Алексей ВМ
STM32F4 как уменьшить время входа в обработчик прерывания
8 часов назад, SSerge сказал:
Ждать будет ровно один такт, нагло вклиниваясь между циклами процессора.
Это где такое написано? Можете указать источник?
Обычно у DMA приоритет доступа к шине ниже чем у CPU.
В пределе DMA способно отбирать у процессора каждый второй цикл шины.
Опять-же - источник?
Здесь так пишут https://www.st.com/content/ccc/resource/technical/document/application_note/47/41/32/e8/6f/42/43/bd/CD00160362.pdf/files/CD00160362.pdf/jcr:content/translations/en.CD00160362.pdf
When the CPU initiates a data transfer meanwhile the DMA is transferring a block of data from a source to a destination, the round-robin AHB bus matrix halts the DMA bus access and inserts the CPU access, causing the DMA transfer to have a longer latency.
3 часа назад, mcheb сказал:
А какое отношение сей документ имеет к теме топика? В топике указано: STM32F4.
А для STM32F4 есть соответствующий документ: https://www.st.com/content/ccc/resource/technical/document/application_note/27/46/7c/ea/2d/91/40/a9/DM00046011.pdf/files/DM00046011.pdf/jcr:content/translations/en.DM00046011.pdf
в котором в п.2.1.3 явно указано:
If bus access is first granted to the CPU and the CPU is not performing a single data
load/store, the DMA wait time to gain access to SRAM can expand from one AHB cycle for
a single data load/store to N AHB cycles, where N is the number of data words in the CPU
transaction.
The CPU locks the AHB bus to keep ownership and reduces latency during multiple
load/store operations and interrupts entry. This enhances firmware responsiveness but it
can result in delays on the DMA transaction.
Delay on DMA1 SRAM access when in concurrency with CPU depends on the type of
transfer:
• CPU transfer issued by interrupt (context save): 8 AHB cycles
• CPU transfer issued by cache controller (256-bit cache line fill/eviction): 8 AHB
cycles(a)
• CPU transfer issued by LDM/STM instructions: 14 AHB cycles(b)
– Transfers of up to 14 registers from/to memory
Итого: LDM/STM команды могут достигать длительности 14 тактов + пару тактов на арбитраж - вот такая будет задержка для DMA.
А сколько тактов задержки потребуется при команде VSTMDB Rx!, {S0-S31} о которой я писал раньше - сами догадайтесь  :wink:
Хотя уже даже просто пересылка контекста при входе/выходе в ISR вылетит за пределы 50нс...
19 часов назад, SSerge сказал:
Как видно - это не так.
18 часов назад, Forger сказал:
За свое счет разумеется, облажался то ведь не заказчик!
Алексей ВМ вроде писал ранее, что это - дополнительные хотелки заказчика в уже готовый девайс. Так что исполнитель тут не облажался. Ему просто не нужно было соглашаться на эти новые требования. А потребовать у заказчика компенсации средств на полное перепроектирование устройства на новой элементной базе.
2 часа назад, jcxz сказал:
Спасибо. Не ожидал такого, и в реф мануале ни слова.
Самое интересное, что раньше у меня тоже была задача с пересылками по DMA, но не с такими жесткими требованиями по времени. Видимо просто повезло что команд LDM/STM не было, а то бы заметил.
Реализовал выдачу данных по событию capture/compare event.  Прерывание ТС записи DMA по update event  возникает только один раз, прерывание ТС записи DMA по capture/compare event генерируются нормально.
Регистры CCR1 = 0, ARR и RCR содержат правильные значения. Как я понимаю update event возникает только один раз. В чем может быть причина?
Edited by Алексей ВМ
6 часов назад, SSerge сказал:
Это странно. Особенно если учесть что PUSH/POP - это как раз и есть частный случай STM/LDM. Да и при каждом прерывании - 8 слов контекста - как с куста.
Может просто везло и такие процедуры с большим кол-вом (регистров в POSH/POP) не попадали никогда на работу DMA? Если эти процессы циклические и зависимые друг от друга - такое возможно. Ну или в компиляторе стояла опция, ограничивающая количество регистров в PUSH/POP? Или стеки находились в другом регионе ОЗУ, не пересекающемся с DMA?
В 30.08.2019 в 20:22, Алексей ВМ сказал:
Не понял. А сколько должно быть?
Если в RCR загружено N-1, то update event возникает один раз на каждые N*(ARR+1) тиков таймера.
Может быть оно так и должно быть?
Ещё один момент: количество пересылок по DMA, которые будут сделаны на каждый update event.
Это устанавливается в поле DBL регистра TIMx->DCR.
Вообще один раз, больше не возникает, запись в регистры ARR и RCR (через DMAR) перед этим прерыванием производится правильно. СС1 шлепают нормально, данные выводятся, UIF выставляется, но записи в регистры ARR и RCR не производится, прерывания от выполнения этой записи не возникает.
1 час назад, Алексей ВМ сказал:
У меня так было когда в обработчике прерывания от DMA забывал сбросить запрос в регистрах DMA->LIFCR или DMA->HIFCR.
TCIF сбрасываю. Если не сбрасывать, будет заходить в обработчик снова и снова по первой записи. Другие флаги не выставляются, то есть ошибок записи тоже нет.
