Перейти к содержанию
Проблема с Synopsys
Пытаюсь скомпилировать исходник для симуляции:
vcs ../src/module.v -sverilog  -full64 +v2k -debug_all
drozel@PC:/media/sf_shareFolder/work/verilog/sim> /vcs ../src/module.v -sverilog  -full64 +v2k -debug_all
Warning-[LNX_OS_VERUN] Unsupported Linux version
  Linux version 'openSUSE 42.1 (x86_64)
  VERSION = 42.1
  CODENAME = Malachite
  # /etc/SuSE-release is deprecated and will be removed in the future, use
  /etc/os-release instead' is not supported on 'x86_64' officially, assuming
  linux compatibility by default. Set VCS_ARCH_OVERRIDE to linux or suse32 to
  override.
  Please refer to release notes for information on supported platforms.
Warning-[LINX_KRNL] Unsupported Linux kernel
  Linux kernel '4.1.13-5-default' is not supported.
  Supported versions are 2.4* or 2.6*.
                         Chronologic VCS (TM)
         Version G-2012.09_Full64 -- Tue Jan 19 14:06:20 2016
               Copyright (c) 1991-2012 by Synopsys Inc.
                         ALL RIGHTS RESERVED
This program is proprietary and confidential information of Synopsys Inc.
and may be used and disclosed only as authorized in a license agreement
controlling such use and disclosure.
Parsing design file '../src/module.v'
Top Level Modules:
       module
No TimeScale specified
Starting vcs inline pass...
2 modules and 0 UDP read.
    However, due to incremental compilation, no re-compilation is necessary.
Assertion failed "rename(tmp_file, out_file) == 0" at line 833 in file cgmop.c
Command line: /soft/vcs/amd64/bin/cgmop1 -pic -gen_obj rmapats.m rmapats_mop.o
--- Stack trace follows:
sh: 26924: command not found
No context available
filelist.hsopt:2: recipe for target 'rmapats_mop.o' failed
make: *** [rmapats_mop.o] Error 255
Make exited with status 2
CPU time: .080 seconds to compile + 0 seconds to elab + .008 seconds to link
Кто знает, в чем может быть проблема?
OS: OpenSUSE 13.2 x64
Пробовал запускать и 32 и 64-битный vcs - ошибка одна
Изменено пользователем drozel
Поделиться сообщением
Ссылка на сообщение
Поделиться на другие сайты
А вас не смущает, что тул 6-й ред хат требует?
Как мне сказали, работает на сусе. Правда, возможно, на более старой версии.
Думаете, без шансов?
Ссылка на сообщение
Подтверждаю что на сюсе x64 всё работает. Запускал симуляцию 2 года назад на последнем на тот момент дистрибутиве сюсе. Сейчас уже нет доступа к тому компу, поэтому точную версию дистрибутива и vcs сказать не могу. Но работало точно, и архитектура была x64. Всё симулировалось.
Ссылка на сообщение
Уважаемый, drozel.
VCS падает по причине того, что вы запускаете его в расшаренной папке.
Виртуал бокс не поддерживает хардлинки, которые vcs пытается использовать на этапе компиляции.
https://www.virtualbox.org/ticket/818
Ссылка на сообщение
Может уже за два года это исправили и в host Linux.
В VMware, линки не работают только, если host - Windows.
Ссылка на сообщение
ниразу.
подтверждаю на RHEL7 -> RHEL7 в VBox такая же проблема с vcs, если пускать из расшареной папки
Ссылка на сообщение
ниразу.
У меня в host Linux везде работают линки (с vcs в том числе). Но в vbox надо их разрешить в настройках виртуалки (они там по-умолчанию отключены по соображениям безопасности).
Ссылка на сообщение
можно скрин где это включается?
не могу найти такой птички в настройках((
PS: Vbox 5.0.8
Ссылка на сообщение
PS: Vbox 5.0.8
Это не в настройках.
Это отдельной командой:
VBoxManage setextradata VM_NAME VBoxInternal2/SharedFoldersEnableSymlinksCreate/SHARE_NAME 1
Ссылка на сообщение
Присоединяйтесь к обсуждению
Гость
Ответить в этой теме...
  • Создать...
