moonrock 0 21 февраля, 2008 Опубликовано 21 февраля, 2008 · Жалоба Что за сообщение? Я все переоблазил, не могу понять что оно хочет Вот текст файла Reusable Block Verification Log ------------------------------- 04:11 PM Thursday, February 21, 2008 Job Name: C:\MentorGraphics\Lib\Lib.lmc The following library element(s) ["padstacks, cells, pdb entries, etc."] have been modified within the central library. These library elements are utilized by the following reusable blocks: Cell 'SOT89' (Partition: CellDBLibs\SMD.cel) is newer than RB cell 'MD'. Cell 'EXR_PADSONLY' (Partition: CellDBLibs\Through.cel) is newer than RB cell 'MD'. Cell 'LED_DUAL_CC' (Partition: CellDBLibs\Through.cel) is newer than RB cell 'MD'. Cell 'SMA' (Partition: CellDBLibs\SMD.cel) is newer than RB cell 'MD'. Padstack 'WSO8' is newer than RB cell 'MD'. Padstack 'EIA0603' is newer than RB cell 'MD'. Padstack 'SO8' is newer than RB cell 'MD'. Padstack 'EIA0805' is newer than RB cell 'MD'. Padstack 'EIA1812' is newer than RB cell 'MD'. Padstack 'EIA2512' is newer than RB cell 'MD'. Padstack 'EIA535 SIZE A' is newer than RB cell 'MD'. Padstack 'Round 2.0-1.0' is newer than RB cell 'MD'. Padstack 'SO20' is newer than RB cell 'MD'. Padstack 'Round 1.6-0.8' is newer than RB cell 'MD'. Padstack 'Round 2.8-1.2' is newer than RB cell 'MD'. Padstack 'SOD80' is newer than RB cell 'MD'. Padstack '11-4C1' is newer than RB cell 'MD'. Padstack 'DIP6SMD' is newer than RB cell 'MD'. Padstack 'SOT23-5' is newer than RB cell 'MD'. Padstack 'SOT23' is newer than RB cell 'MD'. Padstack 'SOT89CNTR' is newer than RB cell 'MD'. Padstack 'Via 1.0-0.5' is newer than RB cell 'MD'. Padstack 'SOT89' is newer than RB cell 'MD'. Padstack 'M3' is newer than RB cell 'MD'. Padstack 'Square 2.0-1.0' is newer than RB cell 'MD'. Padstack 'SMA' is newer than RB cell 'MD'. Part 'EXR_PADSONLY' is newer than RB cell 'MD'. Part 'L119GRWA' is newer than RB cell 'MD'. Part 'MURA160T3' is newer than RB cell 'MD'. The following RB cell(s) are being set to unverified: MD To correct these issues, the central library elements listed above will need to be overwritten with the original data contained within the central library. This action will realign the library information to the reusable block. Reusable Block verification complete. что характерно если открыть этот блок в expedition то он там как провереный, а в библиотеке непроверенный бррр! помогите пожалуста Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Vadim 0 21 февраля, 2008 Опубликовано 21 февраля, 2008 · Жалоба В свое время я отказался разбираться во всем этом, ибо все это очень запутано :) Завел себе папку Reusable_Projects, где живут проекты для многократного использования, и при возникновении проблем такого рода открываю соответствующий проект и синхронизирую его с библиотекой. В Library Manager тупо удаляю соответствующий Reusable Block и создаю его снова. Попробуйте, может понравится :) Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
fill 2 22 февраля, 2008 Опубликовано 22 февраля, 2008 · Жалоба Судя по диагностике вы изменили несколько CELL и padstack, которые были применены в Reuse_Block, как только вы сохранили изменения, например в CELL, LM вам сообщил, что изменения коснулись и Reuse_Block, и он стал unverified. Открываем Reuse_Block_Editor, выбираем наш блок и жмем иконку редактировать, внутри открывшейся топологии выбираем ECO>Update_Cells&Padstacks, после обновления выбираем File>Save_Reuse_Block после успешного сохранения блок стал verified Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
