ModelSim не генерирует Wave.
я этот Модельсим в белых тапках видел чесслово.
Вот последний тестбенч
Spoiler
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
use ieee.std_logic_unsigned.all;
entity qspi_tb is
end qspi_tb;
architecture behavior of qspi_tb is
component QUADSPI is
port
	 CLK         : in std_logic;
	 RST         : in std_logic := '0';
	 SPI_CS      : in std_logic;
	 SPI_CLK     : in std_logic;
	 SPI_DATA    : inout std_logic_vector(3 downto 0);
	 DATA_OUT    : out std_logic_vector(7 downto 0);
	 DATA_IN     : in std_logic_vector(7 downto 0);
	 READY_READ  : out std_logic;
	 READY_WRITE : out std_logic
end component;
type QSpiStateType is (ST_IDLE, ST_INSTR);
signal QSpiState : QSpiStateType := ST_IDLE;
signal reset   : std_logic := '1';
signal clock   : std_logic;
signal qspi_cs   : std_logic := '1';
signal qspi_clk  : std_logic;
signal qspi_data : std_logic_vector(3 downto 0);
signal s_spi_data_out  : std_logic_vector(7 downto 0);
signal s_spi_data_in   : std_logic_vector(7 downto 0);
signal s_ready_read  : std_logic;
signal s_ready_write : std_logic;
constant clk_period : time := 40 ns;
constant spi_clk_period : time := 400 ns;
signal clk_ena : std_logic;
signal s_clk_count : std_logic_vector(31 downto 0);
signal clk1 : std_logic;
signal clk2 : std_logic;
signal clk3 : std_logic;
begin
clk3 <= not clk2 and clk1; --rising edge
U_QSPI : QUADSPI
port map
    CLK        => clock,
	 RST        => reset,
	 SPI_CS     => qspi_cs,
	 SPI_CLK    => qspi_clk,
	 SPI_DATA   => qspi_data,
	 DATA_OUT    => s_spi_data_out,
	 DATA_IN     => s_spi_data_in,
	 READY_READ  => s_ready_read,
	 READY_WRITE => s_ready_write
clk_process :process
begin
    clock <= '0';
    wait for clk_period/2;
    clock <= '1';
end process;
spi_clk_process : process
begin
    qspi_clk <= '0';
    wait for spi_clk_period/2;
    qspi_clk <= '1';
end process;
process
begin
    if (rising_edge(clock)) then
        clk1 <= qspi_clk;
        clk2 <= clk1;
    end if;
end process;
stim_proc: process
variable clk_count : integer range 0 to 255 := 0;
begin
        case QSpiState is
	    when ST_IDLE =>
	       qspi_cs <= '1';
               wait for 80 ns;
               qspi_cs <= '0';
		QSpiState <= ST_INSTR;
	    when ST_INSTR =>
		--if (rising_edge(qspi_clk)) then
		if (clk3 = '1') then
		    clk_count := clk_count + 1;
		end if;
           case clk_count is
	       --instruction
               when 0 =>
	       when 1 => qspi_data <= X"0";
	       when 2 => qspi_data <= X"7";
	       --address
	        when 3 => qspi_data <= X"0";
	        when 4 => qspi_data <= X"0";
	        when 5 => qspi_data <= X"1";
	        when 6 => qspi_data <= X"2";
	        when 7 => qspi_data <= X"3";
	        when 8 => qspi_data <= X"4";
	        --alt
	        when 9 => qspi_data <= X"A";
	        when 10 => qspi_data <= X"B";
	        --dummy
	        when 11 => qspi_data <= X"5";
	        when 12 => qspi_data <= X"5";
	        --data
	        when 13 => qspi_data <= X"8";
	        when 14 => qspi_data <= X"8";
	        when 15 => qspi_data <= X"9";
	        when 16 => qspi_data <= X"9";
	        when others =>
                   clk_count := 0;
                   qspi_cs <= '1';
            end case;
        end case;
    end if;
    wait;
end process stim_proc;
end behavior;
добавил
process
begin
        clk1 <= qspi_clk;
        clk2 <= clk1;
    end if;
end process;
всё. ничего не генерируется. убираю - как синхронизироваться с qspi_clk? я уже два дня танцы с бубном устраиваю. то эти сигналы не видит то те.
19 minutes ago, andrew_b said:
По-хорошему, надо начинать с тестбенча.
Сначала вы "рисуете" входные воздействия для вашего модуля, а потом у же пишете сам модуль, который их обрабатывает.
ну да. я очень знаю что QuadSPI мастер генерирует.
Edited by jenya7
Ну так не бывает, чтобы совсем ничего. Давайте по порядку. clk3 формируется? По коду вижу, что должно, худо-бедно.
clk_count не инкрементируется? Логично. При каждом "входе в процесс" переменная clk_count обнуляется (строка объявления переменной) [в данном случае переменной логично предпочесть сигнал, так оно понятней должно быть]
Соответственно, максимальное значение, которого может достичь эта переменная будет равно 1. С последующим обнулением к следующему такту. Это во-первых. А во-вторых, сигнал QSpiState в каком состоянии находится? Нужно всё мониторить. Как правильно тут выше подсказали, забудьте пока про QUADSPI, сначала нужно с тестбенчем разобраться. Всё по иерархии. Сначала сигналы, которые явно задаются, затем всё, что от них зависит, после то, что зависит от зависимых и т.д.
UPD:
да, еще неприятный момент...
                qspi_cs <= '1';
                wait for 80 ns;
                qspi_cs <= '0';
период такта 40 ns, а вы внутри периода ждете 80 ns. Как-то нелогично. Может, логичней state'ов добавить, чтобы просто такта за 3 всё это сделать, но без мешанины rising_edge+wait?
qspi_cs
в том то и дело - вообще ничего не генерируется. убираю процесс - вижу сигналв в Wave.
это как? это инициализация сигнала. у меня во всех процесах есть инициализация сигналов и всё прекрасно работает.  процес начинается после begin.
UPD:
                qspi_cs <= '1';
                wait for 80 ns;
                qspi_cs <= '0';
как раз таки эта конструкция работает.
я вижу qspi_cs генерируется правильно.
Может, просто переобозвалось как-то в среде? Несите скрин в студию, где у вас присутствует тот процесс, но ничего не генерируется. Ну и побольше накидайте в waveform всего, что найдете в тестбенче.
Нет, это инициализация переменной (в данном случае clk_count). В VHDL сигналы и переменные немного разные сущности. Я бы настоятельно рекомендовал пока забыть про переменные, а пользоваться исключительно сигналами.
сигнал обновится на следующем клоке а переменная на этом, в этом её преимущество.
точно, да, инициализация один раз, если в теле нет обнуления, тупанул.
Но всё же,
покажите все сигналы/переменные из тестбенча. Что там куда пропадает?
а, вижу. Тут проблема с чувствительностью процесса еще есть:
2 hours ago, jenya7 said:
process
begin
        clk1 <= qspi_clk;
        clk2 <= clk1;
    end if;
end process;
wait until rising_edge(clock) бы лучше подошло
да вы можете взять эти два файла и собрать проект в модельсиме за 5 минут. так на скринах всего не покажешь.
я исхожу из того что QuadSPI master выдаст мне вот такую картину маслом
соответсвенно мой слейв который распарсит это - модуль QUADSPI.
я пытаюсь в тестбенче воссоздать этот пакет от мастера.
я думаю этот процесс точно описывает посылку мастера
        case QSpiState is
	    when ST_IDLE =>
	       qspi_cs <= '1';
               wait for 80 ns;
               qspi_cs <= '0';
	    when ST_INSTR =>
		end if;
           case clk_count is
	       --instruction
               when 0 =>
	       --address
	        --alt
	        --dummy
	        --data
	        when others =>
                   clk_count := 0;
                   qspi_cs <= '1';
            end case;
        end case;
    end if;
осталось разобраться почему он не работает в модельсиме.
Edited by jenya7
Ды вот, пришлось вспомнить, где у меня тут что установлено ))
3 часа назад, jenya7 сказал:
А когда молотком по пальцу попадает, то винит молоток.
Что там в эпиграфе к "Ревизору" было?
1 hour ago, jenya7 said:
если всё, о чём вспоминали тут, исправлено, но SPI_DATA по-прежнему в "X" или "U", то еще стоит обратить внимание на направление порта
двунаправленная шина.
Заменив строки файла quadspi.vhd
process(CLK)
    variable clk_count : integer range 0 to 6 := 0;
begin
    if (rising_edge(CLK)) then
        case QSpiState is
на
process(CLK)
begin
    SPI_DATA <= "ZZZZ";
        case QSpiState is
можно увидеть, что на шине появляются значения отличные от "X" или "U". Но это в качестве примера, показать, как с двунаправленными шинами можно поступать. Точнее -- это надо с протоколом выверять. Высокий импенданс ('Z') можно подавать как со стороны тестируемого юнита, так и со стороны тестбенча.
12 hours ago, FakeDevice said:
process(CLK)
begin
    SPI_DATA <= "ZZZZ";
        case QSpiState is
ну Z я вижу на шине. а другие сигналы не приходят. у меня подозрение что условие clk_count := clk_count + 1; не выполняется.
13 hours ago, FakeDevice said:
еще осталась проблема с
в процессе stim_proc
а как без этого. без клока никак.
Если клок не указан в списке чувствительности процесса, то просто заменить на
wait until rising_edge(clock);
спасибо. помогло.
сейчас проблема - не генерируется clk3 (clk3 <= not clk2 and clk1)
так не работало. вообще ничего не генерировалось
process
begin
        clk1 <= qspi_clk;
        clk2 <= clk1;
    end if;
end process;
перенес
begin
    qspi_clk <= '0';
    qspi_clk <= '1';
    clk1 <= qspi_clk;
    clk2 <= clk1;
end process;
modelsim.thumb.png.8e49ca67bffcba57c61b80fe74df4601.pngmodsim.thumb.png.dc5bcea58a3e8e9085eaba035b7f9cc3.png
clk1, clk2, clk3 не генерируются.
Edited by jenya7
11 minutes ago, jenya7 said:
спасибо. помогло.
process
begin
        clk1 <= qspi_clk;
        clk2 <= clk1;
    end if;
end process;
Здесь же таже самая проблема, заменить if rising_edge на wait until rising_edge
