Anton_1000
    34
About Anton_1000
  • Birthday 08/13/1977
  1. C:\SIM900DevIDE\antiks>mkdir .\output Подпапка или файл .\output уже существует. C:\SIM900DevIDE\antiks>rem perl ..\EmbatSIM\gsmos\tools\globalmacro C:\SIM900DevIDE\antiks>perl ..\EmbatSIM\gsmos\tools\renew "perl" не является внутренней или внешней командой, исполняемой программой или пакетным файлом. C:\SIM900DevIDE\antiks>make OS=win APPDIR=C:\SIM900DevIDE\antiks echo Compiling [../EmbatSIM/gsmos/flcode/fl_Main.c] Compiling [../EmbatSIM/gsmos/flcode/fl_Main.c] C:\ARM\RVCT\Programs\2.2\349\win_32-pentium\armcc.exe ../EmbatSIM/gsmos/flcode/f l_Main.c -c --cpu=ARM9E --debug --no_debug_macros --littleend --split_sections --fpu=SoftVFP --apcs /interwork -I.\ainc -I ../EmbatSIM/gsmo s/flinc -I C:\ARM\RVCT\Data\2.2\349\include\windows Warning: C2083W: -g defaults to -O2 if no optimisation level is specified echo Compiling [.\code/fl_customer.c] Compiling [.code/fl_customer.c] C:\ARM\RVCT\Programs\2.2\349\win_32-pentium\tcc.exe .\code/fl_customer.c -c -- cpu=ARM9E --debug --no_debug_macros --littleend --split_sections --fpu=SoftVFP - -apcs /interwork -I.\ainc -I ../EmbatSIM/gsmos/flinc -I C:\ ARM\RVCT\Data\2.2\349\include\windows Warning: C2083W: -g defaults to -O2 if no optimisation level is specified Warning: L6319W: Ignoring --keep command. Cannot find section bootnor_start.o(SI GNATURE_AREA). Warning: L6306W: '~PRES8' section image2dlms.o(init) should not use the address of 'REQ8' function fl_entry. ../EmbatSIM/gsmos/flcode/scatter.map(line 28, col 24) Warning: L6314W: No sectio n matches pattern fl_Main.o(RW). ../EmbatSIM/gsmos/flcode/scatter.map(line 28, col 28) Warning: L6314W: No sectio n matches pattern fl_Main.o(ZI). ../EmbatSIM/gsmos/flcode/scatter.map(line 29, col 18) Warning: L6314W: No sectio n matches pattern *.o(RW). ../EmbatSIM/gsmos/flcode/scatter.map(line 29, col 22) Warning: L6329W: Pattern * .o(ZI) only matches removed unused sections. Finished: 0 information, 6 warning and 0 error messages. C:\SIM900DevIDE\antiks>move *.o .\output C:\SIM900DevIDE\antiks\fl_customer.o C:\SIM900DevIDE\antiks\fl_Main.o C:\SIM900DevIDE\antiks>move *.cla .\output C:\SIM900DevIDE\antiks\antiks.cla C:\SIM900DevIDE\antiks>move *.elf .\output C:\SIM900DevIDE\antiks\antiks.elf C:\SIM900DevIDE\antiks>move *.map .\output C:\SIM900DevIDE\antiks\antiks.map C:\SIM900DevIDE\antiks>if exist *.sym move *.sym .\output C:\SIM900DevIDE\antiks\antiks.sym C:\SIM900DevIDE\antiks>pause Для продолжения нажмите любую клавишу . . . Для страждущих: в папке C:\SIM900DevIDE\EmbatSIM\gsmos\tools в файле version1 меняем строку на SYMFILE = 1137B03V01SIM900M64_ST_EAT.SYM и ошибка исчезает, но появляется куча всяких WARNINGov стоит ли обращать на них внимание?
  2. Вроде стринг.ш нашолся. Но У меня сходная история: выдает фатальную ошибку L6002U. Если можно поподробней как от неё избавиться?
  3. C:\SIM900DevIDE\antiks>mkdir .\output C:\SIM900DevIDE\antiks>rem perl ..\EmbatSIM\gsmos\tools\globalmacro C:\SIM900DevIDE\antiks>perl ..\EmbatSIM\gsmos\tools\renew "perl" не является внутренней или внешней командой, исполняемой программой или пакетным файлом. C:\SIM900DevIDE\antiks>make OS=win APPDIR=C:\SIM900DevIDE\antiks echo Compiling [../EmbatSIM/gsmos/flcode/fl_Main.c] Compiling [../EmbatSIM/gsmos/flcode/fl_Main.c] C:\ARM\RVCT\Programs\2.2\349\win_32-pentium\armcc.exe ../EmbatSIM/gsmos/flcode/fl_Main.c -c --cpu=ARM9E --debug --no_debug_macros --littleend --split_sections --fpu=SoftVFP --apcs /interwork -I.\ainc -I ../EmbatSIM/gsmo s/flinc -I C:\ARM\RVCT\Data\2_2b576\include\windows Warning: C2083W: -g defaults to -O2 if no optimisation level is specified echo Compiling [.\code/fl_customer.c] Compiling [.code/fl_customer.c] C:\ARM\RVCT\Programs\2.2\349\win_32-pentium\tcc.exe .\code/fl_customer.c -c -- cpu=ARM9E --debug --no_debug_macros --littleend --split_sections --fpu=SoftVFP - -apcs /interwork -I.\ainc -I ../EmbatSIM/gsmos/flinc -I C:\ ARM\RVCT\Data\2_2b576\include\windows Warning: C2083W: -g defaults to -O2 if no optimisation level is specified "../EmbatSIM/gsmos/flinc/fl_stdlib.h", line 37: Error: #5: cannot open source i nput file "string.h": No such file or directory #include <string.h> ^ make: *** [fl_customer.o] Error 1 C:\SIM900DevIDE\antiks>move *.o .\output C:\SIM900DevIDE\antiks\fl_Main.o C:\SIM900DevIDE\antiks>move *.cla .\output Файл с таким именем уже существует или не найден. C:\SIM900DevIDE\antiks>move *.elf .\output Файл с таким именем уже существует или не найден. C:\SIM900DevIDE\antiks>move *.map .\output Файл с таким именем уже существует или не найден. C:\SIM900DevIDE\antiks>if exist *.sym move *.sym .\output C:\SIM900DevIDE\antiks>pause Для продолжения нажмите любую клавишу . . . при компиляции демо проекта выскакивает ошибка о невозможности найти файл string.h. Где может находится этот йфайл и где указать путь к нему? Эти строки стоят в настройках пути к компилятору: 1. C:\Program Files\ARM\RVCT\Data\2.2\349\lib 2. C:\ARM\RVCT\Programs\2.2\349\win_32-pentium 3. C:\ARM\RVCT\Data\2_2b576\include\windows
  4. спасибо, помогло. После КЕЙЛа угнетает работа с консолью.
  5. При компиляции примера выскакивает такая лабуда, похоже преокт не компилится.В чёмпричина?: C:\SIM900DevIDE\anton1>mkdir .\output Подпапка или файл .\output уже существует. C:\SIM900DevIDE\anton1>rem perl ..\EmbatSIM\gsmos\tools\globalmacro C:\SIM900DevIDE\anton1>perl ..\EmbatSIM\gsmos\tools\renew "perl" не является внутренней или внешней командой, исполняемой программой или пакетным файлом. C:\SIM900DevIDE\anton1>make OS=win APPDIR=C:\SIM900DevIDE\anton1 echo Compiling [../EmbatSIM/gsmos/flcode/fl_Main.c] Compiling [../EmbatSIM/gsmos/flcode/fl_Main.c] C:\Program Files\ARM\RVCT\Programs\2.2\349\win_32-pentium\armcc.exe ../EmbatSIM/ gsmos/flcode/fl_Main.c -c --cpu=ARM9E --debug --no_debug_macros --littleend --s plit_sections --fpu=SoftVFP --apcs /interwork -DSIMCOM_FTR -DSIMCOM -I.\ainc -I ../EmbatSIM/gsmos/flinc -I C:\Program Files\ARM\RVCT\Da ta\2_2b576\include\windows Warning: C2083W: -g defaults to -O2 if no optimisation level is specified Error: C3065E: type of input file 'Files\ARM\RVCT\Data\2_2b576\include\windows' unknown Error: C3079E: armcc command with no effect make: *** [fl_Main.o] Error 1 C:\SIM900DevIDE\anton1>move *.o .\output Файл с таким именем уже существует или не найден. C:\SIM900DevIDE\anton1>move *.cla .\output Файл с таким именем уже существует или не найден. C:\SIM900DevIDE\anton1>move *.elf .\output Файл с таким именем уже существует или не найден. C:\SIM900DevIDE\anton1>move *.map .\output Файл с таким именем уже существует или не найден. C:\SIM900DevIDE\anton1>if exist *.sym move *.sym .\output C:\SIM900DevIDE\anton1>pause Для продолжения нажмите любую клавишу . . .
  6. После включения модуль работает в нормальном режиме. Делает звонки, отсылает СМС.
  7. При включении модема получаю через КОМ-порт " 49 49 49 49 FE FE FE FE ", и отсутствует надпись "READY". Имеет ли это какое-то значение.
  8. Подскажите, пожайлуста, в каком документе можно посмотреть описание SMS API? В SIM9000 Embedded AT Appl. Note V1.0 я этого не нашёл
  9. тыж такой умный, догадайся мол сама
  10. что-то читал на этом форуме, но там всё скомкано, что без пол литры не разберёшся
  11. Перефраизирую вопрос: с помощью какой смски можно дрыгать ногой GPIO&
  12. Глядя на описание модуля у него присутствует порты: * I2C, * GPIO, * PWM, * ADC. Внутри стоит ARM926EJ-S (156MHz). Если для моей задачи достаточно управлять через GPIO реле, каким образом прошить мою программу в АРМ МК?
  13. Это обьявление массива структур. Похоже данный код заработал, и массив "лёг" куда нужно.
  14. Помогите разместить данную таблицу во флэш АРМ ADUC7060 в среде KEIL. Слово const, похоже, не работает и как проверить? struct ROW_TABLE { unsigned char state; unsigned char event; unsigned char nextState; void (*pStateFunc)(void); }; // *** F U N C T I O N S *** // void EmptyFunc(void); void EmptyFunc1(void); // *** S T A T E T A B L E *** // const struct ROW_TABLE table[] = { // STATE EVENT NEXT STATE STATE_FUNC // ---------------------------------------------------------------- { STATE_Normal , EVENT_Timer_1, STATE_Next_state, EmptyFunc }, { STATE_Next_state , EVENT_Timer_1, STATE_Normal, EmptyFunc1 }, { 0, 0, 0, EmptyFunc } };
