bnb62 0 30 августа, 2021 Опубликовано 30 августа, 2021 (изменено) · Жалоба if(f_mount(&SDFatFs,(TCHAR const*)USERPath,0)!=FR_OK) { Error_Handler(); } // else // { // FRESULT f_stat (const TCHAR* path, FILINFO* fno); /* Get file status */ //read dir // fileInfo.fname = (char *)sect; fileInfo.fsize = sizeof(sect); res = f_opendir(&dir, "/"); if (res == FR_OK) { while(1) { res = f_readdir(&dir, &fileInfo); if (res==FR_OK && fileInfo.fname[0]) { fn = fileInfo.fname; if(strlen(fn)) HAL_UART_Transmit(&huart2,(uint8_t*)fn,strlen(fn),0x1000); //else // HAL_UART_Transmit(&huart2,(uint8_t*)fileInfo.lfname,strlen((char*)fileInfo.lfname),0x1000); DWORD size = fileInfo.fsize; WORD data_f = fileInfo.fdate; WORD time_f = fileInfo.ftime; if(data_f >= prev_data_f ){ if(time_f >prev_time_f){ prev_time_f = time_f; prev_data_f = data_f; fn = fileInfo.fname; // (char *)! save name current file //names[12] = {'L','o','g','_',in/100%10+0x30,in/10%10+0x30,in%10+0x30,'.','t','x','t',NULL}; for(uint8_t i=0;i<12;i++){ names[i] = dir.fn[i]; //fileInfo.fname[i]; //fn[i];// } } } // sprintf(str1," : %1u %1u ",dat,tim); // HAL_UART_Transmit(&huart2,(uint8_t*)str1,strlen(str1),0x1000); // sprintf(str1," size: %1u",fileInfo.fsize); // HAL_UART_Transmit(&huart2,(uint8_t*)str1,strlen(str1),0x1000); if(fileInfo.fattrib&AM_DIR) { HAL_UART_Transmit(&huart2,(uint8_t*)" [DIR]",7,0x1000); } } else break; HAL_UART_Transmit(&huart2,(uint8_t*)"\r\n",2,0x1000); } // f_getfree("/", &fre_clust, &fs); // sprintf(str1,"fre_clust: %lu\r\n",fre_clust); // HAL_UART_Transmit(&huart2,(uint8_t*)str1,strlen(str1),0x1000); // sprintf(str1,"n_fatent: %lu\r\n",fs->n_fatent); // HAL_UART_Transmit(&huart2,(uint8_t*)str1,strlen(str1),0x1000); // sprintf(str1,"fs_csize: %d\r\n",fs->csize); // HAL_UART_Transmit(&huart2,(uint8_t*)str1,strlen(str1),0x1000); // tot_sect = (fs->n_fatent - 2) * fs->csize; // sprintf(str1,"tot_sect: %lu\r\n",tot_sect); // HAL_UART_Transmit(&huart2,(uint8_t*)str1,strlen(str1),0x1000); // fre_sect = fre_clust * fs->csize; // sprintf(str1,"fre_sect: %lu\r\n",fre_sect); // HAL_UART_Transmit(&huart2,(uint8_t*)str1,strlen(str1),0x1000); // sprintf(str1, "%lu KB total drive space.\r\n%lu KB available.\r\n", fre_sect/2, tot_sect/2); // HAL_UART_Transmit(&huart2,(uint8_t*)str1,strlen(str1),0x1000); // // sprintf(str1,"Total: %u MB.", (uint32_t)(tot_sect/2000)); // SSD1306_GotoXY(0,39); // SSD1306_Puts(str1, &Font_7x10, SSD1306_COLOR_WHITE); // sprintf(str1," Free: %u MB.", (uint32_t)(fre_sect/2000)); // SSD1306_GotoXY(0,50); // SSD1306_Puts(str1, &Font_7x10, SSD1306_COLOR_WHITE); // SSD1306_UpdateScreen(); //HAL_Delay(5000); //FATFS_UnLinkDriver(USERPath); f_closedir(&dir); } //FATFS_UnLinkDriver(USERPath); // uint8_t in = ((names[4]-0x30)*100) + ((names[5]-0x30)*10) + (names[6]-0x30); // in++; // names[4] = in/100%10+0x30; // names[5] = in/10%10+0x30; // names[6] = in%10+0x30; HAL_UART_Transmit(&huart2,(uint8_t*)"\r\n",2,0x1000); HAL_UART_Transmit(&huart2,(uint8_t*)names,strlen(names),0x1000); // File_create(); } HAL_TIM_Encoder_Start(&htim4, TIM_CHANNEL_ALL); Здравствуйте! Обращаюсь с надеждой получить информацию по работе с именами файлов в актуальной версии FATFS/ +stm32f7. Творю логгер данных с сохранением на microСD карточку HC, с перспективой XC (128GB). STM32F765 (3 channels CAN). Реализовал всё: создание файлов, Time Stamp RTC. Сортировку файлов после включении или RST для продолжения записи в самый свежий файл... И, вот, в этой процедуре застрял. Не могу получить из структуры имя файла в байтовый массив, чтобы работать с ним - изменить порядковый номер в имени при достижении назначенного размера для создания нового файла или замены в самого старого. Всё как в видеорегистраторах. В ascii имени через преобразование сделал. Но не могу никак получить имя файла в массив. Имена Лонг не требуются. Достаточно и старого формата 8.3 - имена короткие и однообразные. Но... если выключаю поддержку длинных имен, то имя и расширение преобразуются в прописные символы... -заглавные. В библиотеке есть такое преобразование... но оно почему-то работает странно. Буду рад получить исходники примеров или уроки. Изменено 30 августа, 2021 пользователем bnb62 add code Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
VladimirG 0 30 августа, 2021 Опубликовано 30 августа, 2021 (изменено) · Жалоба Здравствуйте. Так вроде там структура FILINFO в которой массив с именем файла. typedef struct { FSIZE_t fsize; /* File size */ WORD fdate; /* Modified date */ WORD ftime; /* Modified time */ BYTE fattrib; /* File attribute */ #if _USE_LFN != 0 TCHAR altname[13]; /* Alternative file name */ TCHAR fname[_MAX_LFN + 1]; /* Primary file name */ #else TCHAR fname[13]; /* File name */ #endif } FILINFO; Достаточно просто скопировать данные через memcpy или по элементно. Изменено 30 августа, 2021 пользователем VladimirG Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
bnb62 0 30 августа, 2021 Опубликовано 30 августа, 2021 · Жалоба Благодарю за отклик и путеуказание. Мне скоро 59, из них 50 с паяльником. memcpy ? и как элементарно? Вот тут я копирую элементарно? for(uint8_t i=0;i<12;i++){ names[i] = dir.fn[i]; //fileInfo.fname[i]; //fn[i];// } Только в имени файла не имя, а текст "System Volume Information". вернее его первые 12 символов. Впрочем, спасибо! Займусь изучением структур указателей и ссылок. И указателей на указателей указателей ... блть, что-ж нам в асме не жилось? :-). Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
VladimirG 0 30 августа, 2021 Опубликовано 30 августа, 2021 (изменено) · Жалоба 2 hours ago, bnb62 said: if (res==FR_OK && fileInfo.fname[0]) Тут лучше так if (res==FR_OK && fileInfo.fname[0] != '\0') 2 hours ago, bnb62 said: for(uint8_t i=0;i<12;i++){ names[i] = dir.fn[i]; //fileInfo.fname; //fn;// } Тут как то так. С учётом того, что у вас не используються длинные имена. uint8_t names[13]; for(uint8_t i=0;i<12;i++){ names[i] = dir.fn[i]; } 2 hours ago, bnb62 said: //names[12] = {'L','o','g','_',in/100%10+0x30,in/10%10+0x30,in%10+0x30,'.','t','x','t',NULL}; Этак конструкция мне не понятна, in/100%10+0x30, это вычисление символа? тут не хватает обявления типа и размер не 12 а 13 байт. 23 minutes ago, bnb62 said: Благодарю за отклик и путеуказание. Мне скоро 59, из них 50 с паяльником. memcpy ? и как элементарно? Вот тут я копирую элементарно? for(uint8_t i=0;i<12;i++){ names[i] = dir.fn[i]; //fileInfo.fname[i]; //fn[i];// } Только в имени файла не имя, а текст "System Volume Information". вернее его первые 12 символов. Впрочем, спасибо! Займусь изучением структур указателей и ссылок. И указателей на указателей указателей ... блть, что-ж нам в асме не жилось? :-). /* File attribute bits for directory entry (FILINFO.fattrib) */ #define AM_RDO 0x01 /* Read only */ #define AM_HID 0x02 /* Hidden */ #define AM_SYS 0x04 /* System */ #define AM_DIR 0x10 /* Directory */ #define AM_ARC 0x20 /* Archive */ Наверное вы забыли сравнить атрибут перед дейстивем с файлом, так как "System Volume Information" это директория. Изменено 30 августа, 2021 пользователем VladimirG Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
bnb62 0 30 августа, 2021 Опубликовано 30 августа, 2021 (изменено) · Жалоба в последнем закомментированном фрагменте я явно присваивал имя файла с вставкой его переменной части in преобразованной в ascii. И это работало. if (res==FR_OK && fileInfo.fname[0] != '\0') Это мне непонятно. (обратный слэш). В копипасте откуда-то предполагалась проверка, что в нулевом байте массива имени не NULL. Изменено 30 августа, 2021 пользователем bnb62 Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
bnb62 0 30 августа, 2021 Опубликовано 30 августа, 2021 (изменено) · Жалоба 1 hour ago, VladimirG said: Quote Наверное вы забыли сравнить атрибут перед действием с файлом, так как "System Volume Information" это директория. Это факт. Всё трудно даётся. Особенно когда надергал копипастом из чужих и устаревших "примеров", а библиотека-то обновилась... Придётся изучать... Огромное спасибо за ликбез! А так же, великому энтузиасту http://microsin.net/programming/file-systems/fatfs-file-system.html Изменено 30 августа, 2021 пользователем bnb62 Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
jcxz 182 30 августа, 2021 Опубликовано 30 августа, 2021 · Жалоба 2 часа назад, bnb62 сказал: Вот тут я копирую элементарно? for(uint8_t i=0;i<12;i++){ names[i] = dir.fn[i]; //fileInfo.fname[i]; //fn[i];// } Зачем в счётчике цикла uint8_t? В счётчиках цикла на ARM лучше всего использовать int или uint. Так оптимальнее: #define ncell(m) (sizeof(m) / sizeof((m)[0])) uint8_t names[ncell(dir.fn)]; int i = ncell(dir.fn) - 1; do names[i] = dir.fn[i]; while (--i >= 0); Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
bnb62 0 30 августа, 2021 Опубликовано 30 августа, 2021 (изменено) · Жалоба Должен добавить для интересующихся темой, что актуальная библия FATFS обновилась так же в STM32 MX CUBE - добавлены полезные функции. /* FatFs module application interface */ FRESULT f_open (FIL* fp, const TCHAR* path, BYTE mode); /* Open or create a file */ FRESULT f_close (FIL* fp); /* Close an open file object */ FRESULT f_read (FIL* fp, void* buff, UINT btr, UINT* br); /* Read data from the file */ FRESULT f_write (FIL* fp, const void* buff, UINT btw, UINT* bw); /* Write data to the file */ FRESULT f_lseek (FIL* fp, FSIZE_t ofs); /* Move file pointer of the file object */ FRESULT f_truncate (FIL* fp); /* Truncate the file */ FRESULT f_sync (FIL* fp); /* Flush cached data of the writing file */ FRESULT f_opendir (DIR* dp, const TCHAR* path); /* Open a directory */ FRESULT f_closedir (DIR* dp); /* Close an open directory */ FRESULT f_readdir (DIR* dp, FILINFO* fno); /* Read a directory item */ FRESULT f_findfirst (DIR* dp, FILINFO* fno, const TCHAR* path, const TCHAR* pattern); /* Find first file */ FRESULT f_findnext (DIR* dp, FILINFO* fno); /* Find next file */ FRESULT f_mkdir (const TCHAR* path); /* Create a sub directory */ FRESULT f_unlink (const TCHAR* path); /* Delete an existing file or directory */ FRESULT f_rename (const TCHAR* path_old, const TCHAR* path_new); /* Rename/Move a file or directory */ FRESULT f_stat (const TCHAR* path, FILINFO* fno); /* Get file status */ FRESULT f_chmod (const TCHAR* path, BYTE attr, BYTE mask); /* Change attribute of a file/dir */ FRESULT f_utime (const TCHAR* path, const FILINFO* fno); /* Change timestamp of a file/dir */ FRESULT f_chdir (const TCHAR* path); /* Change current directory */ FRESULT f_chdrive (const TCHAR* path); /* Change current drive */ FRESULT f_getcwd (TCHAR* buff, UINT len); /* Get current directory */ FRESULT f_getfree (const TCHAR* path, DWORD* nclst, FATFS** fatfs); /* Get number of free clusters on the drive */ FRESULT f_getlabel (const TCHAR* path, TCHAR* label, DWORD* vsn); /* Get volume label */ FRESULT f_setlabel (const TCHAR* label); /* Set volume label */ FRESULT f_forward (FIL* fp, UINT(*func)(const BYTE*,UINT), UINT btf, UINT* bf); /* Forward data to the stream */ FRESULT f_expand (FIL* fp, FSIZE_t szf, BYTE opt); /* Allocate a contiguous block to the file */ FRESULT f_mount (FATFS* fs, const TCHAR* path, BYTE opt); /* Mount/Unmount a logical drive */ FRESULT f_mkfs (const TCHAR* path, BYTE opt, DWORD au, void* work, UINT len); /* Create a FAT volume */ FRESULT f_fdisk (BYTE pdrv, const DWORD* szt, void* work); /* Divide a physical drive into some partitions */ int f_putc (TCHAR c, FIL* fp); /* Put a character to the file */ int f_puts (const TCHAR* str, FIL* cp); /* Put a string to the file */ int f_printf (FIL* fp, const TCHAR* str, ...); /* Put a formatted string to the file */ TCHAR* f_gets (TCHAR* buff, int len, FIL* fp); /* Get a string from the file */ #define f_eof(fp) ((int)((fp)->fptr == (fp)->obj.objsize)) #define f_error(fp) ((fp)->err) #define f_tell(fp) ((fp)->fptr) #define f_size(fp) ((fp)->obj.objsize) #define f_rewind(fp) f_lseek((fp), 0) #define f_rewinddir(dp) f_readdir((dp), 0) #define f_rmdir(path) f_unlink(path) #ifndef EOF #define EOF (-1) #endif 9 hours ago, bnb62 said: Изменено 31 августа, 2021 пользователем bnb62 Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
bnb62 0 31 августа, 2021 Опубликовано 31 августа, 2021 · Жалоба Задача решена, всем спасибо. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
