jenya7 0 September 6, 2020 Posted September 6, 2020 (edited) · Report post В модуле есть компонент component wb_nor_flash is generic ( sector_addr_width : integer := 10; other_addr_width : integer := 16 --sector_addr_width+other_addr_width:integer:=sector_addr_width+other_addr_width ); port ( clk_i: in std_logic; rst_i: in std_logic; wb_addr_i: in std_logic_vector(3 downto 0); wb_dat_i: in std_logic_vector(15 downto 0); wb_dat_o: out std_logic_vector(15 downto 0); wb_stb_i: in std_logic; wb_cyc_i: in std_logic; wb_we_i: in std_logic; wb_ack_o: out std_logic; CEn: out std_logic; OEn: out std_logic; WEn: out std_logic; BYTEn: out std_logic; RESETn: out std_logic; RY_BYn: in std_logic; ADDR: out std_logic_vector(sector_addr_width+other_addr_width-1 downto 0); DQ: inout std_logic_vector(15 downto 0) ); end component; и я делаю мап на него U_NOR_FLASH: wb_nor_flash port map ( clk_i => FLASH_CLK, rst_i => '0', wb_addr_i => s_wb_addr_i, wb_dat_i => s_wb_dat_i, wb_dat_o => s_wb_dat_o, wb_stb_i => s_wb_stb_i, wb_cyc_i => '1', --wb_cyc_i, wb_we_i => s_wb_we_i, wb_ack_o => s_wb_ack_o, CEn => CEn, OEn => s_oe, --OEn, WEn => WEn, BYTEn => BYTEn, --BYTEn, RESETn => s_reset, --RESETn, RY_BYn => RY_BYn, ADDR => ADDR, DQ => s_dq --DQ ); Если я включаю в SignalTap любой сигнал из U_NOR_FLASH например DQ получаю ошибку Quote Error (35030): Partition "Top" contains I/O cells that do not connect to top-level pins or have illegal connectivity Error (35032): Output port "pre_syn.bp.U_NOR_FLASH_U_NOR_FLASH_DQ_0_~direct" on partition "Top" must drive a top-level pin but is driving "<nothing>" Error (35032): Output port "pre_syn.bp.U_NOR_FLASH_U_NOR_FLASH_DQ_10_~direct" on partition "Top" must drive a top-level pin but is driving "<nothing>" Error (35032): Output port "pre_syn.bp.U_NOR_FLASH_U_NOR_FLASH_DQ_11_~direct" on partition "Top" must drive a top-level pin but is driving "<nothing>" Error (35032): Output port "pre_syn.bp.U_NOR_FLASH_U_NOR_FLASH_DQ_12_~direct" on partition "Top" must drive a top-level pin but is driving "<nothing>" Error (35032): Output port "pre_syn.bp.U_NOR_FLASH_U_NOR_FLASH_DQ_13_~direct" on partition "Top" must drive a top-level pin but is driving "<nothing>" Error (35032): Output port "pre_syn.bp.U_NOR_FLASH_U_NOR_FLASH_DQ_14_~direct" on partition "Top" must drive a top-level pin but is driving "<nothing>" Error (35032): Output port "pre_syn.bp.U_NOR_FLASH_U_NOR_FLASH_DQ_15_~direct" on partition "Top" must drive a top-level pin but is driving "<nothing>" Error (35032): Output port "pre_syn.bp.U_NOR_FLASH_U_NOR_FLASH_DQ_1_~direct" on partition "Top" must drive a top-level pin but is driving "<nothing>" Error (35032): Output port "pre_syn.bp.U_NOR_FLASH_U_NOR_FLASH_DQ_2_~direct" on partition "Top" must drive a top-level pin but is driving "<nothing>" Error (35032): Output port "pre_syn.bp.U_NOR_FLASH_U_NOR_FLASH_DQ_3_~direct" on partition "Top" must drive a top-level pin but is driving "<nothing>" Error (35032): Output port "pre_syn.bp.U_NOR_FLASH_U_NOR_FLASH_DQ_4_~direct" on partition "Top" must drive a top-level pin but is driving "<nothing>" Error (35032): Output port "pre_syn.bp.U_NOR_FLASH_U_NOR_FLASH_DQ_5_~direct" on partition "Top" must drive a top-level pin but is driving "<nothing>" Error (35032): Output port "pre_syn.bp.U_NOR_FLASH_U_NOR_FLASH_DQ_6_~direct" on partition "Top" must drive a top-level pin but is driving "<nothing>" Error (35032): Output port "pre_syn.bp.U_NOR_FLASH_U_NOR_FLASH_DQ_7_~direct" on partition "Top" must drive a top-level pin but is driving "<nothing>" Error (35032): Output port "pre_syn.bp.U_NOR_FLASH_U_NOR_FLASH_DQ_8_~direct" on partition "Top" must drive a top-level pin but is driving "<nothing>" Error (35032): Output port "pre_syn.bp.U_NOR_FLASH_U_NOR_FLASH_DQ_9_~direct" on partition "Top" must drive a top-level pin but is driving "<nothing>" Error (15856): Output port O of I/O output buffer "pre_syn.bp.U_NOR_FLASH_U_NOR_FLASH_DQ_0_~direct~output" must drive a top-level pin Error (15856): Output port O of I/O output buffer "pre_syn.bp.U_NOR_FLASH_U_NOR_FLASH_DQ_10_~direct~output" must drive a top-level pin Error (15856): Output port O of I/O output buffer "pre_syn.bp.U_NOR_FLASH_U_NOR_FLASH_DQ_11_~direct~output" must drive a top-level pin Error (15856): Output port O of I/O output buffer "pre_syn.bp.U_NOR_FLASH_U_NOR_FLASH_DQ_12_~direct~output" must drive a top-level pin Error (15856): Output port O of I/O output buffer "pre_syn.bp.U_NOR_FLASH_U_NOR_FLASH_DQ_13_~direct~output" must drive a top-level pin Error (15856): Output port O of I/O output buffer "pre_syn.bp.U_NOR_FLASH_U_NOR_FLASH_DQ_14_~direct~output" must drive a top-level pin Error (15856): Output port O of I/O output buffer "pre_syn.bp.U_NOR_FLASH_U_NOR_FLASH_DQ_15_~direct~output" must drive a top-level pin Error (15856): Output port O of I/O output buffer "pre_syn.bp.U_NOR_FLASH_U_NOR_FLASH_DQ_1_~direct~output" must drive a top-level pin Error (15856): Output port O of I/O output buffer "pre_syn.bp.U_NOR_FLASH_U_NOR_FLASH_DQ_2_~direct~output" must drive a top-level pin Error (15856): Output port O of I/O output buffer "pre_syn.bp.U_NOR_FLASH_U_NOR_FLASH_DQ_3_~direct~output" must drive a top-level pin Error (15856): Output port O of I/O output buffer "pre_syn.bp.U_NOR_FLASH_U_NOR_FLASH_DQ_4_~direct~output" must drive a top-level pin Error (15856): Output port O of I/O output buffer "pre_syn.bp.U_NOR_FLASH_U_NOR_FLASH_DQ_5_~direct~output" must drive a top-level pin Error (15856): Output port O of I/O output buffer "pre_syn.bp.U_NOR_FLASH_U_NOR_FLASH_DQ_6_~direct~output" must drive a top-level pin Error (15856): Output port O of I/O output buffer "pre_syn.bp.U_NOR_FLASH_U_NOR_FLASH_DQ_7_~direct~output" must drive a top-level pin Error (15856): Output port O of I/O output buffer "pre_syn.bp.U_NOR_FLASH_U_NOR_FLASH_DQ_8_~direct~output" must drive a top-level pin Error (15856): Output port O of I/O output buffer "pre_syn.bp.U_NOR_FLASH_U_NOR_FLASH_DQ_9_~direct~output" must drive a top-level pin Никогда такой проблемы не было. Что то новое. Edited September 6, 2020 by jenya7 Quote Share this post Link to post Share on other sites More sharing options...
Flip-fl0p 2 September 6, 2020 Posted September 6, 2020 · Report post Нельзя подключить к signaltap сигналы, которые находятся в IO буферах. Как пример - двунаправленная шина. Quote Share this post Link to post Share on other sites More sharing options...
jenya7 0 September 6, 2020 Posted September 6, 2020 · Report post 4 hours ago, Flip-fl0p said: Нельзя подключить к signaltap сигналы, которые находятся в IO буферах. Как пример - двунаправленная шина. фига се. я не знал. проблема что промежуточные сигналы signaltap не видит в списке. Quote Share this post Link to post Share on other sites More sharing options...
Мур 1 September 6, 2020 Posted September 6, 2020 · Report post 3 hours ago, jenya7 said: фига се. я не знал. проблема что промежуточные сигналы signaltap не видит в списке. В списке много чего нет!.. Всегда можно стать на промежуточные буферизированные точки двунаправленной шины. Создайте их.. Вам же только слушать! Только придется быть назойливым, потому как умный синтезатор будет игнорировать тупиковые связи(и в списке их точно не будет!) Quote Share this post Link to post Share on other sites More sharing options...
new123 0 September 8, 2020 Posted September 8, 2020 · Report post On 9/6/2020 at 5:21 PM, Мур said: потому как умный синтезатор будет игнорировать тупиковые связи(и в списке их точно не будет!) я в таких случаях приписываю директиву компилятору, примерно так reg log_1 /* synthesis noprune */; Тогда синтезатор не выкидывает и в сигналтапе можно наблюдать. Для wire директива чуть другая, не помню как точно. Quote Share this post Link to post Share on other sites More sharing options...
EugeneS 0 September 13, 2020 Posted September 13, 2020 · Report post On 9/8/2020 at 5:46 PM, new123 said: я в таких случаях приписываю директиву компилятору, примерно так reg log_1 /* synthesis noprune */; Тогда синтезатор не выкидывает и в сигналтапе можно наблюдать. Для wire директива чуть другая, не помню как точно. syn_keep ? Quote Share this post Link to post Share on other sites More sharing options...
jenya7 0 September 13, 2020 Posted September 13, 2020 · Report post On 9/8/2020 at 5:46 PM, new123 said: я в таких случаях приписываю директиву компилятору, примерно так reg log_1 /* synthesis noprune */; Тогда синтезатор не выкидывает и в сигналтапе можно наблюдать. Для wire директива чуть другая, не помню как точно. это где? Quote Share this post Link to post Share on other sites More sharing options...
des00 16 September 14, 2020 Posted September 14, 2020 · Report post 13 hours ago, jenya7 said: это где? симплифай, квартус. в виваде другой формат этого констрейна Quote Share this post Link to post Share on other sites More sharing options...
jenya7 0 September 14, 2020 Posted September 14, 2020 · Report post 1 hour ago, des00 said: симплифай, квартус. в виваде другой формат этого констрейна что то я отстал от жизни. что такое симплифай? Quote Share this post Link to post Share on other sites More sharing options...
des00 16 September 14, 2020 Posted September 14, 2020 · Report post 1 hour ago, jenya7 said: что то я отстал от жизни. что такое симплифай? https://www.synopsys.com/implementation-and-signoff/fpga-based-design/synplify-pro.html Quote Share this post Link to post Share on other sites More sharing options...
jenya7 0 September 14, 2020 Posted September 14, 2020 · Report post 1 hour ago, des00 said: https://www.synopsys.com/implementation-and-signoff/fpga-based-design/synplify-pro.html так деньги хотят. Quote Share this post Link to post Share on other sites More sharing options...
Raven 0 September 14, 2020 Posted September 14, 2020 · Report post On 9/6/2020 at 9:54 AM, jenya7 said: Если я включаю в SignalTap любой сигнал из U_NOR_FLASH например DQ получаю ошибку Никогда такой проблемы не было. Что то новое. А вы подключаете сигналы из Source, или из Netlist? Quote Share this post Link to post Share on other sites More sharing options...
jenya7 0 September 14, 2020 Posted September 14, 2020 · Report post 1 hour ago, Raven said: А вы подключаете сигналы из Source, или из Netlist? я выбираю pre-synthesis. Quote Share this post Link to post Share on other sites More sharing options...
new123 0 September 14, 2020 Posted September 14, 2020 · Report post 7 hours ago, des00 said: симплифай, квартус. не не, я так делаю, чтобы синтезатор не выкидывал регистры и можно бы было в сигналтапе наблюдать. Симлифлай даже не знал что это такое. Quote Share this post Link to post Share on other sites More sharing options...
EugeneS 0 September 14, 2020 Posted September 14, 2020 · Report post 20 hours ago, jenya7 said: это где? https://www.intel.com/content/www/us/en/programmable/quartushelp/17.0/hdl/vhdl/vhdl_file_dir.htm Quote Share this post Link to post Share on other sites More sharing options...
