dimone 0 21 марта, 2018 Опубликовано 21 марта, 2018 · Жалоба Подскажите пожалуйста, куда к0пать: Если Impаст запускается из ISE navigator, то USB программатор опредляется и нормально работает: CPROGRESS_START - Starting Operation. Connecting to cable (Usb Port - USB21). Checking cable driver. Driver file xusb_xlp.sys found. Driver version: src=1029, dest=1029. Driver windrvr6.sys version = 10.2.1.0. WinDriver v10.21 Jungo (c) 1997 - 2010 Build Date: Aug 31 2010 x86_64 64bit SYS 14:14:44, version = 1021. Cable PID = 0008. Max current requested during enumeration is 74 mA. Type = 0x0004. Cable Type = 3, Revision = 0. Setting cable speed to 6 MHz. Cable connection established. Firmware version = 1303. File version of C:/Xilinx/14.7/ISE_DS/ISE/data/xusb_xlp.hex = 1303. Firmware hex file version = 1303. PLD file version = 0012h. PLD version = 0012h. PROGRESS_END - End Operation. Но если из "Plan Аheаd"-, то не опредляется , и пишет : PROGRESS_START - Starting Operation. Connecting to cable (Usb Port - USB21). Checking cable driver. Source driver files not found. The Platform Cable USB is not detected. Please connect a cable.If a cable is connected, please disconnect and reconnect to the usb port, follow the instructions in the 'Found New Hardware Wizard', then retry the Cable Setup operation. Cable connection failed. Connecting to cable (Parallel Port - LPT1). Checking cable driver. Your driver installation is not complete. Please re-run your application or run install_drivers.exe from the ISE installation area as an Administrator to complete the driver installation. Service using windrvr6.sys : SYSTEM\CurrentControlSet\Services\windrvr6. ImagePath = \SystemRoot\System32\drivers\WINDRVR6.SYS. DisplayName = windrvr6. Start = 2. ErrorControl = 1. Type=1. Service using windrvr6.sys : SYSTEM\CurrentControlSet\Services\WinDriver6. ImagePath = \SystemRoot\system32\drivers\windrvr6.sys. Start = 3. ErrorControl = 1. Type=1. Cable connection failed. Connecting to cable (Parallel Port - LPT2). Checking cable driver. Your driver installation is not complete. Please re-run your application or run install_drivers.exe from the ISE installation area as an Administrator to complete the driver installation. Service using windrvr6.sys : SYSTEM\CurrentControlSet\Services\windrvr6. ImagePath = \SystemRoot\System32\drivers\WINDRVR6.SYS. DisplayName = windrvr6. Start = 2. ErrorControl = 1. Type=1. Service using windrvr6.sys : SYSTEM\CurrentControlSet\Services\WinDriver6. ImagePath = \SystemRoot\system32\drivers\windrvr6.sys. Start = 3. ErrorControl = 1. Type=1. Cable connection failed. Connecting to cable (Parallel Port - LPT3). Checking cable driver. Your driver installation is not complete. Please re-run your application or run install_drivers.exe from the ISE installation area as an Administrator to complete the driver installation. Service using windrvr6.sys : SYSTEM\CurrentControlSet\Services\windrvr6. ImagePath = \SystemRoot\System32\drivers\WINDRVR6.SYS. DisplayName = windrvr6. Start = 2. ErrorControl = 1. Type=1. Service using windrvr6.sys : SYSTEM\CurrentControlSet\Services\WinDriver6. ImagePath = \SystemRoot\system32\drivers\windrvr6.sys. Start = 3. ErrorControl = 1. Type=1. Cable connection failed. Connecting to cable (Parallel Port - LPT4). Checking cable driver. Your driver installation is not complete. Please re-run your application or run install_drivers.exe from the ISE installation area as an Administrator to complete the driver installation. Service using windrvr6.sys : SYSTEM\CurrentControlSet\Services\windrvr6. ImagePath = \SystemRoot\System32\drivers\WINDRVR6.SYS. DisplayName = windrvr6. Start = 2. ErrorControl = 1. Type=1. Service using windrvr6.sys : SYSTEM\CurrentControlSet\Services\WinDriver6. ImagePath = \SystemRoot\system32\drivers\windrvr6.sys. Start = 3. ErrorControl = 1. Type=1. Cable connection failed. PROGRESS_END установка не помогает: wdreg.exe -inf C:\Xilinx\14.7\ISE_DS\ISE\bin\nt64\xusbdrvr.inf install WDREG utility v10.21. Build Aug 31 2010 14:21:54 Processing HWID USB\VID_03FD&PID_0008 Installing a signed driver package for USB\VID_03FD&PID_0008 Device node (hwid:USB\VID_03FD&PID_0008): exists and is configured. Installing. CM_Get_DevNode_Status ret value 0, status 180600a, problem 0 LOG ok: 1, ENTER: DriverPackageInstallA LOG ok: 1, ENTER: DriverPackageInstallW LOG ok: 1, Looking for Model Section [DeviceList.ntamd64]... LOG ok: 1, Installing INF file 'C:\Xilinx\14.7\ISE_DS\ISE\bin\nt64\xusbdrvr.inf' (Plug and Play). LOG ok: 1, Looking for Model Section [DeviceList.ntamd64]... LOG ok: 1, Installing devices with Id "USB\VID_03FD&PID_0008&REV_0000" using INF "C:\WINDOWS\System32\DriverStore\FileRepository\xusbdrvr.inf_amd64_1af2fe242bfdedb1\xusbdrvr.inf". LOG ok: 1, Will force install because driver is not better and force flag is set. LOG ok: 1, ENTER UpdateDriverForPlugAndPlayDevices... LOG ok: 0, RETURN UpdateDriverForPlugAndPlayDevices. LOG ok: 1, Installation was successful. LOG ok: 1, Installing devices with Id "USB\VID_03FD&PID_000F&REV_0000" using INF "C:\WINDOWS\System32\DriverStore\FileRepository\xusbdrvr.inf_amd64_1af2fe242bfdedb1\xusbdrvr.inf". LOG ok: 1, Installation did not occur because the hardware isn't currently present. LOG ok: 1, Phantom Device with Hardware/Compatible Id 'USB\VID_03FD&PID_000F&REV_0000' already has 'C:\WINDOWS\System32\DriverStore\FileRepository\xusbdrvr.inf_amd64_1af2fe242bfdedb1\xusbdrvr.inf' installed on it. LOG ok: 0, Install completed LOG ok: 1, RETURN: DriverPackageInstallW (0x0) LOG ok: 1, RETURN: DriverPackageInstallA (0x0) difx_install_preinstall_inf: err 0, last event 0, last error 0. SUCCESS install: completed successfully Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
