Frezer 0 May 20, 2016 Posted May 20, 2016 (edited) · Report post К сожалению обзавестись лицензией последней версии у меня сейчас возможности нет, поэтому попытаю счастье просто задав вопрос :rolleyes: Суть проблемы вот в чем: составил схему для моделирования, запустил и вот что вышло: **** 01/01/02 03:19:48 ********* PSpice 9.2 (Mar 2000) ******** ID# 1 ******** ** Profile: "proto2-proto2" [ E:\TEST\lab3-proto2-proto2.sim ] **** CIRCUIT DESCRIPTION ****************************************************************************** ** Creating circuit file "lab3-proto2-proto2.sim.cir" ** WARNING: THIS AUTOMATICALLY GENERATED FILE MAY BE OVERWRITTEN BY SUBSEQUENT SIMULATIONS *Libraries: * Local Libraries : .LIB ".\lab3.lib" * From [PSPICE NETLIST] section of C:\Program Files\Orcad\PSpice\PSpice.ini file: .lib "C:\Program Files\Orcad\Capture\Library\PSpice\IXYS.lib" .lib "C:\Program Files\Orcad\Capture\Library\PSpice\IXFK120N20.lib" .lib "C:\Program Files\Orcad\Capture\Library\PSpice\ixdd415si.lib" .lib "C:\Program Files\Orcad\Capture\Library\PSpice\blf242.lib" .lib "E:\TEST\lab3.lib" .lib "E:\TEST\LAB2.lib" .lib "E:\TEST\LAB1.lib" .lib "nom.lib" *Analysis directives: .DC LIN V_V2 0 60 0.01 .PROBE V(*) I(*) W(*) D(*) NOISE(*) .INC ".\lab3-proto2.net" **** INCLUDING lab3-proto2.net **** * source LAB3 V_V1 N00267 0 5.5Vdc V_V2 N00216 0 60Vdc M_Q3 N00216 N00267 0 0 501N04A **** RESUMING lab3-proto2-proto2.sim.cir **** .END WARNING -- Library file E:\TEST\lab3.lib has changed since index file lab3.ind was created. WARNING -- The timestamp changed from Tue Jan 01 03:18:58 2002 to Tue Jan 01 03:19:38 2002. Making new index file lab3.ind for library file lab3.lib Index has 1 entries from 1 file(s). * PSpice Model Editor - Version 9.2 *$ ********** *SYM=POWMOSN .subckt 501N04A 10 20 30 * TERMINALS: D G S * 500 Volt 4.5 Amp 1.5 ohm N-Channel Power MOSFET 10-30-2001 M1 1 2 3 3 DMOS L=1U W=1U RON 5 6 9.5 DON 6 2 D1 ROF 5 7 3.5 DOF 2 7 D1 D1CRS 2 8 D2 D2CRS 1 8 D2 CGS 2 3 .6N RD 4 1 1.5 DCOS 3 1 D3 RDS 1 3 5.0MEG LS 3 30 .1N LD 10 4 1N LG 20 5 1N .MODEL DMOS NMOS LEVEL=3 VTO=3.0 KP=6.0 .MODEL D1 D IS=.5F CJO=1P BV=100 M=.5 VJ=.6 TT=1N .MODEL D2 D IS=.5F CJO=175P BV=500 M=.5 VJ=.6 TT=1N RS=10M .MODEL D3 D IS=.5F CJO=250P BV=500 M=.3 VJ=.4 TT=400N RS=10M .ENDS *$ ERROR -- Model 501N04A used by M_Q3 is undefined Не знаю, что можно сделать, чтобы работало... Описываю примерный порядок произведенных действий: 1) скопировал текст модели из спецификации транзистора с сайта производителя 2) создал olb библиотеку в Orcad Capture 3) создал part, отрисовал и ввел параметры (см. рис. содержание библиотеки olb.bmp) 4) создал lib библиотеку в PSpice Model Editor (см. рис. библиотека lib.lib) 5) создал новую модель, перешел в текстовое представление, удалил все и скопировал содержание модели из спецификации (см. рис. содержание библиотеки lib.bmp) 6) сохранил все, пооткрывал все файлы - убедился, что все сохранилось 7) создал проект для моделирования, вставил файлы и попытался запустить процесс, однако ошибка все испортила. Лог моделирования см. вверху, параметры моделирования см. рис. параметры моделирования.bmp. Обращаю внимание, что все библиотеки были подключены. Также пробовал создать part для модели из lib библиотеки командой File->Create Capture Parts... Однако выдает ошибку типа: "Error - Failed to Find File [C:\...\Pspice\IXYS.err]!!!". Создание файла с таким расширением успеха не принесло. Edited May 20, 2016 by Frezer Quote Share this post Link to post Share on other sites More sharing options...
SSerge 3 May 20, 2016 Posted May 20, 2016 · Report post **** INCLUDING lab3-proto2.net **** * source LAB3 V_V1 N00267 0 5.5Vdc V_V2 N00216 0 60Vdc M_Q3 N00216 N00267 0 0 501N04A У спайса первая буква в имени компонента не просто так, она определяет что за тип модели будет использоваться. А именно, буква M в имени M_Q3 значит что спайс будет искать модель полевого транзистора с именем 501N04A, т.е. строку начинающуюся с .MODEL 501N04A ...... А модель, что Вы пытаетесь прикрутить сделана иначе - в виде подсхемы (.subckt), для таких компонентов их имя в нетлисте должно начинаться с буквы X, что-то вроде: X_Q3 N00216 N00267 0 501N04A Как сделать и подключить свой компонент и модель: http://electronix.ru/forum/index.php?showt...mp;#entry211107 Quote Share this post Link to post Share on other sites More sharing options...
Frezer 0 May 23, 2016 Posted May 23, 2016 · Report post А модель, что Вы пытаетесь прикрутить сделана иначе - в виде подсхемы (.subckt), для таких компонентов их имя в нетлисте должно начинаться с буквы X, что-то вроде: X_Q3 N00216 N00267 0 501N04A Как сделать и подключить свой компонент и модель: http://electronix.ru/forum/index.php?showt...mp;#entry211107 Интересная версия :rolleyes: В процессе решения проблемы возникла следующая трудность: по умолчанию в PSpiceTemplate: M^@REFDES %d %g %s %s @MODEL ?L/ \[email protected]/ ?W/ \[email protected]/ ?AD/ \[email protected]/ ?AS/ \[email protected]/ ?PD/ \[email protected]/ ?PS/ \[email protected]/ ?NDR/ \[email protected]/ ?NRS/ \[email protected]/ ?NRG/ \[email protected]/ ?NRB/ \[email protected]/ ?M/ \[email protected]/ Если, как предлагалось в примере, заменить строку выше на: X^@REFDES %d %g %s %s @MODEL или просто заменить М на Х в первой строчке, то, при симуляции выдает (и в 1-м и во 2-м случаях): ERROR -- Incorrect number of interface nodes for X_Q1 Я так понимаю это что-то связано с количеством/нумерацией пинов? :blink: Quote Share this post Link to post Share on other sites More sharing options...
Frezer 0 May 23, 2016 Posted May 23, 2016 · Report post ERROR -- Incorrect number of interface nodes for X_Q1 Убрал запись %s и все вроде встало, однако вот какая проблема: при запуске моделирования расчет остановился, выдав ошибку (см. прикрепленный); может кто знает с чем связано и где исправить/почитать? __________________.txt Quote Share this post Link to post Share on other sites More sharing options...
Zurabob 0 May 24, 2016 Posted May 24, 2016 · Report post Добрый день. Я конечно не специалист в PSpice , но у вас проблемы со сходимостью. Т.е. если бы вы нарисовали график , то он бы улетел в бесконечность. Моделирование не может быть продолжено из-за слишком больших чисел. ИМХО , где то ошибка в подключении чего то. ИМХО у вас течёт слишком большой ток где то из-за нулевого сопротивления где то. Quote Share this post Link to post Share on other sites More sharing options...
SSerge 3 May 24, 2016 Posted May 24, 2016 · Report post Для начала предлагаю включить резистор на несколько ом между затвором и источником напряжения, а если не поможет, то и в цепь стока тоже. Quote Share this post Link to post Share on other sites More sharing options...
Frezer 0 June 1, 2016 Posted June 1, 2016 · Report post Для начала предлагаю включить резистор на несколько ом между затвором и источником напряжения, а если не поможет, то и в цепь стока тоже. Добавление выше указанных резисторов не исправила ситуацию, однако изменение точности расчетов, в появляющемся при этой ошибке окне, позволило совершить моделирование до конца. Правда результат был получен не тот, который ожидался... Может быть проблема из-за этого изменения, хотя за точность "перевода" реального транзистора в виртуальный я не ручаюсь. Quote Share this post Link to post Share on other sites More sharing options...
def_rain 0 June 3, 2016 Posted June 3, 2016 (edited) · Report post Здравствуйте господа! Подскажите по базовому пакету Allegro. 1. Есть нарисованный замкнутый многоугольник посредством инструмента add line. Хочу преобразовать его в полигон, на том же слое Silkscreen. Есть ли такая возможность? По логике замкнутый контур и полигон почти одно и то же, только полигон залит полностью... 2. Каким образом можно встроить нарисованную линию в сетку? Сетка кратна линии, правая и левая граница линии должны быть ровно по сетке. См. фото. Edited June 3, 2016 by def_rain Quote Share this post Link to post Share on other sites More sharing options...
vitan 0 June 3, 2016 Posted June 3, 2016 · Report post меню compose shape Quote Share this post Link to post Share on other sites More sharing options...
Frezer 0 June 14, 2016 Posted June 14, 2016 · Report post Здравствуйте, еще такой вопрос возник: как строить АЧХ понятно: ставишь VAC, симулируешь в AC Sweep, а вот как получить графики ФЧХ (есть мнение, что в том же симуляторе, только с помощью оператора P(сигнал), однако я не уверен, что это верно)? Пока не разобрался... Quote Share this post Link to post Share on other sites More sharing options...
SSerge 3 June 14, 2016 Posted June 14, 2016 · Report post Здравствуйте, еще такой вопрос возник: как строить АЧХ понятно: ставишь VAC, симулируешь в AC Sweep, а вот как получить графики ФЧХ (есть мнение, что в том же симуляторе, только с помощью оператора P(сигнал), однако я не уверен, что это верно)? Пока не разобрался... Можно и так, а вообще в меню PSpice->Markers->Advanced есть готовые маркеры для фазы и амплитуды в децибеллах. Quote Share this post Link to post Share on other sites More sharing options...
Frezer 0 June 16, 2016 Posted June 16, 2016 · Report post Спасибо, а есть ли возможность читать проект из версии 10.5 в 9.2? Quote Share this post Link to post Share on other sites More sharing options...
SSerge 3 June 16, 2016 Posted June 16, 2016 · Report post Спасибо, а есть ли возможность читать проект из версии 10.5 в 9.2? Если не захочет открывать .opj, то откройте непосредственно файл .dsn. Формат файлов .dsn не менялся до версии 16.2 включительно. Новые версии дают возможность редактировать некоторые параметры компонентов, но эти изменения в основном косметические, т.е. влияют на то как выглядит схема, а не на функциональность. Старые версии просто сбросят такие параметры в значение по умолчанию. Даже если .opj откроется в 9.2, там где-то не совпадают соглашения о путях до временных файлов, нужно будет заново создать профили моделирования. Quote Share this post Link to post Share on other sites More sharing options...
Frezer 0 June 20, 2016 Posted June 20, 2016 · Report post Если не захочет открывать .opj, то откройте непосредственно файл .dsn. Хех, как раз именно .dsn и нету... Может поэтому то и возмущается Тут еще одна проблемка назрела, может кто поможет: моделировал работу компаратора AD8611, собрал по схемке, как в даташите: Вышло примерно вот так: Выдало ошибку: ERROR - Convergence problem in transient analysis at Time = 121.7E-09 Time step = 145.5E-21, minimum allowable step size = 1.000E-18 These supply currents failed to converge: I(X_U1.E3) = 10.00GA \ 10.00GA I(X_U1.E4) = -10.00GA \ -10.00GA I(X_U1.V1) = -10.00GA \ -10.00GA I(X_U1.V2) = -10.00GA \ -10.00GA Внимание вопрос: что это такое и как вылечить? Я так понимаю, что он насчитал предельные значения по току... Есть вариант, что ошибка в схеме подключения или в самой модели (текст модели прилагаю). Самое интересное, что такое только при анализе Time Domain, в AC Sweep/Noise все считает... AD8612.txt Quote Share this post Link to post Share on other sites More sharing options...
Frezer 0 July 8, 2016 Posted July 8, 2016 · Report post Здравствуйте, еще такая проблема возникла... с памятью :rolleyes: В общем надо сформировать в проге из готовой платы слой, в котором бы отображались вместо переходных отверстий их условные обозначения согласно drill table, однако я позабыл как это делается и чето не могу вспомнить... Может кто поможет? Quote Share this post Link to post Share on other sites More sharing options...
