Stariy Alex
Cadence OrCAD 16.0
Текст представления программы, чаще всего используемая для производства PCB, ИМХО, не нуждается в переводе
All OrCAD 16.0 products are now supported in Windows Vista™ Enterprise.
New Cadence OrCAD and PSpice Bundle!
Cadence OrCAD EE Designer Plus
OrCAD EE Designer Plus provides powerful schematic entry and simulation in one premium package. This competitively priced, complete front-end design solution includes:
OrCAD Capture schematic entry, the world's leading schematic capture tool
PSpice A/D for analog and mixed-signal simulation
PSpice advanced analysis capabilities—sensitivity analysis, optimization, Smoke (stress analysis), and Monte Carlo (yield analysis)—to automatically maximize the performance of circuits
For more information contact us at info@ema-eda.com or call 800-813-7494.
Cadence OrCAD Capture
Improved support for complex hierarchical designs, including better support for occurrence properties and externally referenced designs.
Support for placing and moving text and drawing objects on fine grid independent of connectivity objects
Enhancements to archiving adds an option to include PSpice models in the archive libraries which improves the performance of archived simulation profiles
Improved error messages and DRC engine
Cadence Help Online Documentation System replaces CDSDoc, providing faster invocation time, advanced search capabilities, and built-in viewing window
Usability enhancements and implementation of over 100 CCRs for improved quality and performance
Cadence OrCAD Capture CIS Option
Support for including mechanical parts and assemblies in standard component information system (CIS) Bill of Materials (BOM)
Better support for Japanese characters in CIS
Better BOM generation for non-English operating systems
Cadence PSpice A/D
Improved speed for power electronics designs, especially those using ABM if-then expressions, which will simulate up to 50x faster
CheckPoint Restart feature allows you to save the state of a transient simulation at specific times as CheckPoints. Prior to restarting, you can change component values, so if you’re not getting the results you want, you can tune your circuit without having to restart from the beginning. This is particularly useful for circuits that have a long startup time like a switch mode power supply. You can simulate once to reach steady state, tune the circuit to get the final result you want, and then simulate from the beginning to verify the full simulation. In this situation, CheckPoint Restart can be a significant time saver
Autoconvergence feature allows PSpice to automatically modify convergence options as necessary. This reduces the need for user interaction for problem circuits
Improved transient convergence. Adaptive iteration, improvements in the step time algorithm, and an improved switch model allow PSpice to converge on certain types of problem circuits
Run in resume mode accessible from graphical user interface (GUI)
Minimum step size recalculation
Tasks such as adding a trace, adding a plot, zooming the view, or adding a text label are now available using the right mouse button to display a context-sensitive menu in the Probe window
Probe window cursors now display X and Y coordinates on the status bar of the Probe window
Improved simulation speed for E and G device-based circuits
PSpice libraries have 120 new power devices. Updated vendor libraries include 290 new LED models
Cadence PSpice AA
PSpice Advanced Analysis support for legacy PSpice models. Traditional tolerance specifications can now be used by the Monte Carlo and Sensitivity tools. This includes the use of PDF custom distributions and device and lot tolerances
Cadence OrCAD PCB Designer (including OrCAD PCB Editor)
OrCAD Layout translator user interface opens from within OrCAD PCB Editor
Usability enhancements made within the display canvas and to the command structure
Redesigned color / visibility GUI
Enhancements made to the underlying graphics system, based on OpenGL graphics engine
Physical and spacing constraints incorporated in the Allegro constraint management system
Interactive and automatic controls for component fanout (pin escaping)
Context-sensitive editing paradigm built on selecting database objects first, followed by action command
Cadence OrCAD Layout
Support for GerbTool Version 15.0
Implementation of numerous CCRs for improved quality and performance
PS. Солдаты грянули ура - полки увидели Петра...
Edited by Stariy Alex
Это ваше мнение или текст из рекламы? Боюсь вас разочаровать, оркад в привычном смысле самый слабый продукт для разработки плат. У нас его если и используют, то только для разработки схем, то есть редактор схем плюс программа моделирования.
А по цене он не самый дешевый.
У Потапова значит Кадстар лучше?
Вообще-то это не мое мнение - у меня - схемная часть Оркад а pcb (лет 18)
Kадстар (для DOSа 88 года, а затем 92-го v7,1). Далее, начиная с версии 4,0 для Вин95.
В Винде основной принцип тот-же - тяжеловесная болванка и экзотика для Китайцев.
У меня просто многолетняя привычка.
Оркад же стройный и не нахожу его хуже всех - наоборот. Vinnetu хорошо его описал.
А по мне OrCad - отстой как Capture, так и Layout во всех видах даже по сравнению с PCAD-ом.
В моей версии (10.5) сильно напрягает отсутствие отката на несколько пунктов назад как в Layout, так и в Capture.
Совершенно по дурацки реализованы графические редакторы. После AutoCada - г- но полнейшее.
Такое впечатление, что работаешь не с графикой, а с какой-то неуклюжей базой данных.
Понятие Obstacle в Layout совершенно дикое и введено, по всей вероятности, чисто из-за упрощения программных решений.
Базы данных CIS на уровне нашей 1С бухгалтерии, да и к тому же настраивать самому надо.
Если бы не удобный интерфейс для PSpice моделирования, то продукт был бы абсолютно никчемным.
Но тут есть одно но... Это не разработка фирмы Cadence, а приобретение.
С PSpice фирма Cadence по-моему ничего путного так и не сделала. Ни тебе микропроцессоров, как в Proteuse, ни хотя бы какого либо черного ящика со скриптами внутри.
Правда, в рекламке порадовали фразы:
Остальное не интересно. Обычная реклама.
И вообще, за те деньги, которые это дело стоит, можно было бы постараться более тщательно.
Есть предложение: давайте сообщение о выходе продукта не будем превращать в фанатское мерянье пиписками. Я например, считаю Танго во всех его ипостасях редким дерьмом, но это еще не повод стараться навязывать свое мнение другим. Для меня он стоит ниже Падса, Кадстара, АД и даже :) Оркада. Конкретные претензии к каким-то функциям я полагаю можно предъявить к любому продукту. Имхо, метание дерьма не является аргументом для нормальных людей. Если главный недостаток софта только в том, что вы его не знаете - это скорее всего проблема не пакета, а прокладки между стулом и клавиатурой.
Прошу прошения, ничего личного - просто достал пионерский задор.
Ех, коллеги!
Знаю также, что 15 числа сего месяца официально вышла Allegro 16.0.
Вот ее бы посмотреть...
На сегодняшний день на сайте Cadence её - 16-ю версию - для загрузки не выложили.
Из SPB только 1551 и 157.
Подождём, как в осле появится. Скачаем, посмотрим. Торопиться некуда. 7-й Quartus вышел, я скачал, попробовал. Один из рабочих проектов почему-то не откомпилировался, так я вернулся на предыдущую версию. Так и с Оркадом. Будет что-то лучше - рано или поздно появится в сети, скачаем, посмотрим.
Собирался что-то такое же написать. Очень правильный пост. Поддерживаю
Беда как раз и заключается в том, что основную часть проектов приходится делать именно в OrCad, поскольку его PSpice часть (от MicroSim, царство ей небесное) еще никто не превзошел.
Так вот, еще раз повторю, оба графических редактора, мягко говоря, необходимо доводить до кондиции. Эти редакторы очень похожи на учебные примеры из книг Архангельского, а надо хотя бы некое подобие продуктов от Autodesk.
Голословные упреки в незнании продукта оставляю на совести заявляющих, поскольку по-существу ответов не было. Было злобное метание продукта коричневого цвета и меряние детородными органами.
Ну я бы так не сказал - попробуйте поработать в System Vision Pro или в AvanceMS от Mentora.
Когда я говорил о том, что "никто не превзошел", я имел в виду и этот аспект тоже. К сожалению, широкое распространение OrCad'а в мире сыграло злую шутку со всеми остальными хорошими пакетами.
К своему стыду вынужден признаться, что не имел дела с перечисленными Вами пакетами. Буду очень признателен, если намекнете, где их можно найти, естесственно с "порошками" от жадности.
Большое спасибо за письмо, но мне это, к сожалению, не поможет, поскольку я не "свой". Попробую своими силами...
21-го числа они выложили 16-ю версию.
Скачать - скачаем.
А как посмотрим?
Лекарства-то пока нету!
