моделирование памяти в active-hdl
Всем здравствуйте !
Подскажите что не так. Моделирую память в Actve-HDL на VHDL.
На waveform после записи показывает старое (после инициализации) значение.
В Memory Viem подсвечивает старое значение красным цветом.
Нового записанного байта нигде не видно ?!
Что делаю неправильно ?
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_arith.all;
use ieee.std_logic_unsigned.all;
use ieee.numeric_std.all;
use std.textio.all;
entity RAM_DP is
generic	(
width			:natural := 8;	  -- Width of data[] and q[] ports.
widthad			:natural := 8	  -- Width of the address port.
port	(
clk			: in  std_logic := '0';
wren      	: in  std_logic := '0';
rdaddress 	: in  std_logic_vector(widthad-1 downto 0);
wraddress 	: in  std_logic_vector(widthad-1 downto 0);
data		: in  std_logic_vector(width-1 downto 0);
q			: out std_logic_vector(width-1 downto 0)
end RAM_DP;
architecture TELESH of RAM_DP is
signal rdaddress_reg	: std_logic_vector(widthad-1 downto 0) := (others => '0');
signal wraddress_reg	: std_logic_vector(widthad-1 downto 0) := (others => '0');
signal data_reg			: std_logic_vector(width-1 downto 0) := (others => '0');
signal q_tmp			: std_logic_vector(width-1 downto 0);
signal wren_reg 		: std_logic := '1';
--type memory   is array (((2**widthad) - 1) downto 0) of std_logic_vector(width-1 downto 0);
--signal RAM				: memory;
begin
input_register:	process(clk)
begin
if (rising_edge(clk)) then
	rdaddress_reg	<= rdaddress;
	wraddress_reg	<= wraddress;
	data_reg		<= data;
	wren_reg		<= wren;
end if;
end process input_register;
write_read: process(clk, wren_reg, data_reg, q_tmp)
variable RAM		: memory;
variable i			: integer :=0;
begin
-- initialize RAM
for i in RAM'low to RAM'high loop
RAM(i) := (conv_std_logic_vector(i,width));
--	RAM(i) <= (conv_std_logic_vector(i,width));
--	RAM(i) := (others => '0');
end loop;
if wren_reg = '1' then
	RAM(conv_integer(wraddress_reg)) := data_reg;
--		RAM(conv_integer(wraddress_reg)) <= data_reg;
end if;
end if;
q_tmp <= RAM(conv_integer(rdaddress_reg));
end if;
end process write_read;
q <= q_tmp;
end TELESH;
-- Title       : Test Bench for ram_dp
-- Design      : UROK2
-- Author      : SHUR!K
-- Company     : SI
-- File        : $DSN\src\TestBench\ram_dp_TB.vhd
-- Generated   : 31.10.2017, 14:46
-- By          : Active-HDL Built-in Test Bench Generator ver. 1.2s
-- Description : Automatically generated Test Bench for ram_dp_tb
library ieee;
use std.textio.all;
-- Add your library and packages declaration here ...
entity ram_dp_tb is
-- Generic declarations of the tested unit
	generic(
	width : NATURAL := 8;
	widthad : NATURAL := 8 );
end ram_dp_tb;
architecture TB_ARCHITECTURE of ram_dp_tb is
-- Component declaration of the tested unit
component ram_dp
	generic(
port(
	clk : in std_logic;
	wren : in std_logic;
	rdaddress : in std_logic_vector((widthad-1) downto 0);
	wraddress : in std_logic_vector((widthad-1) downto 0);
	data : in std_logic_vector((width-1) downto 0);
	q : out std_logic_vector((width-1) downto 0) );
end component;
-- Stimulus signals - signals mapped to the input and inout ports of tested entity
signal clk : std_logic;
signal wren : std_logic := '0';
signal rdaddress : std_logic_vector((widthad-1) downto 0) := "00000000";
signal wraddress : std_logic_vector((widthad-1) downto 0) := "00000000";
signal data : std_logic_vector((width-1) downto 0) := "00000000";
-- Observed signals - signals mapped to the output ports of tested entity
signal q : std_logic_vector((width-1) downto 0);
-- Add your code here ...
begin
-- Unit Under Test port map
UUT : ram_dp
	generic map (
		width => width,
		widthad => widthad
	port map (
		clk => clk,
		wren => wren,
		rdaddress => rdaddress,
		wraddress => wraddress,
		data => data,
		q => q
-- Add your stimulus here ...
write:	process
begin
	wait for 500 ns;
	wren <= '1';
	data <= "01101001";
	wraddress <= "00001001";
	wait for 200 ns;
	wren <= '0';
	data <= "00000000";
	wraddress <= "00000000";
	wait for 200 ns;
	wren <= '1';
	data <= "01101010";
	wait for 200 ns;
	wren <= '0';
	data <= "00000000";
	wait for 400 ns;
	wren <= '0';
	rdaddress <= "00001001";
	wait;
end process write ;
clock:	process
begin
	clk <= '1';
	wait for 100 ns;
	clk <= '0';
	wait for 100 ns;
end process clock ;
end TB_ARCHITECTURE;
configuration TESTBENCH_FOR_ram_dp of ram_dp_tb is
for TB_ARCHITECTURE
	for UUT : ram_dp
		use entity work.ram_dp(telesh);
	end for;
end for;
end TESTBENCH_FOR_ram_dp;
RAM_DP.vhd
ram_dp_TB.vhd
Разберитесь со списком чувствительности процесса. Это первое.
    end if;
end if;
Поменяйте местами условия. При таком порядке условий и таком списке чувствительности rising_edge(clk) всегда будет false.
Ну и каждый раз, заходя в процесс, вы очищаете память.
Всем спасибо !
Ошибка была в том что память инициализировалась всё время при входе в процесс !
Авторизация
