How to prevent unauthorized access in data centers?
In some large data centers or telecommunications rooms with complex management personnel or multiple departments, it’s important to ensure that the optical connection is not disconnected by some misoperations.
Lockable fiber optic connectors are products based on this security requirement.On the basis of ordinary fiber optic connectors, the lock connector adds a unique locking and independent unlocking tool, which uses to lock the dedicated fiber port.It can effectively prevent accidental inserting and removing by other personnel and improve the security of the entire network.
How does it work?
Here are two lockable connectors: SC secure lockable connector and LC secure lockable connector.
Secure-Keyed SC connector has unique keying details and can be locked by simply plugging it into the adapter. Once the connector is locked, only the matching color key can open and release the connector. The security lock sc connector comes in five different colors and can be used in different applications. For fiber ports that are not being used temporarily, dust caps with the same locking function have also been developed. The difference is that the dust cap can be opened with any color key.
The secure locking LC connector was developed from adding a lockable accessory to the traditional duplex connector. The removal of the security lock will not interfere with the LC adapter or cause network performance degradation.
Both locking LC/SC fiber optic connectors are fully compatible with conventional adapters without the need to use specific cables or adapters. It can be easily installed and removed without affecting adjacent ports.
It is especially suitable for networks with higher security levels such as military, government, finance, education, and medical treatment, which can effectively prevent unauthorized tampering.
About HYC Co., Ltd
HYC has 20 years of OEM/ODM manufacturing experience in optical passive devices in the optical communications industry and is committed to providing high-quality connected products for global data users. At present, HYC has several major product lines such as optical fiber connectors, optical fiber jumpers, PLC optical splitters, WDM wavelength division multiplexers, and MEMS optical switches. The factory has more than 1,000 employees and has strong production capabilities.
Присоединяйтесь к обсуждению
Гость
Ответить в этой теме...
