toshas 0 Posted April 16, 2014 · Report post ссылка для загрузки - http://www.xilinx.com/support/download.html или http://www.xilinx.com/support/download/ind...ols/2014-1.html release notes - http://www.xilinx.com/support/documentatio...all-license.pdf из главного - доступ к UltraScale, production для маленьких Artix. Quote Ответить с цитированием Share this post Link to post Share on other sites More sharing options...
Koluchiy 0 Posted April 16, 2014 · Report post Традиционный соцопрос. Как оно в плане глючности? Имеет ли смысл переходить с глючного ISE на Vivado? Quote Ответить с цитированием Share this post Link to post Share on other sites More sharing options...
disel 0 Posted April 16, 2014 · Report post Placer and router multithreading now can use up to 8 CPU Интерестно насколько реально это работает. Quote Ответить с цитированием Share this post Link to post Share on other sites More sharing options...
Alex77 0 Posted April 16, 2014 · Report post Если нужно 7 семейство - переход не избежен. Из ug904 ************************************* Multithreading with the Vivado Tools On multiprocessor systems, Vivado tools use multithreading to speed up certain processes, including DRC reporting, static timing analysis, placement, and routing. The maximum number of simultaneous threads varies, depending on the OS, number of processors, and the particular task. The maximum number of threads by task is: • DRC reporting: 8 • Static timing analysis: 8 • Placement: 8 • Routing: 8 There is also a general limit that applies to all tasks and is based on the OS. For Windows systems, the limit is 2; for Linux systems the limit is 8. The limit can be changed using a parameter called general.maxThreads. To change the limit: Vivado% set_param general.maxThreads <new limit> ************************************* Quote Ответить с цитированием Share this post Link to post Share on other sites More sharing options...
_Ivan_ 0 Posted April 17, 2014 · Report post а лицуха, что идет с зедбордой в комплекте подойдет, если она версии 2013. чего то там? Quote Ответить с цитированием Share this post Link to post Share on other sites More sharing options...
yes 0 Posted April 17, 2014 · Report post Если нужно 7 семейство - переход не избежен. если нужны старшие виртексы 7 для остальных 7 айс вполне айс, например для цинка его используют в апп. нотах Quote Ответить с цитированием Share this post Link to post Share on other sites More sharing options...
Alex77 0 Posted April 17, 2014 · Report post а лицуха, что идет с зедбордой в комплекте подойдет, если она версии 2013. чего то там? Это надо смотреть что "внутри" сей лицензии. Я лично не имею её посему не знаю. если нужны старшие виртексы 7 для остальных 7 айс вполне айс, например для цинка его используют в апп. нотах АЙС для 7 семейства вообще не айс. ИСЕ "застыло" на версии 14.7 в 2013 году. И только избранные плисы. И "глюки" не исправляются. В Вивадо нынче есть уже 8 семейство. и До кучи win8.1 64бит обещена поддержка. АЙС под WinXP 32 вечно "вылетал" изза не хватки памяти (3гб). Quote Ответить с цитированием Share this post Link to post Share on other sites More sharing options...
Bad0512 0 Posted April 18, 2014 · Report post АЙС под WinXP 32 вечно "вылетал" изза не хватки памяти (3гб). Зачем запускать АЙС на XP 32bit? Нищебродство или мазохизм? Quote Ответить с цитированием Share this post Link to post Share on other sites More sharing options...
10ff 0 Posted April 18, 2014 · Report post А ISE 14.8 уже можно не ждать? Развития больше не будет? Quote Ответить с цитированием Share this post Link to post Share on other sites More sharing options...
Alex77 0 Posted April 18, 2014 · Report post А ISE 14.8 уже можно не ждать? Развития больше не будет? 14.8 может и будет. НО официально развитие этой ISE завершено. Максимум будут исправляться "глюки" для семеств спартан3/6 итд (что мало вероятно). 7 семейство было реализовано в "демо" режиме. Зачем запускать АЙС на XP 32bit? Нищебродство или мазохизм? Если ВЫ идёте в ногу со временем (обновляете с десяток компьютеров на самые современные каждые полгода и пользуетесь ТОЛЬКО лицензионными продуктами) - тогда да - я Нищеброд и мазохист Впредь выбирайте выражения политкорректные. PS: До появления 7 семейства вполне было достаточно "XP 32bit". C 7 можно и нужно работать только в 64битных системах с памятью от 8 гиг и далее в зависимости от используемого семества. Quote Ответить с цитированием Share this post Link to post Share on other sites More sharing options...
curly07 0 Posted April 18, 2014 · Report post А ISE 14.8 уже можно не ждать? Развития больше не будет? Версии ISE 14.8 не будет. Xilinx перестал развивать этот продукт. 14.7 - крайняя версия. Все силы программистов брошены на развитие Vivado. При этом ISE будет доступна для заказа. Сейчас ISE входит в Vivado Design Suite. Quote Ответить с цитированием Share this post Link to post Share on other sites More sharing options...
Bad0512 0 Posted April 18, 2014 · Report post Если ВЫ идёте в ногу со временем (обновляете с десяток компьютеров на самые современные каждые полгода и пользуетесь ТОЛЬКО лицензионными продуктами) - тогда да - я Впредь выбирайте выражения политкорректные. PS: До появления 7 семейства вполне было достаточно "XP 32bit". C 7 можно и нужно работать только в 64битных системах с памятью от 8 гиг и далее в зависимости от используемого семества. Если политкорректно, то инструмент надо выбирать в соответствии с задачей, ещё неплохо бы читать системные требования, да и вообще в целом читать очень полезно. З Ы Про лицензионность речь вообще не шла. Quote Ответить с цитированием Share this post Link to post Share on other sites More sharing options...
yes 0 Posted April 18, 2014 · Report post да я не агитирую за ISE, естественно приходится перебираться на Vivado но более частая ситуация - 6 семейство + немного 7-го, где ISE гораздо удобнее, чем 7-e + 8-е на младшие 7-ки вроде бы вполне нормальная времянка выходит, ну и битстрим, я предполагаю, без ошибок Quote Ответить с цитированием Share this post Link to post Share on other sites More sharing options...
myq 0 Posted April 22, 2014 · Report post Доброго времени суток, уважаемые коллеги. Странная вещь происходит при установке Vivado 2014.1 на ноут win7. На этом ноуте прекрасно стояли 2013.2, например, всякие ISE и Quartus. В конце установки вылетает ошибка: название онка: Execution of Pre/Post Installation Tasks Failed содержимое окна: Warning: Xilinx software was installed successfully, but unexpected status was returned from the following po..... (за границей фотографии, на телефон снимал) ERROR: [Common 17-217] Failed to load feature 'core'. Далее, если кликнуть по иконке Vivado 2014.1, винда дооолго думает, потом пишет: Error when launching 'C:\Xilinx\Vivado\2014.1\bin\vivado.bat': Launcher time out и всё, среда не пускается. Кто-нибудь с этим сталкивался? Гугл пока молчит. Quote Ответить с цитированием Share this post Link to post Share on other sites More sharing options...
Alex77 0 Posted April 23, 2014 (edited) · Report post Доброго времени суток, уважаемые коллеги. Странная вещь происходит при установке Vivado 2014.1 на ноут win7. На этом ноуте прекрасно стояли 2013.2, например, всякие ISE и Quartus. В конце установки вылетает ошибка: название онка: Execution of Pre/Post Installation Tasks Failed содержимое окна: Warning: Xilinx software was installed successfully, but unexpected status was returned from the following po..... (за границей фотографии, на телефон снимал) ERROR: [Common 17-217] Failed to load feature 'core'. Далее, если кликнуть по иконке Vivado 2014.1, винда дооолго думает, потом пишет: Error when launching 'C:\Xilinx\Vivado\2014.1\bin\vivado.bat': Launcher time out и всё, среда не пускается. Кто-нибудь с этим сталкивался? Гугл пока молчит. А каким методом ставилось ? Из архива или по интернету ? (лично пробывал оба способа - работают). Может "криво" скачалось ? "По умолчанию" все "нужные" пути на диске я делаю английскими и имя пользователя тоже. ps: win7 64bit only for Vivado. Edited April 23, 2014 by Alex77 Quote Ответить с цитированием Share this post Link to post Share on other sites More sharing options...
