sine with cordic vhdl
Привет всем. Просто доделал, решил поделиться) Может молодым спецам пригодится)
Кордик для вычисления синуса 100KHz c четвертью в 250 тактов. (если какие нибудь замечания будут, или советы по оптимизации, был бы рад)
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.NUMERIC_STD.ALL;
use IEEE.STD_LOGIC_SIGNED.ALL;
-- Uncomment the following library declaration if using
-- arithmetic functions with Signed or Unsigned values
--use IEEE.NUMERIC_STD.ALL;
-- Uncomment the following library declaration if instantiating
-- any Xilinx primitives in this code.
--library UNISIM;
--use UNISIM.VComponents.all;
entity Toplvl is
port (
		clk 		: std_logic;
		reset 	: std_logic;
		sinus1 	: out std_logic_vector(16 downto 0));
end Toplvl;
architecture Behavioral of Toplvl is
signal quarter_1 : std_logic_vector (1 downto 0);
signal t 		  : std_logic_vector (16 downto 0);
signal e 		  : std_logic_vector (16 downto 0);
component math
port (
			clk 		: in std_logic;
			reset 	: in std_logic;
			qu			: out std_logic_vector (1 downto 0);
			cosin 	: out std_logic_vector (16 downto 0);
			sinus 	: out std_logic_vector (16 downto 0));
end component;
component right
port (
		clk 		: in std_logic;
		x 			: in std_logic_vector(16 downto 0);
		y 			: in std_logic_vector(16 downto 0);
		quarter  : in std_logic_vector (1 downto 0);
		xo 		: out std_logic_vector(16 downto 0);
		yo 		: out std_logic_vector(16 downto 0));
end component;
begin
--sinus1 <= yx;
math_end : math
port map (
clk => clk,
reset => reset,
qu => quarter_1,
cosin => t,
sinus => e);
right_end : right
port map (
clk => clk,
reset => reset,
x => t,
y => e,
quarter => quarter_1,
yo => sinus1);
end Behavioral;
entity math is
port (
			clk 		: in std_logic;
			sinus 	: out std_logic_vector (16 downto 0);
			cosin 	: out std_logic_vector (16 downto 0));
end math;
architecture Behavioral of math is
type my_type is array (0 to 16) of signed (16 downto 0);
signal x : my_type;
signal y : my_type;
signal z : my_type;
signal j : my_type :=("00111110011110010", "00100100111011010", "00010011011111111", "00001001111011110", "00000100111101111",
														"00000010011111000", "00000001001111011", "00000000100111110", "00000000010011011", "00000000001010000",
															 "00000000000101000", "00000000000010100", "00000000000001010", "00000000000000101", "00000000000000011",
															  "00000000000000010", "00000000000000001");
signal l : std_logic_vector(16 downto 0);
signal f : std_logic_vector(16 downto 0);
component delay
port (
		clk 	: in std_logic;
		quarter_do : out std_logic_vector(1 downto 0));
end component;
component rotation
generic (
			first  : integer := 0;
			second : integer := 1;
			third  : integer := 2;
			fourth : integer := 3);
  Port (
			clk 			: in std_logic;
		Angle 		: out std_logic_vector (12 downto 0);
		quarter_in  : out std_logic_vector (1 downto 0));
end component;
signal xangle  : std_logic_vector(12 downto 0);
signal xxangle : signed(16 downto 0);
begin
rotation_XYN : rotation
port map (
  clk => clk,
Angle => xangle,
reset => reset
delay_XYN : delay
port map (
  clk => clk,
reset => reset,
quarter_do => qu
xxangle(16) <= '0';
xxangle(15 downto 4) <= signed(xangle(11 downto 0));
xxangle(3 downto 0) <= (others => '0');
process(clk)
begin
if rising_edge(clk) then
if reset <= '1' then
	x(0) <= "00000100110110110";
	y(0) <= "00000000000000000";
	z(0) <= signed(xxangle);
		For n in 0 to 15 loop
			if (z(n) < 0) then
				x(n+1) <= x(n) + (y(n)/2**n);
				y(n+1) <= y(n) - (x(n)/2**n);
				z(n+1) <= z(n) + j(n);
			else
				x(n+1) <= x(n) -(y(n)/2**n);
				y(n+1) <= y(n) +(x(n)/2**n);
				z(n+1) <= z(n) - j(n);
			end if;
		f <= std_logic_vector(x(16));
		l <= std_logic_vector(y(16));
	cosin <= f;
	sinus <= l;
	end loop;
end if;
end if;
end process;
end Behavioral;
entity rotation is
generic (
  Port (
			clk 			: in std_logic;
end rotation;
architecture Behavioral of rotation is
signal Ang			 : std_logic_vector (12 downto 0) := (others => '0');
signal state		 : unsigned (1 downto 0) := to_unsigned(first,2);
signal count_ang	 : std_logic_vector (11 downto 0) := (others => '0');
begin
process (clk)
begin
if (rising_edge(clk)) then
	if (reset = '1') then
	case(state) is
		when to_unsigned(first,2) => if (count_ang >= 3999) then		--00
						state <= to_unsigned(second,2);
						count_ang <= "000000010000";
						quarter_in <= "01";
						Ang <= Ang - 16;
					else
						state <= to_unsigned(first,2);
						quarter_in <= "00";
						Ang <= Ang + 16;
						count_ang <= count_ang + 16;
					end if;
		when to_unsigned(second,2) => if (count_ang >= 3999) then		--01
						state <= to_unsigned(third,2);
						quarter_in <= "10";
						Ang <= Ang + 16;
					else
						quarter_in <= "01";
						Ang <= Ang - 16;
						end if;
		when to_unsigned(third,2) => if (count_ang >= 3999) then
						state <= to_unsigned(fourth,2);
						quarter_in <= "11";
						Ang <= Ang - 16;
					else
						quarter_in <= "10";
						Ang <= Ang + 16;
						end if;
		when to_unsigned(fourth,2) => if (count_ang >= 3999) then
						quarter_in <= "00";
						Ang <= Ang + 16;
					else
						quarter_in <= "11";
						Ang <= Ang - 16;
						end if;
		when others => count_ang <= (others => '0');
	end case;
end if;
end if;
end process;
Angle <= Ang;
end Behavioral;
entity delay is
port (
		clk 	: in std_logic;
end delay;
architecture Behavioral of delay is
signal delay_1 : std_logic_vector(1 downto 0);
signal delay_2 : std_logic_vector(1 downto 0);
signal delay_3 : std_logic_vector(1 downto 0);
signal delay_4 : std_logic_vector(1 downto 0);
signal delay_5 : std_logic_vector(1 downto 0);
signal delay_6 : std_logic_vector(1 downto 0);
signal delay_7 : std_logic_vector(1 downto 0);
signal delay_8 : std_logic_vector(1 downto 0);
signal delay_9 : std_logic_vector(1 downto 0);
signal delay_10 : std_logic_vector(1 downto 0);
signal delay_11 : std_logic_vector(1 downto 0);
signal delay_12 : std_logic_vector(1 downto 0);
signal delay_13 : std_logic_vector(1 downto 0);
signal delay_14 : std_logic_vector(1 downto 0);
signal delay_15 : std_logic_vector(1 downto 0);
signal delay_16 : std_logic_vector(1 downto 0);
signal delay_17 : std_logic_vector(1 downto 0);
signal delay_18 : std_logic_vector(1 downto 0);
signal delay_19 : std_logic_vector(1 downto 0);
component rotation
generic (
  Port (
			clk 			: in std_logic;
end component;
begin
port map (
  clk => clk,
reset => reset,
quarter_in => delay_1
process(clk)
begin
	delay_2 <= delay_1;
	delay_3 <= delay_2;
	delay_4 <= delay_3;
	delay_5 <= delay_4;
	delay_6 <= delay_5;
	delay_7 <= delay_6;
	delay_8 <= delay_7;
	delay_9 <= delay_8;
	delay_10 <= delay_9;
	delay_11 <= delay_10;
	delay_12 <= delay_11;
	delay_13 <= delay_12;
	delay_14 <= delay_13;
	delay_15 <= delay_14;
	delay_16 <= delay_15;
	delay_17 <= delay_16;
	delay_18 <= delay_17;
	delay_19 <= delay_18;
	quarter_do <= delay_19;
end if;
end process;
end Behavioral;
entity right is
port (
		clk 		: in std_logic;
end right;
architecture Behavioral of right is
signal xq1 : std_logic_vector(16 downto 0);
signal xq2 : std_logic_vector(16 downto 0);
signal yq1 : std_logic_vector(16 downto 0);
signal yq2 : std_logic_vector(16 downto 0);
signal xr : std_logic_vector(16 downto 0);
signal yr : std_logic_vector(16 downto 0);
begin
xq1 <= x + 0;
yq1 <= y + 0;
xq2 <= 0 - x;
yq2 <= 0 - y;
process(clk)
begin
		case (quarter) is
			when "00" =>
				yr <= yq1;
				xr <= xq1;
			when "01" =>
				yr <= yq1;
				xr <= xq2;
			when "10" =>
				yr <= yq2;
				xr <= xq2;
			when "11" =>
				yr <= yq2;
				xr <= xq1;
			when others =>
				xr <= (others => '0');
				yr <= (others => '0');
			end case;
	else
	end if;
end if;
end process;
xo <= xr;
yo <= yr;
end Behavioral;
Ну и результат
Изменено пользователем Boobrilla
А вот у Вас в модуле Toplvl есть порты, которые объявляются без указания направления. Это так задумано, или ошибка, или ISE позволяет такие вольности с языком ?
entity Toplvl is
    port (
            clk         : std_logic;
            reset     : std_logic;
end Toplvl;
Из советов по оптимизации я бы модуль delay - описал так(только параметры WIDTH и LENGTH указал):
Это по сути многоразрядный сдвиговый регистр.
Ваш подход "в лоб" уж больно некрасиво смотрится.
А если надо длину задержки поменять ?
LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
ENTITY SHIFT_RAM IS
    GENERIC
        WIDTH      : INTEGER := 24;
        LENGTH     : INTEGER := 6
    PORT
       CLK          : IN   STD_LOGIC;
       DATA_IN      : IN   STD_LOGIC_VECTOR(WIDTH-1 DOWNTO 0);
       DATA_OUT     : OUT  STD_LOGIC_VECTOR(WIDTH-1 DOWNTO 0)
END ENTITY;
ARCHITECTURE RTL OF SHIFT_RAM IS
    TYPE      REG_RAM IS ARRAY (LENGTH-1 DOWNTO 0) OF STD_LOGIC_VECTOR(WIDTH-1 DOWNTO 0);
    SIGNAL    REG  : REG_RAM;
    ATTRIBUTE RAMSTYLE : STRING;
    ATTRIBUTE RAMSTYLE OF REG : SIGNAL IS "M9K";
BEGIN
    SHIFT_REG_PROC : PROCESS
        CLK
    BEGIN
        IF (RISING_EDGE(CLK)) THEN                              -- По каждому переднему фронту
            REG <= REG(LENGTH-2 DOWNTO 0) & DATA_IN;             -- Запишем в младший разряд данные со входа и сдвинем их
        END IF;
    END PROCESS SHIFT_REG_PROC;
    DATA_OUT <= REG(LENGTH-1);
END ARCHITECTURE;
Изменено пользователем Flip-fl0p
По портам не заметил) Но, видимо, ISE позволяет) (оба in).
По поводу подхода "в лоб" - я слишком еще не опытен. Лучше сделать так, как точно будет работать) Ну а если нужно будет изменить длину задержки, то просто добавлять/удалять кол-во переменных действий) В моем случае задержка была 190 ns = 19 по 10 ns.
А если задержка 1000 ns ? Тогда 100 по 10 ? :wacko:
Ну выходит что так) Но я бы просто тогда наверно вермя такта менял, если бы этого позволяло задание
где тестбенч для симуляции?
Тестбенч не кидал, ибо он стандартно "пустой", ничего не добавлял. Кроме наверное ресета = 1 .
ENTITY Final IS
END Final;
ARCHITECTURE behavior OF Final IS
   COMPONENT Toplvl
   PORT(
        clk : IN  std_logic;
        reset : IN  std_logic;
        sinus1 : OUT  std_logic_vector(16 downto 0)
   END COMPONENT;
  --Inputs
  signal clk : std_logic := '0';
  signal reset : std_logic := '0';
	--Outputs
  signal sinus1 : std_logic_vector(16 downto 0);
  -- Clock period definitions
  constant clk_period : time := 10 ns;
BEGIN
-- Instantiate the Unit Under Test (UUT)
  uut: Toplvl PORT MAP (
         clk => clk,
         reset => reset,
         sinus1 => sinus1
  -- Clock process definitions
  clk_process :process
  begin
	clk <= '0';
	wait for clk_period/2;
	clk <= '1';
  end process;
  -- Stimulus process
  stim_proc: process
  begin
     -- hold reset state for 100 ns.
     wait for 100 ns;
     wait for clk_period*10;
	reset <= '1';
     -- insert stimulus here
     wait;
  end process;
END;
Ну и результат
Какой SFDR у вас в итоге получился? Сколько ресурсов при этом было сожрано? По сравнению с классической DDS (четверть периода в RAM block плюс логика управления) какие преимущества у вашего решения?
Ну и более глобальный вопрос ( на вырост ) : с какой целью все эти усилия по изобретению очередного велосипеда?
Сейчас отобьете у человека желание заниматься проектированием ПЛИС. :)
То что человек выложил готовый модуль - это хорошо, честь ему и хвала за старание и плюсик в карму.
То что модуль задокументирован чуть больше чем никак - это плохо. Ибо отсутствие какой-либо документации кода (хотя бы комментариев) сводит на нет всю пользу модуля.
Проще с нуля написать, чем разобраться в этом коде. Тем более, по моему скромному мнению, многие куски кода написаны уж больно "некрасиво".
Авторизация
