Art55555
Прием данных с AD9697
Есть Kintex 7 и AD9697. Для такта использую AD9528 ( в связке с SI570).
Со стандартом JESD204B никогда не работал, разбираюсь. Есть знающие?
На данный момент на выходе вижу нули.
Файл прилагаю как в теле, так и в прикреплённых.
ad9697.vhd
-- Company:
-- Engineer:
-- Create Date: 19.09.2019 11:47:46
-- Design Name:
-- Module Name: ad9697 - Behavioral
-- Project Name:
-- Target Devices:
-- Tool Versions:
-- Description:
-- Dependencies:
-- Revision:
-- Revision 0.01 - File Created
-- Additional Comments:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
library UNISIM;
    use UNISIM.VComponents.all;
-- Uncomment the following library declaration if using
-- arithmetic functions with Signed or Unsigned values
--use IEEE.NUMERIC_STD.ALL;
-- Uncomment the following library declaration if instantiating
-- any Xilinx leaf cells in this code.
--library UNISIM;
--use UNISIM.VComponents.all;
entity ad9697 is
	 Port (
            clk         : in STD_LOGIC;
            reset        : in STD_LOGIC;
			ADC0_p   : in STD_LOGIC;
			ADC0_n   : in STD_LOGIC;
			ADC1_p   : in STD_LOGIC;
			ADC1_n   : in STD_LOGIC;
			ADC2_p   : in STD_LOGIC;
			ADC2_n   : in STD_LOGIC;
			ADC3_p   : in STD_LOGIC;
			ADC3_n   : in STD_LOGIC;
			MGT_clk_p    : in STD_LOGIC;    --clk_out1
			MGT_clk_n    : in STD_LOGIC;
			SYNCINB_p : out STD_LOGIC;
			SYNCINB_n  : out STD_LOGIC;
			SYS_REF_CLOCK_p   : in STD_LOGIC;
			SYS_REF_CLOCK_n    : in STD_LOGIC;
            SYS_REF_CLOCK_OUT: out STD_LOGIC;
			PDWN : out STD_LOGIC;
			test_out0   : out std_logic_vector (15 downto 0);
			test_out1   : out std_logic_vector (15 downto 0);
			test_out2   : out std_logic_vector (15 downto 0);
			test_out3   : out std_logic_vector (15 downto 0);
			test_out4   : out std_logic_vector (15 downto 0)
end ad9697;
architecture Behavioral of ad9697 is
signal ADC_p : std_logic_vector (3 downto 0);
signal ADC_n : std_logic_vector (3 downto 0);
signal rx_reset		:   STD_LOGIC;
component  jesd204_phy_0 is
  PORT(
  -- System Reset Inputs for each direction
	tx_sys_reset : in  STD_LOGIC;
	rx_sys_reset : in  STD_LOGIC;
  -- Reset Inputs for each direction
	tx_reset_gt : in  STD_LOGIC;
	rx_reset_gt : in  STD_LOGIC;
  -- Reset Done for each direction
	tx_reset_done    : out  STD_LOGIC;
	rx_reset_done    : out  STD_LOGIC;
  -- GT Common 0 I/O
	qpll_refclk : in  STD_LOGIC;
	common0_qpll_lock_out 	 : out  STD_LOGIC;
	common0_qpll_refclk_out  : out  STD_LOGIC;
	common0_qpll_clk_out 	 : out  STD_LOGIC;
	rxencommaalign : in  STD_LOGIC;
	tx_core_clk : in  STD_LOGIC;
	txoutclk		 : out  STD_LOGIC;
	rx_core_clk  : in  STD_LOGIC;
	rxoutclk	  : out  STD_LOGIC;
	drpclk   : in  STD_LOGIC;
  -- PRBS mode
    gt_prbssel : in std_logic_vector(2 downto 0);
  -- Tx Ports
  -- Lane 0
	gt0_txcharisk	: in std_logic_vector(3 downto 0);
	gt0_txdata	 	: in std_logic_vector(31 downto 0);
  -- Lane 1
	gt1_txcharisk : in std_logic_vector(3 downto 0);
	gt1_txdata    : in std_logic_vector(31 downto 0);
  -- Lane 2
	gt2_txcharisk : in std_logic_vector(3 downto 0);
	gt2_txdata    : in std_logic_vector(31 downto 0);
  -- Lane 3
	gt3_txcharisk : in std_logic_vector(3 downto 0);
	gt3_txdata    : in std_logic_vector(31 downto 0);
  -- Rx Ports
  -- Lane 0
	gt0_rxcharisk 	: out std_logic_vector(3 downto 0);
	gt0_rxdisperr		: out std_logic_vector(3 downto 0);
	gt0_rxnotintable 	: out std_logic_vector(3 downto 0);
	gt0_rxdata		: out std_logic_vector(31 downto 0);
  -- Lane 1
	gt1_rxcharisk     : out std_logic_vector(3 downto 0);
	gt1_rxdisperr     : out std_logic_vector(3 downto 0);
	gt1_rxnotintable  : out std_logic_vector(3 downto 0);
	gt1_rxdata        : out std_logic_vector(31 downto 0);
  -- Lane 2
	gt2_rxcharisk		: out std_logic_vector(3 downto 0);
	gt2_rxdisperr     : out std_logic_vector(3 downto 0);
	gt2_rxnotintable  : out std_logic_vector(3 downto 0);
	gt2_rxdata        : out std_logic_vector(31 downto 0);
  -- Lane 3
	gt3_rxcharisk		: out std_logic_vector(3 downto 0);
	gt3_rxdisperr     : out std_logic_vector(3 downto 0);
	gt3_rxnotintable  : out std_logic_vector(3 downto 0);
	gt3_rxdata        : out std_logic_vector(31 downto 0);
  -- Serial ports
	rxn_in   : in std_logic_vector(3 downto 0);
	rxp_in   : in std_logic_vector(3 downto 0);
	txn_out  : out std_logic_vector(3 downto 0);
	txp_out  : out std_logic_vector(3 downto 0)
end component;
component jesd204_0 is
	port (
	  rx_reset_done		: in  STD_LOGIC;
	  rx_reset			: in  STD_LOGIC;
	  rx_sysref			: in  STD_LOGIC;
	  gt0_rxcharisk		: in std_logic_vector(3 downto 0);
	  gt0_rxdata		: in std_logic_vector(31 downto 0);
	  gt0_rxdisperr		:in std_logic_vector(3 downto 0);
	  gt0_rxnotintable	:in std_logic_vector(3 downto 0);
	  gt1_rxcharisk		: in std_logic_vector(3 downto 0);
	  gt1_rxdata		: in std_logic_vector(31 downto 0);
	  gt1_rxdisperr		:in std_logic_vector(3 downto 0);
	  gt1_rxnotintable	:in std_logic_vector(3 downto 0);
	  gt2_rxcharisk		: in std_logic_vector(3 downto 0);
	  gt2_rxdata		: in std_logic_vector(31 downto 0);
	  gt2_rxdisperr		:in std_logic_vector(3 downto 0);
	  gt2_rxnotintable	:in std_logic_vector(3 downto 0);
	  gt3_rxcharisk		: in std_logic_vector(3 downto 0);
	  gt3_rxdata		: in std_logic_vector(31 downto 0);
	  gt3_rxdisperr		:in std_logic_vector(3 downto 0);
	  gt3_rxnotintable	:in std_logic_vector(3 downto 0);
	  rx_aresetn		: in  STD_LOGIC;
	  rx_reset_gt		: out  STD_LOGIC;
	  rxencommaalign_out: out  STD_LOGIC;
	  rx_tvalid			: out  STD_LOGIC;
	  rx_tdata			: out std_logic_vector(127 downto 0);
	  rx_start_of_frame	: out std_logic_vector(3 downto 0);
	  rx_end_of_frame	: out std_logic_vector(3 downto 0);
	  rx_start_of_multiframe: out std_logic_vector(3 downto 0);
	  rx_end_of_multiframe: out std_logic_vector(3 downto 0);
	  rx_frame_error: out std_logic_vector(15 downto 0);
	  rx_sync: out  STD_LOGIC;
		s_axi_aclk  	: in  STD_LOGIC;
		s_axi_aresetn	: in  STD_LOGIC;
		s_axi_awaddr  : in std_logic_vector(11 downto 0);
		s_axi_awvalid	: in  STD_LOGIC;
		s_axi_awready	: out  STD_LOGIC;
		s_axi_wdata	: in std_logic_vector(31 downto 0);
		s_axi_wstrb	: in std_logic_vector(3 downto 0);
		s_axi_wvalid	: in  STD_LOGIC;
		s_axi_wready	: out  STD_LOGIC;
		s_axi_bresp	: out std_logic_vector(1 downto 0);
		s_axi_bvalid	: out  STD_LOGIC;
		s_axi_bready	: in  STD_LOGIC;
		s_axi_araddr	: in std_logic_vector(11 downto 0);
		s_axi_arvalid	: in  STD_LOGIC;
		s_axi_arready	: out  STD_LOGIC;
		s_axi_rdata	: out std_logic_vector(31 downto 0);
		s_axi_rresp	: out std_logic_vector(1 downto 0);
		s_axi_rvalid	: out  STD_LOGIC;
	s_axi_rready	: in  STD_LOGIC
end component;
component ila_0 IS
PORT (
clk : IN STD_LOGIC;
 probe0 : IN STD_LOGIC_VECTOR(15 DOWNTO 0);
 probe1 : IN STD_LOGIC_VECTOR(15 DOWNTO 0);
 probe2 : IN STD_LOGIC_VECTOR(15 DOWNTO 0);
 probe3 : IN STD_LOGIC_VECTOR(15 DOWNTO 0);
 probe4 : IN STD_LOGIC_VECTOR(15 DOWNTO 0)
END component;
--signal reset : std_logic := '0';
signal clk_mgt: std_logic := '0';
signal SYS_REF_CLOCK: std_logic := '0';
signal	tx_sys_reset :   STD_LOGIC;
signal	rx_sys_reset :   STD_LOGIC;
signal	tx_reset_gt :   STD_LOGIC;
signal	rx_reset_gt :   STD_LOGIC;
signal	tx_reset_done    :   STD_LOGIC;
signal	rx_reset_done    :   STD_LOGIC;
  -- GT Common 0 I/O
signal	qpll_refclk :   STD_LOGIC;
signal	common0_qpll_lock_out 	 :   STD_LOGIC;
signal	common0_qpll_refclk_out  :   STD_LOGIC;
signal	common0_qpll_clk_out 	 :   STD_LOGIC;
signal	rxencommaalign :   STD_LOGIC;
signal	tx_core_clk :   STD_LOGIC;
signal	txoutclk		 :   STD_LOGIC;
signal	rx_core_clk  :   STD_LOGIC;
signal	rxoutclk	  :   STD_LOGIC;
signal	drpclk   :   STD_LOGIC;
  -- PRBS mode
signal    gt_prbssel :  std_logic_vector(2 downto 0);
  -- Tx Ports
  -- Lane 0
signal	gt0_txcharisk	:  std_logic_vector(3 downto 0);
signal	gt0_txdata	 	:  std_logic_vector(31 downto 0);
  -- Lane 1
signal	gt1_txcharisk :  std_logic_vector(3 downto 0);
signal	gt1_txdata    :  std_logic_vector(31 downto 0);
  -- Lane 2
signal	gt2_txcharisk :  std_logic_vector(3 downto 0);
signal	gt2_txdata    :  std_logic_vector(31 downto 0);
  -- Lane 3
signal	gt3_txcharisk :  std_logic_vector(3 downto 0);
signal	gt3_txdata    :  std_logic_vector(31 downto 0);
  -- Rx Ports
  -- Lane 0
signal	gt0_rxcharisk 	:  std_logic_vector(3 downto 0);
signal	gt0_rxdisperr		:  std_logic_vector(3 downto 0);
signal	gt0_rxnotintable 	:  std_logic_vector(3 downto 0);
signal	gt0_rxdata		:  std_logic_vector(31 downto 0);
  -- Lane 1
signal	gt1_rxcharisk     :  std_logic_vector(3 downto 0);
signal	gt1_rxdisperr     :  std_logic_vector(3 downto 0);
signal	gt1_rxnotintable  :  std_logic_vector(3 downto 0);
signal	gt1_rxdata        :  std_logic_vector(31 downto 0);
  -- Lane 2
signal	gt2_rxcharisk		:  std_logic_vector(3 downto 0);
signal	gt2_rxdisperr     :  std_logic_vector(3 downto 0);
signal	gt2_rxnotintable  :  std_logic_vector(3 downto 0);
signal	gt2_rxdata        :  std_logic_vector(31 downto 0);
  -- Lane 3
signal	gt3_rxcharisk		:  std_logic_vector(3 downto 0);
signal	gt3_rxdisperr     :  std_logic_vector(3 downto 0);
signal	gt3_rxnotintable  :  std_logic_vector(3 downto 0);
signal	gt3_rxdata        :  std_logic_vector(31 downto 0);
  -- Serial ports
signal	rxn_in   :  std_logic_vector(3 downto 0);
signal	rxp_in   :  std_logic_vector(3 downto 0);
signal	txn_out  :  std_logic_vector(3 downto 0);
signal	txp_out  :  std_logic_vector(3 downto 0);
signal	refclk0p  :   STD_LOGIC;
signal	refclk0n	:   STD_LOGIC;
signal		glblclkp  :   STD_LOGIC;
signal		glblclkn  :   STD_LOGIC;
signal		tx_reset	:   STD_LOGIC;
signal		tx_start_of_frame		:  std_logic_vector(3 downto 0);
signal		tx_start_of_multiframe:  std_logic_vector(3 downto 0);
signal		txp	:  std_logic_vector(3 downto 0);
signal		txn	:  std_logic_vector(3 downto 0);
signal	s_axi_aclk  	:   STD_LOGIC;
signal	s_axi_aresetn	:   STD_LOGIC;
signal	s_axi_awaddr  :  std_logic_vector(11 downto 0);
signal	s_axi_awvalid	:   STD_LOGIC;
signal	s_axi_awready	:   STD_LOGIC;
signal	s_axi_wdata	:  std_logic_vector(31 downto 0);
signal	s_axi_wstrb	:  std_logic_vector(3 downto 0);
signal	s_axi_wvalid	:   STD_LOGIC;
signal	s_axi_wready	:   STD_LOGIC;
signal	s_axi_bresp	:  std_logic_vector(1 downto 0);
signal	s_axi_bvalid	:   STD_LOGIC;
signal	s_axi_bready	:   STD_LOGIC;
signal	s_axi_araddr	:  std_logic_vector(11 downto 0);
signal	s_axi_arvalid	:   STD_LOGIC;
signal	s_axi_arready	:   STD_LOGIC;
signal	s_axi_rdata	:  std_logic_vector(31 downto 0);
signal	s_axi_rresp	:  std_logic_vector(1 downto 0);
signal	s_axi_rvalid	:   STD_LOGIC;
signal	s_axi_rready	:   STD_LOGIC;
signal		tx_aresetn	:   STD_LOGIC;
signal		tx_sysref	:   STD_LOGIC;
signal		tx_sync	:   STD_LOGIC;
signal  rx_aresetn		:   STD_LOGIC;
--signal  rx_reset_gt		:   STD_LOGIC;
signal  rxencommaalign_out:   STD_LOGIC;
signal  rx_tvalid			:   STD_LOGIC;
signal  rx_tdata			:  std_logic_vector(127 downto 0);
signal  rx_start_of_frame	:  std_logic_vector(3 downto 0);
signal  rx_end_of_frame	:  std_logic_vector(3 downto 0);
signal  rx_start_of_multiframe:  std_logic_vector(3 downto 0);
signal  rx_end_of_multiframe:  std_logic_vector(3 downto 0);
signal  rx_frame_error:  std_logic_vector(15 downto 0);
signal  rx_sync:   STD_LOGIC;
signal  rx_sysref:   STD_LOGIC;
signal  CLKFBIN,CLKFBOUT:   STD_LOGIC;
signal  SYS_REF_CLOCK_1:   STD_LOGIC;
signal  rx_core_4x,rx_core_4x_g:   STD_LOGIC;
signal  rx_core_2x,rx_core_2x_g:   STD_LOGIC;
signal  rx_core_i,rx_core:   STD_LOGIC;
signal  trig0:  std_logic_vector(15 downto 0);
signal  trig1:  std_logic_vector(15 downto 0);
signal  trig2:  std_logic_vector(15 downto 0);
signal  trig3:  std_logic_vector(15 downto 0);
signal  trig4:  std_logic_vector(15 downto 0);
signal  clk_mgt_g:   STD_LOGIC;
signal  cnt_sys_ref:  std_logic_vector(15 downto 0);
begin
 SYS_REF_CLOCK_OUT<=rx_core_4x_g;
process (SYS_REF_CLOCK_1)
  begin
    if(SYS_REF_CLOCK_1'event and SYS_REF_CLOCK_1='1')then
        cnt_sys_ref<=cnt_sys_ref+1;
--        if cnt1=500 then ;end if;
end if;
end process;
IBUFGDS_inst1 : IBUFDS_GTE2
--   generic map (
--      DIFF_TERM => TRUE, -- Differential Termination
--      IBUF_LOW_PWR => TRUE) -- Low power (TRUE) vs. performance (FALSE) setting for referenced I/O standards
--      IOSTANDARD => "LVDS_25")
   port map (
      CEB =>'0',
      O =>  clk_mgt,  -- Clock buffer : out
      I =>   MGT_clk_p,  -- Diff_p clock buffer : in  (connect directly to top-level port)
      IB =>  MGT_clk_n  -- Diff_n clock buffer : in  (connect directly to top-level port)
      BUFG5 : BUFG
     port map (
        O => clk_mgt_g, -- 1-bit output: Output feedback clock (connect to feedback input of DCM/PLL)
        I => clk_mgt  -- 1-bit input: Feedback clock input (connect to input port)
--IBUFGDS_inst2: IBUFDS_GTE2
----   generic map (
----      DIFF_TERM => TRUE, -- Differential Termination
----      IBUF_LOW_PWR => TRUE) -- Low power (TRUE) vs. performance (FALSE) setting for referenced I/O standards
----      IOSTANDARD => "LVDS_25")
--   port map (
--      CEB =>'0',
--      O =>  SYS_REF_CLOCK,  -- Clock buffer : out
--      I =>   SYS_REF_CLOCK_p,  -- Diff_p clock buffer : in  (connect directly to top-level port)
--      IB =>  SYS_REF_CLOCK_n  -- Diff_n clock buffer : in  (connect directly to top-level port)
IBUFDS_inst2: IBUFDS
   generic map (
      IBUF_LOW_PWR => TRUE, -- Low power (TRUE) vs. performance (FALSE) setting for referenced I/O standards
   port map (
OBUFGDS_inst3: OBUFDS
--   generic map (
   port map (
      I =>  rx_core_i,  -- Clock buffer : out
      O =>   SYNCINB_n,  -- Diff_p clock buffer : in  (connect directly to top-level port)
      OB =>  SYNCINB_p  -- Diff_n clock buffer : in  (connect directly to top-level port)
   MMCME2_BASE_inst : MMCME2_BASE
generic map (
        BANDWIDTH => "OPTIMIZED", -- Jitter programming (OPTIMIZED, HIGH, LOW)
        CLKFBOUT_MULT_F => 4.0, -- Multiply value for all CLKOUT (2.000-64.000).
        CLKFBOUT_PHASE => 0.0, -- Phase offset in degrees of CLKFB (-360.000-360.000).
        CLKIN1_PERIOD => 5.0, -- Input clock period in ns to ps resolution (i.e. 33.333 is 30 MHz).
    -- CLKOUT0_DIVIDE - CLKOUT6_DIVIDE: Divide amount for each CLKOUT (1-128)
        CLKOUT1_DIVIDE => 4,
        CLKOUT2_DIVIDE => 8,
        CLKOUT3_DIVIDE => 16,
        CLKOUT4_DIVIDE => 32,
        CLKOUT5_DIVIDE => 64,
        CLKOUT6_DIVIDE => 1,
        CLKOUT0_DIVIDE_F => 8.0, -- Divide amount for CLKOUT0 (1.000-128.000).
    -- CLKOUT0_DUTY_CYCLE - CLKOUT6_DUTY_CYCLE: Duty cycle for each CLKOUT (0.01-0.99).
        CLKOUT0_DUTY_CYCLE => 0.5,
        CLKOUT1_DUTY_CYCLE => 0.5,
        CLKOUT2_DUTY_CYCLE => 0.5,
        CLKOUT3_DUTY_CYCLE => 0.5,
        CLKOUT4_DUTY_CYCLE => 0.5,
        CLKOUT5_DUTY_CYCLE => 0.5,
        CLKOUT6_DUTY_CYCLE => 0.5,
    -- CLKOUT0_PHASE - CLKOUT6_PHASE: Phase offset for each CLKOUT (-360.000-360.000).
        CLKOUT0_PHASE => 0.0,
        CLKOUT1_PHASE => 0.0,
        CLKOUT2_PHASE => 0.0,
        CLKOUT3_PHASE => 0.0,
        CLKOUT4_PHASE => 0.0,
        CLKOUT5_PHASE => 0.0,
       CLKOUT6_PHASE => 0.0,
       -- CLKOUT4_CASCADE => FALSE, -- Cascade CLKOUT4 counter with CLKOUT6 (FALSE, TRUE)
        DIVCLK_DIVIDE => 1, -- Master division value (1-106)
        REF_JITTER1 => 0.0, -- Reference input jitter in UI (0.000-0.999).
        STARTUP_WAIT => FALSE -- Delays DONE until MMCM is locked (FALSE, TRUE)
    port map (
    -- Clock Outputs: 1-bit (each) output: User configurable clock outputs
        CLKOUT0 => OPEN, -- 1-bit output: CLKOUT0
        CLKOUT0B => OPEN, -- 1-bit output: Inverted CLKOUT0
        CLKOUT1 => rx_core_4x, -- 1-bit output: CLKOUT1
        CLKOUT1B => OPEN, -- 1-bit output: Inverted CLKOUT1
        CLKOUT2 => rx_core_2x, -- 1-bit output: CLKOUT2
        CLKOUT2B => OPEN, -- 1-bit output: Inverted CLKOUT2
        CLKOUT3 => rx_core_i, -- 1-bit output: CLKOUT3
        CLKOUT3B => OPEN, -- 1-bit output: Inverted CLKOUT3
        CLKOUT4 => OPEN, -- 1-bit output: CLKOUT4
        CLKOUT5 => OPEN, -- 1-bit output: CLKOUT5
        CLKOUT6 => OPEN, -- 1-bit output: CLKOUT6
    -- Feedback Clocks: 1-bit (each) output: Clock feedback ports
        CLKFBOUT => CLKFBOUT, -- 1-bit output: Feedback clock
        CLKFBOUTB => OPEN, -- 1-bit output: Inverted CLKFBOUT
    -- Status Ports: 1-bit (each) output: MMCM status ports
        LOCKED => OPEN, -- 1-bit output: LOCK
    -- Clock Inputs: 1-bit (each) input: Clock input
        CLKIN1 => SYS_REF_CLOCK_1, -- 1-bit input: Clock
    -- Control Ports: 1-bit (each) input: MMCM control ports
        PWRDWN => '0', -- 1-bit input: Power-down
    RST => '0', -- 1-bit input: Reset
-- Feedback Clocks: 1-bit (each) input: Clock feedback ports
CLKFBIN => CLKFBIN -- 1-bit input: Feedback clock
    BUFG1 : BUFG
   port map (
      O => CLKFBIN, -- 1-bit output: Output feedback clock (connect to feedback input of DCM/PLL)
      I => CLKFBOUT  -- 1-bit input: Feedback clock input (connect to input port)
    BUFG0 : BUFG
   port map (
      O => SYS_REF_CLOCK_1, -- 1-bit output: Output feedback clock (connect to feedback input of DCM/PLL)
      I => SYS_REF_CLOCK  -- 1-bit input: Feedback clock input (connect to input port)
    BUFG2 : BUFG
   port map (
      O => rx_core_4x_g, -- 1-bit output: Output feedback clock (connect to feedback input of DCM/PLL)
      I => rx_core_4x  -- 1-bit input: Feedback clock input (connect to input port)
    BUFG3 : BUFG
   port map (
      O => rx_core_2x_g, -- 1-bit output: Output feedback clock (connect to feedback input of DCM/PLL)
      I => rx_core_2x  -- 1-bit input: Feedback clock input (connect to input port)
    BUFG4 : BUFG
   port map (
      O => rx_core_clk, -- 1-bit output: Output feedback clock (connect to feedback input of DCM/PLL)
      I => rx_core_i  -- 1-bit input: Feedback clock input (connect to input port)
ADC_p <=ADC3_p&ADC2_p&ADC1_p&ADC0_p;
ADC_n <=ADC3_n&ADC2_n&ADC1_n&ADC0_n;
   x_jesd204_phy_0 :  jesd204_phy_0
  PORT MAP(
	tx_sys_reset 			  => tx_sys_reset,
	rx_sys_reset 			  => reset, -------------
	tx_reset_gt 			  => tx_reset_gt,
	rx_reset_gt 			  => rx_reset_gt, ------------
	tx_reset_done  			  => tx_reset_done,
	rx_reset_done   		  => rx_reset_done,
	qpll_refclk 			  => SYS_REF_CLOCK_1, ------------------------qpll_refclk,--SYS_REF_CLOCK_1, ------------------------
	common0_qpll_lock_out 	  => common0_qpll_lock_out,
	common0_qpll_refclk_out   => common0_qpll_refclk_out,
	common0_qpll_clk_out 	  => common0_qpll_clk_out,
	rxencommaalign 			  => rxencommaalign, ----------------
	tx_core_clk				  => tx_core_clk,
	txoutclk				  => txoutclk,
	rx_core_clk  			  => rx_core_clk,  ------------------
	rxoutclk	 			  => rxoutclk,
	drpclk   				  => SYS_REF_CLOCK_1, ------------------------qpll_refclk,--*SYS_REF_CLOCK_1, 					--
    gt_prbssel 				  => "000",
	gt0_txcharisk			  => gt0_txcharisk,
	gt0_txdata	 			  => gt0_txdata,
	gt1_txcharisk 			  => gt1_txcharisk,
	gt1_txdata    			  => gt1_txdata,
	gt2_txcharisk 			  => gt2_txcharisk,
	gt2_txdata    			  => gt2_txdata,
	gt3_txcharisk 			  => gt3_txcharisk,
	gt3_txdata    			  => gt3_txdata,
	gt0_rxcharisk 			  => gt0_rxcharisk,
	gt0_rxdisperr			  => gt0_rxdisperr,
	gt0_rxnotintable 		  => gt0_rxnotintable,
	gt0_rxdata				  => gt0_rxdata,
	gt1_rxcharisk    		  => gt1_rxcharisk,
	gt1_rxdisperr   		  => gt1_rxdisperr,
	gt1_rxnotintable		  => gt1_rxnotintable,
	gt1_rxdata      		  => gt1_rxdata,
	gt2_rxcharisk			  => gt2_rxcharisk,
	gt2_rxdisperr   		  => gt2_rxdisperr,
	gt2_rxnotintable		  => gt2_rxnotintable,
	gt2_rxdata      		  => gt2_rxdata,
	gt3_rxcharisk			  => gt3_rxcharisk,
	gt3_rxdisperr   		  => gt3_rxdisperr,
	gt3_rxnotintable		  => gt3_rxnotintable,
	gt3_rxdata      		  => gt3_rxdata,
	rxn_in  				  => ADC_n, --------------------
	rxp_in  				  => ADC_p, -------------------
	txn_out 				  => txn_out,
	txp_out 				  => txp_out
x_jesd204_0: jesd204_0
	port map (
	rx_reset			 => rx_reset,
	rx_sysref			 => rx_sysref,
	rx_aresetn				   => rx_aresetn,
	rxencommaalign_out		   => rxencommaalign_out,
	rx_tvalid				   => rx_tvalid,
	rx_tdata				   => rx_tdata,
	rx_start_of_frame		   => rx_start_of_frame,
	rx_end_of_frame			   => rx_end_of_frame,
	rx_start_of_multiframe	   => rx_start_of_multiframe,
	rx_end_of_multiframe	   => rx_end_of_multiframe,
	rx_frame_error			   => rx_frame_error,
	rx_sync					   => rx_sync,
	s_axi_aclk  	          => s_axi_aclk,
	s_axi_aresetn	          => s_axi_aresetn,
	s_axi_awaddr              => s_axi_awaddr,
	s_axi_awvalid	          => s_axi_awvalid,
	s_axi_awready	          => s_axi_awready,
	s_axi_wdata	              => s_axi_wdata,
	s_axi_wstrb	              => s_axi_wstrb,
	s_axi_wvalid	          => s_axi_wvalid,
	s_axi_wready	          => s_axi_wready,
	s_axi_bresp	              => s_axi_bresp,
	s_axi_bvalid	          => s_axi_bvalid,
	s_axi_bready	          => s_axi_bready,
	s_axi_araddr	          => s_axi_araddr,
	s_axi_arvalid	          => s_axi_arvalid,
	s_axi_arready	          => s_axi_arready,
	s_axi_rdata	              => s_axi_rdata,
	s_axi_rresp	              => s_axi_rresp,
	s_axi_rvalid	          => s_axi_rvalid,
	s_axi_rready	          => s_axi_rready
 i_ILA55 : ila_0
     port map
       clk         => rx_core_clk,--inClk,
       probe0       => trig0,
       probe1       => trig1,
       probe2       => trig2,
       probe3       => trig3,
       probe4       => trig4
 trig0(0)<=rx_tvalid;
 trig1<=rx_tdata(15 downto 0);
 trig2<=rx_tdata(31 downto 16);
 trig3<=rx_tdata(47 downto 32);
 trig4<=rx_tdata(63 downto 48);
end Behavioral;
советую начать изучать jesd204 иначе будет туго.
Чтобы он заработал надо приёмную и передающую часть , перед тем как поднимется линк , настраивать на одни параметры линии : число линий, скорость, режимы работы.
Причём ацп надо сначало по его spi запрограмировать.
В первом приближении , если у вас всё настроено, то смотрят сигнал SYNC_N - если он в нуле , значит нет синхронизации по линку. Но для этого , повторюсь надо кучу всего настроить.
Тактовые частоты , sysref и т.д.
p/s/
для начала надо добиться приёма в ПЛИС служебного символа "К" (K.28.5) по линиям - это будет означать, что по крайней мере частоты работы между ПЛИС и АЦП одинаковые.
Потом надо идти дальше по джезду.
p/s/
Получается, мои действия следующие:
1) По даташиту 9697 выбираю требуемый режим передачи данных с АЦП. это парамерты (L,M,S K и т.д.)
2) Ввожу эти параметры в 2 ядра (JESD PHY и просто JESD), генерю ядра, делаю битник.
3) С помощью SPI настраиваю 9697 на эти параметры.
Теперь вопросы?
1) Где этот SYNC_N смотреть?
2) Где смотреть символ "К"?
13 минут назад, Art55555 сказал:
SYNC_N  - это сигнал выходной для приёмника jesd204 и входной для передатчика , у вашего АЦП это сигнал в дифф. виде - SYNCINB (20,21) нога.
Символ "К" надо ловить в ПЛИС с гигабитных трансиверов после преобразования 10/8 , это служебный символ .
его 16-чный код 0xBC   (K.28.5  ) . Он передаётся в линию до момента синхронизации . Как только приёмник jesd204 примет Символ "К" по всем линиям джезда , приёмник переведёт SYNC_N  из "0" в "1" .
з.ы.
советую отключить в ацп скрэмблирование.
з.ы.
Смотрите, что в итоге получается.
Принял за основу следующие данные:
N'=16, N=14, L=4, M=1, F=1, CS=0, K=32.
Вопросы:
1) Я так и не нашёл где в Xilinx Core JESD PHY и JESD настраиваются N', N, M, CS? Регистрами они на АЦП настраиваются, а вот их ПЛИСная "вторая половина" отсутствует.
2) Последовательность у меня получается следующая (выложу по регистрово сегодня)
сброс, powerdown link JESD, настройка (N'=16, N=14, L=4, M=1, F=1, CS=0, K=32.),  powerup link JESD.
Всё правильно?
3) Критерием того, что как минимум есть коннект, есть сигнал SYNC_N. Я правильно понимаю, что это выходной сигнал из порта rx_sync компонента JESD? На данный момент я его отправляю на OBUFDS, после чего, на АЦП? Так?
1 час назад, Art55555 сказал:
я с xilinx -ким ждездом не работал , но что точно это то что SYNC_N - это выходной сигнал у приёмника по jesd204 .
В процессе коннекта SYNC_N - сначала в нуле , а потом при синхронизации встаёт в единицу.
Выкладываю команды.
I have AD9697, Kintex 7 and AD9528 for clocking. AD9528 works with SI570 (100 MHz base).
AD9528 gives me 2 clocks 1200 MHz (OUT0 and OUT 13) for ADC and FPGA.
Alsow AD9528 gives m2  2 clocks 120 MHz (OUT2 and OUT 3) for ADC and FPGA for SYS_REF. Additional clk 120 MHz foe FPGA OUT1. This seems well -counters OK.
All screenshots here (AD9528 parameters):
https://yadi.sk/d/yStQBZxBSRFnRQ
Next stage I setup AD9697:
I want to setup theese parameters JESD:
What I do:
1) PWDN hard reset  '1'
2) PWDN hard reset  '0'.
3) Power down  via SPI ( 0002 03) (address and command)
4) Power up  via SPI ( 0002 00) (address and command)
5) Soft reset  0000 81
6) JESD lind down 0571 01
7) NEXT
1228 4F
1228 0F
1222 00
1222 04
1222 00
1262 08
1262 00
8) Setup Link Parameters:
058B 03
058C 00
058D 1F
058E 10
058F 0D
0590 0F
9) JESD lind up 0571 00.
SYNC low((
Скрины
Edited by Art55555
Получилось поставить линк, но теперь что-то данные плохие идут.
AD9528 gives me  clocks:
1000 Mhz - for AD9697
250 Mhz - Ref CLK (for  Kintex)
31.25 Mhz - SysRef  (for AD9697 and Kintex).
I setup AD9697:
What I do:
0571 15
058B 03
058C 00
058D 1F
058E 10
058F 0D
0590 0F
0571 14
SYNC OK (always '1'))
Next:
0551 01, 0552 02, 0553 03, 0554 04, 0555 05, 0556 06, 0557 07, 0558 08  - Test pattrern refisters/
Tests:
1) 0574 01 - Result: b5b5b5b5----b5 (127 bit)
2) 0574 04, 0574 054, 0574 06 - Link down.
3) 0573 0E Result: 0705030108060402 0705030108060402
4) 0573 01 Result: aa55aa55aa55aa55aa55aa55aa55aa55
5) 0573 02  Result: ff00ff00ff00ff00ff00ff00ff00ff00ff00ff00ff00
6)0573 11  Result: b54ab54ab54ab54ab54ab54ab54ab54a
7) 057321 Result: aa55aa55aa55aa55aa55aa55aa55aa55
If  0571 14 - data wrong. Ramp test - fail/
