Возникли вопросы по  АЦП АЦП AD9235BRUZ-65.
1. Какой уровень сигнала должен быть на входе CLK (13) ? Максимум нигде в даташите не указан.
2. Есть генератор, CB3LV-3I-65M5360, 3.3 В. Можно ли его использовать как тактовый для AD9235BRUZ-65 ? В даташите прочел следующие (стр. 19):
Spoiler
TSSOP EVALUATION BOARD
The AD9235 evaluation board provides the support circuitry required to operate the ADC in its various modes and configu-rations. The converter can be driven differentially, through an AD8138 driver or a transformer, or single-ended. Separate pow-er pins are provided to isolate the DUT from the support cir-cuitry. Each input configuration can be selected by proper con-nection of various jumpers (refer to the schematics). Figure 43 shows the typical bench characterization setup used to evaluate the ac performance of the AD9235. It is critical that signal sources with very low phase noise (<1 ps rms jitter) be used to realize the ultimate performance of the converter. Proper filter-ing of the input signal, to remove harmonics and lower the inte-grated noise at the input, is also necessary to achieve the speci-fied noise performance.
The AUXCLK input should be selected in applications requiring the lowest jitter and SNR performance, i.e., IF undersampling characterization. It allows the user to apply a clock input signal that is 4× the target sample rate of the AD9235. A low-jitter, differential divide-by-4 counter, the MC100LVEL33D, provides a 1× clock output that is subsequently returned back to the CLK input via JP9. For example, a 260 MHz signal (sinusoid) is divided down to a 65 MHz signal for clocking the ADC. Note that R1 must be removed with the AUXCLK interface. Lower jitter is often achieved with this interface since many RF signal generators display improved phase noise at higher output frequencies and the slew rate of the sinusoidal output signal is 4× that of a 1× signal of equal amplitude.
Complete schematics and layout plots follow and demonstrate the proper routing and grounding techniques that should be applied at the system level.
An alternative differential analog input path using an AD8351 op amp is included in the layout but is not populated in produc-tion. Designers interested in evaluating the op amp with the ADC should remove C15, R12, and R3 and populate the op amp circuit. The passive network between the AD8351 outputs and the AD9235 allows the user to optimize the frequency response of the op amp for the application.
Не понятна фраза "For example, a 260 MHz signal (sinusoid) is divided down to a 65 MHz signal for clocking the ADC" Почему синус, а не прямоугольник ?
3. Что обозначает "Flexible analog input: 1 V p-p to 2 V p-p range" ? Это имеется в виду дифференциальный вход ?
AD9235.pdf
CB3LV.pdf
1. High / Low Input Voltage. 2.0V min / 0.8V max. Максимум указан в Absolute Maximum Ratings.
Quote
Если по джиттеру подходит, пуркуа бы и не па?
ЗЫ. Вообще-то, великоват джиттер для такого АЦП, так что сами смотрите.
Это просто зависит от референса. См. п. АNALOG INPUT.   Скорее всего, там другого нет, вроде.
Все увидел:
CLK, MODE  min –0.3  max AVDD + 0.3
До этого видел только MODE:aggressive:
Проходит. Вопрос был именно в 3.3 В. Как я понял можно спокойно использовать ?
Спасибо огромное, а то я пол дня голову себе ломал. Но все равно ряд вопросов остался. Что значит  "Flexible analog input: 1 V p-p to 2 V p-p range" ?
И почему именно синусоида берется в качестве тактового сигнала в Evaluation Board ?
Дык, написал же выше. Какой референс выберите - такой диапазон и будет.
Quote
Там всё равно формирователь внутри АЦП, так что пофиг. Синус меньше помех создаёт.
ЗЫ. Посмотрел - есть Single-Ended mode. Тогда при референсе 1V можно подавать на один из входов 2V p-p, хоть это и ухудшит характеристики.
В дифф. режиме с этим референсом можно подавать 1V p-p на каждый из входов в противофазе.
Спасибо еще раз:)
Возможно я туплю, но можно ли подать на вход(в Single-Ended mode) напряжение выше 2 В? 2.8 или 3 В например ?
8 hours ago, uzzzer said:
Спасибо еще раз:)
Сдохнуть - не сдохнет. А зачем?
У меня сигнал с амплитудой до 2.5-2.8 В, с частотой 100 кГц. Особого выбора не было, на складе из подходящих только эти есть. Если он не сдохнет на 3 В, значит буду с ним работать.
А поделить сигнал как-нибудь неужто нельзя?
С референсом там непонятки, но судя по всему, 1V - максимум.
Хоть можно попробовать подать и больше - даташит впрямую не запрещает.
Можно поделить, мне просто не понятно, вот что: в Absolute Maximum Ratings написано одно, описание Evaluation Board другое, в АNALOG INPUT третье... Вот я и хочу понять, прежде чем использовать.
1 час назад, uzzzer сказал:
Absolute Maximum Ratings - это предельное значение, т.е. при достижении прибор не сгорит, но работать может неправильно.
в АNALOG INPUT - рабочие значения.
Обычно там добавляют, что работать может неправильно не более 1 часа. А потом сгорит ;)
On 10/20/2020 at 11:03 AM, uzzzer said:
Можно поделить...
Так в чём проблема? Делите :)
