jenya7 0 13 октября, 2016 Опубликовано 13 октября, 2016 (изменено) · Жалоба странная проблема с UART. сначала инициализация. void UART_Init (UART_MemMapPtr uartch, int sysclk, int baud) { register uint16_t sbr, brfa; uint8_t temp; if (uartch == UART2_BASE_PTR) { PORTE_PCR16 = PORT_PCR_MUX(0x3); PORTE_PCR17 = PORT_PCR_MUX(0x3); SIM_SCGC4 |= SIM_SCGC4_UART2_MASK; } /* Make sure that the transmitter and receiver are disabled while we change settings. */ UART_C2_REG(uartch) &= ~(UART_C2_TE_MASK| UART_C2_RE_MASK ); /* Configure the UART for 8-bit mode, no parity */ UART_C1_REG(uartch) = 0; /* We need all default settings, so entire register is cleared */ /* Calculate baud settings */ sbr = (uint16_t)((sysclk*1000)/(baud * 16)); /* Save off the current value of the UARTx_BDH except for the SBR field */ temp = UART_BDH_REG(uartch) & ~(UART_BDH_SBR(0x1F)); UART_BDH_REG(uartch) = temp | UART_BDH_SBR(((sbr & 0x1F00) >> 8)); UART_BDL_REG(uartch) = (uint8_t)(sbr & UART_BDL_SBR_MASK); /* Determine if a fractional divider is needed to get closer to the baud rate */ brfa = (((sysclk*32000)/(baud * 16)) - (sbr * 32)); /* Save off the current value of the UARTx_C4 register except for the BRFA field */ temp = UART_C4_REG(uartch) & ~(UART_C4_BRFA(0x1F)); UART_C4_REG(uartch) = temp | UART_C4_BRFA(brfa); /* Enable receiver and transmitter */ UART_C2_REG(uartch) |= (UART_C2_TE_MASK | UART_C2_RE_MASK | UART_C2_RIE_MASK); //errors – FOR DEBUG ONLY UART_C3_REG(uartch) |= UART_C3_PEIE_MASK | UART_C3_FEIE_MASK | UART_C3_NEIE_MASK | UART_C3_ORIE_MASK; NVIC_EnableIRQ(UART2_RX_TX_IRQn); //FOR DEBUG ONLY NVIC_EnableIRQ(UART2_ERR_IRQn ); } void UART2_RX_TX_IRQHandler(void) { if ((UART_S1_REG(channel) & UART_S1_RDRF_MASK)) { uint8_t chr = UART2->D; UART_SendByte(UART2, chr); } } void UART2_ERR_IRQHandler(void) { uint32_t st = UART2_BASE_PTR->S1; } так я посылаю строку на терминал void UART_SendByte (UART_MemMapPtr channel, char ch) { /* Wait until space is available in the FIFO */ while(!(UART_S1_REG(channel) & UART_S1_TDRE_MASK)); /* Send the character */ UART_D_REG(channel) = (uint8_t)ch; } void UART_SendString(UART_MemMapPtr uartChannel, const char *p) { while(*p) { UART_SendByte(uartChannel, *p++); } } в main.c UART_Init (UART2, 60000, 115200); UART_SendString(UART2, "HELLO EVERYBODY\0"); While (1) { } на терминале вижу мусор. но если ввожу задержку void UART_SendString(UART_MemMapPtr uartChannel, uint8_t *p) { while(*p) { UART_SendByte(uartChannel, *p++); //~100us for (int i = 0; i < 10000; i++) { asm("NOP"); } } } на терминале вижу коректную строку. также если печатаю попадаю в UART2_ERR_IRQHandler с ошибкой Framing Error . очень похоже на Framing Error вопрос откуда она береться. Изменено 13 октября, 2016 пользователем Jenya7 Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Kabdim 0 13 октября, 2016 Опубликовано 13 октября, 2016 · Жалоба С процом незнаком, но... включения фифо нигде не вижу. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
jenya7 0 13 октября, 2016 Опубликовано 13 октября, 2016 (изменено) · Жалоба С процом незнаком, но... включения фифо нигде не вижу. так я без фифо. у них фифо дурацкий. нету отдельного флага на принятие чара и достижения заданного уровня фифо. один флаг на все и крутись как хочешь. хотя...сейчас посмотрел. есть Receive Buffer/FIFO Empty Flag. можно и его использовать. но по любому фифо выключен и не должен влиять на посылку. Изменено 13 октября, 2016 пользователем Jenya7 Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
mantech 32 13 октября, 2016 Опубликовано 13 октября, 2016 · Жалоба так я без фифо. Может не в тему, с их кинетисами не работал, но в МХ серии уарт с выключенным фифо у меня отказывался нормально работать, пришлось включить и установить прерывание по 1 входящему символу. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Kabdim 0 14 октября, 2016 Опубликовано 14 октября, 2016 · Жалоба но по любому фифо выключен и не должен влиять на посылку. Опять же вангование на основе чтения доки, но кмк там описано, что UART_S1_REG(channel) & UART_S1_TDRE_MASK флаг работает только с фифо. Такое ощущение что без фифо он всегда 1, вследствие чего в регистр пихается новое значение до отправки старого. Проверьте пожалуйста. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
jenya7 0 14 октября, 2016 Опубликовано 14 октября, 2016 · Жалоба Опять же вангование на основе чтения доки, но кмк там описано, что UART_S1_REG(channel) & UART_S1_TDRE_MASK флаг работает только с фифо. Такое ощущение что без фифо он всегда 1, вследствие чего в регистр пихается новое значение до отправки старого. Проверьте пожалуйста. А вы знаете вы таки правы. Надо проверять Transmit Complete Flag (UART_S1_TC_MASK). Тогда все работает. Снимаю шляпу. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Kabdim 0 17 октября, 2016 Опубликовано 17 октября, 2016 · Жалоба Получено достижение "Отладка по документации". Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
