> Как задать значения для проверки таблицы истинности?
_alex__
сообщение Mar 14 2017, 14:03
Пользователь №: 82 059
Имеется устройство с таким vhdl кодом:
entity New1 is
port(
    x1,x2,x3,x4,x5 : in bit;
    y1,y10,y11,y12,y13,y14,y15,y16,y17,y18,y19,y2,y20,y21,y22,y23,y24,y25,y26,y
27,y28,y29,y3,y30,y31,y32,y4,y5,y6,y7,y8,y9 : out bit
end New1;
architecture New1_functional of New1 is
begin
y1 <= x1 and x2 and x3 and x4 and x5;
y10 <= (not x1) and x2 and x3 and x4 and (not x5);
y11 <= (not x1) and x2 and x3 and (not x4) and x5;
y12 <= x1 and x2 and x3 and x4 and (not x5);
y13 <= (not x1) and x2 and x3 and (not x4) and (not x5);
y14 <= (not x1) and x2 and (not x3) and x4 and x5;
y15 <= (not x1) and x2 and (not x3) and x4 and (not x5);
y16 <= (not x1) and x2 and (not x3) and (not x4) and x5;
y17 <= (not x1) and x2 and (not x3) and (not x4) and (not x5);
y18 <= (not x1) and (not x2) and x3 and x4 and x5;
y19 <= (not x1) and (not x2) and x3 and x4 and (not x5);
y2 <= x1 and (not x2) and x3 and x4 and (not x5);
y20 <= (not x1) and (not x2) and x3 and (not x4) and x5;
y21 <= (not x1) and (not x2) and x3 and (not x4) and (not x5);
y22 <= (not x1) and (not x2) and (not x3) and x4 and x5;
y23 <= x1 and x2 and x3 and (not x4) and x5;
y24 <= (not x1) and (not x2) and (not x3) and x4 and (not x5);
y25 <= (not x1) and (not x2) and (not x3) and (not x4) and x5;
y26 <= (not x1) and (not x2) and (not x3) and (not x4) and (not x5);
y27 <= x1 and x2 and x3 and (not x4) and (not x5);
y28 <= x1 and x2 and (not x3) and x4 and x5;
y29 <= x1 and x2 and (not x3) and x4 and (not x5);
y3 <= x1 and (not x2) and x3 and (not x4) and x5;
y30 <= x1 and x2 and (not x3) and (not x4) and x5;
y31 <= x1 and x2 and (not x3) and (not x4) and (not x5);
y32 <= x1 and (not x2) and x3 and x4 and x5;
y4 <= x1 and (not x2) and x3 and (not x4) and (not x5);
y5 <= x1 and (not x2) and (not x3) and x4 and x5;
y6 <= x1 and (not x2) and (not x3) and x4 and (not x5);
y7 <= x1 and (not x2) and (not x3) and (not x4) and x5;
y8 <= x1 and (not x2) and (not x3) and (not x4) and (not x5);
y9 <= (not x1) and x2 and x3 and x4 and x5;
end New1_functional;
Нужно проверить таблицу истинности для всех возможных значений на входе.
Помогите написать vhdl тестовый файл, содержащий полный набор входных значений и
вывода значений выходов таблицы истинности в stdout.
Maverick
сообщение Mar 15 2017, 11:56
я только учусь...
Из: Украина
Пользователь №: 24 839
подайте на вход 5 битный счетчик, результаты запишите в файл, далее матлабом или ПО проверяете результат работы..
If it doesn't work in simulation, it won't work on the board.
"Ты живешь в своих поступках, а не в теле. Ты — это твои действия, и нет другого тебя" Антуан де Сент-Экзюпери повесть "Маленький принц"
_alex__
сообщение Mar 25 2017, 19:22
помогите написать код для подачи на мое устройство кода с двоичного 5-разрядного счетчика.
Александр77
сообщение Mar 26 2017, 08:50
Из: Дубна, Московская область
Пользователь №: 51 111
Как-то так
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity New1_test
port(
y1,y10,y11,y12,y13,y14,y15,y16,y17,y18,y19,y2,y20,y21,y22,y23,y24,y25,y26,y27,y2
8,y29,y3,y30,y31,y32,y4,y5,y6,y7,y8,y9 : out std_logic
end entity;
architecture tst of New1_test is
component New1 is
port(
    x1,x2,x3,x4,x5 : in std_logic;
27,y28,y29,y3,y30,y31,y32,y4,y5,y6,y7,y8,y9 : out std_logic
end component;
signal x1,x2,x3,x4,x5 : std_logic:='0';
begin
D1:New1
port map(
    x1,
    x2,
    x3,
    x4,
    x5,
    y1,
    y10,
    y11,
    y12,
    y13,
    y14,
    y15,
    y16,
    y17,
    y18,
    y19,
    y2,
    y20,
    y21,
    y22,
    y23,
    y24,
    y25,
    y26,
    y27,
    y28,
    y29,
    y3,
    y30,
     y31,
    y32,
    y4,
    y5,
    y6,
    y7,
    y8,
     y9
count:process
variable cnt_v:unsiged(4 downto 0):=to_unsigned(0,5);
constant step_c:unsigned(4 downto 0):=to_unsigned(1,5);
begin
    wait for 100 ns; x5<=std_logic(cnt_v(4)); x4<=std_logic(cnt_v(3)); x3<=std_logic(cnt_v(2)); x2<=std_logic(cnt_v(1)); x1<=std_logic(cnt_v(0));
   wait for 100 ns; cnt_v:=cnt_v+step_v;
end tst;
А еще с целью уменьшения в последующем строк и назначений, можно в самом проекте изначально объявлять сигналы векторами.
RSS Текстовая версия Сейчас: 23rd May 2018 - 01:00
Страница сгенерированна за 0.01052 секунд с 7
