Runner2 0 Posted May 10, 2012 · Report post Всем привет! Осваиваю ПЛИС. Чип XC6SLX9-3TQG144C, SPI флеш память AT45DB041D. Среда Xilinx ISE Design Suite 13.4, программирую IMPACT -ом В саму плисину все прекрасно загружается и прошивка работает. При попытке запрограммировать флеш память '1': Erasing device... done. '1': Erasure completed successfully. INFO:iMPACT - Address 0x00000000 is in sector 0. INFO:iMPACT - Address 0x00053393 is not located at the start of a sector boundary. The whole sector will be erased. INFO:iMPACT - Address 0x00053393 is in sector 6. INFO:iMPACT - Address 0x00000000 is in sector 0. INFO:iMPACT - Address 0x00053393 is not located at the start of a sector boundary. The whole sector will be erased. INFO:iMPACT - Address 0x00053393 is in sector 6. INFO:iMPACT - Address 0x00000000 is in sector 0. INFO:iMPACT - Address 0x00053393 is not located at the start of a sector boundary. The whole sector will be erased. INFO:iMPACT - Address 0x00053393 is in sector 6. INFO:iMPACT - Address 0x00000000 is in sector 0. INFO:iMPACT - Address 0x00053393 is not located at the start of a sector boundary. The whole sector will be erased. INFO:iMPACT - Address 0x00053393 is in sector 6. INFO:iMPACT - Address 0x00000000 is in page 0. INFO:iMPACT - Address 0x00053393 is in page 1291. '1': Programming Flash...done. '1': Programming completed successfully. INFO:iMPACT - Address 0x00000000 is in page 0. INFO:iMPACT - Address 0x00053393 is in page 1291. '1': Verifying device...done. '1': Verification completed successfully. '1': Configuration data download to FPGA was not successful. DONE did not go high, please check your configuration setup and mode settings. INFO:iMPACT - '1': Flash was not programmed successfully. PROGRESS_END - End Operation. Elapsed time = 98 sec. Сбой программирования. При этом флешка стирается и проверяется командой Blank Chek без ошибок. Вся схемотехника подключения флешки к плисине вроде сделана по Spartan-6 FPGA Configuration User Guide, только DONE не подтянут к Vcc, а висит на этом выводе светодиод с резистором на землю. Подскажите что я делаю не так, заранее спасибо. Quote Ответить с цитированием Share this post Link to post Share on other sites More sharing options...
vitalinea 0 Posted May 10, 2012 · Report post ... '1': Configuration data download to FPGA was not successful. DONE did not go high, please check your configuration setup and mode settings. ... По умолчанию, во время конфигурирования DONE это open-drain пин. Во время конфигурирования он изнутри удерживается в нуле. После окончания конфигурирования, этот пин отпускается и он должен перейти в 1 не позднее чем за один такт CCLK. Если он не успевает подтянуться к 1 за это время -- конфигурирование считается неуспешным. Проверте как быстро DONE переходит из 0 в 1. Если слишком медленно, то есть такие варианты: 1) либо добавить небольшой подтягивающий резистор, 2) либо уменьшить частоту CCLK, 3) либо в bitgen опциях сделать DONE пин totem-pole, а не open-drain (если у вас несколько FPGA в конфигурационной цепочке и их DONE пины соединены -- естественно так делать не стоит). Quote Ответить с цитированием Share this post Link to post Share on other sites More sharing options...
Runner2 0 Posted May 10, 2012 · Report post При программировании флешки DONE вообще не переходит в состояние 1. bitgen опции это где такие? Есть вот в опциях Generate Programing File, разделе -g DonePin: есть варианты Pull UP и Float. Изменение этого параметра эффекта не дает.... Я просто никогда раньше не работал с плисами со внешней флешкой... А со встроенной проблем не было... Попробую подтянуть DONE резистором Спасибо за советы. Quote Ответить с цитированием Share this post Link to post Share on other sites More sharing options...
Bad0512 0 Posted May 11, 2012 · Report post Всем привет! Осваиваю ПЛИС. Чип XC6SLX9-3TQG144C, SPI флеш память AT45DB041D. Среда Xilinx ISE Design Suite 13.4, программирую IMPACT -ом В саму плисину все прекрасно загружается и прошивка работает. При попытке запрограммировать флеш память '1': Erasing device... done. '1': Erasure completed successfully. INFO:iMPACT - Address 0x00000000 is in sector 0. INFO:iMPACT - Address 0x00053393 is not located at the start of a sector boundary. The whole sector will be erased. INFO:iMPACT - Address 0x00053393 is in sector 6. INFO:iMPACT - Address 0x00000000 is in sector 0. INFO:iMPACT - Address 0x00053393 is not located at the start of a sector boundary. The whole sector will be erased. INFO:iMPACT - Address 0x00053393 is in sector 6. INFO:iMPACT - Address 0x00000000 is in sector 0. INFO:iMPACT - Address 0x00053393 is not located at the start of a sector boundary. The whole sector will be erased. INFO:iMPACT - Address 0x00053393 is in sector 6. INFO:iMPACT - Address 0x00000000 is in sector 0. INFO:iMPACT - Address 0x00053393 is not located at the start of a sector boundary. The whole sector will be erased. INFO:iMPACT - Address 0x00053393 is in sector 6. INFO:iMPACT - Address 0x00000000 is in page 0. INFO:iMPACT - Address 0x00053393 is in page 1291. '1': Programming Flash...done. '1': Programming completed successfully. INFO:iMPACT - Address 0x00000000 is in page 0. INFO:iMPACT - Address 0x00053393 is in page 1291. '1': Verifying device...done. '1': Verification completed successfully. '1': Configuration data download to FPGA was not successful. DONE did not go high, please check your configuration setup and mode settings. INFO:iMPACT - '1': Flash was not programmed successfully. PROGRESS_END - End Operation. Elapsed time = 98 sec. Сбой программирования. При этом флешка стирается и проверяется командой Blank Chek без ошибок. Вся схемотехника подключения флешки к плисине вроде сделана по Spartan-6 FPGA Configuration User Guide, только DONE не подтянут к Vcc, а висит на этом выводе светодиод с резистором на землю. Подскажите что я делаю не так, заранее спасибо. Есть подозрение (судя по приведённому вами логу) что вы подсовываете импакту неправильный формат файла. Он пытается писать флэшку с адреса 0x53393, хотя логично было бы начать с нуля. Скорее всего флэшке нужен формат типа Intel HEX (который тоже ещё надо сформировать тем же импактом), а вы пытаетсь скормить ей *.bin, что в корне неверно. А вообще всё это описано в мануалах на импакт. Quote Ответить с цитированием Share this post Link to post Share on other sites More sharing options...
troiden 0 Posted May 11, 2012 · Report post Impact грузит во флеш MCS-файл. Quote Ответить с цитированием Share this post Link to post Share on other sites More sharing options...
Runner2 0 Posted May 11, 2012 · Report post Есть подозрение (судя по приведённому вами логу) что вы подсовываете импакту неправильный формат файла. Он пытается писать флэшку с адреса 0x53393, хотя логично было бы начать с нуля. Скорее всего флэшке нужен формат типа Intel HEX (который тоже ещё надо сформировать тем же импактом), а вы пытаетсь скормить ей *.bin, что в корне неверно. А вообще всё это описано в мануалах на импакт. С чего вы взяли что я пытаюсь скормить ей бин файл? Я формирую и пытаюсь загрузить MCS формат Вообще для генерации файла для флешки доступно всего 3 формата.: MCS, EXO, UFP Только сгенерировав файл MCS он один доступен при выборе SPI флеш, остальные форматы в окне выбора файла хоть ты их и сгенерил недоступны. Подтянул DONE к питанию через резистор 330 Ом, положительного эффекта нет все тоже самое.... Неосиливаю, в чем проблема.... :blink: Quote Ответить с цитированием Share this post Link to post Share on other sites More sharing options...
tinker73 0 Posted May 19, 2012 · Report post Предлагаю проверить 1) состояние пинов M[1:0] = 2'b01 (т.е. SPI master) 2) находится ли VCC_AUX в допустимых пределах в момент загрузки из флеши (нет глитчей,просадок напряжения и т.д.) 3) если уж совсем ничего не помогает, то выпаять и прошить флешку в программаторе, запаять в плату, и после этого проверить всё с отключенным JTAG-ом , в первую очередь проверить уровни 0 и 1 для всех сигналов флеши (нет ли КЗ или обрывов), находится ли частота CCLK в допустимых пределах, нет ли "звона" на длинных линияхSPI, проверить питание флеши, и т.д по всему списку. 4)попробовать другой экземпляр и/или даже тип флешки (например Numonix M25P) Quote Ответить с цитированием Share this post Link to post Share on other sites More sharing options...
seemann 0 Posted May 25, 2012 (edited) · Report post У нас была такая проблема с Spartan 6 Automotive. Исчезла, когда уменьшили тактовою частоту CCLK с 26 на 10 MHz. Edited May 25, 2012 by seemann Quote Ответить с цитированием Share this post Link to post Share on other sites More sharing options...
aat_81 0 Posted March 17, 2016 · Report post Понимаю, что прошло много времени, но попытаюсь - удалось ли решить данную проблему? Если да то каким способом? Сам столкнулся с подобным поведением и чужой опыт был бы кстати :) Quote Ответить с цитированием Share this post Link to post Share on other sites More sharing options...
_4afc_ 0 Posted March 18, 2016 · Report post Понимаю, что прошло много времени, но попытаюсь - удалось ли решить данную проблему? Если да то каким способом? Сам столкнулся с подобным поведением и чужой опыт был бы кстати :) 1. Проблемы с JTAG (длинные провода) или высокая скорость JTAG 2. Отсутствие подтягивающих резисторов у флешки. Quote Ответить с цитированием Share this post Link to post Share on other sites More sharing options...
aat_81 0 Posted March 18, 2016 · Report post 1. Проблемы с JTAG (длинные провода) или высокая скорость JTAG 2. Отсутствие подтягивающих резисторов у флешки. Проблема точно не с JTAG, т.к. загрузить FPGA могу. Мало того, флешка тоже записывается нормально(проверял считывая прошивку обратно на компьютер). Получается проблема только в загрузке плиски от флешки. Думаю вечером разберусь и отпишусь в чем дело было. Quote Ответить с цитированием Share this post Link to post Share on other sites More sharing options...
aat_81 0 Posted March 19, 2016 · Report post В общем проблема была банальной. Контакты М1 и М0 были подключены к земле и питанию через 10 кОм резисторы, после избавления от этих резисторов проблема исчезла. Quote Ответить с цитированием Share this post Link to post Share on other sites More sharing options...
