ModelSim не генерирует Wave.
Есть такой тестбенч
Spoiler
LIBRARY ieee;
USE ieee.std_logic_1164.ALL;
entity qspi_tb is
end qspi_tb;
architecture behavior of qspi_tb is
component QUADSPI is
port
	 CLK         : in std_logic;
	 RST         : in std_logic := '0';
	 SPI_CS      : in std_logic;
	 SPI_CLK     : in std_logic;
	 SPI_DATA    : inout std_logic_vector(3 downto 0);
	 DATA_OUT    : out std_logic_vector(7 downto 0);
	 DATA_IN     : in std_logic_vector(7 downto 0);
	 READY_READ  : out std_logic;
	 READY_WRITE : out std_logic
end component;
signal reset   : std_logic := '1';
signal clock   : std_logic;
signal qspi_cs   : std_logic := '1';
signal qspi_clk  : std_logic;
signal qspi_data : std_logic_vector(3 downto 0);
signal s_spi_data_out  : std_logic_vector(7 downto 0);
signal s_spi_data_in   : std_logic_vector(7 downto 0);
signal s_ready_read  : std_logic;
signal s_ready_write : std_logic;
constant clk_period : time := 40 ns;
constant spi_clk_period : time := 10 ns;
signal clk_ena : std_logic;
signal clk_count : std_logic_vector(7 downto 0);
begin
U_QSPI : QUADSPI
port map
    CLK        => clock,
	 RST        => reset,
	 SPI_CS     => qspi_cs,
	 SPI_CLK    => qspi_clk,
	 SPI_DATA   => qspi_data,
	 DATA_OUT    => s_spi_data_out,
	 DATA_IN     => s_spi_data_in,
	 READY_READ  => s_ready_read,
	 READY_WRITE => s_ready_write
--clk_process :process
--begin
	--clock <= '0';
	--wait for clk_period/2;
	--clock <= '1';
--end process;
spi_clk_process : process
begin
    --if (qspi_cs = '0') then
	 qspi_clk <= '0';
	 wait for spi_clk_period/2;
	 qspi_clk <= '1';
    --end if;
end process;
stim_proc: process
variable clk_count : integer range 0 to 255 := 0;
begin
    qspi_cs <= '0';
    if (rising_edge(clock)) then
        if (rising_edge(qspi_clk)) then
	    clk_count := clk_count + 1;
	end if;
        case clk_count is
	    --instruction
            when 0 =>
	    when 1 => qspi_data <= X"0";
	    when 2 => qspi_data <= X"7";
	    --address
	    when 3 => qspi_data <= X"0";
	    when 4 => qspi_data <= X"0";
	    when 5 => qspi_data <= X"1";
	    when 6 => qspi_data <= X"2";
	    when 7 => qspi_data <= X"3";
	    when 8 => qspi_data <= X"4";
	    --alt
	    when 9 => qspi_data <= X"A";
	    when 10 => qspi_data <= X"B";
	    --dummy
	    when 11 => qspi_data <= X"5";
	    when 12 => qspi_data <= X"5";
	   --data
	   when 13 => qspi_data <= X"8";
	   when 14 => qspi_data <= X"8";
	   when 15 => qspi_data <= X"9";
	   when 16 => qspi_data <= X"9";
	   when others =>
               clk_count := 0;
               qspi_cs <= '1';
        end case;
    end if;
    wait;
end process stim_proc;
end behavior;
Открываю проект в ModelSim загружаю файлы, компилирую, всё хорошо ошибок нет. загружаю сигналы в Wave. clock определяю как системный clock . Нажимаю Run, симуляция бежит но clock  и сигналы не генерируются.
В чем может быть проблема?
Edited by jenya7
так у вас же процесс формирования сигнала clock закомментирован
Quote
--begin
    --clock <= '0';
    --clock <= '1';
--end process;
я пробовал генерировать из тестбенча но он не генерировался в Wave. Так я в Wave его определяю Right click -> Clock... так тоже не генерируется.
Форсировать clock из "wave" -- точно неправильно. Разбирайтесь, добивайтесь того, чтобы из тест-бенча генерировался.
я немного изменил тестбенч
Spoiler
LIBRARY ieee;
entity qspi_tb is
end qspi_tb;
port
	 CLK         : in std_logic;
end component;
constant spi_clk_period : time := 400 ns;
begin
U_QSPI : QUADSPI
port map
    CLK        => clock,
	 RST        => reset,
	 SPI_CS     => qspi_cs,
begin
	clock <= '0';
	clock <= '1';
end process;
begin
    qspi_clk <= '0';
    qspi_clk <= '1';
end process;
stim_proc: process
begin
    qspi_cs <= '1';
    wait for 80 ns;
    qspi_cs <= '0';
	end if;
        case clk_count is
	    --instruction
            when 0 =>
	    --address
	    --alt
	    --dummy
	   --data
	   when others =>
               clk_count := 0;
               qspi_cs <= '1';
        end case;
    end if;
    wait;
end behavior;
клоки генерируются.
Но не ивента qspi_cs хотя я вначале генерирую его
qspi_cs <= '1';
wait for 80 ns;
qspi_cs <= '0';
я что то упускаю?
Edited by jenya7
3 minutes ago, jenya7 said:
Но не ивента qspi_cs хотя я врачале генерирую его
я что то упускаю?
Начать можно с того, что на картинке шкалы времени не видно. Возможно, в начале симуляции что-то и было.
таки да. в начале есть qspi_cs и клоки генерируются. а компонент не работает.
значит что то не так с моим QUADSPI или я что то упускаю в таймингах.
Edited by jenya7
Есть немного. Во-первых, непонятно, что с сигналом RST. на waveform его не видно, в тест-бенче он после инициализации тоже нигде не формируется. Ну и то, что прям по старту симуляции у вас на модуль идет управляющий сигнал SPI_CS -- тоже, как правило, неверно. Подождите хотя бы с 10-20 тактов, потом подавайте. Возможно, какая-то завязка есть. Затем, из картинки видно, что и на SPI_DATA постоянно подается "UUUU". Как должна реагировать в данном случае схема? Я тоже не знаю. В общем, проверяйте сигнал за сигналом, чтобы полностью соответствовало временным диаграммам из документации, для начала. А потом, если ВСЕ условия окажутся соблюденными, но так и не заработает -- будет иметь смысл разбираться дальше. Вы не торопитесь, тут больше зависит от внимательности и тщательности. Методом перебора здесь вы ничего хорошего не добьетесь.
Вот теперь я понимаю почему я люблю SignalTap.
В диаграме
мы видим - clk3 исправно генерируется. а s_counter = 0. хотя я добавил в условие
if (clk3 = '1') then
    s_counter <= s_counter + '1';
end if;
ну хорошо - мой косяк :)).
вот сгенерировался вполне логичный случай
видим в ST_INSTR - два clk3. и s_counter инкрементируется.
when ST_INSTR =>
	end if;
	case clk_count is
        when 1 =>
             s_instruction(7 downto 4) <= SPI_DATA;
        when 2 =>
            s_instruction(3 downto 0) <= SPI_DATA;
            clk_count := 0;
            QSpiState <= ST_ADDR;
       when others =>
            clk_count := 0;
	        --QSpiState <= ST_ADDR;
    end case;
SPI_DATA = U. ну съехали тайминги получил другое значение на SPI_DATA. но U?
Edited by jenya7
end if;
Это лишь часть правды. Выкладывайте весь модуль ))
quadspi.vhdqspi_tb.vhd
это модуль и тест бенч.
Я понял - это та ещё проблема синхронизировать модуль и тест бенч. тест бенчи нужно уметь писать.
Edited by jenya7
Не факт. В тестбенче у вас qspi_data зависит от некоторых сигналов. Например, от clk_count. Вы уверены, что clk_count и, соответственно, qspi_data формируются так, как вы ожидаете? Ну и сразу замечу, что конструкции типа
Quote
 являются некорректными. Вложенный rising_edge -- это неправильно. Плюс, вопрос на засыпку... Согласно тест-бенчу, как часто должно обновляться значение счетчика clk_count? Судя по коду -- оно вообще не будет обновляться. Процесс доходит до строки "wait;" и всё, до рестарта симуляции в этом процессе больше ничего не произойдет. Т.е. процесс нужно переписать либо так, чтобы он каждый раз срабатывал по очередному клоку, либо нужно будет использовать цикл, в котором последовательно, с учетом ожиданий следующих тактов, менялись бы значения clk_count и qspi_data. Но я бы для начала рекомендовал бы первый вариант, "перезапускаемый" процесс без оператора "wait;" А счётчик clk_count вообще можно вынести в другой процесс.
мне кажется тестбенч должен писать тестировщик иначе есть соблазн подогнать тестбенч под правильный ответ :)
2 часа назад, jenya7 сказал:
Хороший ПЛИСовик должен уметь писать тесты. Иначе никак.
По-хорошему, надо начинать с тестбенча.
Сначала вы "рисуете" входные воздействия для вашего модуля, а потом у же пишете сам модуль, который их обрабатывает.
