jenya7 0 17 августа, 2018 Опубликовано 17 августа, 2018 (изменено) · Жалоба Настраиваю CAN void CAN_Setup(void) { GPIO_InitTypeDef GPIO_InitStructure; NVIC_InitTypeDef NVIC_InitStructure; CAN_InitTypeDef CAN_InitStructure; CAN_FilterInitTypeDef CAN_FilterInitStructure; /* CAN GPIOs configuration **************************************************/ /* Enable GPIO clock */ RCC->AHBENR |= RCC_AHBPeriph_GPIOB; /* Connect CAN pins to AF9 */ GPIO_PinAFConfig(GPIOB, GPIO_PinSource8, GPIO_AF_9); GPIO_PinAFConfig(GPIOB, GPIO_PinSource9, GPIO_AF_9); /* Configure CAN RX and TX pins */ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8| GPIO_Pin_9; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_OType = GPIO_OType_PP; GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP; GPIO_Init(CAN_GPIO_PORT, &GPIO_InitStructure); /* NVIC configuration *******************************************************/ NVIC_InitStructure.NVIC_IRQChannel = USB_LP_CAN1_RX0_IRQn; NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0x0; NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0x0; NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; NVIC_Init(&NVIC_InitStructure); NVIC_InitStructure.NVIC_IRQChannel = CAN1_RX1_IRQn; NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0x0; NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0x0; NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; NVIC_Init(&NVIC_InitStructure); /* CAN configuration ********************************************************/ /* Enable CAN clock */ RCC_APB1PeriphClockCmd(RCC_APB1Periph_CAN1, ENABLE); /* CAN register init */ CAN_DeInit(CAN1); CAN_StructInit(&CAN_InitStructure); // CAN cell init CAN_InitStructure.CAN_TTCM = DISABLE; CAN_InitStructure.CAN_ABOM = DISABLE; CAN_InitStructure.CAN_AWUM = DISABLE; CAN_InitStructure.CAN_NART = DISABLE; CAN_InitStructure.CAN_RFLM = DISABLE; CAN_InitStructure.CAN_TXFP = DISABLE; CAN_InitStructure.CAN_Mode = CAN_Mode_Normal; /* CAN Baudrate = 1MBps (CAN clocked at 36 MHz) */ CAN_InitStructure.CAN_BS1 = CAN_BS1_9tq; CAN_InitStructure.CAN_BS2 = CAN_BS2_8tq; CAN_InitStructure.CAN_Prescaler = 2; CAN_InitStructure.CAN_SJW = CAN_SJW_1tq; //CAN_InitStructure.CAN_BS1 = CAN_BS1_3tq; //CAN_InitStructure.CAN_BS2 = CAN_BS2_5tq; //CAN_InitStructure.CAN_Prescaler = 39; //CAN_InitStructure.CAN_SJW = 2; CAN_Init(CANx, &CAN_InitStructure); /* CAN filter init */ CAN_FilterInitStructure.CAN_FilterNumber = 0; CAN_FilterInitStructure.CAN_FilterMode = CAN_FilterMode_IdMask; CAN_FilterInitStructure.CAN_FilterScale = CAN_FilterScale_32bit; CAN_FilterInitStructure.CAN_FilterIdHigh = 0x0000; CAN_FilterInitStructure.CAN_FilterIdLow = 0x0000; CAN_FilterInitStructure.CAN_FilterMaskIdHigh = 0x0000; CAN_FilterInitStructure.CAN_FilterMaskIdLow = 0x0000; CAN_FilterInitStructure.CAN_FilterFIFOAssignment = 0; CAN_FilterInitStructure.CAN_FilterActivation = ENABLE; CAN_FilterInit(&CAN_FilterInitStructure); /* Enable FIFO 0 message pending Interrupt */ CAN_ITConfig(CANx, CAN_IT_FMP0, ENABLE); /* Enable FIFO 1 message pending Interrupt */ CAN_ITConfig(CANx, CAN_IT_FMP1, ENABLE); } Посылаю TxMessage.StdId = ( (0x100 *(i+1)) + CAN_COM_WHO_IS); TxMessage.DLC = 1; TxMessage.RTR = CAN_RTR_DATA; TxMessage.IDE = CAN_ID_STD; CAN_Transmit(CAN1, &TxMessage); В функции посылки - все мейлбоксы заняты - я попадаю в transmit_mailbox = CAN_TxStatus_NoMailBox; uint8_t CAN_Transmit(CAN_TypeDef* CANx, CanTxMsg* TxMessage) { uint8_t transmit_mailbox = 0; /* Check the parameters */ assert_param(IS_CAN_ALL_PERIPH(CANx)); assert_param(IS_CAN_IDTYPE(TxMessage->IDE)); assert_param(IS_CAN_RTR(TxMessage->RTR)); assert_param(IS_CAN_DLC(TxMessage->DLC)); /* Select one empty transmit mailbox */ if ((CANx->TSR&CAN_TSR_TME0) == CAN_TSR_TME0) { transmit_mailbox = 0; } else if ((CANx->TSR&CAN_TSR_TME1) == CAN_TSR_TME1) { transmit_mailbox = 1; } else if ((CANx->TSR&CAN_TSR_TME2) == CAN_TSR_TME2) { transmit_mailbox = 2; } else { transmit_mailbox = CAN_TxStatus_NoMailBox; } if (transmit_mailbox != CAN_TxStatus_NoMailBox) { /* Set up the Id */ CANx->sTxMailBox[transmit_mailbox].TIR &= TMIDxR_TXRQ; if (TxMessage->IDE == CAN_Id_Standard) { assert_param(IS_CAN_STDID(TxMessage->StdId)); CANx->sTxMailBox[transmit_mailbox].TIR |= ((TxMessage->StdId << 21) | \ TxMessage->RTR); } else { assert_param(IS_CAN_EXTID(TxMessage->ExtId)); CANx->sTxMailBox[transmit_mailbox].TIR |= ((TxMessage->ExtId << 3) | \ TxMessage->IDE | \ TxMessage->RTR); } /* Set up the DLC */ TxMessage->DLC &= (uint8_t)0x0000000F; CANx->sTxMailBox[transmit_mailbox].TDTR &= (uint32_t)0xFFFFFFF0; CANx->sTxMailBox[transmit_mailbox].TDTR |= TxMessage->DLC; /* Set up the data field */ CANx->sTxMailBox[transmit_mailbox].TDLR = (((uint32_t)TxMessage->Data[3] << 24) | ((uint32_t)TxMessage->Data[2] << 16) | ((uint32_t)TxMessage->Data[1] << 8) | ((uint32_t)TxMessage->Data[0])); CANx->sTxMailBox[transmit_mailbox].TDHR = (((uint32_t)TxMessage->Data[7] << 24) | ((uint32_t)TxMessage->Data[6] << 16) | ((uint32_t)TxMessage->Data[5] << 8) | ((uint32_t)TxMessage->Data[4])); /* Request transmission */ CANx->sTxMailBox[transmit_mailbox].TIR |= TMIDxR_TXRQ; } return transmit_mailbox; } Если принимающая сторона не приняла мейлбокс он не освободился ? Изменено 19 августа, 2018 пользователем IgorKossak [codebox] для длинного кода, [code] - для короткого! Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Obam 30 17 августа, 2018 Опубликовано 17 августа, 2018 · Жалоба Коллега, вы хрензнает сколько лет на форуме, листинг в (1024 по вертикали) 4 экрана - перебор. Ну хоть чуть-чуть уважения к окружающим. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
esaulenka 5 17 августа, 2018 Опубликовано 17 августа, 2018 · Жалоба листинг ... - перебор Листинг - это единственная полезная часть исходного сообщения. Если его выкинуть (спрятать), останется просто бессмысленное "у меня не работает". Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
x893 34 17 августа, 2018 Опубликовано 17 августа, 2018 · Жалоба Настраиваю ... Если принимающая сторона не приняла мейлбокс он не освободился ? Да Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
jenya7 0 19 августа, 2018 Опубликовано 19 августа, 2018 · Жалоба для отладки я изменил случай когда все мейлбоксы заняты else { transmit_mailbox = CAN_TxStatus_NoMailBox; //force pending messages to be sent anyway CANx->sTxMailBox[0].TIR |= TMIDxR_TXRQ; CANx->sTxMailBox[1].TIR |= TMIDxR_TXRQ; CANx->sTxMailBox[2].TIR |= TMIDxR_TXRQ; } я становлюсь скопом на ножку CAN_TX и не вижу никаких выходящих сигналов. что происходит? кто может объяснить? Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
jenya7 0 13 сентября, 2018 Опубликовано 13 сентября, 2018 · Жалоба CAN по прежнему не работает.Вопрос - нужно ли чистить флаги в прерывании? я за основу взял пример где флаги не чистяться. void USB_LP_CAN1_RX0_IRQHandler(void) { can_params.message_received = 1; can_params.fifo_num = CAN_FIFO0; } void CAN1_RX1_IRQHandler(void) { can_params.message_received = 1; can_params.fifo_num = CAN_FIFO1; } Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
jenya7 0 17 сентября, 2018 Опубликовано 17 сентября, 2018 · Жалоба CAN заработал. надо было перемычку замкнуть на пин 8 конвертора. Другая проблема. При приеме слейв через какое то время отсыхает. Я смотрю на ESR и вижу что TEC увеличивается при каждом принятии пакета, хотя данные пришли, иногда уменьшается но чаще увеличивается. Когда TEC = 0xFF прием отсыхает и LEC = 5. Как бороться с этой бедой? Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Alechek 0 17 сентября, 2018 Опубликовано 17 сентября, 2018 · Жалоба Другая проблема. При приеме слейв через какое то время отсыхает. Я смотрю на ESR и вижу что TEC увеличивается при каждом принятии пакета, хотя данные пришли, иногда уменьшается но чаще увеличивается. Когда TEC = 0xFF прием отсыхает и LEC = 5. Ничего тут не напутано? На прием REC работает, на передачу TEC. Сдается мне, что физически что-то как-то не так подключено. Физический интерфейс имеется? Резистор в линии имеется? Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
jenya7 0 17 сентября, 2018 Опубликовано 17 сентября, 2018 · Жалоба Ничего тут не напутано? На прием REC работает, на передачу TEC. Сдается мне, что физически что-то как-то не так подключено. Физический интерфейс имеется? Резистор в линии имеется? я вижу приходящие сообщения от мастера. слейв ему отвечает и ответ я тоже вижу. Вы говорите TEC - это значит слейв послал с ошибкой? Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Alechek 0 17 сентября, 2018 Опубликовано 17 сентября, 2018 · Жалоба CAN контроллер всегда слушает линию. Если вдруг в линии не то, что мы ожидали (коллизия), передатчик сообщает об ошибке. Доминатное состояние достигается за счет драйвера, рецессивное за счет нагрузки в линии. Для подтверждения приема служит бит ACK, его генерирует приемник, он контролируется передатчиком. Передатчик по-умолчанию будет посылать сообщение, пока его кто-нибудь не примет (или достигнется лимит TEC) Контроллер в STM32 можно настроить так, чтобы сообщение он принял, а АСК бит не выдал и даже не проконтролировал! Полагаю, где-то тут ваш случай. Передачу данных очень наглядно отображает даже дешевый логический анализатор. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
jenya7 0 17 сентября, 2018 Опубликовано 17 сентября, 2018 (изменено) · Жалоба CAN контроллер всегда слушает линию. Если вдруг в линии не то, что мы ожидали (коллизия), передатчик сообщает об ошибке. Доминатное состояние достигается за счет драйвера, рецессивное за счет нагрузки в линии. Для подтверждения приема служит бит ACK, его генерирует приемник, он контролируется передатчиком. Передатчик по-умолчанию будет посылать сообщение, пока его кто-нибудь не примет (или достигнется лимит TEC) Контроллер в STM32 можно настроить так, чтобы сообщение он принял, а АСК бит не выдал и даже не проконтролировал! Полагаю, где-то тут ваш случай. Передачу данных очень наглядно отображает даже дешевый логический анализатор. с анализатором (USB-CAN Plus) мастер работает нормально. да и данными мастер-слейв вроде как обмениваются. бес его знает что там CANу не нравиться. я что то не нашел где там АСК отменить. я отменил бесперерывную посылку (NART =1). послал один раз и все, не фиг линию грузить. Изменено 17 сентября, 2018 пользователем Jenya7 Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Edit2007 3 17 сентября, 2018 Опубликовано 17 сентября, 2018 · Жалоба я что то не нашел где там АСК отменить :wacko: Почитайте спецификацию на CAN?хотя бы в русском переводе. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
jenya7 0 17 сентября, 2018 Опубликовано 17 сентября, 2018 · Жалоба :wacko: Почитайте спецификацию на CAN?хотя бы в русском переводе. я могу читать отсюда и до Урала, там регистров с гулькин нос. все биты просмотрел. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
adnega 10 17 сентября, 2018 Опубликовано 17 сентября, 2018 · Жалоба там регистров с гулькин нос. все биты просмотрел. Может, это Silent mode The bxCAN can be put in Silent mode by setting the SILM bit in the CAN_BTR register. In Silent mode, the bxCAN is able to receive valid data frames and valid remote frames, but it sends only recessive bits on the CAN bus and it cannot start a transmission. If the bxCAN has to send a dominant bit (ACK bit, overload flag, active error flag), the bit is rerouted internally so that the CAN Core monitors this dominant bit, although the CAN bus may remain in recessive state. Silent mode can be used to analyze the traffic on a CAN bus without affecting it by the transmission of dominant bits (Acknowledge Bits, Error Frames). Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
jenya7 0 18 сентября, 2018 Опубликовано 18 сентября, 2018 · Жалоба Может, это спасибо. попробую. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
