alter 0 February 3, 2010 Posted February 3, 2010 · Report post Ядро линукса не видит MTD партиции NOR flash. ARM - Cirrus logic EP9315A. RAM 2x32 MБ (nCS0) , NOR flash Spansion S29GL512P 64MБ (nCS6), linux-crater_1-0-3. При загрузке ядра выдает следующее: physmap platform flash device: 02000000 at 60000000 physmap-flash.0: Found 1 x16 devices at 0x0 in 16-bit bank NOR chip too large to fit in mapping. Attempting to cope... Amd/Fujitsu Extended Query Table at 0x0040 physmap-flash.0: CFI does not contain boot bank location. Assuming top. number of CFI chips: 1 cfi_cmdset_0002: Disabling erase-suspend-program due to code brokenness. Reducing visibility of 65536KiB chip to 32768KiB cmdlinepart partition parsing not available Searching for RedBoot partition table in physmap-flash.0 at offset 0x1fe0000 No RedBoot partition table detected in physmap-flash.0 ... Root-NFS: No NFS server available, giving up. VFS: Unable to mount root fs via NFS, trying floppy. No filesystem could mount root, tried: jffs2 Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(2,0) MTD партиции нужны для работы с JFFS2 (jffs2 ramdisk на NOR flash). В конфигурационном файле заданы следующие ключи: #Memory Technology Devices (MTD) CONFIG_MTD=y CONFIG_MTD_DEBUG=y # CONFIG_MTD_CONCAT is not set CONFIG_MTD_PARTITIONS=y CONFIG_MTD_REDBOOT_PARTS=y CONFIG_MTD_REDBOOT_DIRECTORY_BLOCK=-1 CONFIG_MTD_REDBOOT_PARTS_UNALLOCATED=y # CONFIG_MTD_REDBOOT_PARTS_READONLY is not set # CONFIG_MTD_CMDLINE_PARTS is not set # CONFIG_MTD_AFS_PARTS is not set # User Modules And Translation Layers CONFIG_MTD_CHAR=y CONFIG_MTD_BLKDEVS=y CONFIG_MTD_BLOCK=y CONFIG_NFTL=m # RAM/ROM/Flash chip drivers CONFIG_MTD_CFI=y CONFIG_MTD_GEN_PROBE=y CONFIG_MTD_CFI_ADV_OPTIONS=y CONFIG_MTD_CFI_NOSWAP=y CONFIG_MTD_MAP_BANK_WIDTH_1=y CONFIG_MTD_MAP_BANK_WIDTH_2=y CONFIG_MTD_MAP_BANK_WIDTH_4=y CONFIG_MTD_CFI_I1=y CONFIG_MTD_CFI_I2=y CONFIG_MTD_CFI_INTELEXT=y CONFIG_MTD_CFI_AMDSTD=y CONFIG_MTD_CFI_STAA=y CONFIG_MTD_CFI_UTIL=y CONFIG_MTD_RAM=y # Mapping drivers for chip access CONFIG_MTD_PHYSMAP=y CONFIG_MTD_PHYSMAP_START=0x0 CONFIG_MTD_PHYSMAP_LEN=0x0 CONFIG_MTD_PHYSMAP_BANKWIDTH=1 Quote Share this post Link to post Share on other sites More sharing options...
sasamy 1 February 3, 2010 Posted February 3, 2010 (edited) · Report post physmap platform flash device: 02000000 at 60000000 physmap-flash.0: Found 1 x16 devices at 0x0 in 16-bit bank NOR chip too large to fit in mapping. Attempting to cope... Посмотрите board файл - похоже просто неправильно размер флеша прописан, platform_device по имени physmap-flash, обратите внимание на start и end. Особенно на end :) Edited February 3, 2010 by sasamy Quote Share this post Link to post Share on other sites More sharing options...
alter 0 February 3, 2010 Posted February 3, 2010 · Report post Огромное спасибо за ПРАВИЛЬНЫЙ совет!!! :) Действительно в файле 9315a.c был жестко прописан размер флеши в 32 МБ... ДА! и я был осторожен с концом (по любому не учел бы ...)! Спасибо. Quote Share this post Link to post Share on other sites More sharing options...
