IMPАСТ halflife
Подскажите пожалуйста, куда к0пать:
Если Impаст запускается из ISE navigator, то USB программатор опредляется и нормально работает:
CPROGRESS_START - Starting Operation.
Connecting to cable (Usb Port - USB21).
Checking cable driver.
Driver file xusb_xlp.sys found.
Driver version: src=1029, dest=1029.
Driver windrvr6.sys version = 10.2.1.0. WinDriver v10.21 Jungo (c) 1997 - 2010 Build Date: Aug 31 2010 x86_64 64bit SYS 14:14:44, version = 1021.
Cable PID = 0008.
Max current requested during enumeration is 74 mA.
Type = 0x0004.
Cable Type = 3, Revision = 0.
Setting cable speed to 6 MHz.
Cable connection established.
Firmware version = 1303.
File version of C:/Xilinx/14.7/ISE_DS/ISE/data/xusb_xlp.hex = 1303.
Firmware hex file version = 1303.
PLD file version = 0012h.
PLD version = 0012h.
PROGRESS_END - End Operation.
Но если из "Plan Аheаd"-, то не опредляется , и пишет
Source driver files not found.
The Platform Cable USB is not detected. Please connect a cable.If a cable is connected, please disconnect
and reconnect to the usb port, follow the instructions in the 'Found New Hardware Wizard', then retry
the Cable Setup operation.
Cable connection failed.
Connecting to cable (Parallel Port - LPT1).
Your driver installation is not complete. Please re-run your application or run
install_drivers.exe from the ISE installation area as an Administrator to complete the driver installation.
Service using windrvr6.sys : SYSTEM\CurrentControlSet\Services\windrvr6.
ImagePath = \SystemRoot\System32\drivers\WINDRVR6.SYS.
DisplayName = windrvr6.
Start = 2.
ErrorControl = 1.
Type=1.
Service using windrvr6.sys : SYSTEM\CurrentControlSet\Services\WinDriver6.
ImagePath = \SystemRoot\system32\drivers\windrvr6.sys.
Start = 3.
ErrorControl = 1.
Type=1.
Connecting to cable (Parallel Port - LPT2).
Start = 2.
ErrorControl = 1.
Type=1.
Start = 3.
ErrorControl = 1.
Type=1.
Connecting to cable (Parallel Port - LPT3).
Start = 2.
ErrorControl = 1.
Type=1.
Start = 3.
ErrorControl = 1.
Type=1.
Connecting to cable (Parallel Port - LPT4).
Start = 2.
ErrorControl = 1.
Type=1.
Start = 3.
ErrorControl = 1.
Type=1.
PROGRESS_END
установка не помогает:
wdreg.exe -inf C:\Xilinx\14.7\ISE_DS\ISE\bin\nt64\xusbdrvr.inf install
WDREG utility v10.21. Build Aug 31 2010 14:21:54
Processing HWID USB\VID_03FD&PID_0008
Installing a signed driver package for USB\VID_03FD&PID_0008
Device node (hwid:USB\VID_03FD&PID_0008): exists and is configured. Installing.
CM_Get_DevNode_Status ret value 0, status 180600a, problem 0
LOG ok: 1, ENTER:  DriverPackageInstallA
LOG ok: 1, ENTER:  DriverPackageInstallW
LOG ok: 1, Looking for Model Section [DeviceList.ntamd64]...
LOG ok: 1, Installing INF file 'C:\Xilinx\14.7\ISE_DS\ISE\bin\nt64\xusbdrvr.inf' (Plug and Play).
LOG ok: 1, Installing devices with Id "USB\VID_03FD&PID_0008&REV_0000" using INF "C:\WINDOWS\System32\DriverStore\FileRepository\xusbdrvr.inf_amd64_1af2fe242bfdedb1\xusbdrvr.inf".
LOG ok: 1, Will force install because driver is not better and force flag is set.
LOG ok: 1, ENTER UpdateDriverForPlugAndPlayDevices...
LOG ok: 0, RETURN UpdateDriverForPlugAndPlayDevices.
LOG ok: 1, Installation was successful.
LOG ok: 1, Installing devices with Id "USB\VID_03FD&PID_000F&REV_0000" using INF "C:\WINDOWS\System32\DriverStore\FileRepository\xusbdrvr.inf_amd64_1af2fe242bfdedb1\xusbdrvr.inf".
LOG ok: 1, Installation did not occur because the hardware isn't currently present.
LOG ok: 1, Phantom Device with Hardware/Compatible Id 'USB\VID_03FD&PID_000F&REV_0000' already has 'C:\WINDOWS\System32\DriverStore\FileRepository\xusbdrvr.inf_amd64_1af2fe242bfdedb1\xusbdrvr.inf' installed on it.
LOG ok: 0, Install completed
LOG ok: 1, RETURN: DriverPackageInstallW  (0x0)
LOG ok: 1, RETURN: DriverPackageInstallA  (0x0)
difx_install_preinstall_inf: err 0, last event 0, last error 0. SUCCESS
install: completed successfully
Авторизация
