ArtDenis 0 November 24, 2014 Posted November 24, 2014 (edited) · Report post Может уже обсуждалось. Как побороть ошибку билда кикада под 7-й виндой (с помощью KiCadWinbuilder): -- Checking for GLEW -- Downloading You have not informed bzr of your Launchpad ID, and you must do this to write to Launchpad or access private data. See "bzr help launchpad-login". bzr: ERROR: exceptions.UnicodeEncodeError: 'ascii' codec can't encode characters in position 34-43: ordinal not in range(128) Traceback (most recent call last): File "bzrlib\commands.pyo", line 930, in exception_to_return_code File "bzrlib\commands.pyo", line 1141, in run_bzr File "bzrlib\commands.pyo", line 673, in run_argv_aliases File "bzrlib\commands.pyo", line 697, in run File "bzrlib\cleanup.pyo", line 136, in run_simple File "bzrlib\cleanup.pyo", line 166, in _do_with_cleanups File "bzrlib\builtins.pyo", line 1649, in run File "bzrlib\branch.pyo", line 1463, in create_checkout File "bzrlib\bzrdir.pyo", line 906, in create_workingtree File "bzrlib\workingtree_4.pyo", line 1565, in initialize File "bzrlib\transform.pyo", line 2535, in build_tree File "bzrlib\transform.pyo", line 2590, in _build_tree File "bzrlib\progress.pyo", line 116, in update File "bzrlib\ui\text.pyo", line 374, in _progress_updated File "bzrlib\ui\text.pyo", line 554, in show_progress File "bzrlib\ui\text.pyo", line 536, in _repaint File "bzrlib\ui\text.pyo", line 440, in _show_line UnicodeEncodeError: 'ascii' codec can't encode characters in position 34-43: ordinal not in range(128) bzr 2.6b1 on python 2.6.6 (Windows-7-6.1.7601-SP1) arguments: ['bzr', 'co', '--lightweight', 'lp:glew-cmake', 'glew-cmake'] plugins: bzrtools[2.5.0], changelog_merge[2.6b1], colo[0.4.0], explorer[1.3.0dev], fastimport[0.14.0dev], git[0.6.8dev], launchpad[2.6b1], loom[2.3.0dev], netrc_credential_store[2.6b1], news_merge[2.6b1], pipeline[1.4.0], qbzr[0.23.0dev], rewrite[0.6.4dev], svn[1.2.2dev], upload[1.2.0dev], xmloutput[0.8.8] encoding: 'cp1251', fsenc: 'mbcs', lang: None *** Bazaar has encountered an internal error. This probably indicates a bug in Bazaar. You can help us fix it by filing a bug report at https://bugs.launchpad.net/bzr/+filebug including this traceback and a description of the problem. ERROR Checking out source code! ERROR Bazaar said: Для продолжения нажмите любую клавишу . . . Edited November 24, 2014 by ArtDenis Quote Share this post Link to post Share on other sites More sharing options...
Сергей Борщ 60 November 24, 2014 Posted November 24, 2014 · Report post Может уже обсуждалось.Потрудитесь прочитать предыдущую страницу. Quote Share this post Link to post Share on other sites More sharing options...
ArtDenis 0 November 24, 2014 Posted November 24, 2014 · Report post Сергей Борщ, точно. Просмотрел... :rolleyes: Quote Share this post Link to post Share on other sites More sharing options...
max_donetsk 0 November 25, 2014 Posted November 25, 2014 · Report post Отписываюсь по результату. Забегая наперед, скажу, ничего не получилось. В общем поставил на виртуальную машину WinXP SP3. Скачал kicadwinbuilder 3.4, попробовал, результат тот же, что и в Win7. Решил потом попробовать с kicadwinbuilder 3.3, результат тот же, не собирается kicad, но что заметил, в командной строке проходит проверка на компилятор MinGW. Отдельно я его не ставил, может в этом проблема? Если да, то посоветуйте, пожалуйста, что конкретно нужно поставить. Еще есть предположение на то, что быть может на компьютер нужно установить какой-то SDK, ведь не может быть, что на одном компьютере kicad собирается, а на другом нет, явно, что чего-то не хватает. Quote Share this post Link to post Share on other sites More sharing options...
Сергей Борщ 60 November 25, 2014 Posted November 25, 2014 · Report post проходит проверка на компилятор MinGW. Отдельно я его не ставил, может в этом проблема? Нет, отдельно его ставить не нужно - он идет в комплекте с kicadwinbuilder. может на компьютер нужно установить какой-то SDK,kicadwinbuilder и есть такой SDK. Quote Share this post Link to post Share on other sites More sharing options...
max_donetsk 0 November 26, 2014 Posted November 26, 2014 · Report post Тогда даже не знаю, в чем может быть такое дикое нежелание kicadwinbuilderа собрать сборку на моих двух компьютерах. Единственное, что я не делал, так это то, что не давал своих Launcpad ID, но, думаю, что это не так важно. Quote Share this post Link to post Share on other sites More sharing options...
baranovskiykonstantin 0 November 26, 2014 Posted November 26, 2014 (edited) · Report post Может стоит попробовать собрать из корня диска С: ?)) Знаю, звучит глупо, но мало ли... P.S. Я имею в виду c:\kicad-winbuilder\... вместо d:\... Edited November 26, 2014 by Барановский Константин Quote Share this post Link to post Share on other sites More sharing options...
max_donetsk 0 November 26, 2014 Posted November 26, 2014 · Report post Может стоит попробовать собрать из корня диска С: ?)) Знаю, звучит глупо, но мало ли... P.S. Я имею в виду c:\kicad-winbuilder\... вместо d:\... Пробовал, даже сократил еще больше имя, пробовал из директории c:\kicad\... и никак. У меня такое чувство, что чего-то не хватает установленного из программ того, что стоит у вас. Quote Share this post Link to post Share on other sites More sharing options...
Сергей Борщ 60 November 26, 2014 Posted November 26, 2014 · Report post Так а на чем у вас сейчас процесс заканчивается? По какой ошибке вываливается? Там есть папочка с логами, прикрепите сюда архив с ее содержимым. Quote Share this post Link to post Share on other sites More sharing options...
max_donetsk 0 November 26, 2014 Posted November 26, 2014 · Report post Так а на чем у вас сейчас процесс заканчивается? По какой ошибке вываливается? Там есть папочка с логами, прикрепите сюда архив с ее содержимым. Заканчивается на том же самом месте, что и на Win 7. Ну в общем, выкладываю логи, посмотрите, пожалуйста, может что-то увидите logs.zip Quote Share this post Link to post Share on other sites More sharing options...
AVL 0 November 26, 2014 Posted November 26, 2014 · Report post Заканчивается на том же самом месте, что и на Win 7. Ну в общем, выкладываю логи, посмотрите, пожалуйста, может что-то увидите Все указывает на то, что у Вас проблемы с bzr.exe. На сколько помню Вам уже писали, что bzr.exe кривой в сборке KiCad Winbuilder. У меня были подобные чудеса. Из-за того, что bzr.exe падал на каком-то этапе при клонировании каждого из хранилищ, то ошибки потом при сборке с помощью cmake появлялись в различных местах. Мне помогло следующее: удалял из KiCad Winbuilder полностью содержимое директории, в которой находится программа bzr. Далее внутрь этой директории копировал содержимое директории C:/Program files/bzr (bzr ставил под винду штатным способом с помощью инсталлятора bzr, скачанного с официального сайта bzr). Точные наименования директорий не укажу сейчас, поскольку нет под рукой той машины с виндой. После этого нужно обязательно удалить все директории с закаченными клонами хранилищ (если не ошибаюсь, хранилища закачиваются в директорию src). Иначе KiCad Winbuilder больше не будет пытаться склонировать хранилища, которые он пытался дать команду склонировать, а они недоклонировались и находятся теперь в разрушенном состоянии. Quote Share this post Link to post Share on other sites More sharing options...
break 0 November 27, 2014 Posted November 27, 2014 · Report post Это всё хорошо, но я не понял про ГОСТовские дополнения. Как их туда вклячить? AHTOXA Сборку 4289 можно советовать только врагу. Куча глюков, и откатиться нельзя - старые версии не понимают формат его PCB файла, а в этой версии больше нет возможности сохранения в старом формате. Quote Share this post Link to post Share on other sites More sharing options...
AHTOXA 3 November 27, 2014 Posted November 27, 2014 · Report post AHTOXA Сборку 4289 можно советовать только врагу. Пардон. Я не советовал какую-то конкретную сборку, я просто подсказал, где можно взять готовые. А какая версия сейчас правильная? Quote Share this post Link to post Share on other sites More sharing options...
AVL 0 November 27, 2014 Posted November 27, 2014 · Report post Это всё хорошо, но я не понял про ГОСТовские дополнения. Как их туда вклячить? Если есть интерес к возможности ГОСТ сборки под винду, давайте создам ветку на базе lp:kicad-winbuilder, туда внесу все изменения, которые для этого делал. Quote Share this post Link to post Share on other sites More sharing options...
max_donetsk 0 November 27, 2014 Posted November 27, 2014 · Report post Ребят, доброго времени суток! Вроде бы пошло, коллективный разум победил, спасибо всем за советы, завтра отпишу, что и как делал, если все пройдет до конца гладко. Quote Share this post Link to post Share on other sites More sharing options...
