rom67
вышел хотфикс OrCAD/Allegro 17.2
DATE: 10-29-2016   HOTFIX VERSION: 008
CCRID   PRODUCT        PRODUCTLEVEL2   TITLE
1644406 ALLEGRO_EDITOR SHAPE            Alternate symbol placement results in illegal parent identifier error
1647098 SIP_LAYOUT     OTHER            SiP crashes on symbol copy and rotate
1647154 APD            OTHER            Disconnected Clines not working
1648817 GRE            IFP_INTERACTIVE  Allegro PCB Editor stops responding on adding netgroups to a nested netgroup
1649829 CONCEPT_HDL    CORE             Project Manager: A delay is observed before the sub menus of the File and Tools menus appear
1652930 ALLEGRO_EDITOR OTHER            Command-line version of switchversion not working
1653109 ASDA           DESIGN_CORRUPTIO SDA not pulling latest library information for part
1655377 FLOWS          PROJMGR          Project Manager crashes on Windows 10
вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: 009
DATE: 12-8-2016    HOTFIX VERSION: 009
1212577 PSPICE         MODELEDITOR      IBIS translation fails without any information in log file
1311687 PSPICE         MODELEDITOR      Timeout error while translating IBIS model
1327174 PSPICE         MODELEDITOR      Log file should list error details during IBIS Translation
1499665 ALLEGRO_EDITOR INTERACTIV       Offset Move depends on move setting.
1516093 ALLEGRO_EDITOR PADS_IN          Pads library translator does not translate slot orientation
1565795 ALLEGRO_EDITOR UI_GENERAL       Search does not work in the Defined Variables window
1568817 ALLEGRO_EDITOR UI_GENERAL       Padstack editor not accepting comma as decimal separator with system locale set as LANG ru_RU.UTF-8
1569272 ALLEGRO_EDITOR PLACEMENT        Get the error message 'E- (SPMHDB-394): Placement cannot be completed ... 'after creating Place Replicate circuit
1577379 CONCEPT_HDL    CORE             Packager-XL gives different results when run from DE-HDL and ADW Flow Manager
1578523 ALLEGRO_EDITOR PAD_EDITOR       Library Padstack Browser does not refresh preview
1578533 ALLEGRO_EDITOR PAD_EDITOR       New Padstack Editor does not automatically update the geometry
1581129 CONSTRAINT_MGR UI_FORMS         Unable to dock the Electrical worksheet in Constraint Manager
1582103 ALLEGRO_EDITOR PADS_IN          PADS Library Import creates additional filled shape not present in source data
1591027 ADW            LIBDISTRIBUTION  Library Distribution redistributes previously distributed models
1592026 CIS            VIEW_DATABASE_PA View database part does not work from schematic pages of an externally referenced design
1593389 CAPTURE        GEN_BOM          Include files in Tools - BOM not working
1593404 SIP_LAYOUT     EDIT_ETCH        Slide command moves via toward the object
1595872 CIS            PART_MANAGER     Capture CIS Part Manager PCB Footprint update case-sensitivity issue
1596955 ALLEGRO_EDITOR EDIT_ETCH        Scribble mode is not working as per expectation.
1600936 ALLEGRO_EDITOR INTERACTIV       Pin DataTips differ between 16.6 and 17.2
1605961 ALLEGRO_EDITOR COLOR            Wildcards not working in the Filter Nets field of the Color Dialog window
1606392 ALLEGRO_EDITOR PLACEMENT        Filmmask not shown when component is attached to cursor
1607016 ADW            TDA              TDO crashes after LRM update during check-in hierarchy
1608059 CONCEPT_HDL    CREFER           Removing crefs from top-level design also removes .csb files from lower-level blocks
1608278 CAPTURE        OTHER            Crystal Reports: User is prompted for ODBC password to create a BOM report
1610377 CAPTURE        PROPERTY_EDITOR  Discrepancies between the NET_SPACING_TYPE property (or any other property) text and the actual property
1610456 ALLEGRO_EDITOR DATABASE         Strip design and selecting user defined subclasses results in database corruption.
1612793 CONCEPT_HDL    OTHER            Pattern-based auto-distribution of split symbols not working if there are spaces before commas
1613442 CONCEPT_HDL    CORE             Signal names are not horizontally centered when the wires are added using different methods
1613559 ASDA           IMPORT_DEHDL_SHE custom variables from the BOM Tables are not getting imported
1614093 CONCEPT_HDL    CORE             Import Design window has artificial 64 char limit for path - prevents access to some locations
1614372 CONCEPT_HDL    EDIF300          OFFPAGE symbol is exported as PageBorder in EDIF300 schematic
1615075 APD            LOGIC            Netlist-In wizard fails to import the net names, but gives a successful completion Info message
1616131 ALLEGRO_EDITOR PLACEMENT        While placing a module, the Mirror command in the right-click pop-up menu is not working
1617377 ALLEGRO_EDITOR UI_GENERAL       Visibility pane does not retain the correct layer view
1617404 ALLEGRO_EDITOR UI_GENERAL       axlUIMenuChange does not work as expected in 17.2
1619412 ALLEGRO_EDITOR INTERACTIV       Script to create new padstacks from existing padstack is putting in wrong values for a regular pad
1621842 ALLEGRO_EDITOR PLACEMENT        mechanical symbol without placebound will not place in QuickPlace
1621874 ASDA           PRINT            Print - Save as PDF uses the default printer options only
1621887 ALLEGRO_EDITOR INTERACTIV       Getting a 'Could not satisfy the snap condition' message when using the Snap pick to option
1622680 ALLEGRO_EDITOR PADS_IN          Import PADS fails with the 'ERROR: *NET* section found. Translation of netlist is not allowed.' message
1623832 ADW            COMPONENT_BROWSE Incorrect part placement on schematic in Design Entry HDL 16.6-S073
1624813 CAPTURE        GENERAL          The Value property is always left aligned when placing a symbol on the schematic
1624953 ALLEGRO_EDITOR UI_GENERAL       Custom views in 17.2 do not return to original
1625000 ASDA           CANVAS_EDIT      File - Save Project does not provide any indication of saving or progress bar
1625163 CONSTRAINT_MGR OTHER            There is no status for the analyze command in the Constraint Manager in 17.2
1626647 PSPICE         ENVIRONMENT      Capture crashes when loading a design with two hyphens in sim profile name
1628357 CONSTRAINT_MGR OTHER            Constraint Manager shows differences if exporting and importing constraints on the same board.
1628409 ALLEGRO_EDITOR PAD_EDITOR       Pad Stack Editor does not remember last used directory
1631443 CONCEPT_HDL    ERCDX            ERC reports warning due to lower-case value of some properties in chips.prt
1632195 SCM            OTHER            'No known page border found' error in cref.log
1632365 CONSTRAINT_MGR OTHER            Select command is disabled in the right-click pop-up menu from Constraint Manager in SPB 17.2
1632462 ALLEGRO_EDITOR 3D_CANVAS        3D View (new) and PCB Editor crash when checking collisions
1632590 ALLEGRO_EDITOR 3D_CANVAS        PCB Editor crashes when 3D View is open and more 16.6 boards are opened
1633433 CONSTRAINT_MGR UI_FORMS         Expand - Collapse feature for multiple objects not working correctly
1633454 ADW            TDA              TDO crashes if DAO throws an exception
1633526 PSPICE         AA_PPLOT         Spaces in Simulation Profile cause error in Parametric Plotter
1633608 ALLEGRO_EDITOR COLOR            'Retain objects custom color' should not enabled as default.
1636216 ALLEGRO_EDITOR 3D_CANVAS        Interactive 3D canvas (Unsupported prototype) is not mapping step model when assigned to device
1636899 ALLEGRO_EDITOR 3D_CANVAS        The new 3D Viewer is not taking the Package Height set on the PLACE_BOUND layer into account when displaying it.
1638185 CAPTURE        DATABASE         Opening CIS database locks all part libraries none of which are open
1639409 ASDA           CANVAS_EDIT      Handling of MAKE_BASE property from DE-HDL designs imported into SDA
1639541 CONSTRAINT_MGR OTHER            PCB Editor 17.2 crashes when making changes in Constraint Manager
1639613 APD            STREAM_IF        The stream out command has created sharp angles in the GDSII output file
1640061 ASDA           HIERARCHY        Incorrect message received when invalid characters are specified for subdesign suffix
1641118 F2B            DESIGNVARI       Some DNI parts are not identified in the variant view due to the BLOCK
1641410 ASDA           CONSTRAINT_MANAG No errors or issues reported when incorrect topology is applied to a net or an Xnet
1642891 CONSTRAINT_MGR CONCEPT_HDL      DE-HDL crashes randomly while working on Constraint Manager
1643003 CAPTURE        PROJECT_MANAGER  Start page shows latest as S004 after installing S005
1643532 ALLEGRO_EDITOR OTHER            Strip design command fails to delete symbol text in the attached design
1645529 ASDA           CONSTRAINT_MANAG Unable to delete the diff pair from the nets
1645639 CONSTRAINT_MGR CONCEPT_HDL      DE-HDL crashes when the XNET_PINS property value has a trailing comma character
1646354 CONSTRAINT_MGR CONCEPT_HDL      Cannot select Design Instance/Block Filter from the View menu in Constraint Manager
1646612 PCB_LIBRARIAN  CORE             Generate Symbol option crashes Part Developer
1646932 ALLEGRO_EDITOR MANUFACT         Manufacture - Auto Rename Refdes keeps defaulting to Use Default Grid even if another is chosen
1647190 APD            REPORTS          'Sorted by Bond Finger' report shows incorrect wire bond connection
1647673 ASDA           EXPORT_PCB       Two Physical folders are seen after installation of QIR
1647729 ALLEGRO_EDITOR SKILL            axlFillet returns t when fillet is not added.
1647779 CONSTRAINT_MGR OTHER            'Software Version' in the cmDiffUtility viewer does not show the correct version
1647843 ALLEGRO_EDITOR ARTWORK          Misleading information in command window when artwork import fails
1648575 CAPTURE        OTHER            Suppress warning setting must be written in capture.ini file
1649060 CONSTRAINT_MGR CONCEPT_HDL      Rename dcfx to dcf process results in error in log file and dcf not updated
1650106 ALLEGRO_EDITOR 3D_CANVAS        3D canvas rotates mirrored components in unmirrored angle
1650238 SIP_LAYOUT     WIREBOND         When performing 'Adjust Min DRC', the reference bond finger should not move.
1650734 APD            SHAPE            Shape on L1 does not flood properly
1650793 CONSTRAINT_MGR CONCEPT_HDL      Conflict of XNET_PINS definition between the chips and the SIGNAL_MODEL is not handled correctly
1650801 ALLEGRO_EDITOR SCHEM_FTB        Running Export Physical with Update PCB enabled in Project Manager crashes netrev.exe
1651011 ALLEGRO_EDITOR 3D_CANVAS        Interactive 3D viewer shows mechanical symbol mirrored
1651063 ALLEGRO_EDITOR CROSS_SECTION    Cross-section preview is incorrect
1651066 ALLEGRO_EDITOR DATABASE         Pins not connecting even after running the Tools - Derive Connectivity command
1651700 ALLEGRO_EDITOR SKILL            Running axlXSectionModify() on a layer removes the value of the material
1651925 ALLEGRO_EDITOR ARTWORK          Searching for a macro in the artwork data file: Count for the macro does not match the actual count in the output
1652230 CONCEPT_HDL    CORE             The master.tag and vlog004u.sir files are not created in the entity directory on saving symbols
1653080 CONCEPT_HDL    ERCDX            Difference in results from SPB16.6 in 'erc.rpt' when logic_data is renamed as worklib in SPB17.2 on RHEL6.5
1653422 ADW            LIBIMPORT        Classifications not linked to a Part Number or Cell Model are removed during Library Import
1653526 ALLEGRO_EDITOR DATABASE         Via padstack keepout is not displayed on the canvas when pads suppression is enabled.
1653951 ALLEGRO_EDITOR CROSS_SECTION    Cross Section Editor changes lost despite selecting No to the 'All changes will be lost ...' message
1656224 ADW            FLOW_MGR         Copy Project wizard no longer allows dashes in the 'Name of new project folder' field
1656581 ALLEGRO_EDITOR OTHER            PDF generated for layer with shape shows undesired voids if film is mirrored and Filled Shape is not selected
1656608 APD            REPORTS          Incorrect calculation in the metal usage report
1656726 CONCEPT_HDL    CORE             Interface command always disabled in the Wire menu
1656841 CONSTRAINT_MGR UI_FORMS         Incorrect layer information is displayed in the Edit Via List dialog when a filter is applied
1657220 ALLEGRO_EDITOR SKILL            axlXSectionGet() returns Primary list of layers and not All stackups
1657257 SIP_LAYOUT     EXTRACT          When using extracta, custom layer names not getting retained
1658440 ALLEGRO_EDITOR PAD_EDITOR       The location of a drill in the .pad file is different from the .dra file
1658445 CONSTRAINT_MGR CONCEPT_HDL      When DCF file is converted to ASCII, no further updates are allowed.
1659473 SIP_LAYOUT     WIREBOND         When moving wirebonds they are jumping instead of sliding
1659498 ALLEGRO_EDITOR INTERACTIV       Unable to turn off line on Etch Wire for Jumpers
1659644 CONCEPT_HDL    OTHER            Predefined nets are not listed if 16.6 design is being opened in 17.2
1660475 CONSTRAINT_MGR UI_FORMS         The CTRL+V shortcut is not working in the Export Constraints window in Constraint Manager 17.2
1660492 ALLEGRO_EDITOR UI_GENERAL       PCB Editor crashes when using multiple desktops on Windows 10
1661133 CONSTRAINT_MGR ANALYSIS         PCB Editor crashes if comma is used in the Value field for Analysis Mode
1661307 CONSTRAINT_MGR CONCEPT_HDL      Prevent creation of diff pairs on VOLTAGE nets
1661357 ALLEGRO_EDITOR EDIT_ETCH        PCB Editor crashes when using Route - Connect
1661874 ASDA           DESIGN_CORRUPTIO Unable to delete the ZERO part from the schematic page
1662799 ADW            SRM              Mechanical symbols are not being displayed in the Mechanical tab of Symbol Rollback Manager
1664797 SIG_INTEGRITY  GUI              Unnecessary coupled interconnect models were generated during View Waveform.
1664858 ALLEGRO_EDITOR EDIT_ETCH        PCB Editor crashes during Auto Interactive trunk route.
1664911 ALLEGRO_EDITOR OTHER            PCB Editor freezes after DRC Update is performed
1666329 CONSTRAINT_MGR OTHER            SCM Import Physical process crashes cmfeedback
1666551 ALLEGRO_EDITOR ARTWORK          Import Artwork, Mirror option separates imported artwork to different XY locations
1666723 ECW            TDO-SHAREPOINT   TDO login is not working with Site Minder because of incorrect characters in the Site Minder login form HTML
1667068 ALLEGRO_EDITOR SHAPE            Update shape removing the shape voiding
1669828 F2B            DESIGNVARI       Variant Editor crashes on Windows 10 T540 P laptops but works fine on Windows 10 desktops
1670221 ALLEGRO_EDITOR DATABASE         Non-recoverable corruption error is reported when saving the board after adding a layer
1672134 ALLEGRO_EDITOR ZONES            TDP needs FIXED component override
вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: 010
DATE: 01-6-2017    HOTFIX VERSION: 010
1524700 F2B            DESIGNVARI       Variant file cannot be loaded
1597787 CONCEPT_HDL    MARKERS          Save As in Marker dialog causes DE-HDL to crash
1599843 CONCEPT_HDL    INTERFACE_DESIGN Moving NG causes extra elements or moving
1620017 F2B            PACKAGERXL       Packager Fails with ERROR(SPCOPK-1053) when $PART_NUMBER property for components has a value
1632977 CONCEPT_HDL    INTERFACE_DESIGN Connectivity error when moving NG members
1635941 ALLEGRO_EDITOR INTERFACES       Shape created by IPC 2581 for negative film is not same as the shape on board
1656357 CONCEPT_HDL    CORE             Pasting a signal name across pages causes the name to overlap with the wire segment
1657346 CONCEPT_HDL    PDF              Wire Pattern set to two-dot chain line in a schematic appears as a solid line in the PDF output
1658048 ALLEGRO_EDITOR COLOR            color_lastgroup is not working in SPB 17.2
1658874 CONCEPT_HDL    CORE             'Insert (n) Pages' command does not work when the CONFIRM_WRITE directive is ON
1659030 RF_PCB         LIBRARY          Offset is not calculated from the center if using negative values for input pins when placing MSOP symbols
1659097 CONCEPT_HDL    CORE             mouse stroke fails to be enabled on startup with left moust button (LMB)
1659532 CONCEPT_HDL    CORE             About Import Design command with the CONFIRM_WRITE directive
1659929 CONSTRAINT_MGR UI_FORMS         Using wildcards in filename for Import Constraints does not work in 17.2
1660200 ALLEGRO_EDITOR UI_GENERAL       Move by Sym Pin # edit box is obfuscated
1662821 ALLEGRO_EDITOR OTHER            Cross section chart does not show stack vias in 17.2
1663641 CONCEPT_HDL    COPY_PROJECT     File - Copy Project in Project Manager creates two designs if there are dashes in the design name
1665652 ALLEGRO_EDITOR SHAPE            Critical fillet and shape issues in 17.2
1665918 CONCEPT_HDL    CHECKPLUS        Error (100) Program Internal Error "Create_flat_node" with checkplus run
1667056 ASI_PI         GUI              Power Feasibility Editor does not list capacitors connected to selected nets/parts
1668137 ALLEGRO_EDITOR SCRIPTS          PCB Editor crashing when running Script Replay
1669651 CONCEPT_HDL    CREFER           CreferHDL values are invisible
1669707 CONCEPT_HDL    CORE             Pin numbers not visible on the canvas after replacing a part with the same symbol but a different part property
1670339 ALLEGRO_EDITOR OTHER            Small shapes define on the mechanical symbol Board Geometry – Outline are not converted to the Cutout subclass.
1670564 ALLEGRO_EDITOR MANUFACT         exported gerber file can't import in brd
1670687 ALLEGRO_EDITOR NC               nclegend.log reports missing columns which are present in the NC Legend
1670811 PSPICE         AA_MC            AA MC Plot settings options
1671428 ALLEGRO_EDITOR UI_FORMS         Display origin checkbox position changes in Step Mapping dialog
1671728 CONCEPT_HDL    CORE             Option requested to reload preferred_projects.txt without re-opening DE-HDL
1671901 ALLEGRO_EDITOR UI_GENERAL       Toolbar and menus are locked or greyed out
1672477 ALLEGRO_EDITOR DRC_CONSTR       DRC generated by Dynamic fillets
1673499 ALLEGRO_EDITOR DATABASE         Would you please check on the drill table title issue of backdrill design in v172.
1673681 ALLEGRO_EDITOR UI_GENERAL       F1 for Help not working in PCB Editor 17.2
1675499 ALLEGRO_EDITOR DATABASE         Running the Gloss command causes PCB Editor to crash...
1676480 ALLEGRO_EDITOR MANUFACT         Creating Variant Assy_Bot Drawing showing Variant Assy Top Drawing
1677431 ALLEGRO_EDITOR DATABASE         Get ERROR(SPMHA1-141): Invalid sector row. Contact cadence customer support when opening DRA File
1677651 CONSTRAINT_MGR CONCEPT_HDL      DE-HDL crash on design after successful packaging
1677672 CONCEPT_HDL    CORE             Whitespaces in URL links are not resolved correctly on Linux with Firefox
1680837 ALLEGRO_EDITOR SHAPE            Updating the shape makes the shape disconnect from Thru pins of same net
1681059 ALLEGRO_EDITOR SHAPE            Shape Voiding using DV_SQUARECORNERS environmental variable does not always produce voids with square corners.
1682312 SIG_INTEGRITY  LICENSING        Allegro Sigrity SI/PI Product Choices window is blank after installing 17.2-s009 hotfix
вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: 011
DATE: 01-20-2017   HOTFIX VERSION: 011
1618986 CONCEPT_HDL    CORE             Information required about the DONT_FORCE_ORIGIN_ONGRID directive
1629696 PSPICE         PROBE            After successfully exporting traces to csv, PSpice crashes on a subsequent attempt to export traces
1667213 CAPTURE        NETLIST_ALLEGRO  Tools - Create Netlist stops responding on Windows10
1667599 APD            OTHER            Wire Bond operations taking longer than expected to complete
1667678 MODEL_EDITOR   PARSE            Signal model assignment creates ESpice models that do not pass Model Integrity checks
1670120 ALLEGRO_EDITOR UI_GENERAL       In 17.2, the Static Phase meter shows up in the middle of the screen instead of the lower right corner
1670927 ALLEGRO_EDITOR DRAFTING         Using zcopy to create a Route Keepin results in database errors
1675359 ALLEGRO_EDITOR ARTWORK          Subclass ETCH/WIRE is added to artwork definition though the visibility of 'ALL Layers' is turned off
1675619 ALLEGRO_EDITOR MANUFACT         Differences observed in IPC-D-356A between releases 16.6 and 17.2
1676161 ADW            FLOW_MGR         Operation load JNI code failed error while opening project in SPB 17.2
1677405 CONCEPT_HDL    OTHER            When moving a wire with a dot, the dot is not removed directly
1678061 PSPICE         SLPS             Simulating an SLPS co-simulation with a Fixed-step solver with a value smaller than 1E-4 results in a crash
1679347 PSPICE         SLPS             SLPS crashes when co-simulating without opening OrCAD Capture or PSpice
1680113 ALLEGRO_EDITOR SHAPE            Irregular void created on dynamic shapes
1680802 ALLEGRO_EDITOR DATABASE         A 16.3 database locked with disabled export of design data should be view only in 16.6
1681129 ALLEGRO_EDITOR DATABASE         Match Groups in the DE-HDL design are not getting transferred to the board file
1681514 ALLEGRO_EDITOR UI_GENERAL       Opening the Dynamic Shapes State report hangs PCB Editor in 17.2 Hotfix 009
1681727 CAPTURE        NETGROUPS        In 17.2, Capture crashes when closing a design that has assigned Netgroups
1682297 ALLEGRO_EDITOR DATABASE         Derived padstack and associated padshapes not updated when design is upreved for compatibility with the current version
1682447 CONSTRAINT_MGR CONCEPT_HDL      Extraction issue on differential pairs in the given design
1682454 CONSTRAINT_MGR CONCEPT_HDL      Design with NO_XNET_CONNECTION property on parts is exported to PCB Editor; many other components get the property
1682469 CONSTRAINT_MGR CONCEPT_HDL      Creating a CSet from an existing CSet leads to invalid CSet names in Constraint Manager connected to DE-HDL
1683919 ECW            TDO-SHAREPOINT   Site Minder integration for login from TDA not working after SSL certificate update
1684111 ALLEGRO_EDITOR SHAPE            Dynamic Shape not voiding overlapped static shape
1684508 ALLEGRO_EDITOR AUTOVOID         Allegro PCB Editor stops responding when deleting a via
1685540 ALLEGRO_EDITOR OTHER            If text is attached to an object, the object is also printed in the PDF
1685810 ALLEGRO_EDITOR PAD_EDITOR       In 17.2, Padstack Editor does not save adjacent layer information for BOTTOM pads
1685986 ALLEGRO_EDITOR PADS_IN          PADS Translator-generated output shows incorrect unit for the soldermask oversize option
1686127 ALLEGRO_EDITOR SHAPE            The void of shape missed in artwork.
1686791 ALLEGRO_EDITOR OTHER            Searchable property unavailable on bottom layer pins in the generated PDF
вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: 012
DATE: 02-3-2017    HOTFIX VERSION: 012
1659641 ADW            FLOW_MGR         Documentation Editor does not invoke when a .brd file is opened from EDM Flow Manager
1661632 CONCEPT_HDL    OTHER            Page skipped in DE-HDL when navigating using the Page Up and Page Down keys
1668325 ALLEGRO_EDITOR SHAPE            Updating shapes to smooth creates erratic voids.
1670082 CONSTRAINT_MGR ANALYSIS         Inconsistency in Constraint Analysis Modes - Electrical in OrCAD PCB Designer Professional 17.2
1674231 ECW            METRICS          Re-upload for local metric packets that failed on first attempt is not working when Pulse server name contains dots
1674338 APD            SHAPE            Shape is not clearing slivers that are smaller than the 'Minimum aperture for gap width' of '18 um'
1675677 ADW            DBEDITOR         DBeditor Issue-Searching by using the Properties method
1677489 CONCEPT_HDL    CREFER           CRefer points to incorrect page numbers when there are page mismatches in the logical and physical page numbers
1679351 ALLEGRO_EDITOR REPORTS          Missing Fillets Report is not showing missing fillets on the bottom layer
1681002 ALLEGRO_EDITOR OTHER            17.2 STEP output fails to produce an output similar to 16.6
1682287 ALLEGRO_EDITOR EDIT_ETCH        Auto-interactive Delay tune (AiDT) rips lines that have been routed
1682900 ALLEGRO_EDITOR PLACEMENT        Moving a symbol by snapping to segment vertex with 17.2 Hotfix 009 crashes PCB Editor
1684117 CONCEPT_HDL    CONSTRAINT_MGR   Property deleted from Constraint Manager is not getting updated in the DE-HDL canvas
1686803 ALLEGRO_EDITOR INTERFACES       PCB Editor crashes if the 'ipc2581_group_drills' variable is set.
1687816 ALLEGRO_EDITOR PLOTTING         Export PDF Vector text option does not work
1688287 CONSTRAINT_MGR DATABASE         PCB Editor crashing while adding a net to a net group.
1689881 ALLEGRO_EDITOR DFA              Record and replay script for loading DFA spreadsheet not working
1690958 ALLEGRO_EDITOR SKILL            SKILL command axlDBDelLock is not working as explained in the documentation
1692166 APD            DATABASE         DB Doctor returns 'ERROR(SPMHDB-252): A corrupt database pointer was detected' for a specific design
1693431 ALLEGRO_EDITOR SKILL            Running axlXSectionModify and axlXSectionSet results in warnings and corrupts multi-zone cross-section
1693719 ALLEGRO_EDITOR MANUFACT         Incorrect suppressed holes information in the drill file created
1693846 ALLEGRO_EDITOR MANUFACT         PCB Editor crashes when running the gloss command
1694151 CONCEPT_HDL    CORE             Rename Signal for unnamed net added the sig_name at the incorrect position with small text size.
1694867 ALLEGRO_EDITOR SHAPE            Void is deleted by the shape merge command
1695131 ALLEGRO_EDITOR SKILL            PCB Editor crashes when using the axlSpreadsheetDefineCell SKILL function
вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: 013
Fixed CCRs in SPB 17.2 HF013
02-17-2017
CCRID   Product            ProductLevel2 Title
1567741 ADW                COMPONENT_BRO The PPL_list never gets read when using a saveconf.ctr located in the global site.cpm
1697109 ALLEGRO_EDITOR     ARTWORK       Artwork not showing padstacks for the soldermask layer
1697309 ALLEGRO_EDITOR     DATABASE      PCB Editor 17.2 uprev changes NC pins from non-plated to plated
1698624 ALLEGRO_EDITOR     DATABASE      Opening 16.6 board in 17.2 converts non-plated holes to plated
1697092 ALLEGRO_EDITOR     OTHER         axlDBViaStack crashes PCB Editor session and corrupts the board
1687819 ALLEGRO_EDITOR     UI_GENERAL    Change in Region and Language settings of Windows impacts decimal character in Padstack Editor
1696637 ALLEGRO_EDITOR     UI_GENERAL    Padstack Editor uses Region and Language settings for the decimal symbol
1699326 ALLEGRO_EDITOR     UI_GENERAL    Padstack Editor follows the geographical area rules set in the Control Panel while PCB Editor does not
1616138 ALTM_TRANSLATOR    PCB_EDITOR    Board file imported from third-party tool to PCB Editor has the shapes but not the components
1666020 ALTM_TRANSLATOR    PCB_EDITOR    Board converted from a third-party tool to PCB Editor has missing components
1690448 CAPTURE            CORRUPT_DESIG Corrupt design: nets in this design are not displayed when running Edit - Browse - Nets
1690455 CAPTURE            CORRUPT_DESIG Corrupt design: all the nets in this design are not displayed when running Edit - Browse - Nets
1684180 CONCEPT_HDL        CORE          Message should indicate that the user needs to reload the design after setting SET STICKY_OFF
1695987 CONCEPT_HDL        CORE          $PN placement in DE-HDL during part development is not following mouse placement
1675013 ORBITIO            ALLEGRO_SIP_I Failed to import brd file
1698968 SIP_LAYOUT         3D_VIEWER     3D viewer shows keepin and not design outline.
1699884 SIP_LAYOUT         ASSY_RULE_CHE SiP Layout crashes on using Assembly Rules Checker
1689969 SIP_LAYOUT         DIE_EDITOR    SiP Layout crashes when moving dies using relative coordinates
1696239 SIP_LAYOUT         DIE_EDITOR    When using the Die-stack Editor to move and stretch wires, SiP Layout crashes
1695372 SIP_LAYOUT         REPORTS       Running the Metal Usage reports fails on the Primary side.
вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: 014
Fixed CCRs: SPB 17.2 HF014
03-4-2017
1691828 ADW                COMPONENT_BRO Part Information Manager displays incorrect data related to attributes on relationships
1700963 ALLEGRO_EDITOR     DATABASE      Running the 'slide' command results in the cline segment losing connectivity
1685502 ALLEGRO_EDITOR     INTERFACES    The Export - PDF command fails to export the TOP etch subclass with error code SPMHGE-268
1644643 ALLEGRO_EDITOR     MANUFACT      The NC drill legend does not match the drill customization data
1700557 ALLEGRO_EDITOR     MANUFACT      DXF output does not contain drill figure data
1660252 ALLEGRO_EDITOR     NC            NC Drill file generated with errors
1677775 ALLEGRO_EDITOR     NC            Merging of drills not retained in database.
1701554 ALLEGRO_EDITOR     SHAPE         Shape spacing clearance is not updated unless the shape vertex is deleted
1704669 ALLEGRO_EDITOR     SHAPE         Route Keepin is not getting created at a specific location
1685995 ALLEGRO_EDITOR     SKILL         All film sequence numbers are returned as 0 when using the SKILL function axlGetParam
1621336 ALLEGRO_EDITOR     UI_GENERAL    Changing the color visibility does not refresh the screen color immediately
1668817 ALLEGRO_EDITOR     UI_GENERAL    Changing the visibility or the color on the canvas in release 17.2-2016 takes longer than release 16.6
1671268 ALLEGRO_EDITOR     UI_GENERAL    Visibility Window: There is a noticeable lag when enabling etch, via, and pin on a specific layer one by one
1690691 ALLEGRO_EDITOR     UI_GENERAL    Reports not generating if the 'allegro_html_qt' environment variable is disabled
1709903 ALLEGRO_EDITOR     UI_GENERAL    Toggling layer visibility does not change the display until the mouse pointer is moved
1647596 APD                EXPORT_DATA   Allegro Package Designer crashes when trying to export board-level components
1688035 APD                OTHER         Significant difference seen in the percentage of metal between the Metal Usage reports of positive and negative layers
1690777 CONCEPT_HDL        CHECKPLUS     Rules Checker returns an error when the value of the PACK_TYPE property is in lowercase
1700873 CONCEPT_HDL        CORE          With duplicate part table files, running the Assign Power Pins command crashes DE-HDL without any message
1702703 CONCEPT_HDL        CORE          Location of $PN in DE-HDL Symbol Editor is not as precise as it was in 17.2 Hotfix 011
1705999 CONCEPT_HDL        CORE          Signal naming is not working correctly in SPB 17.2
1698259 CONSTRAINT_MGR     CONCEPT_HDL   Unstable $LOCATION property in release 17.2-2016
1702537 CONSTRAINT_MGR     CONCEPT_HDL   ECSet mapping errors reported after removing the signal models on an upreved design
1703981 CONSTRAINT_MGR     TECHFILE      Importing a technology file (.tcf) results in packaging errors
1673115 ECW                INTEGRATION   Import from external data sources (Integrations) truncates input values to 128 characters
1699395 FSP                FPGA_SUPPORT  Selecting a QSF part name in the FPGA Properties window crashes FSP
1704353 INSTALLATION       DOWNLOAD_MGR  Selecting 'View' in Download Manager results in error, 'Object Reference not set to an instance of an object'
1705265 INSTALLATION       DOWNLOAD_MGR  Problem installing OrCAD Library Builder from Download Manager
1646635 PDN_ANALYSIS       PCB_PI        PCB Editor uses 'powerdc.exe' to launch PowerDC instead of the 'powerdc' script
вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: 015
DATE: 03-16-2017 HOTFIX VERSION: 015
1653366 ALLEGRO_EDITOR INTERFACES Unable to attach step model to symbol
1671760 ALLEGRO_EDITOR INTERFACES Step package mapping window unable to display step model
1706879 ALLEGRO_EDITOR MANUFACT Trace gets moved to dielectric layer after using the Gloss function
1708685 ALLEGRO_EDITOR MANUFACT Incomplete ncdrill holes data in drl file
1712057 ALLEGRO_EDITOR PAD_EDITOR Changing text size and restarting Padstack Editor results in incorrectly scaled forms
1709335 ALLEGRO_EDITOR SCHEM_FTB Cannot import netlist from attached design
1687329 ALLEGRO_EDITOR SHAPE Shape is not voiding uniformly when component is rotated in 30 degrees
1698539 ALLEGRO_EDITOR SHAPE A thin shape is left when dv_fixfullcontact is enabled.
1620210 ALLEGRO_EDITOR UI_GENERAL Need to run PCB Editor from both 17.2-2016 and 16.6 releases simultaneously
1711341 ALLEGRO_EDITOR UI_GENERAL Incorrect pad size in Padstack Editor when the German regional settings are used
1712496 ALLEGRO_EDITOR UI_GENERAL Padstack Editor shows incorrect values when using comma and 3 decimal places
1714744 ALLEGRO_EDITOR UI_GENERAL Using comma instead of dot as integer separator results in incorrect diameter value
1715714 ALLEGRO_EDITOR UI_GENERAL If the 'Decimal places' field is set to 3, values in PAD Designer change automatically
1713292 APD WIREBOND Allegro Package Designer crashes when adding wire to a die pad
1710973 ASDA PACKAGER Unable to export Allegro SDA project to PCB Layout
1698697 CONCEPT_HDL COPY_PROJECT Copy project corrupts the .dcf file
1705401 CONCEPT_HDL CORE Alignment issues while pasting signal names in 16.6 Hotfix 084
1707116 CONCEPT_HDL CORE SIG_NAME is placed on non-grid position
1710486 CONCEPT_HDL CORE Rename Signal places sig_name at an incorrect position for an unnamed net
1667786 CONSTRAINT_MGR XNET_DIFFPAIR Parts with NO_XNET_CONNECTION getting extracted into SigXplorer
1709508 SIG_INTEGRITY REPORTS Allegro Sigrity SI crashes when running a reflection simulation
1710097 SIP_LAYOUT DIE_STACK_EDI The IY option of the 'move and stretch wire' command moves the die to incorrect coordinates
1712964 SIP_LAYOUT SYMBOL SiP Layout crashes when using Renumber Pins in Symbol Edit application mode
вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: 016
Fixed CCRs: SPB 17.2 HF016
04-6-2017
1623832 ADW                COMPONENT_BRO Incorrect part placement on schematic in Design Entry HDL 16.6-S073
1673128 ADW                COMPONENT_BRO Directive is saved in project CPM
1673510 ADW                COMPONENT_BRO Lifecycle status color column is not sorted correctly in Component Browser search results
1604734 ADW                DATABASE      Parts displaying non-key properties and values in the Component Browser in ADW
1585203 ADW                DBEDITOR      Optimize check-in of footprints with multiple padstacks
1675677 ADW                DBEDITOR      Database Editor (dbeditor) hangs while searching by property
1142957 ADW                DSN_FLOW      No Help available for schematic design verification
1609186 ADW                DSN_MIGRATION ADW Design Migration utility should handle ADW board reference projects and manage atdm.ini
1676161 ADW                FLOW_MGR      Opening a project in release 17.2 flags the 'Operation load JNI code failed' error
1591757 ADW                GENERIC_UI    Running 'Create Test Schematic' in ADW Flow Manager results in Error SPCOCN-1736
1591027 ADW                LIBDISTRIBUTI Library Distribution redistributes previously distributed models
1588111 ADW                LIBIMPORT     Library Import fails with Java errors while processing .csv files
1632223 ADW                LRM           Checking in a hierarchy causes a crash
1618173 ADW                SRM           SRM does not automatically run when a .brd file is opened from EDM Flow Manager in release 17.2 Hotfix 003
1618832 ADW                SRM           SRM marks parts as updated even when they are not updated
1628403 ADW                TDO-SHAREPOIN Objects remain checked out after multiple failed 'check-in hierarchy' attempts
1636216 ALLEGRO_EDITOR     3D_CANVAS     Interactive 3D canvas (Unsupported prototype) is not mapping Step model when assigned to a device
1642367 ALLEGRO_EDITOR     3D_CANVAS     Component height is not correct in new 3D Viewer
1642668 ALLEGRO_EDITOR     3D_CANVAS     The new 3D canvas does not show STEP model of the drawing (.dra)
1650106 ALLEGRO_EDITOR     3D_CANVAS     3D Canvas: Symbols are mirrored at incorrect angles
1653247 ALLEGRO_EDITOR     3D_CANVAS     New interactive 3D Viewer shows wrong placement
1658275 ALLEGRO_EDITOR     3D_CANVAS     Components on the bottom side are shifted in the new 3D view
1635858 ALLEGRO_EDITOR     ARTWORK       Get 'WARNING: Null REGULAR-PAD specified for padstack' messages in log file when generating artwork for all layers
1639244 ALLEGRO_EDITOR     ARTWORK       When importing an artwork, a sub-folder is created with the value of the ads_sdart environment variable
1658173 ALLEGRO_EDITOR     ARTWORK       ARTWORK: Value of Scale factor for output.
1661760 ALLEGRO_EDITOR     ARTWORK       Import artwork to Design Outline layer does not give error in Allegro prompt.
1666551 ALLEGRO_EDITOR     ARTWORK       Import Artwork: Mirror option separates imported artwork to different XY locations
1633608 ALLEGRO_EDITOR     COLOR         Dehighlight command: The 'Retain Objects Custom Color' option should not be enabled by default
1667778 ALLEGRO_EDITOR     COLOR         Add option to set FORM mini dehl_retain_color to NO
1669462 ALLEGRO_EDITOR     COLOR         Changes made to the Visibility tab are not reflected in the Color Dialog window
1641265 ALLEGRO_EDITOR     CROSS_SECTION The differential impedance value for a layer is not getting updated
1648149 ALLEGRO_EDITOR     CROSS_SECTION Getting warning when calculating impedance in mixed stackup
1671441 ALLEGRO_EDITOR     CROSS_SECTION Enhancement request for cross section dialog box
1673320 ALLEGRO_EDITOR     CROSS_SECTION Diff impedance calculation fails
1690021 ALLEGRO_EDITOR     CROSS_SECTION How to keep settings of expanded/compressed columns in the Xsection
1703831 ALLEGRO_EDITOR     CROSS_SECTION Calculation of Diff Z0 fails in flex designs
1711484 ALLEGRO_EDITOR     CROSS_SECTION ShowAll Column does not retain its status
1607250 ALLEGRO_EDITOR     DATABASE      A board file created in release 16.5 crashes when opened in 16.6 Hotfix 69
1610456 ALLEGRO_EDITOR     DATABASE      Selecting user-defined subclasses when using strip design results in database corruption
1633707 ALLEGRO_EDITOR     DATABASE      Cannot remove Route_Keepout associated with a pin
1638251 ALLEGRO_EDITOR     DATABASE      Unplated hole changed to plated hole after uprev from release 16.6 to 17.2
1672841 ALLEGRO_EDITOR     DATABASE      ERROR(SPMHDB-153): Table corrupt; current/maximum mismatch
1673499 ALLEGRO_EDITOR     DATABASE      Drill table title issues of backdrill designs in release 17.2
1673613 ALLEGRO_EDITOR     DATABASE      COVERLAY_TOP not present in the Non-conductor section of Color Dialog window
1680802 ALLEGRO_EDITOR     DATABASE      Release 16.3 database locked by disabling export of design data should be view-only in release 16.6
1681129 ALLEGRO_EDITOR     DATABASE      Match Groups in DE-HDL design are not getting transferred to the board file
1688123 ALLEGRO_EDITOR     DATABASE      Drill Plating Issue
1697309 ALLEGRO_EDITOR     DATABASE      In release 17.2, PCB Editor uprev changes NC pins from non-plated to plated
1698624 ALLEGRO_EDITOR     DATABASE      Opening a 16.6 board in release 17.2 converts non-plated holes to plated
1701995 ALLEGRO_EDITOR     DATABASE      When upreving a 16.6 brd to release 17.2, lines drawn on OUTLINE are translated to CUTOUT and not DESIGN_OUTLINE
1710772 ALLEGRO_EDITOR     DATABASE      Mirror command not working on zones
1713335 ALLEGRO_EDITOR     DATABASE      Defining Adjacent_layer_keepout_above and/or Adjacent_layer_keepout_below and then saving the .dra file giving error
1693289 ALLEGRO_EDITOR     DFA           File - Save As script does not save the DFA file
1488909 ALLEGRO_EDITOR     DRC_CONSTR    Test Via causes net scheduling verification to fail
1644004 ALLEGRO_EDITOR     DRC_CONSTR    Unreported DRCs from dynamic copper to line and dynamic copper to SMT pin
1651425 ALLEGRO_EDITOR     DRC_CONSTR    The .brd file crashes when moving text controlled with minimum metal to metal constraints
1663494 ALLEGRO_EDITOR     DRC_CONSTR    Reported Mechanical Pin to conductor spacing DRC constraint value is incorrect leading to false DRCs
1672477 ALLEGRO_EDITOR     DRC_CONSTR    Although Allow DRC is not selected, DRC generated by dynamic fillets
1596955 ALLEGRO_EDITOR     EDIT_ETCH     Scribble mode not showing correct finish point in single trace mode
1639483 ALLEGRO_EDITOR     EDIT_ETCH     Manually routing discrete components with incorrect constraints causes PCB Editor to crash
1687049 ALLEGRO_EDITOR     EDIT_ETCH     Create a Via Structure disconnects nets
1704296 ALLEGRO_EDITOR     EDIT_ETCH     Asymmetrical fanout created for BGA Quadrant style
1686873 ALLEGRO_EDITOR     EDIT_SHAPE    Merge static shapes deletes both the shapes selected.
1629925 ALLEGRO_EDITOR     GRAPHICS      Errors reported and no layout data drawn in PCB Editor in release 17.2 Hotfix 003 on Ubuntu 14.04
1628895 ALLEGRO_EDITOR     INTERACTIV    Shape Edit mode: An error message is required when attempting to edit a Shape with the FIXED property
1666379 ALLEGRO_EDITOR     INTERACTIV    Place replicate is not working on the attached test case
1668282 ALLEGRO_EDITOR     INTERACTIV    Grid display incorrect for repeated grids
1675531 ALLEGRO_EDITOR     INTERACTIV    Design Entry CIS: Cross Probing with PCB Editor and Constraint Manager is not working
1694470 ALLEGRO_EDITOR     INTERACTIV    Update description of variable padstack_nowarning_display
1696855 ALLEGRO_EDITOR     INTERACTIV    Mixed grid setting is not displayed correctly on Define Grid screen.
1698192 ALLEGRO_EDITOR     INTERACTIV    Deleting and replacing a component causing database corruption in Hotfix 009
1703671 ALLEGRO_EDITOR     INTERACTIV    An error occurs when defining grids with zero increment value
1703812 ALLEGRO_EDITOR     INTERACTIV    Crash during move when using the 'snap pick to' option set to symbol origin
1719276 ALLEGRO_EDITOR     INTERACTIV    Setting variable grid for 'All Etch' displays an error in the Define Grid form
1635941 ALLEGRO_EDITOR     INTERFACES    Shape created by IPC 2581 for negative film does not match the shape on the board
1639845 ALLEGRO_EDITOR     INTERFACES    Step file not generated when board is exported to a folder with special characters in name
1641339 ALLEGRO_EDITOR     INTERFACES    DXF_IN does not show all the subclasses available in the design
1648183 ALLEGRO_EDITOR     INTERFACES    Allegro STEP Export: Using the 'step_3D_copper' variable, pads not exported in the same plane as traces and shapes
1663422 ALLEGRO_EDITOR     INTERFACES    Shape loses group membership after importing through sub-drawing
1633647 ALLEGRO_EDITOR     MANUFACT      Variant issue: Create Assembly Drawing command not creating filled shapes for keying pegs in attached design
1637959 ALLEGRO_EDITOR     MANUFACT      Thieving uses different clearance values around the route keepin.
1670564 ALLEGRO_EDITOR     MANUFACT      Exported Gerber file cannot be imported in brd
1676480 ALLEGRO_EDITOR     MANUFACT      Creating Variant Assy_Bot Drawing showing Variant Assembly Top Drawing
1716431 ALLEGRO_EDITOR     MANUFACT      Test points generation stops due to an error
1607956 ALLEGRO_EDITOR     OTHER         Unable to generate the model index file from the command line using the mkdeviceindex utility
1623112 ALLEGRO_EDITOR     OTHER         Switch Release unable to identify the 16.6 release when it is installed in the All Users mode
1641994 ALLEGRO_EDITOR     OTHER         DB Doctor: Incorrect spelling of 'eliminated' in the log file messages
1642597 ALLEGRO_EDITOR     OTHER         Importing .tdp file: Footprints not included in the .tdp file are updated in the design
1660496 ALLEGRO_EDITOR     OTHER         SiP Layout crashes when trying to generate abstract level view by using export chips and connectivity
1662821 ALLEGRO_EDITOR     OTHER         Cross section chart does not show stack vias in release 17.2
1670339 ALLEGRO_EDITOR     OTHER         Small shapes defined on the mechanical symbol Board Geometry – Outline are not converted to the Cutout subclass.
1681002 ALLEGRO_EDITOR     OTHER         STEP output in release 17.2 is different from release 16.6
1685464 ALLEGRO_EDITOR     OTHER         The 'alias ~S save' command is not recognized when set in the local env file
1696486 ALLEGRO_EDITOR     OTHER         STEP export results vary between releases 16.6 and 17.2
1706623 ALLEGRO_EDITOR     OTHER         axlBackdrillGet crashes for invalid argument
1586957 ALLEGRO_EDITOR     PAD_EDITOR    In Pad Editor, selecting a pad geometry is not showing up in the Design Layers tab
1610984 ALLEGRO_EDITOR     PAD_EDITOR    Geometry set in tabs not read, only initial value set in Start page is used
1614015 ALLEGRO_EDITOR     PAD_EDITOR    Padstack Editor in release 17.2 does not auto fill geometry in design layers
1628409 ALLEGRO_EDITOR     PAD_EDITOR    Padstack Editor does not remember the last used directory
1636012 ALLEGRO_EDITOR     PAD_EDITOR    Keepout should not be allowed if antipad is not defined for outer layers
1641973 ALLEGRO_EDITOR     PAD_EDITOR    Padstack Editor: Path to the previously opened .pad file is not seeded in the File - Open dialog on a fresh launch
1642789 ALLEGRO_EDITOR     PAD_EDITOR    In release 17.2, 'Units' and 'Decimal Places' in Padstack Editor are not updated as per the .pad file
1646914 ALLEGRO_EDITOR     PAD_EDITOR    The 'Save' button is grayed out in Padstack Editor
1657553 ALLEGRO_EDITOR     PAD_EDITOR    No possibility to specify Padstack Editor default library path at invocation
1657609 ALLEGRO_EDITOR     PAD_EDITOR    Changing Tolerance field in Padstack Editor does not activate the Save button
1662225 ALLEGRO_EDITOR     PAD_EDITOR    Padstack editor dialog message doesn't match available options
1667062 ALLEGRO_EDITOR     PAD_EDITOR    Padstack editor does not retain the decimal places from the previous session
1672774 ALLEGRO_EDITOR     PAD_EDITOR    Pad Editor graphics appear to show offset incorrectly
1674157 ALLEGRO_EDITOR     PAD_EDITOR    Update Symbols does not update Pad Type Information
1675438 ALLEGRO_EDITOR     PAD_EDITOR    Drill hole size warning for the SMD pad
1684376 ALLEGRO_EDITOR     PAD_EDITOR    Pad Editor issues with settings, such as decimal places, layers, and so on
1685810 ALLEGRO_EDITOR     PAD_EDITOR    In release 17.2, Padstack Editor does not save adjacent layer information for BOTTOM pads
1690376 ALLEGRO_EDITOR     PAD_EDITOR    Variable padstack_nowarning_display fails to suppress warnings
1694649 ALLEGRO_EDITOR     PAD_EDITOR    Change Cancel button to No in warning generated when updating padstacks in design layout
1620814 ALLEGRO_EDITOR     PARTITION     Etch and Via are not imported with the partition
939242  ALLEGRO_EDITOR     PLACEMENT     Cross probing between Capture and PCB Editor is inconsistent
1103945 ALLEGRO_EDITOR     PLACEMENT     Place Replicate Create does not include the etch connected to pin
1233019 ALLEGRO_EDITOR     PLACEMENT     Allow cross probe object selection apart from highlighting during place replicate
1569272 ALLEGRO_EDITOR     PLACEMENT     Get the error message 'E- (SPMHDB-394): Placement cannot be completed ... ' after creating Place Replicate circuit
1633581 ALLEGRO_EDITOR     PLACEMENT     On mirroring a part, the cursor moves to the origin of the board
1633601 ALLEGRO_EDITOR     PLACEMENT     Place>Via Arrays>Boundary command: Via arrangement pattern deteriorated in Hotfix 004 as compared to Hotfix 003
1643078 ALLEGRO_EDITOR     PLACEMENT     PCB Editor flags an error message when a module is placed at a specific angle
1682900 ALLEGRO_EDITOR     PLACEMENT     Moving a symbol by snapping to segment vertex in release 17.2 Hotfix 009 crashes PCB Editor
1696932 ALLEGRO_EDITOR     PLACEMENT     Inconsistency with Snap pick to when selecting Segment Midpoint
1654500 ALLEGRO_EDITOR     REPORTS       In release 17.2 Hotfix 006, display of Netin (back anno.) report fails when variable ads_sdreport is set
1623904 ALLEGRO_EDITOR     SCHEM_FTB     Logic import fails, but no error mentioned in the netrev.lst file
1643992 ALLEGRO_EDITOR     SCHEM_FTB     Export Physical fails with the 'netrev.exe has stopped working' error
1668137 ALLEGRO_EDITOR     SCRIPTS       PCB Editor crashes on running Script Replay
1496199 ALLEGRO_EDITOR     SHAPE         Overlapping route keepouts result in a broken shape.
1607954 ALLEGRO_EDITOR     SHAPE         Dynamic Shape not updating correctly
1611446 ALLEGRO_EDITOR     SHAPE         Inconsistent break in shape when creating voids in a design in  16.6 Hotfix 69
1625610 ALLEGRO_EDITOR     SHAPE         Modifying a shape boundary leads to other shapes losing their voids
1626001 ALLEGRO_EDITOR     SHAPE         Shape to route keepout DRCs reported for dynamic shapes in the attached design
1653400 ALLEGRO_EDITOR     SHAPE         Dynamic shape does not void a via.
1665652 ALLEGRO_EDITOR     SHAPE         Critical fillet and shape issues in release 17.2
1668262 ALLEGRO_EDITOR     SHAPE         dynamic shape does not void custom route keepout with arc
1681059 ALLEGRO_EDITOR     SHAPE         Shape voiding using DV_SQUARECORNERS environmental variable does not always produce voids with square corners.
1682569 ALLEGRO_EDITOR     SHAPE         Variable 'dv_squarecorners' not working correctly.
1687329 ALLEGRO_EDITOR     SHAPE         Shape is not voiding uniformly when component is rotated by 30 degrees
1696240 ALLEGRO_EDITOR     SHAPE         SKILL error when merging polygons
1709968 ALLEGRO_EDITOR     SHAPE         In release 17.2, DB Doctor reports error in shape when no error was reported in release 16.6 for the same shape
1596780 ALLEGRO_EDITOR     SKILL         PCB Editor crashes after doing SRM update and save
1623935 ALLEGRO_EDITOR     SKILL         On running the SKILL function, axlSectionModify, Shield and Etch Factor are not updated
1632505 ALLEGRO_EDITOR     SKILL         In release 17.2 Hotfix 004, PCB Editor crashes after SRM update and save
1647729 ALLEGRO_EDITOR     SKILL         When a fillet insert fails, the 'axlFillet' function returns 't' instead of nil
1651701 ALLEGRO_EDITOR     SKILL         Cannot set the etch factor value in the cross-section using the axlXSectionModify() skill command
1658419 ALLEGRO_EDITOR     SKILL         PCB Editor crashes after running SRM
1658948 ALLEGRO_EDITOR     SKILL         axlIsLayerNegative() is not working in release 17.2
1670956 ALLEGRO_EDITOR     SKILL         axlIsLayerNegative() always returns nil
1687239 ALLEGRO_EDITOR     SKILL         Problem with skill function axlCNSGetPhysical - incorrect parse string
1692345 ALLEGRO_EDITOR     SKILL         The axlGetParm documentation example for deleting an artwork record is incorrect.
1707878 ALLEGRO_EDITOR     SKILL         Object rat_t does not work with axlDBPinPairLength.
1626716 ALLEGRO_EDITOR     UI_FORMS      Z-Copy menu is not available with OrCAD PCB designer Professional license
1588769 ALLEGRO_EDITOR     UI_GENERAL    Alt+key shortcuts are not available in release 17.2
1589396 ALLEGRO_EDITOR     UI_GENERAL    Option needed in release 17.2 to change the placement of the Find, Visibility, and Options tabs similar to releases 16.x
1598061 ALLEGRO_EDITOR     UI_GENERAL    Adjust menus to allow side by side view
1599901 ALLEGRO_EDITOR     UI_GENERAL    Color Dialog box is not updating according to visibility tab.
1602563 ALLEGRO_EDITOR     UI_GENERAL    Shortcuts to menu items not working in release 17.2
1603776 ALLEGRO_EDITOR     UI_GENERAL    Alt key not working with menu commands
1609794 ALLEGRO_EDITOR     UI_GENERAL    PCB Editor: Shortcut keys to menus are not available in release 17.2
1611293 ALLEGRO_EDITOR     UI_GENERAL    If the Command window is floating, it cuts off text from the bottom half of the last line.
1611516 ALLEGRO_EDITOR     UI_GENERAL    Keyboard shortcuts have no response
1611652 ALLEGRO_EDITOR     UI_GENERAL    New artwork film not appearing in the drop-down list for Visibility Tab
1614763 ALLEGRO_EDITOR     UI_GENERAL    Cannot scroll to the bottom of an undocked command window in PCB Editor
1617404 ALLEGRO_EDITOR     UI_GENERAL    axlUIMenuChange does not work as expected in release 17.2
1618205 ALLEGRO_EDITOR     UI_GENERAL    New Artwork film added is not updated in Visibility - View
1619873 ALLEGRO_EDITOR     UI_GENERAL    Command Window scrollbar does not reach its end
1624617 ALLEGRO_EDITOR     UI_GENERAL    Dialog box title under Setup > Outlines > Design Outline... Design is misspelled as "Desgin"
1624953 ALLEGRO_EDITOR     UI_GENERAL    Custom views in release 17.2 do not return to original
1631646 ALLEGRO_EDITOR     UI_GENERAL    Visibility pane not retaining the correct layer view
1633726 ALLEGRO_EDITOR     UI_GENERAL    Visibility tab not dynamically updating the view list when artwork film changes
1636864 ALLEGRO_EDITOR     UI_GENERAL    Domain Selection for Visibility does not work with Hotfix 004 unless you save and reopen the board file
1637062 ALLEGRO_EDITOR     UI_GENERAL    The last line of the floating command window in release 17.2 is hidden behind the command window frame
1642645 ALLEGRO_EDITOR     UI_GENERAL    Cannot scroll to the bottom of an undocked command window in PCB Editor
1645335 ALLEGRO_EDITOR     UI_GENERAL    PCB Editor crashes in Hotfixes 004 and 005 if ODE and Allegro Manufacturing options are installed
1646228 ALLEGRO_EDITOR     UI_GENERAL    Running the axlUIMenuInsert command to add a submenu after running the axlUIMenuFind command crashes the tool
1647520 ALLEGRO_EDITOR     UI_GENERAL    PCB Editor crashes after installing release 17.2 Hotfix 005
1647541 ALLEGRO_EDITOR     UI_GENERAL    Release 17.2 Hotfix 005: PCB Editor crashes immediately after launch
1650044 ALLEGRO_EDITOR     UI_GENERAL    Keyboard shortcuts are not working properly in release 17.2
1651912 ALLEGRO_EDITOR     UI_GENERAL    Inconsistent response when using the Alt key
1652423 ALLEGRO_EDITOR     UI_GENERAL    Using the F1 key does not display the help document
1654600 ALLEGRO_EDITOR     UI_GENERAL    Spelling Mistake in "Design Outline" dialog box, Setup->Outlines->Design Outline, misspelled as "Desgin"
1654777 ALLEGRO_EDITOR     UI_GENERAL    Reports UI does not work properly when writing a report file.
1655500 ALLEGRO_EDITOR     UI_GENERAL    Visibility selection ignored after color change
1655514 ALLEGRO_EDITOR     UI_GENERAL    Artwork Film is available in the View section only after you restart PCB Editor
1660200 ALLEGRO_EDITOR     UI_GENERAL    Symbol pin # box is unclear
1663819 ALLEGRO_EDITOR     UI_GENERAL    In release 17.2, SKILL function, axlOpenDesign(), does not work as expected
1670120 ALLEGRO_EDITOR     UI_GENERAL    In release 17.2, Static Phase meter shows up in the middle of the screen instead of the lower-right corner
1671334 ALLEGRO_EDITOR     UI_GENERAL    Design outline is not shown in 'World View' window
1671901 ALLEGRO_EDITOR     UI_GENERAL    Move command followed by object selection grays out or locks toolbar and menus
1672148 ALLEGRO_EDITOR     UI_GENERAL    Add option in release 17.2 to change the placement of the Find, Visibility, and Options tabs similar to earlier release
1673681 ALLEGRO_EDITOR     UI_GENERAL    F1 for Help not working in PCB Editor in release 17.2
1679418 ALLEGRO_EDITOR     UI_GENERAL    On choosing Edit - Move, the 'Symbol pin #' box is obfuscated
1679761 ALLEGRO_EDITOR     UI_GENERAL    Choosing Edit - Spin hides 'Symbol pin #' partially
1681514 ALLEGRO_EDITOR     UI_GENERAL    Opening the Dynamic Shapes State report hangs PCB Editor in release 17.2 Hotfix 009
1686887 ALLEGRO_EDITOR     UI_GENERAL    Hyper Text no longer selects coordinates for easy copy
1687286 ALLEGRO_EDITOR     UI_GENERAL    In 17.2 Hotfix 009, the Static Phase meter shows up in the middle of the screen instead of the lower-right corner
1692416 ALLEGRO_EDITOR     UI_GENERAL    Underscores in menu commands denoting shortcuts are missing in release 17.2
1693968 ALLEGRO_EDITOR     UI_GENERAL    Batch process that uses SKILL is taking too long to process files and generate reports
1702420 ALLEGRO_EDITOR     UI_GENERAL    Unable to maximize reports viewer in 17.2
1703065 ALLEGRO_EDITOR     UI_GENERAL    Menu shortcuts do not work as expected
1703107 ALLEGRO_EDITOR     UI_GENERAL    Scripting using regional settings for decimal separator
1707547 ALLEGRO_EDITOR     UI_GENERAL    Release 17.2: The Alt key function is not working in PCB Editor
1709280 ALLEGRO_EDITOR     UI_GENERAL    Alt+Function key not working in release 17.2.
1636097 ALLEGRO_EDITOR     ZONES         Technology Dependent Packaging footprints not updating in the design
1636185 ALLEGRO_EDITOR     ZONES         Import Placement not placing Technology Dependent Packaging (TDP) footprints in a zone
1639896 ALLEGRO_PROD_TOOLB CORE          MFG collector does not move files to subdirectories
1608804 ALTM_TRANSLATOR    DE_HDL        Translation issues in symbols with multiple physical pins mapping to a single logical function
1658525 ALTM_TRANSLATOR    DE_HDL        Invalid characters in pin names
1658536 ALTM_TRANSLATOR    DE_HDL        All cell names should be generated in lowercase letters
1609962 ALTM_TRANSLATOR    PCB_EDITOR    Errors reported during design translation
1649222 APD                ASSY_RULE_CHE Allegro Package Designer stops responding on running the Acute Angle Metal DRC
1661562 APD                DRC_CONSTRAIN The wrong space calculation on finger to trace
1623666 APD                OTHER         Incorrect vector pin syntax appears in the chips file written using 'RF Module - Export chips & connectivity'
1682398 APD                SHAPE         Deleting islands causes out of date shapes
1640611 APD                SKILL         Launching XtractIM from SiP Layout with the attached design crashes both SiP Layout and XtractIM
1638112 ASDA               CANVAS_EDIT   Unable to rename multiple selected buses using the 'Assign Name' command
1639409 ASDA               CANVAS_EDIT   When importing a DE-HDL design, the MAKE_BASE property should be removed from the nets
1645571 ASDA               CANVAS_EDIT   Various routing inconsistencies with synonym bodies on the canvas
1656336 ASDA               CANVAS_EDIT   Presence of illegal characters in the net name removes the entire net name
1667176 ASDA               CANVAS_EDIT   Unable to add the port symbol in a specific scenario
1641410 ASDA               CONSTRAINT_MA No errors or issues reported when incorrect topology is applied to a net or an Xnet
1641473 ASDA               CONSTRAINT_MA Importing a tech file into SDA makes the tool unresponsive
1645529 ASDA               CONSTRAINT_MA Unable to delete differential pairs on nets
1661350 ASDA               CONSTRAINT_MA Unable to create physical & spacing class from the docked CM
1653109 ASDA               DESIGN_CORRUP SDA not pulling latest library information for part
1661874 ASDA               DESIGN_CORRUP Unable to delete the ZERO part from the schematic page
1647673 ASDA               EXPORT_PCB    After installing release 17.2-2016 Hotfix 009, two folders named 'physical' are created for a design
1646086 ASDA               IMPORT_BLOCK  Importing a DE-HDL design into SDA results in error 'IMPSHT-42 Alias cannot be created'
1613559 ASDA               IMPORT_DEHDL_ Custom variables from the BOM Tables are not getting imported
1645557 ASDA               IMPORT_DEHDL_ Importing a DE-HDL design into SDA adds the COMMENT_BODY attribute to nets
1625209 ASDA               IMPORT_PCB    File Import from PCB Editor shows board differences
1647580 ASDA               IMPORT_PCB    SDA - File Import from PCB Editor has duplicated RefDes on schematic.
1652753 ASDA               MISCELLANEOUS Tcl command window should display correct casing for autocompleted command
1654973 ASDA               MISCELLANEOUS If there is a casing mismatch in the Tcl command name, correct command is not picked from the list
1652718 ASDA               PAGE_MANAGEME Page numbering on the page border does not update correctly when pages are moved, added, deleted
1699454 ASDA               TABLE         In the table object, cursor skips a cell on the first use of the TAB key
1702702 ASDA               TABLE         Copy-pasting table objects to a new page fills the headers and rows in black
1623113 ASI_SI             GUI           Aggressor waveforms are not displayed in the Waveform viewer after running a crosstalk simulation
1668877 CAPTURE            ANNOTATE      Using Ctrl+drag does not preserve the reference designator value
1665454 CAPTURE            NETGROUPS     Incremental copy for alias does not work anymore.
1681727 CAPTURE            NETGROUPS     In release 17.2, Capture crashes when closing a design that has assigned NetGroups
1667213 CAPTURE            NETLIST_ALLEG Tools - Create Netlist stops responding on Windows 10
1634598 CAPTURE            OTHER         The ‘OrCAD_Capture_CIS_option’ license not released even after selecting another product option
1636090 CAPTURE            OTHER         Capture crashes after switching from release 17.2 Hotfix 003 to 004 due to some Tcl files
1648575 CAPTURE            OTHER         The setting to suppress warnings must be added in the capture.ini file
1650029 CAPTURE            OTHER         Crash while archiving a newly created PSpice project without adding simulation profile
1659602 CAPTURE            OTHER         Saving CIS BOM via TCL command window
1678715 CAPTURE            OTHER         Capture.ini [WebResourcesMenu] is not working in release 17.2
1619449 CAPTURE            PROJECT_MANAG Search not working in a PSpice project
1643003 CAPTURE            PROJECT_MANAG Release 17.2-2016 Hotfix 005: The Start page shows incorrect release number of the latest release
1670133 CAPTURE            PROJECT_MANAG Start Page showing wrong Software Version
1670766 CAPTURE            PROJECT_MANAG autoreference does not work properly
1676095 CAPTURE            PROJECT_MANAG (SID:22758) OrCAD Capture Start Page reporting wrong hotfix installed
1610377 CAPTURE            PROPERTY_EDIT Discrepancies between the NET_SPACING_TYPE property (or any other property) text and the actual property
1658315 CAPTURE            TCL_INTERFACE Inserting text with double quotes is not working as expected in PDF created from Capture
1642601 CIS                OTHER         Design Entry CIS: SQL server password is required each time the tool is launched
1592026 CIS                VIEW_DATABASE View database part does not work from schematic pages of an externally referenced design
1665918 CONCEPT_HDL        CHECKPLUS     Error (100) Program Internal Error 'Create_flat_node' with checkplus run
1622715 CONCEPT_HDL        CONSTRAINT_MG Extracting an XNet crashes DE-HDL
1642012 CONCEPT_HDL        CONSTRAINT_MG Schematic-defined net groups without any members cannot be deleted in Constraint Manager
1684117 CONCEPT_HDL        CONSTRAINT_MG Property deleted from Constraint Manager is not getting updated in the DE-HDL canvas
1712279 CONCEPT_HDL        CONSTRAINT_MG Differential pairs are dropped from Net Classes when upreved to release 17.2-2016
1665449 CONCEPT_HDL        COPY_PROJECT  Copy project fails with error COPYPROJ-77
1582276 CONCEPT_HDL        CORE          Need the ability to delete an image placed on the DE-HDL canvas
1594101 CONCEPT_HDL        CORE          No error or warning issued on specifying an incorrect unit for voltage
1623231 CONCEPT_HDL        CORE          Unable to make the Attributes form part of the standard display in DE-HDL
1632504 CONCEPT_HDL        CORE          DE-HDL core dumps during Save Hierarchy on Linux
1642015 CONCEPT_HDL        CORE          Pin exists on block but no corresponding port exists in the underlying schematic
1649829 CONCEPT_HDL        CORE          Project Manager:  A delay is observed before the submenus of the File and Tools menus appear
1659097 CONCEPT_HDL        CORE          Mouse strokes are not enabled on startup in the Pre-select mode
1659532 CONCEPT_HDL        CORE          Need csa files when Import Design command is used with the CONFIRM_WRITE directive
1661778 CONCEPT_HDL        CORE          Advanced Find will not find pins with the SIG_NAME property attached
1666084 CONCEPT_HDL        CORE          All user-defined properties are not listed in the Customize columns in Variant Editor
1667043 CONCEPT_HDL        CORE          Incorrect information in cpm.log file
1670659 CONCEPT_HDL        CORE          SIGNAME text off grid when pasting copy using ctrl+v.
1697732 CONCEPT_HDL        CORE          Warning (SPCOCN-922): The object is being placed towards the left edge of the schematic. Ensure that the objects are pla
1697955 CONCEPT_HDL        CORE          Rename Signal places sig_name at an incorrect position for an unnamed net
1711635 CONCEPT_HDL        CORE          The arrow keys do not work as expected in Windows mode
1713091 CONCEPT_HDL        CORE          Difference in the behavior of 'Add Signal Name' in DE-HDL between releases 16.6 and 17.2
1599843 CONCEPT_HDL        INTERFACE_DES Moving end part of a NetGroup adds extra elements
1632977 CONCEPT_HDL        INTERFACE_DES Connectivity error when moving NetGroup members
1659644 CONCEPT_HDL        OTHER         Predefined nets are not listed if a design from release 16.6 is opened in release 17.2.
1708820 CONCEPT_HDL        OTHER         In a board cache flow, component bodies are missing when importing another board cached flow project.
1670082 CONSTRAINT_MGR     ANALYSIS      Inconsistency in Constraint Analysis Modes - Electrical in OrCAD PCB Designer Professional in release 17.2-2016
1609817 CONSTRAINT_MGR     CONCEPT_HDL   DE-HDL crashes on opening project
1623888 CONSTRAINT_MGR     CONCEPT_HDL   Ambiguous and inaccurate mapping errors reported when an ECSet is applied to a differential pair object
1636404 CONSTRAINT_MGR     CONCEPT_HDL   Release 17.2 Hotfix 004: In DE-HDL Constraint Manager, invalid voltage units are allowed without any error or warning
1639928 CONSTRAINT_MGR     CONCEPT_HDL   The '-filterFile' argument is not recognized when cmDiffUtility is run as a command line operation
1649060 CONSTRAINT_MGR     CONCEPT_HDL   Renaming dcfx to dcf does not update the dcf file and results in an error in the log file
1657048 CONSTRAINT_MGR     CONCEPT_HDL   Unable to navigate through the search results in the CM Reports
1661307 CONSTRAINT_MGR     CONCEPT_HDL   Prevent creation of differential pairs on VOLTAGE nets
1682447 CONSTRAINT_MGR     CONCEPT_HDL   Extraction issue on differential pairs in design
1682454 CONSTRAINT_MGR     CONCEPT_HDL   If a design with NO_XNET_CONNECTION property on parts is exported to PCB Editor, many other components get the property
1718073 CONSTRAINT_MGR     CONCEPT_HDL   ECSet mapping errors on an upreved design in release 17.2: Pins in XNet and CSet do not match
1717336 CONSTRAINT_MGR     DATABASE      Netclass members change during logic import; it's a toggle switch
1718514 CONSTRAINT_MGR     ECS_APPLY     Extracted topology does not use the PINUSE overrides specified on the canvas
1682885 CONSTRAINT_MGR     INTERACTIV    Constraint Manager worksheet switching does not work correctly in Linux
1625163 CONSTRAINT_MGR     OTHER         Status indicator for the Analyze command is missing in Constraint Manager in release 17.2
1628357 CONSTRAINT_MGR     OTHER         Constraint Manager shows differences if exporting and importing the same constraints on the same board
1631114 CONSTRAINT_MGR     OTHER         SKILL functions axlCnsPurgeAll and axlCNSDelete delete spacing constraint sets but not deleting names
1639541 CONSTRAINT_MGR     OTHER         In release 17.2, PCB Editor crashes when updating Constraint Manager
1669523 CONSTRAINT_MGR     OTHER         Select is disabled in Constraint Manager when a command is active in PCB Editor
1670802 CONSTRAINT_MGR     OTHER         Selecting a list of nets using the shift key does not work in Spacing and Physical domain
1670922 CONSTRAINT_MGR     OTHER         Title of the Layer Remove window is Constraint Manager
1678235 CONSTRAINT_MGR     OTHER         Select option grayed out in Constraint Manager if a command is active in PCB Editor
1680917 CONSTRAINT_MGR     OTHER         In release 17.2, nets cannot be selected in Constraint Manager when a PCB Editor command is active
1691125 CONSTRAINT_MGR     OTHER         Highlight command no longer selects the net in CM
1703791 CONSTRAINT_MGR     OTHER         Cross highlighting and assigning color to nets between PCB Editor and CM does not work
1649603 CONSTRAINT_MGR     UI_FORMS      Expand and Collapse commands do not work when multiple objects are selected
1654931 CONSTRAINT_MGR     UI_FORMS      Expand, collapse only works on one of the multiple selected objects.
1660475 CONSTRAINT_MGR     UI_FORMS      In release 17.2, the CTRL+V shortcut is not working in the Export Constraints window in Constraint Manager.
1668794 CONSTRAINT_MGR     UI_FORMS      Incorrect via name shown when filtering via list
1678305 CONSTRAINT_MGR     UI_FORMS      Unable to use the CM worksheet customization (wcfx) from the CDS_SITE area
1679909 CONSTRAINT_MGR     UI_FORMS      Incorrect layer order getting saved when defining BB vias in Constraint Manager PCSet
1691906 CONSTRAINT_MGR     UI_FORMS      Display Issue: When you use the filters, the horizontal scroll bars are duplicated
1606682 ECW                ADMINISTRATIO ECWBackup and ECWRestore fail when data is 1GB or more
1677893 ECW                INTEGRATION   Integrations list update is not working as per scheduled time
1652707 ECW                METRICS       Incorrect date and time displayed in mouseover tooltip on the Metric Trend chart
1654512 ECW                METRICS       Incorrect date and time displayed in mouseover tooltip on the Metric Trend chart
1668953 ECW                METRICS       IE11 Swedish only: Incorrect date and time displayed in mouseover tooltip on the Metric Trend chart
1677443 ECW                METRICS       Queued up metric packets on Pulse server are not processed if there are any packets related to a deleted project
1666723 ECW                TDO-SHAREPOIN TDO login is not working with Site Minder because of incorrect characters in the Site Minder login form HTML
1683919 ECW                TDO-SHAREPOIN Site Minder integration for login from TDA not working after SSL certificate update
1632844 F2B                DESIGNVARI    Part is simultaneously defined as Pref and DNI in Variant Editor with no error
1669828 F2B                DESIGNVARI    Variant Editor crashes on some Windows 10 systems
1644131 F2B                PACKAGERXL    Option needed to package a DE-HDL design with PTF errors into a board file
1663676 F2B                PACKAGERXL    Physical net name (PNN) errors in the log file
1655377 FLOWS              PROJMGR       Project Manager crashes at launch on Windows 10
1621390 GRE                CORE          Design crashes during the Spatial Planning phase
1669583 GRE                DETAIL        AiDT always fails push when there is a connect shape attached to the cline being tuned
1648817 GRE                IFP_INTERACTI Allegro PCB Editor stops responding on adding netgroups to a nested netgroup
1704353 INSTALLATION       DOWNLOAD_MGR  Selecting 'View' in Download Manager results in error: 'Object Reference not set to an instance of an object'
1686350 INSTALLATION       SPB           InstallDiagnose fails to repair some errors
1619610 ORBITIO            ALLEGRO_SIP_I Some mechanical pins appear rotated by 90 degrees when imported
1630458 ORBITIO            ALLEGRO_SIP_I Import OrbitIO Database file (.oio) in SiP: Bill of Materials report does not include standard dies
1635593 ORBITIO            ALLEGRO_SIP_I Importing  .sip file reports undefined argument error while processing shapes
1672369 PCB_LIBRARIAN      EXPLORER      Cannot create a New library build in Library Explorer.
1634392 PCB_LIBRARIAN      OTHER         Launching Library Explorer without -proj option makes it crash
1670811 PSPICE             AA_MC         Advanced Analysis MC plot window options need to be changed
1626647 PSPICE             ENVIRONMENT   Capture crashes when loading a design with two hyphens in sim profile name
1631034 PSPICE             ENVIRONMENT   When simulating the design in release 17.2, Capture crashes but works with release 16.6
1648284 PSPICE             ENVIRONMENT   PSpice project crashes when a design is opened in release 17.2
1663336 PSPICE             MODELEDITOR   Ibis translation not supporting paths with spaces
1647402 PSPICE             PROBE         Unable to print on Windows 10 as no plots are displayed in the Probe window
1678061 PSPICE             SLPS          Simulating an SLPS co-simulation with a Fixed-step solver with a value lower than 1E-4 results in a crash
1631792 SCM                OTHER         The NC net has re-attached itself to another net, RIGHT_LEFT_N, in the design
1632195 SCM                OTHER         'No known page border found' error in cref.log
1679376 SIG_EXPLORER       OTHER         Topology created in OrCAD PCB SI license cannot be reopened with the same license
1626546 SIG_INTEGRITY      FIELD_SOLVERS Extra RL elements in via spice circuit model generated by Via Model Generator
1682312 SIG_INTEGRITY      LICENSING     Allegro Sigrity SI/PI Product Choices window is blank after installing release 17.2 Hotfix 009
1666484 SIP_LAYOUT         CROSS_SECTION On converting a design from release 16.6 to release 17.2, a Dielectric thickness of ‘0.2032’ is added to another layer.
1643557 SIP_LAYOUT         DIE_GENERATOR The dies in the design are not updated on importing die text files
1687988 SIP_LAYOUT         DIE_GENERATOR 'compose die from geometry' does not retain the user-defined padstack name
1715016 SIP_LAYOUT         DIE_GENERATOR Using Die Text-In wizard to replace a die reconnects wire bonds to the wrong die in stack-up
1593404 SIP_LAYOUT         EDIT_ETCH     Slide command moves via toward the object
1641435 SIP_LAYOUT         IMPORT_DATA   Need SiP Stream mapping layer count to match Virtuoso stream layer mapping count
1620601 SIP_LAYOUT         MANUFACTURING Need the ability to create LINES with round end caps in the same way as the LINES appear in the database
1638094 SIP_LAYOUT         OTHER         Cross Section Editor not reading updated information
1647098 SIP_LAYOUT         OTHER         Cadence SIP RF Layout GXL crashes when a symbol is copied and rotated 90 degrees
1705963 SIP_LAYOUT         PADSTACK_EDIT Pad Designer: "None" changing spontaneously into "Circle 0.000" in a pad stack definition and unable to save
1713767 SIP_LAYOUT         REPORTS       Reports in release 17.2 for the Verilog Port Name are adding incorrect data that was not found in release 16.6
1696218 SIP_LAYOUT         SKILL         SiP Layout crashes on reassigning nets
1712964 SIP_LAYOUT         SYMB_EDIT_APP SiP Layout crashes when using Renumber Pins in Symbol Edit application mode
1695885 SIP_LAYOUT         UI_GENERAL    Visibility Tab check box: unchecked "All" disables access to "Shp" check box
1623823 SIP_LAYOUT         WIREBOND      NO_WIREBOND property is ignored by Add/Edit Non-Standard
1641483 SIP_LAYOUT         WIREBOND      SiP Layout - Modify the wirebond report generation for Start and End height when using a DISCRETE class footprint
1639838 SIP_RF             DIEEXPORT     Enhance the error message, SIP-1507, to include that overlapping pins within tolerance are included during die export
1653894 SIP_RF             DIEEXPORT     Redundant error message for die export, when view name is other than "layout"
1681332 SIP_RF             OTHER         Running die export causes Virtuoso to crash
1679336 SPECCTRA           LICENSING     Min/Max Propagation Delay cannot be routed by PCB Router using OrCAD PCB Designer Professional
1641879 XTRACTIM           GUI           XtractIM crashes on extracting a SiP design if 'SI Ignore' is selected for a die stack layer in Cross Section Editor
вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: 017
Fixed CCRs: SPB 17.2 HF017
04-13-2017
1732877 ALLEGRO_EDITOR     SKILL         axlXSectionGet fails in 17.2 HF016
вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: 018
Fixed CCRs: SPB 17.2 HF018
04-23-2017
1721773 ADW                ADW_UPREV     adw_uprev updates all versions in history log to the new version. Should only insert note about uprev.
1684346 ADW                LIBDISTRIBUTI lib_dist_client fails for new release 17.2-2016 design server
1696632 ADW                LIBDISTRIBUTI lib_dist_client fails on release 17.2 Designer Server having release 16.6 Master Server
1705224 ADW                LIBDISTRIBUTI Cannot migrate Library Footprint Models having subdirectory to release 17.2-2016
1721017 ADW                LIBDISTRIBUTI adwserver -install fails intermittently during Master Library Server or MLR distribution
1711373 ALLEGRO_EDITOR     COLOR         Cannot interact with Allegro PCB Editor when Color dialog is open
1725621 ALLEGRO_EDITOR     DATABASE      PCB Editor crashes when moving a group of components or clines
1699796 ALLEGRO_EDITOR     EDIT_ETCH     AiDT fails and reports there are no timing constraints even when propagation delay is set
1726483 ALLEGRO_EDITOR     EDIT_ETCH     PCB Editor crashing when converting corners to arcs
1726678 ALLEGRO_EDITOR     INTERFACES    IDX copper layer export does not export all pin pads
1691036 ALLEGRO_EDITOR     MANUFACT      Fillet not centered on trace
1732304 ALLEGRO_EDITOR     MANUFACT      Countersink does not have drill figure on NCCOUNTERDRILL-1 subclass
1719564 ALLEGRO_EDITOR     OTHER         Cannot open PDF published in release 17.2-2016 in third-party software
1723065 ALLEGRO_EDITOR     OTHER         PDF out does not print the outline correctly
1729247 ALLEGRO_EDITOR     OTHER         Cannot delete shape on Route Keepout layer
1722747 ALLEGRO_EDITOR     PAD_EDITOR    Option to enable 'Connect by Touch' in Pad Editor
1731643 ALLEGRO_EDITOR     PAD_EDITOR    Changes to secondary drill are not saved on padstack update
1727303 ALLEGRO_EDITOR     REPORTS       The 'Shape Dynamic State' report has changed to 'Shape Dynamic Status' in release 17.2-2016
1695879 ALLEGRO_EDITOR     SHAPE         Dynamic shape priority error creates shorts.
1713014 ALLEGRO_EDITOR     SHAPE         Incorrect behavior of donut shaped pads at certain rotations
1647271 ALLEGRO_EDITOR     UI_GENERAL    Preselection is not working for docked Find window
1679964 ALLEGRO_EDITOR     UI_GENERAL    Many dialog boxes are blurred in Allegro PCB Editor
1693055 ALLEGRO_EDITOR     UI_GENERAL    Reports with html links end with an extra > at the end
1698840 ALLEGRO_EDITOR     UI_GENERAL    In release 17.2-2016 Waive DRC report, selected coordinates of a Waived DRC remain blue
1711203 ALLEGRO_EDITOR     UI_GENERAL    Color does not change for selected coordinates in reports and Show Element
1711724 ALLEGRO_EDITOR     UI_GENERAL    In release 17.2-2016, custom interactive menus stop responding when invoking another custom command
1715613 ALLEGRO_EDITOR     UI_GENERAL    With undocked Options window there is a mix up of entered text and funckey
1719301 ALLEGRO_EDITOR     UI_GENERAL    Selected coordinates do not change color in reports and Show Element
1724197 ALLEGRO_EDITOR     UI_GENERAL    Short cuts and hot keys not working in PCB Editor in release 17.2-2016
1728724 ALLEGRO_EDITOR     UI_GENERAL    Funckey is not working in release 17.2-2016
1673703 ALLEGRO_PROD_TOOLB OTHERS        Design compare not reporting the Top and Bottom layer differences
1704474 ALLEGRO_PROD_TOOLB OTHERS        When using Productivity Toolkit - PCB Design Compare, 'Override undefined width' is incorrectly applied
1571035 ALTM_TRANSLATOR    CAPTURE       Circles in third-party schematics not getting translated into Capture
1588911 ALTM_TRANSLATOR    CAPTURE       Capture crashes when translating, project and libraries are empty
1589394 ALTM_TRANSLATOR    CAPTURE       Schematic getting shifted off the page after translation
1631294 ALTM_TRANSLATOR    CAPTURE       Errors while translating third-party design when original design is in metric units
1663176 ALTM_TRANSLATOR    CAPTURE       Only first sheet of design getting translated from third-party schematic into Capture
1694363 ALTM_TRANSLATOR    CAPTURE       Capture is unable to translate third-party designs
1539739 ALTM_TRANSLATOR    CORE          Capture crashes on importing a third-party project
1542860 ALTM_TRANSLATOR    CORE          Capture crashes on clicking Translate after selecting a third-party design
1551642 ALTM_TRANSLATOR    CORE          Unable to import third-party schematics into Capture
1572929 ALTM_TRANSLATOR    CORE          Footprint names getting altered during translation
1568436 ALTM_TRANSLATOR    PCB_EDITOR    Unable to translate third-party layout data into PCB Editor
1629256 ALTM_TRANSLATOR    PCB_EDITOR    Getting empty symbol and devices folders when importing into PCB Editor
1664120 ALTM_TRANSLATOR    PCB_EDITOR    Import from third-party to PCB Editor is not translating data correctly
1701537 ALTM_TRANSLATOR    PCB_EDITOR    Import does not complete and reports errors
1698706 APD                DIE_GENERATOR When using Compose Symbol from Geometry, circle from DXF cannot generate to pin
1714528 APD                DIE_GENERATOR Getting 'illegal pad pointer' warning when creating die from geometry
1714532 APD                DIE_GENERATOR Compose Die from Geometry creates incorrect pad shapes
1734310 APD                MULTI_USER    Symphony server mode malfunctions when die layer present.
1725506 APD                SHAPE         In release 17.2-2016 Hotfix 015, void is not generated in Artwork for BC7 layer causing short
1724395 APD                WIREBOND      Running axlBondWireDelete returns error message
1726609 ASDA               CANVAS_EDIT   Paste should not be allowed in the Current Refdes column of the Change Refdes form
1719754 CONCEPT_HDL        ARCHIVER      Path stored in the compressed file starts from /home instead of the current working directory
1726570 CONCEPT_HDL        CHECKPLUS     Checkplus crashes on Windows 10
1697977 CONCEPT_HDL        CONSTRAINT_MG Differential pair disappears when it is packaged
1679575 CONCEPT_HDL        CORE          Page numbers are duplicated in Hierarchy Viewer when editing page names
1697732 CONCEPT_HDL        CORE          Pasting a signal name results in warning (SPCOCN-922) if the wire is too close to the edge of the page border
1711564 CONCEPT_HDL        CREFER        CRefer crashes while processing a hierarchical design containing subdesigns
1730736 CONCEPT_HDL        OTHER         Crash on generating BOM from design
1608350 CONSTRAINT_MGR     CONCEPT_HDL   Name of buffer model is not passed from Constraint Manager of DE-HDL to SigXplorer
1715803 CONSTRAINT_MGR     CONCEPT_HDL   Extract a net from constraint manager to SigXplorer, the models assigned are not displayed in SigXplorer
1720886 CONSTRAINT_MGR     CONCEPT_HDL   SigXplorer does not extract assigned model from the schematic
1722306 GRE                CORE          Boards with Total Etch Length constraint only should not include z-axis when budgeting pin pairs
1710049 PSPICE             SIMULATOR     Functions are not taking parameters in correct order
1693021 SIG_INTEGRITY      OTHER         PINUSE is not updated correctly at model assignment with specific steps
1730854 SIP_LAYOUT         SYMB_EDIT_APP Cannot delete all the die pin from a symbol using the Symbol Edit application mode
вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: 019
Fixed CCRs: SPB 17.2 HF019
05-6-2017
1701785 ADW                ADWSERVER     Getting 'Unable to locate tools.jar' error while using 'Copy Projects'
1706782 ADW                ADW_UPREV     Design uprev failed with error 'ERROR (FM-107): Failed to run adw_uprev'
1508159 ADW                FLOW_MGR      Flow Manager 'Open Last Project' option points to a deleted project
1690903 ADW                FLOW_MGR      Flow Manager library project list empty after 'Remove From List'
1672037 ALLEGRO_EDITOR     EDIT_ETCH     Add ZigZag Pattern crashes PCB Editor
1695711 ALLEGRO_EDITOR     EDIT_ETCH     In release 17.2-2016, Fiber Weave Effect - Add ZigZag Pattern crashes in Windows 10
1706522 ALLEGRO_EDITOR     INTERFACES    DFX import displays error message '*Error* eval: undefined function - cloneID' but imports outline
1716336 ALLEGRO_EDITOR     INTERFACES    DXF file is not correctly imported into PCB Editor
1720290 ALLEGRO_EDITOR     INTERFACES    Incorrect rotation of padstack after dxf import
1724683 ALLEGRO_EDITOR     INTERFACES    DXF OUT: incorrect Rounded/Chamfered rectangle pad rotation
1732587 ALLEGRO_EDITOR     INTERFACES    Format/content of ipc356 files exported in release 17.2-2016 different from release 16.6
1737516 ALLEGRO_EDITOR     INTERFACES    IDX Import works differently for placed and unplaced parts
1715152 ALLEGRO_EDITOR     SCRIPTS       Clicking Layout in Project Manager fails to load PCB Editor and gives message 'Word too long'
940699  ALLEGRO_EDITOR     SHAPE         Update shape to smooth fails to void a few clines.
1706581 ALLEGRO_EDITOR     SHAPE         Dynamic shape void clearance errors with vias
1638300 ALLEGRO_EDITOR     UI_GENERAL    Version information set in $cdsversion truncated on title bar for some tools
1729510 CONCEPT_HDL        CORE          Changing the name of a split block adds pages that are part of the page gaps
1721065 CONSTRAINT_MGR     CONCEPT_HDL   Physical import errors on changing plane to conductor in stack-up
1734875 CONSTRAINT_MGR     OTHER         'Create Spacing CSet' crashes tool from existing CSet context and grayed out in design context
1473104 ECW                PART_LIST_MAN Pulse does not filter capacitor values correctly
1736580 PCB_LIBRARIAN      SYMBOL_EDITOR Grids are not displayed correctly in Symbol Editor
1738955 PCB_LIBRARIAN      SYMBOL_EDITOR Need ability to edit Symbol Properties
1735215 PSPICE             FRONTENDPLUGI PSpice part search customization CDN_PSPICE_ODBC_SRC environment variable is not working
1733198 PSPICE             PROBE         Probe crashes when exporting trace expressions with multiple plots to CSV files
1737060 SIG_INTEGRITY      SIGNOISE      signoise fails for the AllegroSigrity_HS_Base_Suite option in release 17.2-2016 and release 16.6-2015
1707443 SIP_LAYOUT         WIREBOND      Moving bondfingers violates spacing constraint
вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: 020
Fixed CCRs: SPB 17.2 HF020
05-21-2017
1737443 ADW                DBEDITOR      Revising the schematic model classification for one category causes all parts in the library to be revised
1734123 ALLEGRO_EDITOR     3D_CANVAS     Interactive 3D canvas crashes Allegro PCB Designer in 17.2 S016
1742084 ALLEGRO_EDITOR     DATABASE      Running DB Doctor on DRA files with custom pad shapes resets some of the custom padstack shapes in release 17.2
1739397 ALLEGRO_EDITOR     INTERACTIV    In release 17.2, running the SKILL function axlImportXmlDBRecords causes Allegro PCB Editor to crash
1724588 ALLEGRO_EDITOR     MANUFACT      Backdrill Route keepout suppressing existing Route Keepouts
1740036 ALLEGRO_EDITOR     MANUFACT      Generating the cross-section chart does not provide information about the overall board thickness
1743726 ALLEGRO_EDITOR     OTHER         IDF file export: In release 17.2, only one design outline is exported as against multiple board outlines in release 16.6
1744467 ALLEGRO_EDITOR     OTHER         The 'logical_op_new' variable is not displayed in User Preferences Editor
1729350 ALLEGRO_EDITOR     REPORTS       Net loop report is not working.
1739870 ALLEGRO_EDITOR     SHAPE         The artwork is different from the PCB in release 17.2 Hotfix 17
1698869 ALLEGRO_EDITOR     SKILL         PCB Editor crashes when trying to open another .brd file after running SRM on first .brd file
1739307 ALLEGRO_EDITOR     SKILL         axlCNSDFAExport fails after first run
1743385 ALLEGRO_EDITOR     SKILL         SKILL APIs for STEP model mapping are not available in release 17.2 Hotfix 17 or 18
1685826 ALLEGRO_EDITOR     UI_GENERAL    Reports when opened from Status Form disappear behind PCB Editor canvas when clicking on canvas
1687797 ALLEGRO_EDITOR     UI_GENERAL    Cannot open two HTML windows, one after the other, while using SKILL function
1696229 ALLEGRO_EDITOR     UI_GENERAL    Setting the 'allegro_html' environment variable in User Preferences Editor overwrites existing popup text windows
1708636 ALLEGRO_EDITOR     UI_GENERAL    In SPB 17.2 release, keyboard focus automatically shifts to the newly opened dialog box
1711367 ALLEGRO_EDITOR     UI_GENERAL    Launching two report windows using SKILL is not working in 17.2
1742856 ALLEGRO_EDITOR     UI_GENERAL    Allegro PCB Editor crashes if Project Manager is open for a design in release 17.2 Hotfix 18
1729519 APD                SHAPE         shape degassing does not generate all voids to cover entire shape
1711375 CONCEPT_HDL        CORE          Copy-paste of schematic between two instances of DE-HDL is not working as expected
1737230 CONCEPT_HDL        CORE          On the Linux platform, copying of schematic objects does not work between designs of releases 16.6 and 17.2
1741375 CONCEPT_HDL        CORE          Inconsistent behavior of the Move command when moving a symbol
1743992 CONCEPT_HDL        CORE          Inconsistent behavior of the Move command when moving a symbol
1736093 CONSTRAINT_MGR     CONCEPT_HDL   Incorrect topology extraction and mapping errors related to MUX parts
1743518 CONSTRAINT_MGR     CONCEPT_HDL   Lag observed in expanding and collapsing the net classes in Constraint Manager
1730159 FSP                ALLEGRO_INTEG FSP diff engine does not read PF Thevenin connections in FSP
1664070 ORBITIO            ALLEGRO_SIP_I Display pads of SMD components on correct layer
1709319 ORBITIO            USABILITY     OrbitIO issues an error about Device template while importing brd with Bundles
1741150 PSPICE             ENVIRONMENT   Need a way to prevent the 'pspSimSetting.js' file from being overwritten by a hotfix installation in 17.2
1735354 PSPICE             SIMULATOR     Access to custom nom.lib is not working as expected
1716523 SIP_LAYOUT         COLOR         Tool crashes on using the PageUp, PageDown, and Tab keys in the Color dialog box.
вышел хотфикс OrCAD/Allegro 17.2, HOTFIX VERSION: 021
Fixed CCRs: SPB 17.2 HF021
06-3-2017
1401318 ADW                DBEDITOR      Bulk Edit - Previously modified cells do not turn blue when selected
1621446 ADW                DBEDITOR      Bulk Edit - sorting highlights incorrect cells to mark them as changed
1743997 ADW                LIB_FLOW      Match file for standard models is incorrect
1746052 ALLEGRO_EDITOR     DATABASE      PCB Editor crashes when applying no drc property
1736067 ALLEGRO_EDITOR     DRC_CONSTR    Interlayer checks not reporting DRCs between cline and mask layer
1738587 ALLEGRO_EDITOR     EDIT_ETCH     Line width changing on slide for ETCH - Conductor (Not on a NET)
1745277 ALLEGRO_EDITOR     EDIT_ETCH     PCB Editor crashes on using the slide command
1747942 ALLEGRO_EDITOR     EXTRACT       Fabmaster Out does not export arc in pad_shape
1737202 ALLEGRO_EDITOR     GRAPHICS      Setting the variable display_raster_ops
1744042 ALLEGRO_EDITOR     GRAPHICS      Unused pad suppression is not working on few nets
1703848 ALLEGRO_EDITOR     INTERFACES    IPC 2581 fails with error 'E- (SPMHGE-268)' and the log file is empty
1743899 ALLEGRO_EDITOR     MANUFACT      Glossing dangling vias crashes PCB Editor
1748520 ALLEGRO_EDITOR     OTHER         TDP fails to load on an empty database
1748581 ALLEGRO_EDITOR     PAD_EDITOR    Padstack Editor crashes when changing default pad geometry
1751469 ALLEGRO_EDITOR     PAD_EDITOR    Padstack Editor crashes/freezes when browsing for a shape symbol
1725948 ALLEGRO_EDITOR     SHAPE         Shape differences after conversion from release 16.6 to release 17.2-2016
1729306 ALLEGRO_EDITOR     SHAPE         Seting shape_rki_autoclip variable causes no void to be generated
1698876 ALLEGRO_EDITOR     UI_GENERAL    Tabs are large and text is compressed in release 17.2-2016
1698883 ALLEGRO_EDITOR     UI_GENERAL    In release 17.2-2016, enlarging icons makes selection boxes/text unreadable on 4K monitors
1707933 ALLEGRO_EDITOR     UI_GENERAL    axlUIMenuFind not locating menu as per x_location
1741460 ALLEGRO_EDITOR     UI_GENERAL    Right-click, context menu options grayed in some cases after choosing Edit - Copy
1747588 ALLEGRO_EDITOR     UI_GENERAL    Interacting with PCB Editor by sending messages is not working
1747488 APD                EDIT_ETCH     Route connect is improperly affecting existing routes in locked high speed via structures
1750182 APD                STREAM_IF     The stream out settings are not saved
1752067 ASI_SI             GUI           Links to differential waveforms do not work in Sigrity SI report
1752131 CONCEPT_HDL        COMP_BROWSER  Symbol view in part manager doesn't match the symbol version
1754116 CONCEPT_HDL        COMP_BROWSER  Default Symbol selected is n°2 instead of n°1 in component Browser
1754949 CONCEPT_HDL        COMP_BROWSER  Part Information Manager displays preview window with the wrong symbol and missing footprint
1721334 CONCEPT_HDL        CORE          dsreportgen not able to resolve gated part on schematic
1750916 CONCEPT_HDL        CORE          DE-HDL crashes when trying to uprev a project in release 17.2-2016
1711487 CONCEPT_HDL        INFRA         Restrict opening of release 16.6 designs from a release 17.2-2016 design using File - View Design
1746915 CONSTRAINT_MGR     CONCEPT_HDL   Unable to copy a Physical and Spacing CSet generated from the Constraint Automation flow
1743523 CONSTRAINT_MGR     DATABASE      Suppress warning pop-ups from the constraint automation script
1746941 CONSTRAINT_MGR     UI_FORMS      'Go to Source' from DRC tab is not working in release 17.2-2016
1753010 ECW                METRICS       Metrics not getting collected due to old license in use
1713052 FSP                GUI           Pin/Port Name and Group Name are not aligned properly in FPGA Port and Use Pin Mapping for DeviceInstance
1719099 FSP                GUI           Net naming wrong after building block
1719105 FSP                GUI           Tabular sorting not working in FPGA System Planner
1720479 PSPICE             ENVIRONMENT   Probe window does not open consistently on Windows 10 systems
1723411 PSPICE             ENVIRONMENT   Probe window does not open consistently on Windows 10 systems
1746628 PSPICE             ENVIRONMENT   PSpice Simulation Manager displays same message for all simulations in release 17.2-2016, Hotfix 016
1745976 SIG_INTEGRITY      GEOMETRY_EXTR Arcs with coplanar waveguides are extracted with incorrect spacing
1690820 SIP_LAYOUT         PLATING_BAR   Cannot add fillets to pads with plating bars in release 17.2-2016
1725042 SIP_LAYOUT         PLATING_BAR   Creating a plating bar removes dynamic fillets
1747534 SIP_LAYOUT         SHAPE         Moving fiducial crashes SiP Layout
