ser 0 7 апреля, 2020 Опубликовано 7 апреля, 2020 · Жалоба Добрый день! Не удается запустить SFP модуль, ядро отказывается его включать. Если притянуть TX_DISABLE модуля к земле все работает. Процессор i.MX287, ядро 5.6.2. DTS: ahb@80080000 { mac0: ethernet@800f0000 { phy-mode = "rmii"; pinctrl-names = "default"; pinctrl-0 = <&mac0_pins_a>; phy-supply = <®_board_3v3>; phy-reset-gpios = <&gpio4 13 0>; phy-reset-duration = <100>; phy-handle = <ðphy0>; managed = "in-band-status"; status = "okay"; mdio { #address-cells = <1>; #size-cells = <0>; ethphy0: ethernet-phy@3 { compatible = "ethernet-phy-ieee802.3-c22"; reg = <3>; max-speed = <100>; }; ethphy1: ethernet-phy@1 { compatible = "ethernet-phy-ieee802.3-c22"; reg = <1>; max-speed = <100>; micrel,fiber-mode; sfp = <&fiber>; }; }; }; mac1: ethernet@800f4000 { phy-mode = "rmii"; pinctrl-names = "default"; pinctrl-0 = <&mac1_pins_a>; phy-supply = <®_board_3v3>; phy-handle = <ðphy1>; status = "okay"; }; }; fiber: fiber { compatible = "sff,sfp"; i2c-bus = <&i2c0>; los-gpios = <&gpio0 24 GPIO_ACTIVE_HIGH>; mod-def0-gpios = <&gpio0 6 GPIO_ACTIVE_LOW>; pinctrl-names = "default"; pinctrl-0 = <&sfp_pins_gpio>; tx-disable-gpios = <&gpio0 27 GPIO_ACTIVE_HIGH>; tx-fault-gpios = <&gpio0 4 GPIO_ACTIVE_HIGH>; }; лог ядра: . . [ 2.875500] libphy: SFP I2C Bus: probed [ 2.879840] sfp fiber: Host maximum power 1.0W [ 2.888324] libphy: Fixed MDIO Bus: probed [ 3.005492] libphy: fec_enet_mii_bus: probed [ 3.021072] i2c /dev entries driver . . [ 200.551606] Micrel KSZ8081 or KSZ8091 800f0000.ethernet-1:03: attached PHY driver [Micrel KSZ8081 or KSZ8091] (mii_bus:phy_addr=800f0000.ethernet-1:03, irq=POLL) [ 211.842321] Micrel KSZ8041 800f0000.ethernet-1:01: attached PHY driver [Micrel KSZ8041] (mii_bus:phy_addr=800f0000.ethernet-1:01, irq=POLL) при подключении SFP модуля [ 493.262941] sfp fiber: SM: enter empty:detached:down event tx_clear [ 493.269402] sfp fiber: SM: exit empty:detached:down [ 493.274492] sfp fiber: SM: enter empty:detached:down event insert [ 493.280751] sfp fiber: SM: exit probe:detached:down [ 493.602920] sfp fiber: SM: enter probe:detached:down event timeout [ 493.626051] sfp fiber: module D-Link DEM-220T rev C1 sn S9121H3000239 dc 170316 [ 493.635527] sfp fiber: SM: exit waitdev:detached:down [ 507.866207] sfp fiber: SM: enter waitdev:detached:down event los_low [ 507.872739] sfp fiber: SM: exit waitdev:detached:down [ 508.803644] fec 800f4000.ethernet eth1: Link is Up - 100Mbps/Half - flow control off отключение кабеля [ 2035.134718] sfp fiber: SM: enter waitdev:detached:down event los_high [ 2035.141430] sfp fiber: SM: exit waitdev:detached:down [ 2035.587365] fec 800f4000.ethernet eth1: Link is Down Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
