> Как в Modelsim вывести таблицу истинности?
_alex__
сообщение Mar 13 2017, 11:16
Пользователь №: 82 059
Имеется комбинационное устройство:
entity New1 is
port(
    x1,x2,x3,x4,x5 : in bit;
    y1,y10,y11,y12,y13,y14,y15,y16,y17,y18,y19,y2,y20,y21,y22,y23,y24,y25,y26,y
27,y28,y29,y3,y30,y31,y32,y4,y5,y6,y7,y8,y9 : out bit
end New1;
architecture New1_functional of New1 is
begin
y1 <= x1 and x2 and x3 and x4 and x5;
y10 <= (not x1) and x2 and x3 and x4 and (not x5);
y11 <= (not x1) and x2 and x3 and (not x4) and x5;
y12 <= x1 and x2 and x3 and x4 and (not x5);
y13 <= (not x1) and x2 and x3 and (not x4) and (not x5);
y14 <= (not x1) and x2 and (not x3) and x4 and x5;
y15 <= (not x1) and x2 and (not x3) and x4 and (not x5);
y16 <= (not x1) and x2 and (not x3) and (not x4) and x5;
y17 <= (not x1) and x2 and (not x3) and (not x4) and (not x5);
y18 <= (not x1) and (not x2) and x3 and x4 and x5;
y19 <= (not x1) and (not x2) and x3 and x4 and (not x5);
y2 <= x1 and (not x2) and x3 and x4 and (not x5);
y20 <= (not x1) and (not x2) and x3 and (not x4) and x5;
y21 <= (not x1) and (not x2) and x3 and (not x4) and (not x5);
y22 <= (not x1) and (not x2) and (not x3) and x4 and x5;
y23 <= x1 and x2 and x3 and (not x4) and x5;
y24 <= (not x1) and (not x2) and (not x3) and x4 and (not x5);
y25 <= (not x1) and (not x2) and (not x3) and (not x4) and x5;
y26 <= (not x1) and (not x2) and (not x3) and (not x4) and (not x5);
y27 <= x1 and x2 and x3 and (not x4) and (not x5);
y28 <= x1 and x2 and (not x3) and x4 and x5;
y29 <= x1 and x2 and (not x3) and x4 and (not x5);
y3 <= x1 and (not x2) and x3 and (not x4) and x5;
y30 <= x1 and x2 and (not x3) and (not x4) and x5;
y31 <= x1 and x2 and (not x3) and (not x4) and (not x5);
y32 <= x1 and (not x2) and x3 and x4 and x5;
y4 <= x1 and (not x2) and x3 and (not x4) and (not x5);
y5 <= x1 and (not x2) and (not x3) and x4 and x5;
y6 <= x1 and (not x2) and (not x3) and x4 and (not x5);
y7 <= x1 and (not x2) and (not x3) and (not x4) and x5;
y8 <= x1 and (not x2) and (not x3) and (not x4) and (not x5);
y9 <= (not x1) and x2 and x3 and x4 and x5;
end New1_functional;
Как в Modelsim от Mentor вывести таблицу истинности для всех возможных значений на входе?
Tausinov
сообщение Mar 13 2017, 11:45
Пользователь №: 78 795
Цитата(_alex__ @ Mar 13 2017, 14:16) *
Имеется комбинационное устройство.
Либо подать на вход счетчик, потом ловить выход, либо создать тестовый файл, содержащий полный набор входных значений. В последнем случае можно туда же добавить ожидаемый отклик и сравнивать результаты - будет подобие автоматического тестирования.
_alex__
сообщение Mar 18 2017, 15:15
а тестовый файл здесь задается? тестовый файл тоже на vhdl нужно писать?
hsoft
сообщение Mar 18 2017, 15:41
Пользователь №: 95 415
Тестовый файл это обычный текстовый файл состоящий из строк вида
1111
0101
1010
И так далее, затем функциями Modelsim затаскиваете его в дизайн и подаете на вход DUT.
Почитайте как вектора вытащить из файла и подать на вход тестируемого устройства, руководств валом...
Сообщение отредактировал hsoft - Mar 18 2017, 15:42
_alex__
сообщение Mar 21 2017, 17:54
1111
0101
1010
я правильно понимаю, что в самом файле с вышеуказанным vhdl кодом это все задается?
Golikov A.
сообщение Mar 21 2017, 18:53
Пользователь №: 14 454
вам надо сделать файл верхнего уровня в него воткнуть ваш модуль New1
к нему подключить провода X и Y,
создать файл со всеми вариантам входов,
в файле верхнего уровня этот файл прочесть и на входы подать, информацию с выходов снять и в файл сохранить.
можно полный перебор вариантов сделать просто тупо счетчиком, тогда входной файл не нужен.
_alex__
сообщение Mar 25 2017, 19:43
пытался повторить вот это:
http://we.easyelectronics.ru/plis/modelsim...ego-nachat.html
не получается. vhdl файлы скомпилировались.
симуляция не работает. ошибку выдает error loading design.
Объесните как в этой программе сделать это:
у меня по всей видимости модуль верхнего уровня не видит модуль нижнего уровня.
Сообщение отредактировал _alex__ - Mar 26 2017, 08:17
Maverick
сообщение Mar 25 2017, 20:46
я только учусь...
Из: Украина
Пользователь №: 24 839
Цитата(_alex__ @ Mar 25 2017, 21:43) *
уже неделю разобраться не могу.
CODE
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
--use IEEE.STD_LOGIC_ARITH.ALL;
--use IEEE.STD_LOGIC_UNSIGNED.ALL;
use ieee.numeric_std.all;
entity New1 is
port(
CLK : in std_logic;
y1,y10,y11,y12,y13,y14,y15,y16,y17,y18,y19,y2,y20,y21,y22,y23,y24,y25,y26 : out std_logic;
y27,y28,y29,y3,y30,y31,y32,y4,y5,y6,y7,y8,y9 : out std_logic
end New1;
signal x : std_logic_vector(4 downto 0) := "00000";
signal x1,x2,x3,x4,x5 : std_logic;
begin
process (clk)
begin
if (CLK'event and CLK ='1') then
x <= x+ "00001";
end if;
end process;
x1 <= x(0);
x2 <= x(1);
x3 <= x(2);
x4 <= x(3);
x5 <= x(4);
в моделсиме просто задайте тактовую частоту, для CLK
If it doesn't work in simulation, it won't work on the board.
"Ты живешь в своих поступках, а не в теле. Ты — это твои действия, и нет другого тебя" Антуан де Сент-Экзюпери повесть "Маленький принц"
_alex__
сообщение Mar 26 2017, 09:19
получилось таки с помощью счетчика вывести значения выходов в wave.
а как вывести значения выходов в файл в виде списка двоичных чисел?
RSS Текстовая версия Сейчас: 26th April 2018 - 11:20
Страница сгенерированна за 0.01065 секунд с 7
