Super_Electric 0 25 января, 2005 Опубликовано 25 января, 2005 · Жалоба -- SIMPLE PCI CONTROLLER VERSION 2.1 -- -- Designed for xc95144xl -- -- -- -- **************************** Resource Summary **************************** -- -- Macrocells Product Terms Registers Pins Function Block -- -- Used Used Used Used Inputs Used -- -- 100/144 ( 69%) 524 /720 ( 72%) 76 /144 ( 52%) 57 /81 ( 70%) 262/432 ( 60%) -- -- -- -- Copyright © 2001, 2002 by Shustanov Viktor. All rights reserved. -- -- -- -- This source file may be used and distributed without restriction -- -- provided that this copyright statement is not removed from the file -- -- and that any derivative work contains this copyright notice. -- -- -- -- Disclaimer: These designs are provided "AS IS" with no warranty -- -- whatsoever and auther specfically disclaims any -- -- implied waarenties of merchantability, fitness for -- -- a particular purpose, or agaist infringement. -- -- NOTES: VendorId and DeviceID are arbitrary numbers and have no relation with -- -- potential producer -- -- mailto: [email protected] -- --================================================================================ ==== library IEEE; use IEEE.std_logic_1164.all; use IEEE.std_logic_unsigned.all; use IEEE.std_logic_arith.all; entity pci_controller is port ( -- PCI side signals clk : IN STD_LOGIC; frame : IN STD_LOGIC; ad : INOUT STD_LOGIC_VECTOR (31 DOWNTO 0); cbe : IN STD_LOGIC_VECTOR (3 DOWNTO 0); irdy : IN STD_LOGIC; idsel : IN STD_LOGIC; devsel : OUT STD_LOGIC; trdy : OUT STD_LOGIC; stop : OUT STD_LOGIC; reset : IN STD_LOGIC; inta : OUT STD_LOGIC; -- Local side signals d : INOUT STD_LOGIC_VECTOR (7 DOWNTO 0); iord : OUT STD_LOGIC; iowr : OUT STD_LOGIC; iocs : OUT STD_LOGIC; interrupt : IN STD_LOGIC); end pci_controller; ARCHITECTURE rtl OF pci_controller IS ------------------- PCI configuration space registers signal command_io : STD_LOGIC; signal bar0 : STD_LOGIC_VECTOR (7 DOWNTO 0); signal int_line_reg : STD_LOGIC_VECTOR (7 downto 0); signal late_grant_reg : STD_LOGIC_VECTOR (15 downto 0); ------------------- PCI configuration space constants constant ADDRESS_00H : STD_LOGIC_VECTOR (5 DOWNTO 0) := "000000"; constant ADDRESS_04H : STD_LOGIC_VECTOR (5 DOWNTO 0) := "000001"; constant ADDRESS_08H : STD_LOGIC_VECTOR (5 DOWNTO 0) := "000010"; constant ADDRESS_0CH : STD_LOGIC_VECTOR (5 DOWNTO 0) := "000011"; constant ADDRESS_10H : STD_LOGIC_VECTOR (5 DOWNTO 0) := "000100"; constant ADDRESS_3CH : STD_LOGIC_VECTOR (5 DOWNTO 0) := "001111"; constant IO_WRITE : STD_LOGIC_VECTOR (3 DOWNTO 0) := "0011"; constant IO_READ : STD_LOGIC_VECTOR (3 DOWNTO 0) := "0010"; constant CONFIG_WRITE : STD_LOGIC_VECTOR (3 DOWNTO 0) := "1011"; constant CONFIG_READ : STD_LOGIC_VECTOR (3 DOWNTO 0) := "1010"; constant INT_PIN : STD_LOGIC_VECTOR (7 DOWNTO 0) := "00000001"; constant DEVICE_VENDOR_ID : STD_LOGIC_VECTOR (31 DOWNTO 0) := "01010101010101010101010101010101"; constant CLASS_CODE : STD_LOGIC_VECTOR (31 DOWNTO 0) := "00000010100000000000000000000000"; signal access_address : STD_LOGIC_VECTOR (15 DOWNTO 0); signal pci_state_mashine : integer range 0 to 8; signal ws_cntr : integer range 0 to 10; ATTRIBUTE INIT : string; ATTRIBUTE INIT OF command_io : signal is "R"; ATTRIBUTE INIT OF devsel : signal is "S"; ATTRIBUTE INIT OF trdy : signal is "S"; ATTRIBUTE INIT OF stop : signal is "S"; ATTRIBUTE INIT OF iord : signal is "S"; ATTRIBUTE INIT OF iowr : signal is "S"; ATTRIBUTE INIT OF iocs : signal is "S"; ATTRIBUTE INIT OF d : signal is "ZZZZZZZZ"; BEGIN inta <= interrupt; --================================================================================ ==== -- MAIN PROCESS --================================================================================ ==== process begin wait until clk'event and clk='1'; --================================================================================ ==== -- IO wait states count --================================================================================ ==== case ws_cntr is when 10 => NULL; when others => ws_cntr <= ws_cntr+1; end case; --if ws_cntr /= 10 then -- ws_cntr <= ws_cntr+1; --end if; --================================================================================ ==== -- init on RESET --================================================================================ ==== if reset='0' then pci_state_mashine <= 0; command_io <= '0'; bar0 <= "00000000"; devsel <= 'Z'; trdy <= 'Z'; stop <= 'Z'; ad <= (others =>'Z'); iowr <= '1'; iord <= '1'; iocs <= '1'; d <= "ZZZZZZZZ"; ws_cntr <= 10; end if; --================================================================================ ==== -- PCI STATE MASHINE --================================================================================ ==== ----- ADDRESS PHASE if frame='0' and pci_state_mashine=0 then access_address <= ad(15 downto 0); ----------- configuration space access if idsel='1' then case cbe is when CONFIG_READ => pci_state_mashine <= 1; --devsel <= transport '0' after 6 ns; devsel <= '0' after 6 ns; when CONFIG_WRITE => pci_state_mashine <= 2; --devsel <= transport '0' after 6 ns; devsel <= '0' after 6 ns; when others => NULL; end case; ----------- i/o space access else case cbe is when IO_READ => if command_io='1' then pci_state_mashine <= 3; iocs <= '0'; end if; when IO_WRITE => if command_io='1' then pci_state_mashine <= 4; iocs <= '0'; end if; when others => NULL; end case; end if; end if; ---- DATA PHASE case pci_state_mashine is ----------- configuration read when 1 => --trdy <= transport '0' after 6 ns; --stop <= transport '0' after 6 ns; trdy <= '0' after 6 ns; stop <= '0' after 6 ns; pci_state_mashine <= 5; case access_address(7 downto 2) is when ADDRESS_00H => ad <= DEVICE_VENDOR_ID; when ADDRESS_04H => ad(0) <= command_io; --ad(31 downto 1)<= (31 downto 1 => '0'); ad(31 downto 1)<="0000000000000000000000000000000"; --ad<=("0000000000000000000000000000000"&command_io); when ADDRESS_08H => ad <= CLASS_CODE; when ADDRESS_0CH => ad <= (others => '0'); when ADDRESS_10H => ad(7 downto 0) <= "00000001"; ad(15 downto 8) <= bar0; --ad(31 downto 16) <= (31 downto 16 => '0'); ad(31 downto 16) <= "0000000000000000"; when ADDRESS_3CH => ad(7 downto 0) <= int_line_reg; ad(15 downto 8) <= INT_PIN; --ad(31 downto 16) <= (31 downto 16 => '0'); ad(31 downto 16) <= "0000000000000000"; when others => ad <= (others => '0'); end case; ----------- configuration write when 2 => --trdy <= transport '0' after 6 ns; --stop <= transport '0' after 6 ns; trdy <= '0' after 6 ns; stop <= '0' after 6 ns; pci_state_mashine <= 6; case access_address(7 downto 2) is when ADDRESS_04H => command_io <= ad(0); when ADDRESS_10H => bar0 <= ad(15 downto 8); when ADDRESS_3CH => int_line_reg <= ad(7 downto 0); when others => NULL; end case; ----------- i/o read when 3 => if access_address(15 downto 8)=bar0 then --devsel <= transport '0' after 6 ns; devsel <= '0' after 6 ns; case access_address(3 downto 2) is when "00" => pci_state_mashine <= 8; ad(7 downto 0) <= d; iord <= '0'; ws_cntr <= 0; when "01" => NULL; when "10" => NULL; when others=> NULL; end case; end if; when 8 => ad(7 downto 0) <= d; case ws_cntr is when 6 => --trdy <= transport '0' after 6 ns; --stop <= transport '0' after 6 ns; trdy <= '0' after 6 ns; stop <= '0' after 6 ns; when 7 => --trdy <= transport '1' after 6 ns; --stop <= transport '1' after 6 ns; --devsel <= transport '1' after 6 ns; trdy <= '1' after 6 ns; stop <= '1' after 6 ns; devsel <= '1' after 6 ns; if irdy='0' then pci_state_mashine <= 7; end if; when others => NULL; end case; ----------- i/o write when 4 => if access_address(15 downto 8)=bar0 then --devsel <= transport '0' after 6 ns; --trdy <= transport '0' after 6 ns; --stop <= transport '0' after 6 ns; devsel <= '0' after 6 ns; trdy <= '0' after 6 ns; stop <= '0' after 6 ns; pci_state_mashine <= 6; case access_address(3 downto 2) is when "00" => d <= ad(7 downto 0); iowr <= '0'; ws_cntr <= 0; when "01" => NULL; when "10" => NULL; when others => NULL; end case; end if; ---- DEASSERT ALL SIGNALS when 5|6 => --devsel <= transport '1' after 6 ns; -- trdy <= transport '1' after 6 ns; -- stop <= transport '1' after 6 ns; devsel <= '1' after 6 ns; trdy <= '1' after 6 ns; stop <= '1' after 6 ns; if irdy <= '0' then pci_state_mashine <= 7; end if; iord <= '1'; ---- TRISTATE ALL SIGNALS when 7 => pci_state_mashine <= 0; ad <= (others =>'Z'); devsel <= 'Z'; trdy <= 'Z'; stop <= 'Z'; iord <= '1'; when others => NULL; end case; ---- end of the i/o write operation case ws_cntr is when 8 => iowr <= '1'; when 9 => iocs <= '1'; d <= "ZZZZZZZZ"; when others => NULL; end case; end process; END rtl; Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
one_man_show 0 26 января, 2005 Опубликовано 26 января, 2005 · Жалоба Не грузите пожалуйста длинный код, используйте вставку файла. Воспользуйтесь кнопкой EDIT и сами отредактируйте сообщение. Пожалуйста! Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
