POLL
Posts
384 -
Компактные, в корпусе, AC/DC преобразователи IRM-03-9 MEAN WELL 100 шт, упаковка в пеналах, по 10 штук Цена 260 руб за 1 шт. Продаю упаковкой 100 шт. Пересылка по РФ: Почтой или СДЭК.
Цена UP 1 000 руб штука. ARM Cortex-M3 Memory Protection Unit (MPU) 24-bit SysTick Counter Thumb®-2 instruction set Nested Vector Interrupt Controller 2 x 256Kbytes embedded Flash, 128-bit wide access, memory accelerator, dual bank 100(64+32) Kbytes embedded SRAM with dual banks 16 Kbytes ROM with embedded bootloader routines (UART, USB) and IAP routines Static Memory Controller (SMC): SRAM, NOR, NAND support. NAND Flash controller with 4 Kbytes RAM buffer and ECC External Bus Interface - 16 bits, 8 chip selects, 23-bit address Embedded voltage regulator for single-supply operation POR, BOD and Watchdog for safe reset Quartz or resonator oscillators: 3 to 20 MHz main and optional low power 32.768 kHz for RTC or device clock High precision 8/12 MHz factory trimmed internal RC oscillator with 4 MHz Default Frequency for fast device startup Slow Clock Internal RC oscillator as permanent clock for device clock in low power mode One PLL for device clock and one dedicated PLL for USB 2.0 High Speed Mini Host/Device Temperature Sensor 17 peripheral DMA (PDC) channels and 6-channel central DMA plus dedicated DMA for High-Speed USB Mini Host/Device and Ethernet MAC Sleep, Wait and Backup modes, down to 2.5 μA in Backup mode with RTC, RTT, and GPBR Industrial (-40° C to +85° C) USB 2.0 Device/Mini Host: 480 Mbps, 4 Kbyte FIFO, up to 10 bidirectional Endpoints, dedicated DMA 4 USARTs (ISO7816, IrDA®, Flow Control, SPI, Manchester and LIN support) and one UART 2 TWI (I2C compatible), up to 6 SPIs, 1 SSC (I2S), 1 HSMCI (SDIO/SD/MMC) with up to 2 slots 9-channel 32-bit Timer Counter (TC) for capture, compare and PWM mode, Quadrature Decoder Logic and 2-bit Gray Up/Down Counter for Stepper Motor 32-bit low-power Real-time Timer (RTT) and low-power Real-time Clock (RTC) with calendar and alarm features 256-bit General Purpose Backup Registers (GPBR) Ethernet MAC 10/100 (EMAC - MII/RMII) with dedicated DMA 2 CAN Controllers with 8 Mailboxes True Random Number Generator (TRNG) 103 I/O lines with external interrupt capability (edge or level sensitivity), debouncing, glitch filtering and on-die Series Resistor Termination Six 32-bit Parallel Input/Output Controllers 16-channel 12-bit 1 msps ADC with differential input mode and programmable gain stage 2-channel 12-bit 1 msps DAC Serial Wire/JTAG Debug Port(SWJ-DP) Debug access to all memories and registers in the system, including Cortex-M4 register bank when the core is running, halted, or held in reset. Serial Wire Debug Port (SW-DP) and Serial Wire JTAG Debug Port (SWJ-DP) debug access. Flash Patch and Breakpoint (FPB) unit for implementing breakpoints and code patches. Data Watchpoint and Trace (DWT) unit for implementing watchpoints, data tracing, and system profiling. Instrumentation Trace Macrocell (ITM) for support of printf style debugging. IEEE1149.1 JTAG Boundary-scan on all digital pins. ASF-Atmel software Framework – SAM software development framework Integrated in the Atmel Studio IDE with a graphical user interface or available as standalone for GCC, IAR compilers. DMA support, Interrupt handlers Driver support USB, TCP/IP, Wi-Fi and Bluetooth, Numerous USB classes, DHCP and Wi-Fi encryption Stacks RTOS integration, FreeRTOS is a core component
Импортозамещение
POLL replied to vitaly_n's topic in Компоненты
Я думаю это для больших компаний, госсектор, телекоммуникации и т.п. -
Импортозамещение
Первые ласточки, о чем я говорил. Разработчики вносят в свой код закладки Например тут https://github.com/arendst/Tasmota/commit/98cbf2587a1a914bbd16996ebb48dd451d3da448 прошивка для микроконтроллеров ESP, если устройство недалеко от Москвы или Минска, то начнутся рандомные перезагрузи, отключения и стирание прошивки. Аналогичные штуки вносят в ПО других направления Так что обновлять либы нужно очень аккуратно, эти придурки сами себе открыли ящик пандоры. -
Импортозамещение
У себя, внутри организации, нужно развернуть систему контроля версий. -
Импортозамещение
Ты сам не понимаешь - идет война с "цивилизованным" западом, никакие правила не работают, они делают то, что им выгодно. Никакие лицензии и прочие бумажки - не представляют никакой гарантии. Если они захотят - они перекроют и open source. Для примера, владелец Github это Майкрософт... Если владелец какого-то открытого ПО, русофоб - ему ничего не помешает ограничить свое ПО для России. Конечно, тем или иным способом можно какие-то ограничения обходить, но если это касается ответственных областей - нет никаких гарантий, что в этом ПО не будет закладок. -
Если кому надо, есть остатки, 30 шт. Atmel ATSAM3X8E AU Отдам по 800 руб штука.
Импортозамещение
Что вы говорите, тут по платной подписке доступ прикрывают, а уж open source, по политическим соображением, владельцу репозитория НИЧЕГО не мешает аналогично закрыть. Я уже не говорю, если там есть спонсор и если он попросит, также все прикроют. Вы видимо еще с этим не столкнулись. Выручает если у вашей конторы есть отдельное юр.лицо за рубежом. -
Импортозамещение
Серьезно??? Ты отстал от современной реальности https://www.kommersant.ru/doc/5237468 Российское программное обеспечение и операционные системы, работающие на открытом программном коде, могут оказаться под угрозой блокировки. https://www.kommersant.ru/doc/5237468 -
Импортозамещение
Ошибаешься по этому пункту. Нужно разрабатывать свое ПО, т.к. тот же open source разработчик, по политическим взглядам, может для твоей страны его ЗАБЛОКИРОВАТЬ, запретить использования на территории РФ. Я уже не говорю про платные сервисы, ряд украинских площадок взяли и заблокировали счета россиян и вообще работу с гражданами РФ. -
Ну может у них запасы, подготовились заранее. На сайте написано про cortex м3 https://ic.milandr.ru/products/mikrokontrollery_i_protsessory/32_razryadnye_mikrokontrollery/1986ve9kh_yadro_arm_cortex_m3/k1986ve92qi/ Вроде 600 руб, но цены скорее всего неактуальные и может даже нет в наличии. Вообщем думаю будут контрабасом завозить :)
Чисто из любопытства, сколько будет стоить какой-нить миландровский cortex m4 ? :) Наверное тысяч 10-20 за штуку?
Посоветуйте отладочную плату
POLL replied to eugen_pcad_ru's topic in Отладочные платы
Для начинающего - STM32 Discovery -
И снова CUBE IDE
POLL replied to Vlad_G's topic in Cредства разработки для МК
Попробуй Window -> Preferences -> C/C++ -> Build -> Envirement Add: name: MINGW_HOME value: path-to/mingw64/bin -
JQuery - это прошлый век, пишите на нативном JS :)
