Перейти к содержанию
ADC прерывания в STM32
Пытаюсь настроить ADC1 stm32f217 для работы по прерываниям (по окончании цикла преобразования).
void ADC_Config(void)
 ADC_InitTypeDef       ADC_InitStructure;
 ADC_CommonInitTypeDef ADC_CommonInitStructure;
 DMA_InitTypeDef       DMA_InitStructure;
 GPIO_InitTypeDef      GPIO_InitStructure;
 NVIC_InitTypeDef      NVIC_InitStructure;
 /* Enable ADC1, DMA2 and GPIO clocks ****************************************/
 RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_DMA2 | RCC_AHB1Periph_GPIOA, ENABLE);
 RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1, ENABLE);
 /* DMA2 Stream0 channel2 configuration **************************************/
 DMA_InitStructure.DMA_Channel = DMA_Channel_0;
 DMA_InitStructure.DMA_PeripheralBaseAddr = (uint32_t)ADC1_DR_ADDRESS;
 DMA_InitStructure.DMA_Memory0BaseAddr = (uint32_t)&ADC1ConvertedValue;
 DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralToMemory;
 DMA_InitStructure.DMA_BufferSize = 1;
 DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
 DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Disable;
 DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
 DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
 DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;
 DMA_InitStructure.DMA_Priority = DMA_Priority_High;
 DMA_InitStructure.DMA_FIFOMode = DMA_FIFOMode_Disable;
 DMA_InitStructure.DMA_FIFOThreshold = DMA_FIFOThreshold_HalfFull;
 DMA_InitStructure.DMA_MemoryBurst = DMA_MemoryBurst_Single;
 DMA_InitStructure.DMA_PeripheralBurst = DMA_PeripheralBurst_Single;
 DMA_Init(DMA2_Stream0, &DMA_InitStructure);
 DMA_Cmd(DMA2_Stream0, ENABLE);
 /* Configure ADC1 Channel4 pin as analog input ******************************/
 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4;
 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AN;
 GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL ;
 GPIO_Init(GPIOA, &GPIO_InitStructure);
 /* ADC Common Init **********************************************************/
 ADC_CommonInitStructure.ADC_Mode = ADC_Mode_Independent;
 ADC_CommonInitStructure.ADC_Prescaler = ADC_Prescaler_Div2;
 ADC_CommonInitStructure.ADC_DMAAccessMode = ADC_DMAAccessMode_Disabled;
 ADC_CommonInitStructure.ADC_TwoSamplingDelay = ADC_TwoSamplingDelay_5Cycles;
 ADC_CommonInit(&ADC_CommonInitStructure);
 /* ADC1 Init ****************************************************************/
 ADC_InitStructure.ADC_Resolution = ADC_Resolution_12b;
 // Режим сканирования
 ADC_InitStructure.ADC_ScanConvMode = DISABLE;
 // Непрерывное преобразование
 ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;
 ADC_InitStructure.ADC_ExternalTrigConvEdge = ADC_ExternalTrigConvEdge_None;
 ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
 ADC_InitStructure.ADC_NbrOfConversion = 1;
 ADC_Init(ADC1, &ADC_InitStructure);
 /* Enable and set the ADC interrupt to the highest priority */
 NVIC_InitStructure.NVIC_IRQChannel = ADC_IRQn;
 NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
 NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
 NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
 NVIC_Init(&NVIC_InitStructure);
 /* ADC1 regular channel4 configuration *************************************/
 ADC_RegularChannelConfig(ADC1, ADC_Channel_4, 1, ADC_SampleTime_112Cycles);
 /* Enable DMA request after last transfer (Single-ADC mode) */
 ADC_DMARequestAfterLastTransferCmd(ADC1, ENABLE);
 /* Enable ADC3 DMA */
 ADC_DMACmd(ADC1, ENABLE);
 /* Enable ADC3 */
 ADC_Cmd(ADC1, ENABLE);
В прерываниях пока просто переключаю светодиод (для визуализации прерываний)
void ADC_IRQHandler(void)
  STM_EVAL_LEDToggle(LED2);
  /* Clear the interrupt flag. */
  ADC_ClearFlag(ADC1, ADC_FLAG_EOC);
Не работает.
Правда в инициализации задействовано DMA (в DMA данные попадают как положено - успешно выводятся на COM1).
Но одно другого (DMA и прерывания по окончанию преобразования) вроде не должно касаться.
Гляньте код кому не лень. Может чего напутано в инициализации прерываний или в самоой void ADC_IRQHandler.
Поделиться сообщением
Ссылка на сообщение
Поделиться на другие сайты
Не работает.
EOCIE в регистре ADC_CR1 ?
Или что то типа
ADC_ITConfig(ADC1, ADC_IT_EOC, ENABLE) согласно Вашему стилю?
Правда это все для 1 серии. Но для второй наверняка так же.
Ссылка на сообщение
Ошибочка блин.
Не хватает.
/* Enable ADC1 Interrupt */
ADC_ITConfig(ADC1, ADC_IT_EOC, ENABLE);
Прерывания заработали но появилась проблема с семафором FReeRTOS
 STM_EVAL_LEDOn(LED2);
 portBASE_TYPE xHigherPriorityTaskWoken = pdFALSE;
 /* ADC1 received */
 if (ADC_GetFlagStatus(ADC1, ADC_FLAG_EOC) == SET)
   /* Give the semaphore to wakeup ADC task */
   xSemaphoreGiveFromISR( s_xSemaphore, &xHigherPriorityTaskWoken );
 /* Switch tasks if necessary. */
 if( xHigherPriorityTaskWoken != pdFALSE )
   portEND_SWITCHING_ISR( xHigherPriorityTaskWoken );
Не срабатывает он здесь
      for(;; )
        if (xSemaphoreTake( s_xSemaphore, portMAX_DELAY )==pdTRUE)
          text[1] = ADC1ConvertedValue;
          text[0] = ADC1ConvertedValue >> 8;
          netbuf_ref(buf1, text, sizeof(text));
          netconn_send(connn, buf1);
Ссылка на сообщение
Присоединяйтесь к обсуждению
Гость
Ответить в этой теме...
  • Создать...
