jenya7
Математика в VHDL
Как мне такие вычисления перенести в VHDL?
Spoiler
volt_on_a2d_j1 = (double)(fastBuff_posJ1[29] / 4096.0) * 4.99;
volt_3ms_j1 = volt_on_a2d_j1 * 3.74;
volt_on_a2d_j1 = (double)(fastBuff_posJ1[59] / 4096.0) * 4.99;
volt_6ms_j1 = volt_on_a2d_j1 * 3.74;
volt_delta_j1 = volt_6ms_j1 - volt_3ms_j1;
volt_ct_j1 = volt_6ms_j1 + 0.560;
qc_j1 = Ict_439_j1 * 0.003;
ct_j1 = qc_j1 / volt_delta_j1;
//average to reduce the error
for (ii = 0; ii < 10; ii++)
	volt_on_a2d_j1 = (double)(fastBuff_negJ1[20+ii] / 4096.0) * 4.99;
	volt_on_a2d_j2 = (double)(fastBuff_negJ2[20+ii] / 4096.0) * 4.99;
	volt_3ms_j2 = volt_on_a2d_j2 * 3.74;
	volt_on_a2d_j1 = (double)(fastBuff_negJ1[50+ii] / 4096.0) * 4.99;
	volt_on_a2d_j2 = (double)(fastBuff_negJ2[50+ii] / 4096.0) * 4.99;
	volt_6ms_j2 = volt_on_a2d_j2 * 3.74;
	volt_delta_cf_j1 = volt_6ms_j1 - volt_3ms_j1;
	volt_delta_cf_j2 = volt_6ms_j2 - volt_3ms_j2;
	volt_delta_avg_j1 += volt_delta_cf_j1;
	volt_delta_avg_j2 += volt_delta_cf_j2;
volt_delta_avg_j1 /= 10.0;
volt_delta_avg_j2 /= 10.0;
//calculate capacitor charge I * dT
qc_j1 = If_j1 * 0.003;
qc_j2 = If_j2 * 0.003;
cf_j1 = fabs(qc_j1 / volt_delta_avg_j1);  //volt_delta;
cf_j2 = fabs(qc_j2 / volt_delta_avg_j2);
volt_cf_j1 = (volt_delta_avg_j1 * 2) + DIODE_DROP;
volt_cf_j2 = (volt_delta_avg_j2 * 2) + DIODE_DROP;
cs_j1 = (ct_j1*cf_j1) / (ct_j1+cf_j1);
cs_j2 = (ct_j2*cf_j2) / (ct_j2+cf_j2);
double expon_j1 = exp( (-1) * ( fuzeTime1553_j1/(R_TOTAL*cs_j1) ) );
double expon_j2 = exp( (-1) * ( fuzeTime1553_j2/(R_TOTAL*cs_j2) ) );
volt_cf_fixed_j1 = ( volt_ct_j1 * ( ct_j1+(cf_j1*expon_j1) ) ) / ( cf_j1 * (1-expon_j1) );
volt_cf_fixed_j2 = ( volt_ct_j2 * ( ct_j2+(cf_j2*expon_j2) ) ) / ( cf_j2 * (1-expon_j2) );
i_fixed_j1 = ( (cf_j1 * (volt_cf_fixed_j1 - volt_cf_j1) ) / 0.034) * (-1.0);
i_fixed_j2 = ( (cf_j2 * (volt_cf_fixed_j2 - volt_cf_j2) ) / 0.034) * (-1.0);
double temp_j1 = 2E+06*i_fixed_j1*i_fixed_j1 - 722096*i_fixed_j1 + 33179 ;
double temp_j2 = 2E+06*i_fixed_j2*i_fixed_j2 - 722096*i_fixed_j2 + 33179 ;
VHDL работает с double?
Конечно. Тип real. Так и пишите
signal volt_on_a2d_j1 : real;
volt_on_a2d_j1 <= ...
Правда дальше у вас возникнет вопрос, как ти вычисления разместить в FPGA и это уже совсем другой вопрос.
это сожрет много LE?
Нисколько. В логику вещественная арифметика не синтезируется. Но про синтез ведь вопроса не было.
Скорее всего нет :wink:
Но Вам придётся придумать как числа с плавающей точкой уместить в фиксированной логике и выполнить вычисления на DSP блоках. По-другому оно даже не засинтезирует
не понял. после Pace&Route что мы увидим в RTL? математика требует сумматоры, дивайдеры, что он там еще вставляет. это же должно быть реализовано в железе.
сделал для примера
volt_on_a2d_j1 <= (0.003 * 120) / 0.5;
получаю
Error (10414):  cannot synthesize non-constant real objects or values
Всё верно... Если мы говорим про целочисленные или с фиксированной точкой. Для вычислений с плавающей запятой этот номер не проканает. Можно, наверное, использовать какие-то либы, чтобы оно попробовало синтезировать, но я таких фокусов не знаю (разве только через Матлаб).
UPD Однако оказывается, что VHDL-2008 поддерживает синтез чисел с плавающей запятой. Стало и самому интересно как оно это всё разведёт. По прикидкам подозреваю, что одна операция умножения real'а займёт раза в 3 больше логики, чем аналогичная с фиксированной точкой. Ну и сумма/разница раза в 1.5-2 раза больше. Короче очень много.
а если умножить все  на 1000 и работать с integer? если все так грустно... скорее всего я потеряю точность и выйду за рамки допустимой ошибки :(
Edited by jenya7
6 минут назад, jenya7 сказал:
Именно так и делают: превращают плавующую точку в фиксированную. Но обычно умножают на степень двойки.
Это всё делается до того, как написать VHDL-код и превратить его в железо.
В десятки раз проще будет. Или использовать хотя бы single-precision значения.
Просмотрел IP ядра, которые используются для генерации одной операции для работы с числами с плавающей точкой:
1. Float single-precision multiply: 2-3 DSP
2. Float double-precision multiply: 10-11DSP
3. Float single-precision add/substrate : 1-2 DSP
4. Float double-precision add/substrate: 3 DSP
Хочу подчеркнуть - это только на одну операцию. Впринципе если у вас виртекс лежит в тумбочке, то может и влезет.
я потеряю точность. на что мне умножить 0.0000001234.
Задайтесь сперва вопросом - с какой скоростью вам надо проводить эти вычисления? Возможно, что поставить процессор будет наилучшим решением. Еще один вариант - задествовать High Level Synthesis и из Си получить готовый HDL-код.
нужно очень высокое быстродействие. поэтому решено всю математику перенести в FPGA.
9 минут назад, jenya7 сказал:
я потеряю точность.
А вы думаете, вам IEEE 754 гарантирует точное представлние чисел? Я вас разочарую. Из-за ограничения разрядной сетки точность теряется в любом случае.
36 минут назад, Nick_K сказал:
Там есть специальные типы для этого. Вектор (N downto -M) содержит целую (N downto 0) и дробную части (-1 downto -M). Помнится, Xilinx, что-ли, не поддерживал векторы с отрицательными границами. Учитывая, в каком состоянии у них в целом поддержка VHDL'2008, не удивлюсь, если всё так и осталось.
