4 страниц V  « < 2 3 4
> вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: 008
rloc
сообщение Jul 26 2018, 09:01
Сообщение #46
Узкополосный широкополосник
Из: Moscow
Пользователь №: 1 462
Sigrity 2018 Whats New
https://www.cadence.com/content/cadence-www...cles-by-in.html
https://www.cadence.com/content/cadence-www...-whats-new.html
Прикрепленный файл  Base_SIG18.00.000_README_Release_Notes.pdf ( 6.53 мегабайт ) Кол-во скачиваний: 35
rom67
сообщение Aug 3 2018, 16:27
Сообщение #47
Пользователь №: 88 095
вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: 044
Fixed CCRs: SPB 17.2 HF044
07-27-2018
CCRID   Product            ProductLevel2 Title
1943727 ADW                DBEDITOR      EDM DBEditor: Cannot check in/out schematic model symbols with many linked parts
1800630 ADW                FLOW_MGR      Support spaces in design directory path on Windows
1951052 ADW                LRM           LRM stops responding on project update and removes parts from design
1891428 ADW                PART_MANAGER  Resistor turns into a capacitor when placed
1945194 ALLEGRO_EDITOR     3D_CANVAS     3D Viewer crashes when opening from board file.
1935558 ALLEGRO_EDITOR     INTERFACES    Exported STEP file missing components when viewed in free STEP viewer
1945640 ALLEGRO_EDITOR     MULTI_USER    Symphony client disconnects from server without any notification
1948454 ALLEGRO_EDITOR     MULTI_USER    Window DRC stops responding when run in Symphony
1946619 ALLEGRO_EDITOR     SHAPE         Pin/via with suppressed pad on shape layer and thermal connection type of none should void to drill hole.
1946708 ALLEGRO_EDITOR     SHAPE         Same net hole to shape voiding is incorrect.
1952213 ALLEGRO_EDITOR     SHAPE         Shape voiding from Thru Via when the via regular pad is not completely drilled out by Backdrill hole is not consistent
1889433 ALLEGRO_EDITOR     UI_GENERAL    Command window shows result at the end of a command rather than showing dynamic updates
1933503 ALLEGRO_EDITOR     UI_GENERAL    Extra click required to enable command window
1943692 ALLEGRO_EDITOR     UI_GENERAL    Funckey commands are not working
1945914 ALLEGRO_EDITOR     UI_GENERAL    Mouse focus lost in the command console when doing an 'undo' from the toolbar icon
1945920 ALLEGRO_EDITOR     UI_GENERAL    Focus lost from command window when the toolbar is used for any operation
1949922 ALLEGRO_EDITOR     UI_GENERAL    Focus lost from command window after save or even autosave
1947551 ALLEGRO_EDITOR     WIREBOND      PCB Editor crashes in wirebond edit mode
1935722 ALLEGRO_PROD_TOOLB OTHERS        Panelization: Cannot place parts after migrating design from release 16.6 to 17.2-2016
1951511 APD                REPORTS       The result of Metal Usage Report is incorrect.
1952942 ASDA               GRAPHICS      Need metric (mm) support in grids in SDA
1948122 ASDA               TDO           If user ID has uppercase characters in teamassignmenttemplate.xml, TDO fails to join a project
1931199 CONCEPT_HDL        COPY_PROJECT  Stop hard coding Copy Project license inside EDM
1938153 CONCEPT_HDL        OTHER         Component Browser stops responding on replacing and modifying components
1770601 CONCEPT_HDL        PDF           Wire Pattern set to two-dot chain line not shown in PDF
1791175 PCB_LIBRARIAN      CORE          Allow baseline of cells with pins at symbol origin: change error to warning
1922238 PCB_LIBRARIAN      CORE          Unable to check in into EDM Server due to con2con error SPLBPD-323 - Origin on pin connection point
1936812 PCB_LIBRARIAN      GRAPHICAL_EDI New Symbol Editor: Wrong text being updated when editing text after copy and paste
1804159 PCB_LIBRARIAN      SYMBOL_EDITOR Copy and paste of pins in new symbol editor: issues with pin name, rotation, and move
1927422 PCB_LIBRARIAN      SYMBOL_EDITOR Symbol outline not updated correctly in the new default graphic editor in Part Developer release 17.2-2016
1939272 PCB_LIBRARIAN      SYMBOL_EDITOR Symbol Editor changes origin to bottom left, outline to invisible, shows rectangle with center rectangle at new origin
1928076 RF_PCB             DISCRETE_LIBX dlibx2iff does not work with managed libraries and library-level PTF
1929574 RF_PCB             DISCRETE_LIBX Discrete Library to third-party Translator does not populate the Available Parts section correctly
1850360 TDA                CORE          TDO crashes while changing the root design
1934388 TDA                SDA           SDA TDO crashes on attempting to check in a 'New Block in Shared Area'
kudor
сообщение Aug 6 2018, 22:22
Сообщение #48
Пользователь №: 102 024
ВРоде много пишут о фиксах Symbol Editor, а как на самом деле - что не исправлено? Рабочий Symbol Editor, стоит ставить?
rom67
сообщение Aug 11 2018, 22:51
Сообщение #49
вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: 045
Fixed CCRs: SPB 17.2 HF045
08-10-2018
1934956 ADW                DBEDITOR      Footprint missing from part in release 17.2-2016
1945005 ADW                DSN_MIGRATION Right side of Migration dialog box is cut off
1933245 ADW                FLOW_MGR      'Open last Project' button should open the last opened project
1953210 ADW                LIBDISTRIBUTI Library Distribution is not distributing all symbols. No errors for the missing schematic models.
1953727 ADW                LRM           LRM missing two symbols when migrating from release 16.6 to 17.2-2016
1952923 ALLEGRO_EDITOR     DATABASE      PCB Editor crashes on trying to delete layer
1957171 ALLEGRO_EDITOR     DATABASE      Pastemask offset not working when creating a symbol that requires two top-paste masks
1960059 ALLEGRO_EDITOR     DATABASE      Stackup definition causes custom script to crash
1932864 ALLEGRO_EDITOR     DFM           Exporting DFM Constraints losing the association to design level
1957467 ALLEGRO_EDITOR     EDIT_SHAPE    Compose Shape copies lines to wrong subclass
1938536 ALLEGRO_EDITOR     GRAPHICS      Multiple crashes on different boards after installing hotfix 040
1954075 ALLEGRO_EDITOR     SHAPE         Dynamic Crosshatch shapes should be clipped inside RKI if RKI Autoclip is enabled
1957803 ALLEGRO_EDITOR     SHAPE         Wrong dynamic shape status
1949923 ALLEGRO_EDITOR     UI_GENERAL    Focus lost from command window when any command is active
1963245 ALLEGRO_EDITOR     UI_GENERAL    Alias behaves as Funckey in release 17.2-2016, hotfix 044
1892126 ALLEGRO_PROD_TOOLB CORE          Clines disappear and then reappear suddenly on using Route - Shield Generator
1931127 ALLEGRO_PROD_TOOLB CORE          ZDRC not working for Xhatch Shape
1932563 ALLEGRO_PROD_TOOLB CORE          allegro_legacy_board_outline environment variable not set in PCB Design Compare.
1929855 ALLEGRO_PROD_TOOLB OTHERS        Outline not exported correctly for PCB design compare if Design_Outline and Cutout exist
1956494 APD                DATABASE      DBDoctor removes pads
1956291 APD                INTERACTIVE   axlSpreadsheetSetStyleProp should accept 0 and 1 as Boolean values for protection style
1960127 ASDA               ARCHIVER      Using the Tcl command 'archiveproject' crashes SDA
1953718 ASDA               CONSTRAINT_MA SDA Import Pin Delay fails with extra columns, does not explain why
1924498 CAPTURE            SCHEMATIC_EDI Cannot place part 'B' for heterogeneous part if 'Preferences - Miscellaneous - Auto References' not set
1927129 CAPTURE            SCHEMATIC_EDI unable to place heterogeneous part section directly from place part window
1928255 CAPTURE            SCHEMATIC_EDI Unable to place a specific section from Place Part
1945207 CAPTURE            SCHEMATIC_EDI Part selection pull-down reverts to part '1|A' when placing heterogeneous part
1945661 CAPTURE            SCHEMATIC_EDI Section drop-down in Place Part window is not working
1958121 CAPTURE            SCHEMATIC_EDI Preview and placement of sections of Heterogeneous parts is not correct in New Symbol Editor
1956535 CONCEPT_HDL        CORE          DE-HDL crashes on Import Pin Delay for a CSV file
1960922 CONCEPT_HDL        CORE          DE-HDL crashes on moving netgroup on Windows 10
1964016 CONCEPT_HDL        CORE          In DE-HDL moving around nets connected to Netgroups causes crash on Windows 10
1907040 F2B                PACKAGERXL    Export Physical output board file name reverts to old when changing options
1957862 ORBITIO            ALLEGRO_SIP_I allegro2orbit failed to translate rounded rectangle padstack
Flood
сообщение Aug 13 2018, 16:09
Сообщение #50
Пользователь №: 17 871
Спасибо!
rom67
сообщение Aug 26 2018, 16:24
Сообщение #51
вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: 046
Fixed CCRs: SPB 17.2 HF046
08-24-2018
1880800 ADW                PART_BROWSER  Server connection failure on a running SDA session.
1880895 ADW                PART_BROWSER  NCB - components missing from the component browser
1962336 ALLEGRO_EDITOR     INTERFACES    Smart PDF shows both top and bottom probe layers for a film layer with only a single probe layer (top or bottom)
1955128 ALLEGRO_EDITOR     MANUFACT      Need to close PCB Editor to delete xsectionChart.log generated on placing a cross-section chart
1969088 ALLEGRO_EDITOR     SHAPE         PCB Editor crashes on updating shapes to smooth
1963828 ASDA               DESIGN_EXPLOR Unwired schematic block movement with text is not correct
1954426 ASDA               OPEN_CLOSE_PR Double-clicking to paste a note crashes SDA
1965423 ASDA               OPEN_CLOSE_PR Crash when working with notes in SDA
1960060 ASDA               PART_MANAGER  Original property differences not displayed in Part Manager on selecting a new part from CB and doing reset
1960112 ASDA               PART_MANAGER  Part Manager incorrectly updating part property values
1955723 ASDA               ROUTING       Draw Multiple Bits misses bit 0 when in reverse order.
1952963 CONCEPT_HDL        CORE          Variant Editor takes a long time to load
1962568 CONCEPT_HDL        CORE          Directive DEHDL_BROWSER_FILEPATH does not work
1939192 PCB_LIBRARIAN      SYMBOL_EDITOR pin_text size and location very different between DE-HDL and Symbol Editor resulting in text overlap
1952967 SCM                OTHER         Error while copying a release 17.2-2016 design: message says design created in release 16.3 or an earlier version
1948999 SPIF               OTHER         Some place_keepout shapes and antipads not exported
rom67
сообщение Sep 13 2018, 19:54
Сообщение #52
вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: 047
Fixed CCRs: SPB 17.2 HF047
09-9-2018
1969527 ADW                LIBIMPORT     Getting  java.lang.NullPointerException error on bulk import in hotfix 044
1976219 ALLEGRO_EDITOR     DATABASE       .SAV file not created although message reads it is producing one
1968270 ALLEGRO_EDITOR     DFM           PCB Editor crashes when running DRC
1978421 ALLEGRO_EDITOR     DRC_CONSTR    False DRCs between via and its fillet shown after editing shape boundary
1966772 ALLEGRO_EDITOR     PAD_EDITOR    PCB Editor and DBDoctor crash on editing DRA file: Found bad pointer, run dbdoctor
1973866 ALLEGRO_EDITOR     SHAPE         PCB Editor crashes when deleting a group
1818779 ALLEGRO_EDITOR     UI_FORMS      DialogueBox goes behind Canvas when clicked on Allegro Main Window
1880175 ALLEGRO_EDITOR     UI_GENERAL    Multiple Session of 17.2 PCB Editor gets mixed up in Linux
1946027 ALLEGRO_EDITOR     UI_GENERAL    Arrow Keys in Canvas stop responding after changing the view.
1967701 ALLEGRO_EDITOR     UI_GENERAL    Arrow Key panning does not work when third-party SKILL call is active
1967706 ALLEGRO_EDITOR     UI_GENERAL    Observe Special Characters when command is run
1971183 ALLEGRO_EDITOR     UI_GENERAL    Focus is lost from command line when Save icon is used
1971186 ALLEGRO_EDITOR     UI_GENERAL    Focus from Command line is lost when using CTRL + N
1971190 ALLEGRO_EDITOR     UI_GENERAL    Focus from Command line is lost when using CTRL + Alt
1971200 ALLEGRO_EDITOR     UI_GENERAL    Focus is lost in comand line when you save using command save
1961833 APD                SHAPE         Crash when changing dimension of existing via padstack in the design
1968256 ASDA               EXPORT_PCB    SDA crashes directly after Export to PCB
1970284 ASDA               EXPORT_PCB    Placing part crashes SDA
copov
сообщение Сегодня, 07:25
Сообщение #53
Пользователь №: 3 012
Есть ли смысл выкладывать на FTP?
Hotfix_SPB16.60.112_wint
Aner
сообщение Сегодня, 07:33
Сообщение #54
Из: СПБ
Пользователь №: 35 463
QUOTE (copov @ Sep 20 2018, 10:25) *
yes
7 чел. читают эту тему (гостей: 6, скрытых пользователей: 0)
Пользователей: 1 Ksev-vrn
RSS Текстовая версия Сейчас: 20th September 2018 - 08:44
Страница сгенерированна за 0.00919 секунд с 7
