lvitaly 0 22 апреля, 2008 Опубликовано 22 апреля, 2008 · Жалоба Промелькнул даташит на новый, еще не объявленный камень от Атмел - AT91SAM9M10. Камень монстрообразный, таких у Атмел что-то не припомню. Залил на ftp /upload/MCs/ARM/Doc/AT91SAM9M10_ds.rar продублировал на рапиде http://rapidshare.com/files/109488653/AT91SAM9M10_ds.rar Features • Incorporates the ARM926EJ-S™ ARM® Thumb® Processor – DSP Instruction Extensions – ARM Jazelle® Technology for Java® Acceleration – 32-Kbyte Data Cache, 32-Kbyte Instruction Cache, Write Buffer – CPU Clock Frequency: 400 MHz @ 1.0V +/- 5% – Memory Management Unit – EmbeddedICE™ In-circuit Emulation, Debug Communication Channel Support • Multi Layer AHB Bus Matrix for Large Bandwidth Transfers – Twelve 32-bit Layer Matrix – Boot Mode Select Option, Remap Command • One 64-Kbyte internal ROM, Single-cycle Access at Maximum speed • One 64-Kbyte internal SRAM – Single-cycle Access at System Speed – ITCM and DTCM accesses • DDR2/LPDDR Memory Interface: 4-port DDR2/LP-DDR Controller – 16Bit LP-DDR – 16Bit DDR2 • Video Decoder (VDEV) Supported Standards – MPEG-4 Simple and Advanced Profile, Levels 0-5 – H.264 Baseline Profile, Levels 1-3.1 – H.263 Profile 0,Levels 10-70 – VC-1 • Simple Profile, Low and Medium Levels • Main Profile, Low, Medium and High Levels • Advanced Profile, Low, Medium and High Levels – MPEG-2 Main Profile, Low, Medium and High Levels – DivX Profile Handheld, Portable, Home Theatre and High Definition Profiles – JPEG Profile Baseline DCT (Sequential) and JFIF 1.02 file form • External Bus Interface (EBI) – Sixteen 32-bit Wide Interface, Supporting: – 16-bit DDR2/LPDDR, Sixteen 32-bit SDRAM/LPSDR – Static Memories – NAND Flash (SLC Devices, DMA Channel for Automatic Multiple Block Transfer) – ECC (SLC NandFlash ECC) – CompactFlash Logic • Four High Speed Memory Card Hosts, Supporting (MCI) – MMC/MMCPlus v4.1 – SDcard/SDIO v2.0 – CE ATA Interface • 8-channel DMA Controller – Two Matrix Masters – Memory to Memory Transfer – Linked List Management • 480 Mbps USB Device High Speed Controller with On-Chip UTMI Transceiver • 480 Mbps USB Host Controller with On-chip UTMI Transceiver (1 Dedicated Port + 1 Port Shared with UDP HS) – High Speed EHCI – Full speed OHCI • 10/100 Mbps Ethernet Mac Controller – Media Independent Interface or Reduced Media Independent Interface – 128 Bytes FIFOs and Dedicated DMA Channels for Receive and Transmit – Wake On LAN Capability • LCD Controller Supports – Passive or Active Displays, – Up to 24 bits per Pixel in TFT Mode – Up to 16 bits per Pixel in STN Color Mode – Resolution up to 2048 x 2048, Supports Virtual Screen Buffers • One 8-channel 10-bit Analog-to-Digital Converter – Touch Screen Interface Compatible with Industry Standard 4-wire Sensitive Touch Panels • Universal Video Decoder Provides Decoding of MPEG-2/MPEG-4/H.263/H.264/VC1(WMV9)/JPEG – up to 30 fps @D1 resolution – Image Scaling – Color Conversion – Picture in Picture – Rotation • ITU-R BT. 601/656 Image Sensor Interface – with Programmable Frame Capture Rate – DMA on Preview and Codec Paths – SAV and EAV Synchronization – Preview Path with Scaler • One AC97 Controller (AC97C) – 6-channel Single AC97 Analog Frontend Interface, Slot Assigner • RNG Random Number Generator – Compliant with NIST Special Publication 800-22 – Provides a 32-bit Random Number Each 84 Clock Cycles • Fully-featured System Controller, Including – Reset Controller, Shut Down Controller – Four 32-bit Battery Backup Registers for A Total Of 16 Bytes – Clock Generator and Power Management Controller – Advanced Interrupt Controller and Debug Unit – Periodic Interval Timer, Watchdog Timer and Real-Time Timer and Real Time Clock • Reset Controller (RSTC) – Based on Two Power-on Reset Cells – Reset Source Identification and Reset Output Control • Shut Down Controller (SHDC) – Programmable Shut Down Pin Control and Wake-up Circuitry • Clock Generator (CKGR) – Selectable 32768 Hz Low-power Oscillator or Internal Low-power RC Oscillator on Battery Backup Power Supply, providing a permanent Slow Clock – 12 MHz On-chip Oscillator for Main System Clock and USB Clock – One PLL up to 800MHz – One PLL 480MHz optimized for USB HS • Power Management Controller (PMC) – Very Slow Clock Operating Mode, Software Programmable Power Optimization Capabilities – Two Programmable External Clock Signals • Advanced Interrupt Controller (AIC) – Individually Maskable, Eight-level Priority, Vectored Interrupt Sources – One External Interrupt Sources and One Fast Interrupt Source, Spurious Interrupt Protected • Debug Unit (DBGU) – 2-wire UART and Support for Debug Communication Channel • Periodic Interval Timer (PIT) – 20-bit Interval Timer Plus 12-bit Interval Counter • Watchdog Timer (WDT) – Key-protected, Programmable Only Once, Windowed 16-bit Counter Running at Slow Clock • Real-Time Timer (RTT) – 32-bit Free-running Backup Counter Running at Slow Clock with 16-bit Prescaler • Real-Time Clock (RTC) – Time, Date and Alarm 32-bit Parallel Load – Low Power Consumption – Programmable Periodic Interrupt • Five 32-bit Parallel Input/Output Controllers (PIOA, PIOB, PIOC, PIOD and PIOE) – 160 Programmable I/O Lines Multiplexed with up to Two Peripheral I/Os – Input Change Interrupt Capability on Each I/O Line, Schmitt Trigger input – Individually Programmable Open-drain, Pull-up Resistor and Synchronous Output – Schmitt Trigger on all inputs. • Peripheral DMA Controller Channels (PDC) • Two Synchronous Serial Controllers (SSC) – Independent Clock and Frame Sync Signals for Each Receiver and Transmitter – I²S Analog Interface Support, Time Division Multiplex Support – High-speed Continuous Data Stream Capabilities with 32-bit Data Transfer • Four Universal Synchronous/Asynchronous Receiver Transmitters (USART) – Individual Baud Rate Generator, IrDA Infrared Modulation/Demodulation, Manchester Encoding/Decoding – Support for ISO7816 T0/T1 Smart Card, Hardware Handshaking, RS485 Support • Two Master/Slave Serial Peripheral Interface (SPI) – 8- to 16-bit Programmable Data Length, Four External Peripheral Chip Selects – High speed Synchronous Communications • Two Three-channel 16-bit Timer/Counters (TC) – Three External Clock Inputs, Two multi-purpose I/O Pins per Channel – Double PWM Generation, Capture/Waveform Mode, Up/Down Capability • One Four-channel 16-bit PWM Controller (PWMC) • Two Two-wire Interface (TWI) – Compatible with Standard Two-wire Serial Memories – One, Two or Three Bytes for Slave Address – Sequential Read/Write Operations – Master, Multi-master and Slave Mode Operation – Bit Rate: Up to 400 Kbits – General Call Supported in Slave mode – Connection to Peripheral DMA Controller (PDC) Channel Capabilities Optimizes Data Transfers in Master Mode Only • SAM-BA® Boot Assistant – Default Boot Program – Boot on NandFlash, SDCARD or serial dataflash – Interface with SAM-BA Graphic User Interface • Required Power Supplies: – 0.9V to 1.1V for VDDCORE, VDDPLLA, VDDPLLUTMI, VDDUTMIC – 3.0V to 3.6V for VDDUTMII – 1.8V to 3.6V for VDDBU – 1.65V to 3.6V for VDDOSC – 1.65V to 3.6V for VDDIOP0, VDDIOP1 and VDDIOP2 (Peripheral I/Os) – 1.65V to 1.95V for VDDIOM0 – Programmable 1.65V to 1.95V or 3.0V to 3.6V for VDDIOM1 (Memory I/Os) – 3.0V to 3.6V VDDANA (Analog to Digital Converter) • Available in a 324-ball TFBGA Green Package (pitch 0.8 mm) Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Bladerunner 0 23 апреля, 2008 Опубликовано 23 апреля, 2008 · Жалоба • Available in a 324-ball TFBGA Green Package (pitch 0.8 mm) Все конечно здорово и круто ... но не актуально... так как у нас в России с корпусами типа БГА бальшой трабл с пайкой .. поэтому и приходится рыть компоненты в более демократичных упаковках... Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
АДИКМ 0 23 апреля, 2008 Опубликовано 23 апреля, 2008 · Жалоба Все конечно здорово и круто ... но не актуально... так как у нас в России с корпусами типа БГА бальшой трабл с пайкой .. поэтому и приходится рыть компоненты в более демократичных упаковках... Немного голословное утверждение, ИМХО. посмотрите как ремонтируют сотовые телефоны. утюгом и феном. Хотя бы... Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
chds 0 23 апреля, 2008 Опубликовано 23 апреля, 2008 · Жалоба ... но не актуально... так как у нас в России с корпусами типа БГА бальшой трабл с пайкой .. Очень странно это читать, если даже у нас в Украине за 400 баксов можно купить допотопную конвекционную станцию и ставить BGA у себя на кухне или обратиться к спецам и за 10 баксов поставить на профессиональном оборудовании BGA любой сложности. Ни кто не в курсе, почему Atmel с таким маниакальным постоянством клепает ARM926EJ-S, хотя еще год назад у них в анонсах проскакивало сообщение о том, что готовится выход ARM1176JZF с заявленной стартовой частотой в 620MHz in 90nm technology и полной поддержкой ARM Jazelle? По моему глубокому убеждению ARM926EJ проигрывают XScale, по многим параметрам. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
АДИКМ 0 23 апреля, 2008 Опубликовано 23 апреля, 2008 · Жалоба Очень странно это читать, если даже у нас в Украине за 400 баксов можно купить допотопную конвекционную станцию и ставить BGA у себя на кухне или обратиться к спецам и за 10 баксов поставить на профессиональном оборудовании BGA любой сложности. Ни кто не в курсе, почему Atmel с таким маниакальным постоянством клепает ARM926EJ-S, хотя еще год назад у них в анонсах проскакивало сообщение о том, что готовится выход ARM1176JZF с заявленной стартовой частотой в 620MHz in 90nm technology и полной поддержкой ARM Jazelle? По моему глубокому убеждению ARM926EJ проигрывают XScale, по многим параметрам. Деньги, вложенные в лицензию 926 надо отбить. Если завтра они купят 21 ядро, то это вовсе не означает, что надо сворачивать линейки 7 и 9 армов. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
chds 0 23 апреля, 2008 Опубликовано 23 апреля, 2008 · Жалоба Чего то мне кажется, что Intel вкладывает научные исследования больше денег, но у них есть процы от 200МГц до 4ГГц, как говорится на любой вкус. Почему я так радею за Atmel: до этого хватало мощности ихних МК, но сейчас нужно больше и приходится перелазить с любимого АРМ на непонятный XScale. Может коллективное письмо на Atmel написать, мол хотим АРМ11 :) Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
KRS 0 23 апреля, 2008 Опубликовано 23 апреля, 2008 · Жалоба Может коллективное письмо на Atmel написать, мол хотим АРМ11 :) IMHO ARM11 уже не актуально. Cortex-Axxx уже есть. архитектура у них получше! Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
АДИКМ 0 23 апреля, 2008 Опубликовано 23 апреля, 2008 · Жалоба Здесь перечислены лицензиаты - http://www.arm.com/products/licensing/licencees.html у атмела есть лицензия на 9. а вот на 11 не вижу. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
AlexandrY 2 23 апреля, 2008 Опубликовано 23 апреля, 2008 · Жалоба Более быстрое ядро само по себе ничего не дает. Это уже ясно. Задайтесь вопросом, почему как бы частота у чипов не росла начиная с 60 МГц пины GPIO быстрее чем 3-6 МГц они уже не могут переключать. Все решает периферия и шинная структура и даже уже не на уровне ядра. Аудиомикшеры замыкаются на периферии, видеопотоки от камеры к LCD проходят мимо ядра, Ethernet пишет в память не выходя на шину AHB ядра. Хоть особо и не рекламируют, но в таких SoC-ах уже стоит по нескольку RISC-ов на периферии. Как минимум один на обработке видео, один в MAC контроллере, возможно один на движке защиты софта. Вот эти RISC-и и шины и определяют пропускную способность и мощу чипа, а еще errata. Если задача не вписывается в стандартные функции положенные смартфону, то такие чипы сразу требуют вспомогательных внеших средств типа FPGA и никакая их внутренняя скорость кэша не помогает. Очень странно это читать, если даже у нас в Украине за 400 баксов можно купить допотопную конвекционную станцию и ставить BGA у себя на кухне или обратиться к спецам и за 10 баксов поставить на профессиональном оборудовании BGA любой сложности. Ни кто не в курсе, почему Atmel с таким маниакальным постоянством клепает ARM926EJ-S, хотя еще год назад у них в анонсах проскакивало сообщение о том, что готовится выход ARM1176JZF с заявленной стартовой частотой в 620MHz in 90nm technology и полной поддержкой ARM Jazelle? По моему глубокому убеждению ARM926EJ проигрывают XScale, по многим параметрам. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
chds 0 24 апреля, 2008 Опубликовано 24 апреля, 2008 · Жалоба Здесь перечислены лицензиаты - http://www.arm.com/products/licensing/licencees.html у атмела есть лицензия на 9. а вот на 11 не вижу. У меня от Atmel подписка, так в Мая 2007 года написали: Atmel Licenses ARM1176JZF-S Processor Extends Atmel's Roadmap of Upwards-compatible ARM Technology-based on 32-bit Microcontrollers from the ARM7 Family through to the ARM9 and ARM11 Families Atmel announced that it has licensed the ARM1176JZF-S™ processor for implementation in high-performance system-on-chip (SoC) products.The ARM1176JZF-S core clocks at up to 620MHz in 90nm technology, while achieving a power consumption as low as 0.45 mW/MHz. It features ARM TrustZone® technology for enhanced security, ARM Jazelle® technology for efficient embedded Java execution, and ARM Intelligent Energy Manager (IEM™) technology that can reduce processor energy consumption by 25% to 50%. Но самое интересное, что новость с анонса у самого Atmel исчезла. ))) То AlexandrY: То что сырой мощью сейчас не возьмешь это понятно, хотя и тут вопрос спорный. Например в XScale на ввод вывод стоит свой контроллер, который и занимается таковым не мешая ядру отдыхать. Но АРМ предлагают ядро, а периферию вешают сами производители, так вот эти производители явно не хотят тратить время и ставить дополнительные контроллеры на скоростные интерфейсы. Судя по представленной документации на Ethernet поставили только PDU, а все задачи по сборке на ядро. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
_4afc_ 24 28 апреля, 2008 Опубликовано 28 апреля, 2008 · Жалоба – 12 MHz On-chip Oscillator for Main System Clock and USB Clock Вот никак не пойму что они этим хотели сказать? Встроенного кварцевого резонатора несмотря на огромный корпус - нет. Внешний резонатор может быть 3-20МГц. Что за число 12МГц? Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
chds 0 28 апреля, 2008 Опубликовано 28 апреля, 2008 · Жалоба Вот никак не пойму что они этим хотели сказать? Встроенного кварцевого резонатора несмотря на огромный корпус - нет. Внешний резонатор может быть 3-20МГц. Что за число 12МГц? Видимо имелось в виду это: The Main Oscillator is designed for a 12 MHz fundamental crystal. The 12 MHz is an input of the PLLA and the UPLL used to generate the 480 MHz USB High Speed Clock (UPLLCK). Это просто их рекомендация - ставьте любой, но с 12 МГц точно будет работать Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
defunct 0 28 апреля, 2008 Опубликовано 28 апреля, 2008 · Жалоба Здесь перечислены лицензиаты - http://www.arm.com/products/licensing/licencees.html у атмела есть лицензия на 9. а вот на 11 не вижу. Дык не все лицензиаты перечислены. На ARM11TM - 64 лицензии. А компаний перечислено только 23. Я знаю как минимум две компании выпускающие чипы с ARM11 ядрами, которых нет в списке. Так что.... возможно и у Atmel есть. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
denim 0 29 апреля, 2008 Опубликовано 29 апреля, 2008 · Жалоба TI там смотрю впереди планеты всей...купил все что продавалось :) Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
