AncientFox
Step-down DC-DC-преобразователь и выходной фильтр
Здравствуйте.
Микроконтроллеру требуется три питающих напряжения: 3.3 В, 1.8 В и 1.2 В.
В даташите микроконтроллера описаны требования к разводке питания:
Спойлер
Some precautions need to be taken when using these powers:
- The VDD33 pins must be connected to 3.0V~3.6V voltage supply with
external decoupling capacitors (a 0.1uf capacitor and a 10uf capacitor for
each VDD pin).
- The VDD12 pins must be supplied by 1.2V±5% with the decoupling
capacitors (a 0.1uf and a 10uf for each one of the VDD12 pin.
- The MVDD pins must by supplied by 1.8V±5% with the decoupling
capacitors (a 2.2uf and a 4.7uf for each one of the MVDD).
- The AVDD pin must be connected to 3.0V~3.6V voltage supply with external
decoupling capacitors (a 0.1uf capacitor and a 10uf capacitor for each AVDD
pin).
- The RTCVDD is a RTC power pin which should be provide a 3.3V±10% with
a decoupling capacitor 0.1uf.
- The PLLVDD is a phase lock loop power pin which should be supplied by a
3.3V±10%, and connected with a 10uf and 0.1uf for decoupling.
- The USB0VDD pin should be supplied by a 3.3V with a decoupling capacitor,
10uF for USB0 port.
- The USBPLL0 VDD pin should be supplied a 1.2V with a decoupling
capacitor, 10uf and 0.1uf for USBPLL0.
- The USB1VDD pin should be provided by a 3.3V with a decoupling capacitor,
10uF for USB1 port.
Использую Step-down DC-DC-преобразователи серии TPS6223x.
В даташите преобразователей описаны требования к выходному фильтру:
Спойлер
9.2.2.1 Output Filter Design (Inductor and Output Capacitor)
The TPS6223x is optimized to operate with effective inductance values in the range of 0.7 μH to 4.3 μH and with
effective output capacitance in the range of 2.0 μF to 15 μF. The internal compensation is optimized to operate
with an output filter of L = 1.0 μH/2.2 μH and COUT = 4.7 μF. Larger or smaller inductor/capacitor values can be
used to optimize the performance of the device for specific operation conditions.
Вопрос:
Как совместить требования к конденсатору фильтра преобразователя напряжения (2 uF - 15 uF) и к фильтрации каждой ноги питания микроконтроллера?
Например, питание 1.2 В - семь ног, на каждую ногу нужен конденсатор 10 uF, в итоге набирается 70 uF.
Где я заблудился?..
Edited by AncientFox
Попутали суммарную с распределенной. У того же Ti на сайте калькулятор.
Только что, MegaVolt сказал:
Так а в чём проблема. Никто же не запрещает использовать большую ёмкость.
запрещают
8 минут назад, Aner сказал:
запрещают
Вот же ясно написано:
Мол хотите ставьте если у вас такие условия.
1 минуту назад, MegaVolt сказал:
С таким ответом, ... если и был у вас диплом инженера по электронике то вы его потеряли. Там все четко и строго считается, ... по нагрузочной способности по временам нарастания и тд.
42 минуты назад, Aner сказал:
Пойду обрадую работодателя что меня лишили диплома :hi:
"С таким ответом, ... если и был у вас диплом инженера по электронике то вы его потеряли. Там все четко и строго считается, ... по нагрузочной способности по временам нарастания и тд."
Зачем так грубо?
У вас в даташите говорят про фильтр выходной с учетом ФЧХ усилителя ошибки. Отвяжите эту точку от остальной схемы LC цепью и ставьте после любую нужную емкость.
31 минуту назад, MegaVolt сказал:
Нет, вас никто не лишал. ... просто потеряли. Может таки найдете. На моей практике людей увольняли за такие гуманитарные ответы.
7 минут назад, Aner сказал:
За дословное цитирование даташита? На форуме? Серьёзно?
31 минуту назад, iliusmaster сказал:
Зачем так грубо?
Так какую ставить? 1) Любую 2) Нужную, ... а может посчитаете хотя бы в веббенче на сайте у TI, там же все ест ьи бесплатно.
3 минуты назад, MegaVolt сказал:
не за то, за это:
1) Никто же не запрещает использовать большую ёмкость.
2) Мол хотите ставьте если у вас такие условия.
У вот если вы опытный в таких проектах, то что думать TCу?
Ваш совет таки ставить эти - набирается 70 uF?
13 минут назад, Aner сказал:
за это:
1) Никто же не запрещает использовать большую ёмкость.2) Мол хотите ставьте если у вас такие условия.
Ещё раз: это не мои слова. Это перевод кусочков текста из даташита которые предоставил ТС. Т.е. это не ответ. Это уточниение проблемы с которой столкнулся ТС. Т.е. производитель говорит что оптимально вот эта ёмкость но можно и больше. И почему в этом месте остановился ТС есть пока загадка. Может дорого, может места нет, может не хочет терять оптимум. Может ещё что-то. Я не читаю мысли.
Советы будут после внятно понимания проблемы. Сейчас её не очень видно. Не вдаваясь в детальное проектирование. И советы очень разные. От ставить 70 с двукратным запасом с учётом реальной ёмкости при заданном напряжении и температуре. Или ставить оптимальные ибо и так работать будет. Я думаю что смогу обосновать  и тот и другой путь. Допридумав недостающие условия.
В паспорте на тему расчёта конденсатора ничего нет, ограничений графиками или словами тоже, поэтому для практических случаев такой детали нет.
Плохо, особенно для малых и точных напряжений. Индуктивность будет иметь сопротивление, и напряжение после неё будет болтаться в зависимости от тока потребления.
В реальности конденсатор на 4,7мкФ на приборе покажет в лучшем случае 2,2мкФ
Ставьте 7 штук 4,7мкФ X5R и не берите в голову... ибо понижающие довольно устойчивы.
А у TI что - нет симулятора на свои микросхемы?
2 часа назад, AncientFox сказал:
Вопрос:
Назовите микроконтроллер. Российский? Есть ли отладочные платы со схемами?
Из того что встречал,  ставят на каждую ногу по 0,1uF и один общий танталовый 10uF, а питание PLL, USB могут иметь свои 10uF, но от общего 3.3В их отвязывают индуктивностями.
