sergei94 0 11 декабря, 2020 Опубликовано 11 декабря, 2020 (изменено) · Жалоба Hello i have installed eclipse and the espressif sdk and the example blinky 2 worked great as shown in code 1 bellow. Then i have found a manual serias of narodstream ep5 shown bellow which gives the code shown bellow called code 2https://narodstream.ru/esp8266-urok-5-nastraivaem-toolchain-i-pishem-svoyu-proshivku-v-ide-eclipse-chast-1/ When i Complied code 2 instead of the bilinky 2 code 1 it showed no error,but it didnt blink either. I think its because we used the wrong GPIO. I cant understand the meaning of the CODE2 there is flash stuff, and ATTR,flash map PIN_FUNC_SELECT(PERIPHS_IO_MUX_GPIO2_U, FUNC_GPIO2); gpio_output_set(0, 0, (1 << LED), 0); What kind of code it is? it differs alot from EFR32 simplisity studio. Is there some place i cant learn the meaning of these terms? Code 1 /* The blinky demo using an os timer TODO : work out why this resets after a while */ #include <ets_sys.h> #include <osapi.h> #include <os_type.h> #include <gpio.h> // see eagle_soc.h for these definitions #define LED_GPIO 2 #define LED_GPIO_MUX PERIPHS_IO_MUX_GPIO2_U #define LED_GPIO_FUNC FUNC_GPIO2 #define DELAY 100 /* milliseconds */ LOCAL os_timer_t blink_timer; LOCAL uint8_t led_state=0; LOCAL void ICACHE_FLASH_ATTR blink_cb(void *arg) { GPIO_OUTPUT_SET(LED_GPIO, led_state); PIN_FUNC_SELECT(PERIPHS_IO_MUX_MTDI_U,FUNC_GPIO12); led_state ^=1; } void user_rf_pre_init(void) { } void user_init(void) { // Configure pin as a GPIO PIN_FUNC_SELECT(LED_GPIO_MUX, LED_GPIO_FUNC); // Set up a timer to blink the LED // os_timer_disarm(ETSTimer *ptimer) os_timer_disarm(&blink_timer); // os_timer_setfn(ETSTimer *ptimer, ETSTimerFunc *pfunction, void *parg) os_timer_setfn(&blink_timer, (os_timer_func_t *)blink_cb, (void *)0); // void os_timer_arm(ETSTimer *ptimer,uint32_t milliseconds, bool repeat_flag) os_timer_arm(&blink_timer, DELAY, 1); } Code 2 #include <stdio.h> #include "ets_sys.h" #include "user_interface.h" #include "gpio.h" //------------------------------------------------------ #define LED 2 //------------------------------------------------------ void delay(uint32_t count ) { while(--count); } //------------------------------------------------------ uint32 ICACHE_FLASH_ATTR user_rf_cal_sector_set(void) { enum flash_size_map size_map = system_get_flash_size_map(); uint32 rf_cal_sec = 0; switch (size_map) { case FLASH_SIZE_4M_MAP_256_256: rf_cal_sec = 128 - 8; break; case FLASH_SIZE_8M_MAP_512_512: rf_cal_sec = 256 - 5; break; case FLASH_SIZE_16M_MAP_512_512: case FLASH_SIZE_16M_MAP_1024_1024: rf_cal_sec = 512 - 5; break; case FLASH_SIZE_32M_MAP_512_512: case FLASH_SIZE_32M_MAP_1024_1024: rf_cal_sec = 1024 - 5; break; default: rf_cal_sec = 0; break; } return rf_cal_sec; } //------------------------------------------------------ void ICACHE_FLASH_ATTR user_init() { gpio_init(); PIN_FUNC_SELECT(PERIPHS_IO_MUX_GPIO2_U, FUNC_GPIO2); gpio_output_set(0, 0, (1 << LED), 0); while(1) { delay(1000000); system_soft_wdt_feed(); gpio_output_set(0, (1 << LED), 0, 0); delay(1000000); system_soft_wdt_feed(); gpio_output_set((1 << LED), 0, 0, 0); } } //------------------------------------------------------ Изменено 11 декабря, 2020 пользователем sergei94 Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
