Alex_Golubev 0 25 мая, 2019 Опубликовано 25 мая, 2019 · Жалоба LCD у нас 16 бит RGB666 ссылка плюс тачь. Залез в /home/alexey/work/linux/arch/arm/boot/dts/imx28-evk.dts (ни чего не трогал) Spoiler // SPDX-License-Identifier: GPL-2.0+ // // Copyright 2012 Freescale Semiconductor, Inc. /dts-v1/; #include "imx28.dtsi" / { model = "Freescale i.MX28 Evaluation Kit"; compatible = "fsl,imx28-evk", "fsl,imx28"; memory@40000000 { reg = <0x40000000 0x08000000>; }; reg_3p3v: regulator-3p3v { compatible = "regulator-fixed"; regulator-name = "3P3V"; regulator-min-microvolt = <3300000>; regulator-max-microvolt = <3300000>; regulator-always-on; }; reg_vddio_sd0: regulator-vddio-sd0 { compatible = "regulator-fixed"; regulator-name = "vddio-sd0"; regulator-min-microvolt = <3300000>; regulator-max-microvolt = <3300000>; gpio = <&gpio3 28 0>; }; reg_fec_3v3: regulator-fec-3v3 { compatible = "regulator-fixed"; regulator-name = "fec-3v3"; regulator-min-microvolt = <3300000>; regulator-max-microvolt = <3300000>; gpio = <&gpio2 15 0>; }; reg_usb0_vbus: regulator-usb0-vbus { compatible = "regulator-fixed"; regulator-name = "usb0_vbus"; regulator-min-microvolt = <5000000>; regulator-max-microvolt = <5000000>; gpio = <&gpio3 9 0>; enable-active-high; }; reg_usb1_vbus: regulator-usb1-vbus { compatible = "regulator-fixed"; regulator-name = "usb1_vbus"; regulator-min-microvolt = <5000000>; regulator-max-microvolt = <5000000>; gpio = <&gpio3 8 0>; enable-active-high; }; reg_lcd_3v3: regulator-lcd-3v3 { compatible = "regulator-fixed"; regulator-name = "lcd-3v3"; regulator-min-microvolt = <3300000>; regulator-max-microvolt = <3300000>; gpio = <&gpio3 30 0>; enable-active-high; }; reg_can_3v3: regulator-can-3v3 { compatible = "regulator-fixed"; regulator-name = "can-3v3"; regulator-min-microvolt = <3300000>; regulator-max-microvolt = <3300000>; gpio = <&gpio2 13 0>; enable-active-high; }; reg_lcd_5v: regulator-lcd-5v { compatible = "regulator-fixed"; regulator-name = "lcd-5v"; regulator-min-microvolt = <5000000>; regulator-max-microvolt = <5000000>; }; panel { compatible = "sii,43wvf1g"; backlight = <&backlight_display>; dvdd-supply = <®_lcd_3v3>; avdd-supply = <®_lcd_5v>; port { panel_in: endpoint { remote-endpoint = <&display_out>; }; }; }; apb@80000000 { apbh@80000000 { gpmi-nand@8000c000 { pinctrl-names = "default"; pinctrl-0 = <&gpmi_pins_a &gpmi_status_cfg &gpmi_pins_evk>; status = "okay"; }; ssp0: ssp@80010000 { compatible = "fsl,imx28-mmc"; pinctrl-names = "default"; pinctrl-0 = <&mmc0_8bit_pins_a &mmc0_cd_cfg &mmc0_sck_cfg>; bus-width = <8>; //wp-gpios = <&gpio2 12 0>; vmmc-supply = <®_vddio_sd0>; status = "okay"; }; ssp1: ssp@80012000 { compatible = "fsl,imx28-mmc"; bus-width = <8>; wp-gpios = <&gpio0 28 0>; }; ssp2: ssp@80014000 { #address-cells = <1>; #size-cells = <0>; compatible = "fsl,imx28-spi"; pinctrl-names = "default"; pinctrl-0 = <&spi2_pins_a>; status = "okay"; flash: m25p80@0 { #address-cells = <1>; #size-cells = <1>; compatible = "sst,sst25vf016b", "jedec,spi-nor"; spi-max-frequency = <40000000>; reg = <0>; }; }; pinctrl@80018000 { pinctrl-names = "default"; pinctrl-0 = <&hog_pins_a>; hog_pins_a: hog@0 { reg = <0>; fsl,pinmux-ids = < MX28_PAD_SSP1_CMD__GPIO_2_13 MX28_PAD_SSP1_DATA3__GPIO_2_15 MX28_PAD_ENET0_RX_CLK__GPIO_4_13 MX28_PAD_SSP1_SCK__GPIO_2_12 MX28_PAD_PWM3__GPIO_3_28 MX28_PAD_LCD_RESET__GPIO_3_30 MX28_PAD_AUART2_RX__GPIO_3_8 MX28_PAD_AUART2_TX__GPIO_3_9 >; fsl,drive-strength = <MXS_DRIVE_4mA>; fsl,voltage = <MXS_VOLTAGE_HIGH>; fsl,pull-up = <MXS_PULL_DISABLE>; }; led_pin_gpio3_5: led_gpio3_5@0 { reg = <0>; fsl,pinmux-ids = < MX28_PAD_AUART1_TX__GPIO_3_5 >; fsl,drive-strength = <MXS_DRIVE_4mA>; fsl,voltage = <MXS_VOLTAGE_HIGH>; fsl,pull-up = <MXS_PULL_DISABLE>; }; gpmi_pins_evk: gpmi-nand-evk@0 { reg = <0>; fsl,pinmux-ids = < MX28_PAD_GPMI_CE1N__GPMI_CE1N MX28_PAD_GPMI_RDY1__GPMI_READY1 >; fsl,drive-strength = <MXS_DRIVE_4mA>; fsl,voltage = <MXS_VOLTAGE_HIGH>; fsl,pull-up = <MXS_PULL_DISABLE>; }; lcdif_pins_evk: lcdif-evk@0 { reg = <0>; fsl,pinmux-ids = < MX28_PAD_LCD_RD_E__LCD_VSYNC MX28_PAD_LCD_WR_RWN__LCD_HSYNC MX28_PAD_LCD_RS__LCD_DOTCLK MX28_PAD_LCD_CS__LCD_ENABLE >; fsl,drive-strength = <MXS_DRIVE_4mA>; fsl,voltage = <MXS_VOLTAGE_HIGH>; fsl,pull-up = <MXS_PULL_DISABLE>; }; }; lcdif@80030000 { pinctrl-names = "default"; pinctrl-0 = <&lcdif_24bit_pins_a &lcdif_pins_evk>; status = "okay"; port { display_out: endpoint { remote-endpoint = <&panel_in>; }; }; }; can0: can@80032000 { pinctrl-names = "default"; pinctrl-0 = <&can0_pins_a>; xceiver-supply = <®_can_3v3>; status = "okay"; }; can1: can@80034000 { pinctrl-names = "default"; pinctrl-0 = <&can1_pins_a>; xceiver-supply = <®_can_3v3>; status = "okay"; }; }; apbx@80040000 { saif0: saif@80042000 { pinctrl-names = "default"; pinctrl-0 = <&saif0_pins_a>; status = "okay"; }; saif1: saif@80046000 { pinctrl-names = "default"; pinctrl-0 = <&saif1_pins_a>; fsl,saif-master = <&saif0>; status = "okay"; }; lradc@80050000 { status = "okay"; fsl,lradc-touchscreen-wires = <4>; fsl,ave-ctrl = <4>; fsl,ave-delay = <2>; fsl,settling = <10>; }; i2c0: i2c@80058000 { pinctrl-names = "default"; pinctrl-0 = <&i2c0_pins_a>; status = "okay"; sgtl5000: codec@a { compatible = "fsl,sgtl5000"; reg = <0x0a>; #sound-dai-cells = <0>; VDDA-supply = <®_3p3v>; VDDIO-supply = <®_3p3v>; clocks = <&saif0>; }; at24@51 { compatible = "atmel,24c32"; pagesize = <32>; reg = <0x51>; }; }; pwm: pwm@80064000 { pinctrl-names = "default"; pinctrl-0 = <&pwm2_pins_a>; status = "okay"; }; duart: serial@80074000 { pinctrl-names = "default"; pinctrl-0 = <&duart_pins_a>; status = "okay"; }; auart0: serial@8006a000 { pinctrl-names = "default"; pinctrl-0 = <&auart0_pins_a>; uart-has-rtscts; status = "okay"; }; auart3: serial@80070000 { pinctrl-names = "default"; pinctrl-0 = <&auart3_pins_a>; status = "okay"; }; usbphy0: usbphy@8007c000 { status = "okay"; }; usbphy1: usbphy@8007e000 { status = "okay"; }; }; }; ahb@80080000 { usb0: usb@80080000 { pinctrl-names = "default"; pinctrl-0 = <&usb0_id_pins_a>; vbus-supply = <®_usb0_vbus>; status = "okay"; }; usb1: usb@80090000 { vbus-supply = <®_usb1_vbus>; status = "okay"; }; mac0: ethernet@800f0000 { phy-mode = "rmii"; pinctrl-names = "default"; pinctrl-0 = <&mac0_pins_a>; phy-supply = <®_fec_3v3>; phy-reset-gpios = <&gpio4 13 GPIO_ACTIVE_LOW>; phy-reset-duration = <100>; status = "okay"; }; mac1: ethernet@800f4000 { phy-mode = "rmii"; pinctrl-names = "default"; pinctrl-0 = <&mac1_pins_a>; status = "okay"; }; }; sound { compatible = "fsl,imx28-evk-sgtl5000", "fsl,mxs-audio-sgtl5000"; model = "imx28-evk-sgtl5000"; saif-controllers = <&saif0 &saif1>; audio-codec = <&sgtl5000>; }; leds { compatible = "gpio-leds"; pinctrl-names = "default"; pinctrl-0 = <&led_pin_gpio3_5>; user { label = "Heartbeat"; gpios = <&gpio3 5 0>; linux,default-trigger = "heartbeat"; }; }; backlight_display: backlight { compatible = "pwm-backlight"; pwms = <&pwm 2 5000000>; brightness-levels = <0 4 8 16 32 64 128 255>; default-brightness-level = <6>; }; }; и не увидал RGB666 16 бит. И не понял где находятся драйвер для lcd. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
aaarrr 62 25 мая, 2019 Опубликовано 25 мая, 2019 · Жалоба Драйвер lcd находится в linux/drivers/gpu/drm/mxsfb. Но пока советую обратить внимание на этот раздел: panel { compatible = "sii,43wvf1g"; В linux/drivers/gpu/drm/panel/panel-simple.c находятся описания LCD-панелей. Найдите совместимую, и замените значение compatible в dts. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Alex_Golubev 0 25 мая, 2019 Опубликовано 25 мая, 2019 (изменено) · Жалоба После собрать командой .../buildroot$ make linux-rebuild ? А как быть с тачскрином ? Изменено 25 мая, 2019 пользователем Alex_Golubev Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
aaarrr 62 25 мая, 2019 Опубликовано 25 мая, 2019 · Жалоба 19 minutes ago, Alex_Golubev said: После собрать командой .../buildroot$ make linux-rebuild ? А как быть с тачскрином ? Да, и убедитесь, что imx28-evk.dtb обновился. Для тачскрина добавьте в конце dts: &lradc { fsl,lradc-touchscreen-wires = <4>; status = "okay"; }; Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Alex_Golubev 0 25 мая, 2019 Опубликовано 25 мая, 2019 · Жалоба Quote Да, и убедитесь, что imx28-evk.dtb обновился. Это как просто изменить, сохранить, после открыть и проверить? Вот нашел близкий дисплей et057090dhu но у него распиновка не та. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
aaarrr 62 25 мая, 2019 Опубликовано 25 мая, 2019 · Жалоба 2 minutes ago, Alex_Golubev said: Это как просто изменить, сохранить, после открыть и проверить? Просто дату/время по ls -l посмотреть, или упоминание во время сборки. 2 minutes ago, Alex_Golubev said: Вот нашел близкий дисплей et057090dhu но у него распиновка не та. Совпадать должно только разрешение, тайминги и полярности. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Alex_Golubev 0 25 мая, 2019 Опубликовано 25 мая, 2019 · Жалоба Я вот недавно столкнулся с проблемой, просто интересно почему так. Клонировал ядро линукса Spoiler git clone git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git --branch=v4.19 --depth=1 после выполняю команду Spoiler make ARCH=arm mxs_defconfig И получаю ошибку: Spoiler alexey@alexey:~/work/linux$ make ARCH=arm mxs_defconfig Makefile:595: include/config/auto.conf: Нет такого файла или каталога scripts/kconfig/conf --syncconfig Kconfig *** *** Configuration file ".config" not found! *** *** Please run some configurator (e.g. "make oldconfig" or *** "make menuconfig" or "make xconfig"). *** scripts/kconfig/Makefile:69: ошибка выполнения рецепта для цели «syncconfig» make[2]: *** [syncconfig] Ошибка 1 Makefile:539: ошибка выполнения рецепта для цели «syncconfig» make[1]: *** [syncconfig] Ошибка 2 Makefile:635: ошибка выполнения рецепта для цели «include/config/auto.conf» make: *** [include/config/auto.conf] Ошибка 2 Говорит нету .config Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
aaarrr 62 25 мая, 2019 Опубликовано 25 мая, 2019 · Жалоба Судя по выхлопу, make defconfig был запущен не сразу после клонирования, что-то уже делалось до этого. Попробуйте make clean, а затем уже defconfig. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
gosha-z 2 25 мая, 2019 Опубликовано 25 мая, 2019 · Жалоба 4 hours ago, Alex_Golubev said: Клонировал ядро линукса А что помешало просто скачать tarball? Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Alex_Golubev 0 26 мая, 2019 Опубликовано 26 мая, 2019 · Жалоба Quote скачать tarball Скачивал получал туже ошибку. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
gosha-z 2 26 мая, 2019 Опубликовано 26 мая, 2019 · Жалоба А зачем make defconfig? make ARCH=armmxs_defconfig make ARCH=arm CROSS_COMPILE=path menuconfig (если надо) make ARCH=arm CROSS_COMPILE=path Собственно, результатом этого является bootable Image Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Alex_Golubev 0 26 мая, 2019 Опубликовано 26 мая, 2019 · Жалоба Quote Target packages--->Graphic libraries and applications (graphic/text)--->Qt (obsolete)--->[нужное в нем] А что значит [нужное в нем] ? Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
aaarrr 62 26 мая, 2019 Опубликовано 26 мая, 2019 · Жалоба 1 minute ago, Alex_Golubev said: А что значит [нужное в нем] ? Точно нужен GUI module, ввод с tslib (как и сам tslib, его искать в Librares->Hardware), а вот нужна ли поддержка TIFF, SVG и т.п. - решайте сами. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
Alex_Golubev 0 26 мая, 2019 Опубликовано 26 мая, 2019 · Жалоба Не нашел Qt (obsolete). Spoiler *** Graphic applications *** │ │ │ │ *** cog needs wpewebkit and a toolchain w/ threads *** │ │ │ │ [ ] fswebcam │ │ │ │ [ ] ghostscript │ │ │ │ *** glmark2 needs a toolchain w/ C++, gcc >= 4.9 *** │ │ │ │ [ ] gnuplot │ │ │ │ [ ] jhead │ │ │ │ *** libva-utils needs a toolchain w/ C++, threads, dynamic library *** │ │ │ │ [ ] netsurf │ │ │ │ [ ] pngquant │ │ │ │ [ ] rrdtool │ │ │ │ *** tesseract-ocr needs a toolchain w/ threads, C++, gcc >= 4.8, dynami│ │ │ │ *** Graphic libraries *** │ │ │ │ *** cegui06 needs a toolchain w/ C++, threads, dynamic library *** │ │ │ │ *** directfb needs a glibc or uClibc toolchain w/ C++, NPTL, gcc >= 4.5│ │ │ │ *** efl needs a toolchain w/ C++, dynamic library, gcc >= 4.7, threads,│ │ │ │ [ ] fbdump (Framebuffer Capture Tool) │ │ │ │ [ ] fbgrab │ │ │ │ [ ] fb-test-app │ │ │ │ *** fbterm needs a toolchain w/ C++, wchar, locale *** │ │ │ │ [ ] fbv │ │ │ │ *** freerdp needs a toolchain w/ wchar, dynamic library, threads, C++ *│ │ │ │ [ ] imagemagick │ │ │ │ [ ] linux-fusion communication layer for DirectFB multi │ │ │ │ *** mesa3d needs a toolchain w/ C++, NPTL, dynamic library *** │ │ │ │ *** ocrad needs a toolchain w/ C++ *** │ │ │ │ [ ] psplash [ ] SDL │ │ │ │ [ ] sdl2 │ │ │ │ *** Other GUIs *** │ │ │ │ *** Qt5 needs a toolchain w/ wchar, NPTL, C++, dynamic library *** │ │ │ │ *** tekui needs a Lua interpreter and a toolchain w/ threads, dynamic l│ │ │ │ *** weston needs udev and a toolchain w/ locale, threads, dynamic libra│ │ │ │ [ ] X.org X Window System ---- │ │ │ │ *** midori needs libgtk3 and a glibc toolchain w/ C++, gcc >= 6, host g│ │ │ │ *** vte needs a toolchain w/ wchar, threads, C++, gcc >= 4.8 *** │ │ │ │ *** vte needs an OpenGL or an OpenGL-EGL/wayland backend *** │ │ │ │ [ ] xkeyboard-config Сделал простую программу в qt. Хочу вывести ее на экран. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
aaarrr 62 26 мая, 2019 Опубликовано 26 мая, 2019 · Жалоба 17 minutes ago, Alex_Golubev said: Не нашел Qt (obsolete) Похоже, уже выпилили Qt4 из buildroot'а. Придется взять версию постарше, в 2018.11 точно есть. Цитата Поделиться сообщением Ссылка на сообщение Поделиться на другие сайты Поделиться
