MaratZuev
Передача значения из TCL в HDL
Всем добра.
Хочу  передавать изменяющееся в TCL значение в симулируемый посредством Mentor-а HDL.
Запускаю simulate.bat
set Mentor="c:\MentorGraphics\QuestaSim64_2020.1\win64\questasim.exe"
start "" %Mentor% -do "source simulate.tcl"
где simulate.tcl выглядит так
source compilation.tcl
variable testbench tb
variable library work
if [file exists $library] {
    vdel -all
vlib $library
variable DirectoriesList [pwd]
variable Extension2Compile sv
variable Keys "+define+TEST_NUMBER=3"
if {[compilation $DirectoriesList $Extension2Compile $Keys]} {
    vsim -L work work.$testbench
    run 100ns
} else {
    puts "Error compiling files!"
compilation.tcl, в свою очередь, так:
Spoiler
proc compilation {DirectoriesList Extension2Compile Keys} {
    variable Failure 0
    variable Success 1
    variable DirectoriesListNum [llength $DirectoriesList]
    puts "DirectoriesListNum == $DirectoriesListNum"
    if { $DirectoriesListNum == 0} {
        puts "No directories to compile!"
        return $Failure
    for {set i 0} {$i < $DirectoriesListNum} {incr i} {
        variable CurrDirectoryPath [lindex $DirectoriesList $i]
        puts "CurrDirectoryPath == $CurrDirectoryPath at lindex = $i"
        variable FilesOfCurrDirCompiled $Failure
        variable FilesOfCurrDir2Compile [glob -nocomplain $CurrDirectoryPath/*.$Extension2Compile]
        if [llength $FilesOfCurrDir2Compile] {
            vlog +acc $Keys $CurrDirectoryPath/*.$Extension2Compile
            variable FilesOfCurrDirCompiled $Success
        puts "FilesOfCurrDirCompiled = $FilesOfCurrDirCompiled"
        if {$FilesOfCurrDirCompiled == $Failure} {
            puts "failure"
            return $Failure
        } else {
            puts "success"
    return $Success
итоговый transcript выглядит так:
# Reading pref.tcl
# //  Questa Sim-64
# //  Version 2020.1 win64 Jan 28 2020
# //  Copyright 1991-2020 Mentor Graphics Corporation
# //  All Rights Reserved.
# //  QuestaSim and its associated documentation contain trade
# //  secrets and commercial or financial information that are the property of
# //  Mentor Graphics Corporation and are privileged, confidential,
# //  and exempt from disclosure under the Freedom of Information Act,
# //  5 U.S.C. Section 552. Furthermore, this information
# //  is prohibited from disclosure under the Trade Secrets Act,
# //  18 U.S.C. Section 1905.
# source simulate.tcl
# DirectoriesListNum == 1
# CurrDirectoryPath == D:/tcl2tb/Sim at lindex = 0
# QuestaSim-64 vlog 2020.1 Compiler 2020.01 Jan 28 2020
# Start time: 18:56:06 on Sep 24,2021
# vlog -reportprogress 300 "+acc" "+define+TEST_NUMBER=3" D:/tcl2tb/Sim/tb.sv
# -- Compiling module tb
# Top level modules:
# 	tb
# End time: 18:56:06 on Sep 24,2021, Elapsed time: 0:00:00
# Errors: 0, Warnings: 0
# FilesOfCurrDirCompiled = 1
# success
# End time: 18:56:09 on Sep 24,2021, Elapsed time: 0:07:02
# vsim -L work work.tb
# Start time: 18:56:10 on Sep 24,2021
# ** Note: (vsim-8009) Loading existing optimized design _opt
# Loading sv_std.std
# Loading work.tb(fast)
# TSTNUM1 = 1
# TSTNUM2 = 2
откуда следует, что из TCL в HDL (SV) величины не передались. ЧЯДНТ?
Проект, как всегда, в скрепке.
tcl2hdl.zip
2 hours ago, andrew_b said:
Не читаете документацию на симулятор? Не верю, чтобы там не было это описано.
Не поверите, но, прежде задавать вопросы здесь ли или где, я приучен сам сначала искать где возможно ответы. В документации не нашёл. Но сам дошёл до ответа, как и в предыдущий раз. Видимо, не хватает стимулов в виде порицания.
У vsim есть ключик -G для переопределения всех параметров с таким именем в исходника, либо ключик -g, который перреопределяет параметр с таким именем в модуле верхнего уровня
Анатолий, могли бы написать, в чем была проблема?
On 9/27/2021 at 4:40 PM, MaratZuev said:
Вот в этой строке
кавычки лишние
Это выглядит потрясающе. Для стандартного TCL парсера не должно быть никакой разницы. Я специально проверил в tclsh:
set a "+define+TEST_NUMBER=3"
set b +define+TEST_NUMBER=3
put [expr {$a==$b}]
1
Неужели у Квесты парсер какой-то не стандартный?
Тогда непонятно, как кавычки могли повлиять. Ещё хочу заметить, чтобы в vlog можно было передать несколько ключей, заданных в Keys списком, как независимые параметры, а не одной строкой, нужно написать в compilation.tcl
eval vlog +acc $Keys [list $CurrDirectoryPath/*.$Extension2Compile]
list нужен, чтобы eval не разобрал путь с маской на несколько параметров, если в пути вдруг будут пробелы.
Или в современном варианте
vlog +acc {*}$Keys $CurrDirectoryPath/*.$Extension2Compile
1 hour ago, MaratZuev said:
Прошу пояснить, что Вы подразумеваете под оным?
Оператор {*}, позволяющий непосредственно разворачивать список в несколько параметров, появился относительно недавно.
