER Script changes '-' in layer name to '_' 1835520 CONSTRAINT_MGR OTHER Cannot add members to netclass name with parenthesis 1896638 CONSTRAINT_MGR OTHER Constraint Manager worksheets jump abruptly 1801938 CONSTRAINT_MGR UI_FORMS Add To Netclass window: Focus not on ClassSelection 1854060 CONSTRAINT_MGR UI_FORMS Using the tab key in the Manufacturing workbook jumps a cell 1881832 ECW ROLES_PERMISS Adding Users in SSO environment using PS is error prone 1864870 F2B BOM Incomplete BOM report generated 1846578 PCB_LIBRARIAN GRAPHICAL_EDI radio buttons and clickable buttons are hidden in the UI for verify rules 1854080 PCB_LIBRARIAN METADATA con2con needs to support special characters in Primitive Name 1796377 PCB_LIBRARIAN SYMBOL_EDITOR Unable to move pins using arrows when symbol is opened in Symbol Editor 1839692 PCB_LIBRARIAN SYMBOL_EDITOR Properties tab grayed out in Symbol preview window 1865657 PCB_LIBRARIAN SYMBOL_EDITOR Cannot change symbol properties using the General tab 1906888 PCB_LIBRARIAN SYMBOL_EDITOR Properties button in Symbol Pins tab of the Symbols section is inactive. 1891248 PCB_LIBRARIAN SYMBOL_EDITOR Copy and mirror arc drawing object in the new Symbol Editor results in wrong arc on opening symbol in DE-HDL 1908381 PDN_ANALYSIS PCB_STATICIRD Allegro PCB PDN Analysis crashes after performing analysis and saving result in release 17.2-2016 1825087 PSPICE AA_OPT Graph view menu does not appear when we use 'Curve Fit' in Optimizer. 1808091 PSPICE ENVIRONMENT 'orSimSetup' crashes when 'Restart Simulation' is selected 1811782 PSPICE ENVIRONMENT Setup Simulation Profile no longer enables Advanced Markers when appropriate 1834147 PSPICE ENVIRONMENT PSpice Part Search library icons not displayed if product is installed in the Program Files folder in release 17.2-2016 1841992 PSPICE FRONTENDPLUGI Getting a blank Error dialog while adding a marker 1858574 PSPICE NETLISTER PSpice simulation: Some models cannot be used after upgrading to release 17.2-2016 1865022 PSPICE NETLISTER The division operator is not recognized by PSpice in DEV expressions in release 17.2-2016 1677119 PSPICE PROBE PSpice crashes when plotting simulation message summary 1837046 PSPICE PROBE On Windows 10, PSpice crashes on clicking Yes to see message 1879387 PSPICE PROBE PSpice crashes when we choose to plot simulation message summary 1842231 PSPICE SIMULATOR Wrong results in PSpice Advanced Analysis for DC Sweep Analysis 1843446 PSPICE SIMULATOR Distribution type is not showing under Assign Tolerance window for transistor 1872630 RF_PCB ROUTING Transition taper length does not work in route- Add RF trace 1872636 RF_PCB ROUTING Inherit Width parameter in Route -RF trace only uses width of one side 1872644 RF_PCB ROUTING Regression RF trace: change in trace width not retained while routing 1901201 SIP_LAYOUT EXTRACT extracta is not retaining custom layer names 1813380 SIP_LAYOUT OTHER Layer Compare is not adding the required shapes 1852762 SIP_LAYOUT OTHER Error generated in Package Design Integrity Check when adding soldermask to my design 1886847 SIP_LAYOUT REPORTS Incorrect metal area in metal usage report 1491315 SIP_LAYOUT SHAPE Dynamic shape filling exceeds the shape boundary on running 'create bounding shape' command 1853989 SIP_LAYOUT SHAPE 'Shape - Select' and then' Move' from pop-up with ix 500 iy 0 moves shape diagonally 1868509 SPECCTRA PARSER Autorouter takes long time to invoke 1869317 SYSTEMSI ENG_PBA SystemSI PBA does not align correlation waveforms correctly on Linux platform Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
copov 2 7 мая, 2018 Опубликовано 7 мая, 2018 · Жалоба Очень мощное обновление Cadence Allegro Editor и PSpice и распухло на 300 Мб по сравнению с предыдущим. Нужны ли какие-нибудь дополнительные FEATURE в файл лицензии? Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
rom67 0 15 мая, 2018 Опубликовано 15 мая, 2018 · Жалоба вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: 039 Fixed CCRs: SPB 17.2 HF039 05-11-2018 ================================================================================ ================================================================================ CCRID Product ProductLevel2 Title ================================================================================ ================================================================================ 1915149 ADV_PKG_ROUTER OTHER Auto-connect fails to initialize when rats are selected, but works with bundle 1870109 ADW ADW_UPREV Most mandatory properties turned into optional properties following database uprev 1758396 ADW CONF Server Memory setting in setting.ini is lost if server is re-configured using Conf 1911591 ADW FLOW_MGR Flow Manager does not start on high latency (> 25ms) networks: displays Java Content Disabled dialog 1887861 ADW LIBIMPORT Library Consolidation reports front2back issues but does not provide information about the issues. 1778977 ADW REPORT_GENERA reportgen memory setting too high in release 17.2-2016 resulting in launch failure 1900422 ADW REPORT_GENERA Save in reportgen does not save Preferred Part List entry into .rep file 1903888 ADW REPORT_GENERA Report generator not outputting values as expected for PPL field 1916903 ADW REPORT_GENERA Reportgen -gui is not producing the expected result 1902184 ALLEGRO_EDITOR DATABASE Add connect in package symbol crashes PCB Editor when using the 'clearance_view' variable 1914793 ALLEGRO_EDITOR DATABASE Updating shape crashes Allegro PCB Editor 1905138 ALLEGRO_EDITOR DRC_CONSTR Max Via count DRC disappears on running DRC update 1848015 ALLEGRO_EDITOR MANUFACT Export Creo View cannot find the webpage on the PTC site 1850553 ALLEGRO_EDITOR MANUFACT 'File - Export - Creo View' is not working 1853960 ALLEGRO_EDITOR MANUFACT PTC Creo Interface link is broken 1862305 ALLEGRO_EDITOR MANUFACT PTC Creo interface link is not working 1878682 ALLEGRO_EDITOR MULTI_USER Delay in Symphony server session when server is started from Allegro PCB Editor 1890108 ALLEGRO_EDITOR MULTI_USER Database rejections in Symphony 1887331 ALLEGRO_EDITOR NC Milling (NC route) in Gerber tools is not the same as what it is in the board. 1898179 ALLEGRO_EDITOR RAVEL_CHECKS PCB High-Speed option required for high-speed rules when Venture license is selected 1461142 ALLEGRO_EDITOR SHAPE Pin with nearly-tangent via fails to generate void in dynamic shape, results in short. 1863467 ASDA CROSSPROBE Highlighting all parts in PCB Editor does not highlight all parts in SDA 1910974 ASDA CROSSPROBE Cross-probing between SDA and PCB Editor does not work 1904440 CONCEPT_HDL CORE SPCOCD-577 error on migrating from release 16.6 to release 17.2-2016 1909611 CONCEPT_HDL CORE DE-HDL stops responding on running '_movetogrid' and clicking 'No' 1808743 CONCEPT_HDL PDF Inconsistent display of Publish PDF hyperlinks 1894868 CONCEPT_HDL PDF XREFs getting clipped in the Published PDF 1911676 CONSTRAINT_MGR CONCEPT_HDL DE-HDL Constraint Manager crashes on selecting ECSet and then creating pin-pair option 1913968 CONSTRAINT_MGR CONCEPT_HDL Match Group pin-pairs are not created on applying ECSet to differential pair 1899638 CONSTRAINT_MGR XNET_DIFFPAIR Differential pair buffer models are extracted differently in release 17.2-2016 and release 16.6 1914116 ORBITIO ALLEGRO_SIP_I Unable to import OrbitIO file to SiP Layout 1896487 PCB_LIBRARIAN GRAPHICAL_EDI Use lower-case characters for notes and pin text in New Symbol Editor 1898008 PCB_LIBRARIAN SYMBOL_EDITOR Styling is not available for custom shape and pins. 1644787 PSPICE FRONTENDPLUGI PSpice Model Search window does not show complete library path 1785939 PSPICE FRONTENDPLUGI PSpice Part Search library browser should display path of the library directories 1855867 PSPICE FRONTENDPLUGI PSpice Model Search window does not show complete library path 1887016 PSPICE SIMULATOR Pseudotran should always be invoked first time in case autoconvergence is ON 1895752 SIG_INTEGRITY OTHER Layout Cross Section: Wrong Differential Impedance calculation (0 ohms) in RHEL Linux 7.1 or later versions 1895759 SIG_INTEGRITY OTHER Cross Section does not calculate correct differential pair impedance in Linux CENTOS 7 and gives 0 value 1909257 SIP_LAYOUT INTERACTIVE Error 'E- (SPMHGE-639): Copying component with bond wire is not allowed' when copying SMD symbols 1900970 SIP_LAYOUT SHAPE Shape does not void around SMD Pins and Vias inside pad 1885496 SIP_LAYOUT SYMB_EDIT_APP Pin Numbering: different results for release 16.6 and 17.2-2016 for the same case. 1907796 SIP_LAYOUT SYMB_EDIT_APP SKILL commands fail to change pin number in SiP Layout 1887703 SIP_LAYOUT WIREBOND On trying to add wire bond to a die, SiP Layout crashes displaying a restart message 1903081 SPECCTRA LICENSING PCB Router is failing in Linux 7.1 in release 17.2-2016 1721606 SPECCTRA ROUTE PCB Router stops responding on exit if opened in the stand-alone mode 1844366 SPECCTRA ROUTE Allegro PCB Router will not exit 1873716 SPECCTRA ROUTE PCB Router does not close if opened from Allegro PCB Editor or in the stand-alone mode 1907703 SPIF OTHER PCB Editor crashes on choosing 'File - Export - Router' in release 17.2-2016 1889059 VSDP DIEEXPORT Incorrect pin location if bump cell origin is not at lower left for rotation other than R0 Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
rom67 0 29 мая, 2018 Опубликовано 29 мая, 2018 · Жалоба вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: 040 Fixed CCRs: SPB 17.2 HF040 05-27-2018 ================================================================================ ================================================================================ CCRID Product ProductLevel2 Title ================================================================================ ================================================================================ 1924541 ADW CONF Designer Server configuration cannot be completed 1906973 ADW DBEDITOR Rename attribute fails to preserve values in affected parts 1718524 ADW FLOW_MGR FM: Find Projects does not find any projects when Project Path contains a period 1803310 ADW FLOW_MGR EDM Find Project no longer supports dot in the project path 1916898 ADW FLOW_MGR Flow Manager does not recognize projects with a dot in the path 1887669 ADW LIBDISTRIBUTI ptfgen displaying Java errors 1897991 ADW LIBDISTRIBUTI ptfgen fails with error LIBDIST-1062 in library distribution. 1915319 ADW LIBDISTRIBUTI ptfgen should re-run with the -rewrite2db option automatically 1920309 ADW LIBDISTRIBUTI Java exceptions in the ptfgen log file 1914706 ALLEGRO_EDITOR DFM False Mask to trace DRCs 1912290 ALLEGRO_EDITOR GRAPHICS Infinite PCB cursor: symbol move results in symbol trail and disappearance of cursor and symbol 1927425 ALLEGRO_EDITOR GRAPHICS Infinite PCB Cursor disappear while moving objects on layout 1908867 ALLEGRO_EDITOR INTERACTIV PCB Editor crashes in release 17.2-2016, Hotfix 036 and 037 1906116 ALLEGRO_EDITOR IN_DESIGN_ANA Allegro Integrated Analysis and Checking: Coupling vision shows the influence of voltage net 1918161 ALLEGRO_EDITOR MULTI_USER Symphony crashing and clients disconnecting from server cannot leave session, error applying DBupdate 1919467 ALLEGRO_EDITOR MULTI_USER Random crashes while routing design in Symphony 1918702 ALLEGRO_EDITOR SHAPE Differential Pair vias not voided in a split plane 1905109 ALLEGRO_EDITOR UI_GENERAL PCB Editor randomly stops responding in release 17.2-2016 in Linux 1882365 ASDA CANVAS_EDIT SDA - body changes but not properties when changing version of a symbol 1900370 ASDA CANVAS_EDIT Version command in SDA should use placeholders from selected version 1901120 ASDA CANVAS_EDIT Choosing a different version of a placed component does not use the property placeholders as per the new symbol 1907497 ASDA GRAPHICS DNI Cross Mark much larger than Components 1895135 ASDA MISCELLANEOUS Design created in SDA has the cds.lib containing a pointer to worklib 1895139 ASDA MISCELLANEOUS Irrelevant warning related to worklib when running checkplus on SDA design 1920753 CAPTURE LIBRARY JavaScript exception reported on opening part with name containing '\' in hotfix 038 1925848 CAPTURE LIBRARY New (QIR6) Symbol Editor has Script error / SR 600037969 1916991 CAPTURE NEW_SYM_EDITO New part/symbol editor ignores grid color set in Preferences 1917090 CAPTURE NEW_SYM_EDITO New symbol editor goes into permanent pan mode on clicking the middle mouse button 1918041 CAPTURE NEW_SYM_EDITO Saves As for symbol in library from new symbol editor saving 0 byte files 1918497 CAPTURE NEW_SYM_EDITO Moving multiple items using the arrow keys results in error in new part editor 1918711 CAPTURE NEW_SYM_EDITO Unable to do a Save As from a Library part to change the name 1920889 CAPTURE NEW_SYM_EDITO Unable to edit symbol with name containing '/' 1922123 CAPTURE NEW_SYM_EDITO Save As for symbol in library from new symbol editor saving 0 byte files 1922276 CAPTURE NEW_SYM_EDITO Space between pin name and pin for names having bar 1922282 CAPTURE NEW_SYM_EDITO JavaScript exception on closing new part editor window using keyboard shortcuts 1923526 CAPTURE NEW_SYM_EDITO Unable to "Save As" in new symbol editor. 1927262 CAPTURE NEW_SYM_EDITO The File > Save As command in version 17.2-s038 differs from earlier versions 1919322 CAPTURE PART_EDITOR JavaScript exception on opening parts and creating new part using right-click 1914183 CONSTRAINT_MGR XNET_DIFFPAIR ECSet fails to map in PCB Editor but maps fine in DE-HDL 1908102 ECW DASHBOARD Some lines in Design Dashboard in Pulse are grayed out 1914812 F2B PACKAGERXL Hierarchical variable not evaluated 1639231 PSPICE ENVIRONMENT Remember last location in simulation settings 1804391 PSPICE ENVIRONMENT Libraries with uppercase extension (.LIB) not retained if added using 'Add to Profile' 1879915 PSPICE ENVIRONMENT Check points cannot be loaded from a directory with space in its name 1695306 SIP_LAYOUT STREAM_IF SiP Layout - Stream out issue: Embedded or stacked components using pad reference in more than one layer Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
rom67 0 19 июня, 2018 Опубликовано 19 июня, 2018 · Жалоба вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: 041 Fixed CCRs: SPB 17.2 HF041 06-9-2018 ================================================================================ ================================================================================ CCRID Product ProductLevel2 Title ================================================================================ ================================================================================ 1880083 ADW ADWSERVER ALM fails to connect and authenticate LDAP server 1922218 ALLEGRO_EDITOR 3D_CANVAS PCB Editor stops responding when 3D Canvas is opened for a symbol 1915838 ALLEGRO_EDITOR DFM Outline to non-signal geometry is not working for non-etch layers in design 1925263 ALLEGRO_EDITOR DFM False minimum spoke count DRC 1895486 ALLEGRO_EDITOR INTERFACES Importing IPF displays error regarding line being outside drawing extents (SPMHMF-409) 1927266 ALLEGRO_EDITOR INTERFACES Miniaturization license required when using enterprise licenses 1912186 ALLEGRO_EDITOR IN_DESIGN_ANA Coupling analysis on one net takes a long time 1916015 ALLEGRO_EDITOR NC Improve the message for reporting unsupported characters in the directory path while generating NC Drill data 1926072 ALLEGRO_EDITOR SHAPE Dynamic shape to route keepout not voiding correctly 1903202 ALLEGRO_EDITOR UI_GENERAL HTML report dialog does not handle relative links to files correctly 1880684 ALTM_TRANSLATOR CAPTURE Importing third-party schematic is not working in Capture 1870218 ALTM_TRANSLATOR DE_HDL Unable to translate a third-party design to DE-HDL 1881208 ALTM_TRANSLATOR DE_HDL Third-party to DE-HDL translation: schematic symbols missing all pins 1889909 ALTM_TRANSLATOR DE_HDL Third-party to DE-HDL and OrCAD Capture translator fails with error message or crash 1924375 ASDA NEW_PROJECT SDA new project path truncated at ellipses 1900957 ASI_SI OTHER axlLicDefaultVersion() in SKILL console crashes PCB Editor in release 17.2-2016 and works in release 16.6 1918499 CAPTURE NEW_SYM_EDITO Text in new Part Editor is always left-justified and justification cannot be changed 1921505 CAPTURE NEW_SYM_EDITO Error if property name starts with the less than character '<' 1924273 CAPTURE NEW_SYM_EDITO Error if property name starts with the less than character '<' 1924332 CAPTURE NEW_SYM_EDITO Capture reports an error when editing pin numbers where names contain the less than character '<' 1934655 CAPTURE NEW_SYM_EDITO Properties populated in older release show up blank in new Symbol Editor 1855851 CAPTURE OTHER Crystal Reports not working in release 17.2-2016 1918048 CAPTURE PART_EDITOR Unable to modify pin type and shapes for multiple pins simultaneously in new Part Editor 1919459 CAPTURE PART_EDITOR Part Editor background display color is not consistent when zoomed out/in 1920078 CAPTURE PART_EDITOR Option needed for updating pin type of multiple pins in the 'Edit all pins' menu 1922785 CAPTURE PART_EDITOR Cannot place pin array with zero in the suffix in Symbol Editor 1922831 CAPTURE PART_EDITOR Symbol Editor redraws when scrolling with non-default background and when zoomed out 1923772 CAPTURE PART_EDITOR Placing pin arrays results in error 1888897 CAPTURE SCHEMATICS Capture slowly redraws schematic page 1910087 CONCEPT_HDL CORE DE-HDL crashes when adding Current Probe to a design 1930364 CONCEPT_HDL CORE SIGNAL_MODEL properties not deleted on importing release 16.6 DML design into release 17.2-2016 non-DML design 1920716 CONSTRAINT_MGR CONCEPT_HDL Issue with the passing of physical and spacing CSets between Design Entry HDL and PCB Editor 1902591 ECW OTHER Flow Manager reports a digital certificate error when launched with Pulse 1926029 PCB_LIBRARIAN GRAPHICAL_EDI PDV Symbol Editor opens to a blank page in release 17.2-2016 1884694 PSPICE ENCRYPTION User-defined library encryption is not working as expected 1927537 SIP_LAYOUT ASSY_RULE_CHE SiP Layout crashes when running manufacturing checks on specific designs 1878733 SIP_LAYOUT CROSS_SECTION Layer Function and Manufacture fields in Cross-section Editor are grayed out for soldermask layers in SiP Layout 1900628 SIP_LAYOUT CROSS_SECTION Board thickness in Cross-section Editor does not change even after soldermask layers are added Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
copov 2 22 июня, 2018 Опубликовано 22 июня, 2018 · Жалоба Подскажите пожалуйста. После установки OrCAD/Allegro 17.2, HOTFIX VERSION: 041 редактор символов в Capture работоспособен или все-также не пригоден? Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
copov 2 26 июня, 2018 Опубликовано 26 июня, 2018 · Жалоба Спасибо, сам отвечу. Косяки в символьном редакторе в Capture не исправили... P.S. Такая эта ситуация уже становится неприличной. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
copov 2 27 июня, 2018 Опубликовано 27 июня, 2018 · Жалоба del Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
En_Serg 0 18 июля, 2018 Опубликовано 18 июля, 2018 · Жалоба А в известном месте можно взять Hotfix 42. Такая же ситуация? Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
PCBtech 0 18 июля, 2018 Опубликовано 18 июля, 2018 · Жалоба Спасибо, сам отвечу. Косяки в символьном редакторе в Capture не исправили... P.S. Такая эта ситуация уже становится неприличной. А можете перечислить эти косяки? Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
rom67 0 18 июля, 2018 Опубликовано 18 июля, 2018 · Жалоба вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: 043 Fixed CCRs: SPB 17.2 HF043 07-13-2018 ================================================================================ ================================================================================ CCRID Product ProductLevel2 Title ================================================================================ ================================================================================ 1935813 ADW DBEDITOR Auto merging of DE-HDL and Capture Classifications is not working 1935834 ADW DBEDITOR Some DE-HDL only classifications are removed during the CSV merge process of libimport 1941570 ALLEGRO_EDITOR DATABASE PCB Editor crashes or stops responding on performing 'Info' or 'edit properties' on select pins 1942536 ALLEGRO_EDITOR DATABASE Allegro PCB Editor fails to create backdrill plunges in Zone area 1925899 ALLEGRO_EDITOR DFM PCB Editor crashes when placing components in Hotfix 039 1943113 ALLEGRO_EDITOR DFM Restore normal move/slide via performance when annular ring checking is enabled. 1940939 ALLEGRO_EDITOR EDIT_ETCH PCB Editor crashed on running the Gloss - Line and via cleanup tool 1937754 ALLEGRO_EDITOR GRAPHICS Text string disappears when selected during 'Edit - Text' if using PCB_CURSOR 1937056 ALLEGRO_EDITOR INTERFACES Cannot import IDX acceptance of third-party change to PCB Editor 1940197 ALLEGRO_EDITOR INTERFACES PCB Editor crashes when reading IDX file from third-party 1940232 ALLEGRO_EDITOR IN_DESIGN_ANA PCB Editor crashes when running Return path DRC 1916921 ALLEGRO_EDITOR PLACEMENT Property Pin_Global_Fiducial not inherited from symbol into board 1862241 ALLEGRO_EDITOR REPORTS In 'Summary Drawing Report', the listed quantity for HDI vias is incorrect under Drilling Statistics 1935448 ALLEGRO_EDITOR REPORTS Etch Detailed Length Report lists only one coordinate pair per trace 1948322 ALLEGRO_EDITOR SHAPE Allegro hangs when axlPolyOperation api is called 1795564 ALLEGRO_EDITOR UI_GENERAL In release 17.2-2016, focus is lost from command window after right-click 1919247 ALLEGRO_EDITOR UI_GENERAL Infinite cursor graphics issues on move: Cursor disappears and symbol image remains at old location till refresh 1919256 ALLEGRO_EDITOR UI_GENERAL Infinite cursor graphics issue: Symbol disappears during rotate 1933526 ALLEGRO_EDITOR UI_GENERAL Panning is slow in PCB Editor in Hotfix 038 1933530 ALLEGRO_EDITOR UI_GENERAL Strokes are slower to respond in release 17.2-2016 1933536 ALLEGRO_EDITOR UI_GENERAL Third-party dialog stops responding on running commands 1782227 APD DIE_GENERATOR Ability to specify rectangular shapes in die text in 1933011 ASDA PART_MANAGER Parts changed in library with new pin names are not reported or updated by Part Manager 1924529 CAPTURE NEW_SYM_EDITO Global colors for pin name and number and part body not allowed in release 17.2-2016, Hotfix 038/039 1925846 CAPTURE NEW_SYM_EDITO Opening library or component with special characters in path throws JavaScript exception 1928905 CAPTURE NEW_SYM_EDITO Pin name justification, length, and casing incorrect for generated parts in Hotfix 038 1928965 CAPTURE NEW_SYM_EDITO Cannot move pins in Capture if Pin Name is missing 1932149 CAPTURE NEW_SYM_EDITO JavaScript exception if path to part contains special characters in Hotfix 039 1936301 CAPTURE NEW_SYM_EDITO Cannot edit symbol in new symbol editor: Displays parsing error (SPSMI-1) 1917172 CAPTURE PART_EDITOR Pin name rotating on schematic even when pin name rotate is off in symbol editor 1924456 CAPTURE PART_EDITOR Color preferences for pin, pin name, and pin number do not apply in part editor but only in schematic 1928872 CAPTURE PART_EDITOR Pin name locations are wrong and each needs to be placed manually 1929562 CAPTURE PART_EDITOR Changing pin name while adding a pin not intuitive in Symbol Editor 1932732 CAPTURE PART_EDITOR Part Editor issue: Pin name selection box too long and text not justified in Hotfix 040 1933523 CAPTURE PART_EDITOR Connection box does not appear after changing pin of a placed part in Hotfix 040 1936994 CAPTURE PART_EDITOR Error because of illegal characters in pin name and number and net name 1943074 CAPTURE PART_EDITOR Pin names rotated in Part Editor not rotated when placed on page 1943078 CAPTURE PART_EDITOR Pin name rotate not working. 1945055 CAPTURE PART_EDITOR Pin names not rotated in schematic 1925700 CAPTURE VIEWER Pin numbers and text not shown during Variant View mode anymore. 1914437 CONSTRAINT_MGR CONCEPT_HDL Constraint Difference Report appears even though there is no difference in constraint. 1935152 CONSTRAINT_MGR CONCEPT_HDL Match Groups are not formed with the correct pin pairs 1940575 SIP_LAYOUT ORBITIO_IF Need new routing flow 1923722 SIP_LAYOUT STREAM_IF Use one symbol for all instances of a Via Structure Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
